Winterizing an RV With Antifreeze: How Much You Need and the Steps to Follow
Most RVs need about two to six gallons of RV non-toxic antifreeze, depending on plumbing length and whether the water heater gets bypassed. The basic job is simple. Drain the system, bypass the water heater, then pump antifreeze through every line until it runs pink. One hard freeze can crack water lines, a pump, or fittings, and those repairs add up. This article covers winterizing an RV with antifreeze using Keystone and Winnebago guidance, plus common mistakes and lighting for work without shore power.
How Much RV Antifreeze Do You Need?
Most RVs need about two to six gallons. The range depends on plumbing length and whether the water heater is bypassed. Checking the owner's manual comes first, and buying one extra jug helps avoid running short halfway through the job.
Why the Plumbing Needs Protection
Water expands as it freezes. That pressure can split lines, crack the pump housing, or loosen fittings, and the damage often stays hidden until spring. RV antifreeze lowers the freezing point of the water left in the system, so the lines have room to handle a cold snap. The National Weather Service also warns of freezes well before the coldest nights, which gives owners a window to act.
Gallon Estimates From RV Makers
Searches for how many gallons of antifreeze to winterize RV systems usually end with a range, not one number. Rigs differ in tank size, pipe runs, and bypass kits. That is why Keystone and Winnebago give slightly different figures.
Source
Antifreeze amount
Where it goes
Winnebago
About 2 gallons (some RVs may need a bit more)
Main plumbing run, per the owner's manual
Keystone
4 to 6 gallons of RV non-toxic antifreeze
Pump bypass hose, or at least 4 gallons poured into the freshwater tank if the pump can't be bypassed
Keystone
About 1 quart each
Every drain, every P-trap, and the toilet
Bypassing the water heater matters for the total. Both manufacturers route antifreeze around it, so the tank never fills with product.
How Much RV Antifreeze Do I Need for Drains and Traps?
Drains and traps need their own share on top of the main plumbing run. Keystone suggests about one quart for each drain, each P-trap, and the toilet. A rig with a washer adds one more drain to the count.
Small campers sit near the low end of the range. Anyone sizing up how much antifreeze to winterize camper plumbing needs can start near two gallons, as Winnebago suggests, then add quarts for each trap.
Product choice matters as much as the amount. Winterizing RV antifreeze is commonly sold by the gallon, and the label should say RV or non-toxic. Pink is the usual color, which also makes it easy to see when a line has filled. Buying a few extra quarts costs little compared with a replacement pump.
Batteries need winter care too. While prepping storage, plan for keeping an RV battery charged so the rig starts the season ready.
Many owners winterize at a storage lot or in a driveway without shore power, sometimes after dark. Light and a charged phone make that job easier.
Working Without Shore Power: Light and Phones for Winterizing
Winterizing means crawling into bays and under sinks, often late in the day. Without shore power, a small power station can run an LED work light and keep a phone charged for the manual. It does not replace any winterizing step.
Winterizing at a storage lot often means no shore power and fading light. An EcoFlow portable power station runs an LED work light while the job moves through bays and cabinets, and keeps a phone charged for the manual. It helps with seeing. The antifreeze does the protecting.
A work light and a phone are all the power this job needs. A 1kWh unit can cover an afternoon of winterizing and rides along in the tow vehicle.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Runtime Estimate
The figures below are estimates. They use usable capacity (watt-hours × 0.85) divided by the load in watts.
Unit
Load (example)
Watts used
Estimated runtime
EcoFlow DELTA 3 Classic (about 870Wh usable, estimate)
LED work light + phone (placeholders: 40W + 10W)
About 50W
About 17 hours
Real runtime shifts with the light, the phone, temperature, and battery age. Charging the unit or running lights never counts as finishing winterization. Only drained lines, bypassed equipment, and antifreeze do that.
The same unit also helps with RV battery charging options on the road next season.
Now for the winterizing process itself.
How to Winterize an RV With Antifreeze: Step by Step
Drain, bypass, then pump antifreeze through every line. Work faucet by faucet until pink shows. Finish with the traps and the toilet.
Timing matters. The National Weather Service issues a Freeze Warning when temperatures are forecast to fall below 32°F for a long period, so the job is best done before the first one arrives. Winterizing an RV with antifreeze also follows a set order, and valve locations vary by model. Always follow the RV's own manual.
RV winterization supplies and antifreeze setupRV winterization supplies and antifreeze setup
Gather the Supplies First
A short checklist saves trips to the store mid-job. Keystone's list points to these items:
  • Antifreeze: 4 to 6 gallons of RV non-toxic antifreeze, based on the rig.
  • Pump bypass hose and fittings: A dealer can supply the right hose for the model.
  • Long funnel: Helpful when pouring antifreeze straight into the freshwater tank.
  • Tools for drain plugs and caps: A wrench or socket for the water heater plug is the usual need.
Drain and Bypass
  1. Drain the freshwater tank and low-point drains: First turn off both heat sources on the water heater and let the water cool to room temperature. Disconnect city water and switch off the water pump. Then remove the low-point drain caps and open all faucets, including the outside shower. Then open the tank drain valve and let it empty.
  2. Drain the water heater: With the heater cool and the supply isolated, open the pressure relief valve to confirm the system is depressurized, then remove the drain plug and drain the tank as the water heater manual directs. Tankless units need the manufacturer's procedure.
  3. Set the water heater bypass valves: Turn the valves to the bypass position, which may require removing an access panel. This keeps antifreeze out of the tank.
  4. Deal with filters and the ice maker line: Winnebago says to remove a whole-house filter cartridge. Keystone says to drain the ice maker supply line instead of filling it with antifreeze. A washer follows its own manual.
  5. Close the low-point drains: Reinstall the drain caps and close any faucets or valves left open. Keystone and Winnebago both call for this before antifreeze goes in, since open ports let the antifreeze run straight out.
Pump Antifreeze Through the Lines
  1. Connect the pump bypass hose: Run the hose from the pump's suction side to the antifreeze jug. If the pump can't be bypassed, close the freshwater drain and pour in at least 4 gallons.
  2. Open each faucet until pink appears: Turn on the RV water pump once it has an antifreeze supply. Start with the cold side, one faucet at a time. Then repeat on the hot side, including any outside shower or kitchen faucet.
Finish With Traps and Toilet
  1. Flush the toilet until pink: Leave a little antifreeze in the bowl to protect the seals.
  2. Pour antifreeze into drains and P-traps: Use about a quart for each one. If the RV has a washer, run its fill cycle until antifreeze appears.
  3. Do a final check: Confirm every fixture ran pink and the low-point drain caps are still secure. Reinstall any remaining plugs and close open valves to keep pests out of the freshwater system.
Off-grid systems need winter care too. If the RV has panels, look into winterizing an off-grid solar setup as well.
Finally, avoid the common mistakes.
Common RV Winterizing Mistakes
Using the wrong antifreeze is the big one. Forgetting a fixture is next. And skipping the bypass wastes antifreeze.
Winterized RV parked in snowy storageWinterized RV parked in snowy storage
  • Using automotive antifreeze: Keystone warns that automotive antifreeze is poisonous and unsuitable for potable water systems. The CDC's ATSDR notes that ethylene glycol, a common antifreeze ingredient, is sweet tasting and harmful in large amounts. Camper winterizing antifreeze should be labeled for RV or potable water use.
  • Skipping the water heater bypass: Without it, the tank soaks up antifreeze that never needed to go there. That wastes product and can leave the tank flushing out pink later.
  • Forgetting a fixture: The outdoor shower, ice maker line, and washer are easy to miss. Walking the rig with a checklist helps catch them.
  • Counting on the dry method alone: Blowing out lines with compressed air is a real option. Winnebago notes it still needs antifreeze in the P-traps, the washer, and the toilet.
  • Mishandling low-point drains: Open them at the start so water leaves the system. Reinstall the caps before pumping antifreeze, as Keystone's steps show.
  • Skipping the manual: Valve locations, filter types, and water heater designs differ. The RV's manual beats any general checklist.
  • Pouring antifreeze down open drains and walking away: Traps only stay protected when antifreeze sits in them. Pour the quart in, then leave it alone until spring.
Before storage, review charging an RV battery correctly as part of the same checklist.
Winterizing an RV with antifreeze usually takes two to six gallons of RV non-toxic antifreeze, depending on the rig. Both Winnebago and Keystone point to bypassing the water heater. Keystone also warns against automotive antifreeze. The routine stays the same: drain, bypass, pump antifreeze to every fixture, then finish with the traps and the toilet. Without shore power, an EcoFlow DELTA 3 Classic can keep a work light and phone running. The antifreeze does the protecting.
How much antifreeze do I need to winterize an RV?
Usually two to six gallons of RV non-toxic antifreeze. Winnebago suggests about two gallons, while Keystone lists four to six. Plumbing length and bypass setup change the total, so check the owner's manual first and keep one spare jug on hand.
Can I use car antifreeze in an RV?
No. Keystone warns that automotive antifreeze is poisonous and not suitable for potable water systems. Use only antifreeze labeled for RV or non-toxic use, and store every jug out of reach of children and pets until it is needed.
Do I put antifreeze in the RV water heater?
No. Drain the tank and set the bypass valves so antifreeze skips it. Bypassing keeps the tank from filling with product, which saves antifreeze. Tankless units need the maker's own procedure, so check the manual before starting.
How much antifreeze goes in RV drains?
Keystone suggests about one quart in each drain, each P-trap, and the toilet. That keeps the traps protected over winter. A rig with a washer has an extra drain, so plan on a few more quarts beyond the main plumbing run.
Is blowing out lines enough?
Not by itself. Winnebago notes the dry method with compressed air still needs antifreeze in the P-traps, the washer, and the toilet. Water left in those spots can freeze, so add antifreeze to those spots even after blowing out the lines.
RV and Motorhomes
