Maintenance on RV Air Conditioner Units: A Seasonal Checklist
Your rooftop air conditioner has a rough job. It bakes in the sun, rattles down the highway, and pulls in dust at every campsite. So when the air turns weak in July, the cause is often a basic task that got skipped. A clogged filter alone can cut airflow and let dirt build up on the coils. Most maintenance on RV air conditioner units takes a few minutes and no special tools. This guide covers Dometic's filter schedule, how to shut off power safely, what to check on the roof, and when to call a technician.
RV Air Conditioner Maintenance Basics: The Filter
Is your AC blowing weaker than it did last summer? Start with the return air filter. It sits behind the grille on your ceiling, and it catches dust, pet hair, and lint before they reach the coils. Of all the jobs in RV A/C maintenance, this one does the most for the least effort.
How Often to Clean the Filter
The filter interval depends on the air conditioner. Dometic’s Harrier guidance gives two months for full-time use and six months for seasonal use. The US FreshJet mechanical air distribution box manual, §9.1, calls for cleaning at least every two weeks of operation. Find the schedule for your model and ceiling assembly.
Dometic also gives a firm warning: "NEVER run the unit without the return air filter in place." Without the filter, dirt can plug the evaporator coil and hurt performance over time.
Other brands set their own schedules. If you have an Airxcel (Coleman-Mach) unit or another make, check its manual. And if you've been camping on dirt roads or in desert wind, clean the filter sooner than the schedule says.
When to Clean It Sooner
A schedule is a starting point, and your trips decide the rest. How do you know the filter can't wait? Look at it. If you can see a gray layer of dust or pet hair, it's ready for a wash. Weaker airflow at the ceiling vents is another clue.
It helps to tie the check to something you already do. Look at the filter when you dump the tanks or at the end of each trip. A note in your phone or logbook with the last wash date takes the guessing out of it.
How to Wash and Reinstall It
The job takes a few minutes of work, plus drying time. Turn the AC off first, then follow Dometic's steps:
Remove the filter from behind the return air grille.
Wash it with soap and warm water.
Let it dry all the way.
Put it back before you run the unit again.
Filter care is one part of knowing your AC, and power is another. It helps to know how many watts an RV AC uses before you plan a battery or generator setup.
The filter is the one job you can do with nothing but a sink. Anything past that means cutting power to the unit first, and that often leaves you working in a dark rig.
Shut Off Power First: Lighting the Job Safely
Would you open up a ceiling unit while it's still live? An RV air conditioner can get power from more than one place, so turning the thermostat off isn't enough. Before you remove anything past the filter, every source feeding the AC has to be off.
What to Disconnect Before You Start
Your AC manual lists the exact steps for your model, and those come first. In general, isolating the unit means:
Unplugging shore power at the pedestal
Switching off the onboard inverter
Shutting down the generator
Turning off the AC breaker in your panel
Rigs are wired differently, and an inverter can keep outlets live from the batteries after shore power is unplugged. It's worth learning how inverters versus converters in campers work before you isolate anything. If you're not sure the unit is dead, stop and call a technician.
A Separate Light for the Work
Once every source is off, the coach lights and outlets may go dark too, and you still need to see what you're doing. You also want a charged phone nearby, in case you need to pull up the manual or call for help. A portable power station handles both without touching the RV's wiring. It runs a work light and charges a phone from its own outlets, fully apart from the AC.
A work light and a phone are small loads, so you don't need a big unit. A 1kWh station like the EcoFlow DELTA 3 Classic is enough for an afternoon of work at loads like these. The light plugs straight into the station, and the station never connects to the AC being serviced.
How Long Will the Light Last?
For a planning example, use the Feit WORK2000XLPLUG corded work light (20 W) and budget 20 W for a compatible phone on USB-C, equivalent to the rated output of the Apple A2305 20W USB-C adapter. Use the station’s USB-C port directly. The phone will not draw 20 W continuously. Assume 85% of the 1,024 Wh battery is usable across the outputs.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable, estimated) |
Feit WORK2000XLPLUG and one phone charging over USB-C | 20 W + 20 W budget = 40 W | About 22 h at a constant 40 W (870 Wh ÷ 40 W) |
These are estimates, so check the wattage labels on your own light and charger. Runtime is always limited by the battery's capacity and the real load. Keep the station inside, dry, and away from the open ceiling unit.
Before You Turn the Power Back On
Restoring power is part of the job, and it's easy to rush. Run through a short check first:
The filter is dry and back in place
The ceiling grille and roof shroud are fastened
No tools or rags are left in or on the unit
Everything you cleaned has dried
Then reconnect in the order your manual gives. Let the AC run for a few minutes and listen. A new rattle or an odd smell means shutting it down and looking again.
With the power off and a light set up, you can move on to the seasonal checks. Most of them happen on the roof.
Seasonal RV AC Checklist: Roof, Coils, and Seals
When did you last look at the top of your AC? Most owners rarely do, and leaves, cottonwood fluff, and road grime pile up out of sight. Plan to go through this list once a season or before a big trip.
Getting on the Roof Safely
Only climb up if your RV's roof is rated to walk on, which your owner's manual will tell you. If it isn't, leave the roof work to a shop.
Use a stable ladder on level ground. OSHA's extension ladder fact sheet is written for job sites, but its basics apply at a campsite too. Keep three points of contact while you climb. An extension ladder should also reach at least 3 feet above the roof edge it rests on. Pick a dry, calm day, and have someone on the ground who knows you're up there. Carry tools in a bag or bucket so your hands stay free on the ladder.
What to Check Up Top
This is general camper air conditioner maintenance, so follow your unit's manual wherever it differs. The table covers the main parts to look at.
Part | What to do |
Shroud | Remove it and clear out leaves and debris. Look it over for cracks. |
Condenser coils | Clean them gently, the way your manual describes. |
Fins | Carefully straighten bent fins so air can pass through. |
Mounting bolts and roof gasket | Check the bolts as your manual directs. Look for signs of leaks around the gasket. |
Drain path | Make sure it's clear so water can run off. |
Why do the coils matter so much? ENERGY STAR's cooling maintenance checklist, written for home systems, says dirty coils make a system run longer and can shorten its life. The same checklist notes that a plugged condensate drain can lead to water damage. An RV rooftop unit is a smaller machine, but it also depends on clean coils and a clear drain.
Two rules apply to all RV AC unit maintenance on the roof. Never spray water into the electrical parts, and let everything dry fully before you restore power. Skip the pressure washer too, since thin coil fins bend easily.
While you're up there, you may notice how much open roof you have. Some owners ask about running RV AC on solar, which depends on your panel space, battery size, and the AC's draw.
A Simple Schedule to Follow
How do you keep all of this straight across a camping year? A short schedule helps, and your AC manual has the final say on timing.
When | What to do |
Harrier: every 2 months full-time or 6 months seasonally. FreshJet mechanical ADB: at least every 2 weeks of operation; check your specific manual. | Wash, dry, and reinstall the return air filter |
After dusty trips | Check the filter early |
Once a season or before a big trip | Roof checks: shroud, coils, fins, bolts, gasket, and drain path |
Before the first hot trip of the year | Run the AC at home and watch for weak cooling, odd noises, or drips |
A test run at home is worth ten minutes of your time. If something is wrong, you'd rather find out in your driveway than at a campsite in a heat wave. It also leaves time to book a shop before the busy season.
Most of this list is cleaning and looking. Some problems go past that, and it helps to know where the line is.
When to Call an RV AC Technician
What if the filter is clean, the coils are clear, and the AC still isn't right? That's usually the point where DIY ends. Refrigerant, compressor, and electrical faults need tools and training most owners don't have.
Signs It's Time for a Pro
Call an RV AC technician if you notice:
Weak cooling even with a clean filter
Ice on the coils
A breaker that trips when the AC starts
A burning smell
Water dripping inside the coach
A dirty filter or low airflow is a common cause of icing, so clean the filter first. If the ice comes back, have the unit checked.
Breaker trips can have more than one cause. If the AC only struggles on generator power, compare your setup against the right generator size for RV AC before you assume the unit is bad. If it trips on shore power too, call the technician.
Water inside the coach deserves quick action. EPA's mold and moisture guide says to dry water-damaged areas within 24 to 48 hours to prevent mold growth. It also says to fix the water problem itself, or the mold will likely return.
What to Have Ready When You Call
A good description saves time, and it can save you a second visit. Before you call, write down a few details:
The AC's brand and model number, from the unit's label or your manual
What the problem looks like and when it started
Whether it happens on shore power, generator power, or both
What you've already done, such as washing the filter
Photos help too. A picture of ice on the coils or a water stain on the ceiling tells a technician a lot before the visit. Leave the unit off until it's been checked, above all if you smelled something burning.
Why Refrigerant Work Isn't DIY
You may have searched "how to service a rv air conditioner" and found videos on adding refrigerant. Skip those. Under EPA's Section 608 technician certification rules, technicians who maintain, service, repair, or dispose of equipment that could release refrigerants must be certified. Leave any refrigerant problem to a certified shop, along with compressor and wiring repairs.
Part of knowing how to service an RV air conditioner is knowing which jobs are yours. The filter, the debris, and the visual checks are yours. The refrigerant system and the wiring belong to a pro.
Maintenance on RV air conditioner units comes down to a few habits. Wash the return air filter on the schedule for the installed model (for the Harrier, every 2 months full-time or 6 months seasonally), and never run the unit without it. Cut every power source before you go further, clean the coils each season, and call a technician for refrigerant or electrical faults. While the AC is off, an EcoFlow DELTA 3 Classic can light the job from its own outlets.
How often should I clean my RV AC filter?
For a Dometic Harrier, the published intervals are two months for full-time use and six months for seasonal use. The US FreshJet mechanical air distribution box requires cleaning at least every two weeks of operation. Check the exact model’s manual and inspect sooner after dusty trips.
Can I run my RV AC without a filter?
No. Dometic says never to run the unit without the return air filter in place. Without it, dirt can plug the evaporator coil and hurt cooling over time. If the filter is still wet from washing, wait until it's dry and back in place.
How do I clean RV AC coils?
Clean them gently, and only after every power source is off. Follow your unit's manual, keep water out of the electrical parts, and let everything dry before you turn the power back on. Only go on the roof if it's rated to walk on.
Why is my RV AC freezing up?
A dirty filter or low airflow is often behind it, so wash the filter first. If ice keeps forming with a clean filter, turn the unit off and have a technician look at it.
Do I need to disconnect power to service my RV AC?
Yes. Unplug shore power and switch off the inverter and generator, following your manual. A separate power station can run your work light in the meantime, but it never connects to the AC.
