RV Battery Maintenance: How to Care for Lead-Acid, AGM, and Lithium House Batteries
RV batteries rarely fail all at once. They fade from low water, corroded terminals, deep discharges, or months of storage with a small parasitic draw. The right routine depends on the chemistry: flooded lead-acid needs water checks, AGM needs correct charging, and lithium needs sensible storage charge levels. This guide covers RV battery maintenance by type, with Go RVing and RV maker guidance, a monthly checklist, how to store batteries over winter, and how to keep camp lights and a small fridge going while the house battery is isolated for service.
RV battery maintenance by battery type
Know your chemistry first. Flooded lead-acid needs the most care. Lithium needs the least but has its own storage rules.
Type
Key maintenance
Storage
Flooded lead-acid
Check water in flooded cells; use the water specified by the maker and keep terminals clean.
Charge fully; disconnect; recharge periodically
AGM / gel (sealed)
No water; correct charger profile
Charge and disconnect
Lithium (LiFePO4)
Charger and BMS settings; temperature limits
Store at the state of charge specified for your exact model.
Flooded batteries lose water as they charge, so the plates can be exposed if nobody checks the cells. Go RVing advises checking and adjusting the water level every so often, and topping up with mineral-free water, with distilled being the best choice.
Sealed AGM and gel batteries can't be opened, so there's no water to add. Their weak spot is charging. A converter or charger set to the wrong profile can undercharge or overheat them, so match the setting to the battery label.
Lithium storage targets depend on the model. Go RVing gives a general 50–80% range, but Battle Born’s winter storage guidance calls for fully charging its LiFePO4 batteries before disconnecting them. Use the battery manufacturer’s storage and temperature instructions.
If you're unsure how your house bank differs from the starter battery under the hood, start with what a deep cycle battery is and why RVs rely on one.
Maintenance often means isolating the house battery. If you're camping, you'll still want lights and maybe a fridge.
Camp power while the house battery is isolated
A separate power station runs lamps and charges phones while the house battery is disconnected. If your RV fridge can plug directly into a 120V outlet per its manual, it can run from the station too. It's not a drop-in replacement for the RV battery.
While the house battery is disconnected for cleaning, testing, or storage, an EcoFlow portable power station runs camp lights and phones from its own outlets. It works alongside the RV system, not as a replacement for its battery. Your RV's wiring stays untouched while you work.
For lights and phones during a maintenance day, a 1kWh station covers it easily. You plug each device straight into the unit, so nothing touches the RV battery or its wiring while you clean terminals, test voltage, or swap cables.
EcoFlow DELTA 3 Classic (1024Wh)
  • Camp Basics: 1,024Wh for lights and phones (see estimates).
  • Separate System: Plug devices directly into the station.
  • Fast Recharge: 0 to 80% in about 45 minutes on AC.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
If your RV fridge can plug into a 120V outlet per its manual and must run overnight, a 2kWh station gives more headroom. Check the manual first, because some RV fridges aren't designed to plug into a household outlet.
EcoFlow DELTA 3 Max (2048Wh)
  • Fridge Overnight: 2,048Wh; 2,400W output, per EcoFlow.
  • Check the Manual: Only fridges allowed to plug in directly.
  • Recharge: Wall, solar, or car.
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How do the products divide the job?
  • EcoFlow DELTA 3 Classic: lights and phones during maintenance.
  • EcoFlow DELTA 3 Max: a plug-in fridge overnight, for measured use.
For the lighting example, use an 8.8 W Feit OM60DM/5CCTCA/4 lamp and budget 20 W for one phone via the station’s USB-C port, equivalent to the output rating of the Apple A2305 20W USB-C adapter. For refrigeration, Nohma’s 24-hour test of a Dometic CFX3 45 recorded 278 Wh on 12 V DC, averaging 11.6 W in that test. The Dometic manual also permits direct 120 V AC operation. The refrigerator row uses the measured DC example and a compatible rated DC outlet and cable. For AC operation, measure Wh at the AC plug over a representative day.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3 Max (1,741Wh usable est.)
Feit 8.8 W camp lamp + one phone (20 W USB-C budget)
28.8 W combined
About 30 h
About 60 h
CFX3 45 on 12 V DC (11.6 W average in one test) + Feit 8.8 W lamp
20.4 W combined average
About 43 h
About 85 h
For each example, divide the estimated usable capacity (1,024 or 2,048 Wh × 0.85) by the combined load. These are planning estimates. Temperature, compressor cycling, phone charging, inverter idle draw, and conversion losses can change actual runtime.
Once the work is done, follow how to charge an RV battery after maintenance, so the bank returns to full safely.
Here's the monthly routine.
RV battery maintenance checklist
Regular checks can reveal loose connections, corrosion, or low electrolyte in a flooded battery. Wear eye protection and follow the manufacturer’s isolation procedure before physical maintenance.
  • For lead-acid batteries, use the maker’s resting interval and open-circuit voltage chart when estimating charge. For LiFePO4, read a compatible BMS or calibrated battery monitor; midrange voltage alone is a poor indicator of remaining charge.
  • Inspect the terminals and clean off any corrosion.
  • Tighten loose connections and cable lugs.
  • Check the water level on flooded batteries. Keystone says to top up with distilled water if necessary.
  • Look for swelling, cracks, or leaks around the case.
  • Confirm the charger and converter settings match your battery chemistry.
Lithium banks add a few checks of their own, such as BMS alerts and charging temperature. See lithium solar battery maintenance tips for those details.
Finally, winter storage.
Motorhome parked at a campsite before winter storage.Motorhome parked at a campsite before winter storage.
Storing RV batteries over winter
Parasitic draws drain batteries in storage. Disconnect or remove them. Store at the charge level the maker recommends.
Keystone advises disconnecting the battery when the RV sits for an extended period, since that stops the slow drain from onboard electronics. Propane detectors, clocks, and stereo memory all pull a little power, and a few months is enough to run a lead-acid battery flat.
Use the lithium battery maker’s prescribed winter storage charge and temperature range. Where the maker specifies a full charge, follow that requirement and disconnect loads as instructed.
A discharged lead-acid battery can freeze in cold weather, which can crack the case. Keep it charged per the maker's instructions, and check it now and then over the winter. Read more on keeping an RV battery charged if the RV sits for months.
RV battery maintenance depends on chemistry. Check flooded-cell water levels and use the water specified by the maker. For lithium, use the particular battery’s storage procedure, including charge level and whether to disconnect loads. Check terminals and charger settings regularly.
While the battery is isolated, the EcoFlow DELTA 3 Classic or EcoFlow DELTA 3 Max keeps camp devices running. Pick the Classic when you only need lights and phone charging for a short service session. Pick the Max when a plug-in fridge, allowed by its manual, has to run overnight. Both run devices from their own outlets. Neither one connects to the RV battery or services it, so keep using a charger matched to your battery's chemistry.
How often should I check RV battery water?
Check flooded lead-acid batteries regularly, and Go RVing says to adjust the level periodically using distilled water. Sealed AGM and gel batteries need no water, and lithium never does.
Should I disconnect my RV battery in storage?
Yes. Keystone says disconnecting prevents parasitic draw, the small constant drain from onboard electronics. Charge the battery first, then disconnect it and recheck the charge level periodically during the off-season.
What charge should lithium RV batteries be stored at?
Read the manual for the exact battery. Some models specify a partial storage charge, while Battle Born calls for fully charging its LiFePO4 batteries before winter storage and disconnecting the loads. Observe the specified temperature limits.
Can I use tap water in my RV battery?
Avoid tap water: minerals can accumulate on the plates. Use the water specified for the flooded battery. Trojan prefers distilled water and also permits deionized water.
Can a power station replace my RV battery?
No. A power station runs devices through its own outlets, but it isn't a drop-in swap for an RV battery and doesn't tie into the RV's electrical system.
RV and Motorhomes
