How to Winterize an RV With an Air Compressor: PSI, Steps, and Power Tips
Blowing out your RV's water lines with compressed air can reduce the amount of antifreeze you need and make spring cleanup easier. But too much pressure can damage plumbing fittings, and water left in a low spot can freeze and cause problems. This guide explains how to winterize an RV with an air compressor, using Keystone's published procedure and its 30 PSI limit. You'll also learn which parts still need antifreeze, what compressor to choose, and how to power it at a storage lot without an outlet.
Why Winterize an RV With Compressed Air?
The compressed-air method pushes water out of your RV's plumbing instead of filling every line with antifreeze. You'll still need RV antifreeze for drains, P-traps, and the toilet. This procedure combines compressed air for the water lines with RV antifreeze for drains, P-traps, and the toilet. Keystone's guide lists a compressor adapter and about 1 to 2 gallons of non-toxic RV antifreeze among the supplies. It estimates that the process takes around two hours, though your RV's layout and equipment may add time. Never use automotive antifreeze in the potable water system. Keystone warns that it's poisonous and unsuitable for this purpose.
Why Winterize an RV With Compressed Air?Why Winterize an RV With Compressed Air?
Compressed air vs. RV antifreeze
Both methods protect RV plumbing, but they work differently. Here's how they compare:
Method
What it does
Watch out for
Compressed air
Blows water out of lines
Pressure limits; low spots can hold water
RV antifreeze (full fill)
Fills lines with antifreeze
Flushing in spring; taste
Air + antifreeze in drains
Air for lines, antifreeze for traps and toilet
Uses both, but less antifreeze
The air method can save antifreeze and reduce the amount of flushing you'll do when camping season returns. Still, it takes care to clear each fixture and drain. Owners living in an RV through winter may use a different approach, keeping the plumbing warm instead of preparing the system for storage. Before connecting a compressor, check the pressure limit for your RV.
What PSI to Use to Blow Out RV Water Lines
Keep the air pressure low when winterizing your RV. Keystone's published procedure says not to exceed 30 PSI when blowing out the plumbing and using the city water connection. Your RV owner's manual takes priority, so check it before starting. Other manufacturers may specify different limits. Use an air compressor with an adjustable regulator and a gauge so you can control the output. Don't rely on the compressor's maximum pressure rating. Set the regulator to your RV manufacturer's limit before connecting the air line. A few points to check:
  • Use the correct adapter: Connect the compressor to the RV's city water inlet with an adapter made for winterizing.
  • Check the gauge: Keep an eye on the regulated pressure while blowing out the lines.
  • Follow the RV manual: Check whether your model has additional instructions for the black tank flush, outdoor shower, washer, or other plumbing fixtures.
  • Don't increase pressure to clear a stubborn line: If water keeps coming out, check for an overlooked valve, fixture, or drain instead.
The compressor's electrical demand also matters if you're working at a storage lot. Check how many watts an air compressor uses before choosing a power source. The running wattage is only part of the calculation. Startup surge matters, too.
Powering an air compressor where there's no outlet
A small 120V air compressor is often enough to blow out RV water lines. If you're winterizing at a storage lot without an outlet, a portable power station may run the compressor, provided its running wattage and startup surge stay within the unit's limits. Check the compressor's nameplate before choosing a power source. Winterizing often means working in a storage lot with no electrical hookup nearby. EcoFlow portable power stations can power compatible 120V compressors without the noise of a gas generator. Choose a model based on the compressor's voltage, running watts, and startup surge, then test the setup before winterizing day.
EcoFlow DELTA 3 Max for small compressors
Many RV owners can use a small pancake or hot dog compressor for a plumbing blowout. If its running load and startup surge fit within the EcoFlow DELTA 3 Max's output limits, its 2,048Wh capacity makes it a practical option to bring to the storage lot.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
EcoFlow DELTA 3000 Gen4 for larger compressors
Larger shop compressors need more power, especially when the motor starts. If your compressor exceeds the EcoFlow DELTA 3 Max's output limits, the EcoFlow DELTA 3000 Gen4 offers more headroom with its 3,600W rated output and 7,200W surge capacity. Check the compressor's nameplate and test its startup before relying on it at the storage lot.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How the two products divide the job
The right power station depends on your compressor's power requirements. The EcoFlow DELTA 3 Max suits smaller compressors, while the EcoFlow DELTA 3000 Gen4 provides more output for larger, compatible models.
  • EcoFlow DELTA 3 Max: Small 120V compressors that stay within its rated output and startup limits.
  • EcoFlow DELTA 3000 Gen4: Larger compressors that exceed the EcoFlow DELTA 3 Max's capacity but remain within the Gen4's 3,600W rated output and outlet limits.
Estimated energy use for an RV blowout
These examples show how much battery capacity a compressor session may use. Actual consumption depends on the compressor, how long it runs, and how often its motor cycles.
Task (example)
Energy used
EcoFlow DELTA 3 Max (1,741Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
1,200W compressor (10A label, placeholder) running 30 minutes in cycles
about 600Wh
about 34% of usable capacity
about 23%
Plus LED work light 2 hours (placeholder 20W)
about 640Wh total
about 37%
about 25%
Estimates use 85% of the stated battery capacity as usable energy. Energy consumption is calculated as watts × hours. Compressors cycle on and off, so actual usage may vary. The same startup considerations apply when running power tools from a solar generator. Check the equipment's power requirements before connecting it, and test the setup rather than assuming the motor will start. With the compressor and power source sorted, you can move on to the winterizing steps and clear the RV's plumbing in order.
Step-by-step: Winterizing an RV with compressed air
Drain the tanks and water heater first, blow out each plumbing line, and add RV antifreeze to the drains and toilet. Keystone's instructions provide the steps below. Your RV may have different valves or appliances, so follow its manual wherever the procedure differs.
Step-by-step: Winterizing an RV with compressed airStep-by-step: Winterizing an RV with compressed air
  1. Flush the black tank
If your RV has a black tank flush connection, use the appropriate adapter and compressed air to clear it. Keep the pressure at or below Keystone's 30 PSI limit, or your RV manufacturer's lower specified limit.
  1. Open the low-point drains and faucets
Remove the low-point drain caps and open the faucets. Include the outdoor shower and any other water outlets. Let the water drain before moving to the next step.
  1. Drain the fresh water tank
Open the fresh water tank drain and let the tank empty completely. Check the owner's manual for the location of the drain and any model-specific instructions.
  1. Turn off the water heater
Make sure the water heater is off in both gas and electric modes. Let it cool before draining. Never remove the drain plug while the water is hot or the tank is pressurized.
  1. Drain the water heater
Remove the water heater drain plug and open the pressure relief valve to help the tank drain. If your RV has a tankless water heater, follow its separate winterizing instructions.
  1. Remove the water filter
Take out and discard the filter cartridges if your manufacturer recommends it. Drain the filter housing and use the bypass tube if your system has one. Check the manual for the correct procedure.
  1. Empty the holding tanks
Empty the black and gray holding tanks at an approved dump station. Don't leave wastewater in the tanks during storage.
  1. Set the water heater to bypass
Move the water heater bypass valves into the bypass position. This keeps antifreeze from entering the water heater tank during the remaining steps.
  1. Drain the refrigerator ice maker line
If your RV has a residential refrigerator with an ice maker, drain its water line according to the appliance manual. Keystone's procedure says not to add antifreeze to the ice maker line.
10.Run the water pump
Turn on the water pump for about 30 seconds to clear its suction line, following Keystone's instructions. Turn it off before connecting the compressor.
11.Connect the compressor
Attach the air hose to the RV's city water inlet using the correct winterizing adapter. Set the regulator to the pressure limit specified by your RV manufacturer. Keystone says not to exceed 30 PSI.
12.Blow out the water lines
Turn on the compressor and work through the plumbing until no more water comes out. Keep the pressure regulated throughout the process. Check each fixture rather than assuming one pass through the system clears every line.
13.Clear the toilet supply line
Hold the toilet valve open until the water supply line clears. Make sure you follow the RV manufacturer's instructions for the toilet and its plumbing.
14.Clear the shower lines
Open the shower diverter to clear water from the hose and showerhead. Repeat the process for the outdoor shower and any other kitchen or bathroom fixtures.
15.Winterize the washer, if equipped
If your RV has a washer, follow its manual. Keystone's procedure calls for running a warm fill cycle to open both water valves or opening both valves manually, depending on the setup.
16.Add RV antifreeze to the drains
Pour about one quart of non-toxic RV antifreeze into each drain, P-trap, and toilet, following Keystone's procedure. Leave some antifreeze in the toilet bowl to protect its seal. Use RV-specific antifreeze designed for potable water systems. Never substitute automotive antifreeze.
17.Reinstall drain caps and plugs
Once the blowout and antifreeze steps are complete, reinstall the drain caps and plugs. Close the valves and check that you've secured the connections before leaving the RV in storage.
The plumbing is only one part of winter storage. Check the roof, seals, tires, and exterior before leaving the vehicle for the season. Follow your RV manufacturer's storage instructions to help protect the vehicle from weather and pests.
Winterizing an RV with an air compressor takes a careful drain and blowout, followed by RV antifreeze in the drains, P-traps, and toilet. Keep the pressure within your RV manufacturer's limit. Keystone specifies no more than 30 PSI in its procedure. Use a regulated compressor, clear every fixture, and check that you've drained the water heater and fresh water tank before storing the RV. Follow your owner's manual for any model-specific steps. If you're working without an outlet, the EcoFlow DELTA 3 Max suits compatible small compressors, while the EcoFlow DELTA 3000 Gen4 offers more output for larger compressors you've tested beforehand.
What PSI should I use to blow out RV water lines?
Keystone's winterizing guide specifies no more than 30 PSI for its compressed-air procedure. Your RV manufacturer's manual takes priority, so check the pressure limit for your specific model before connecting a compressor.
Do I still need antifreeze if I use compressed air?
Yes, you'll generally still need RV antifreeze for the drains, P-traps, and toilet. Keystone's procedure calls for about one quarter in each drain, P-trap, and toilet. Follow your RV manual for the exact amount and locations.
What size air compressor do I need to winterize an RV?
A small 120V compressor is often enough for an RV blowout. Check its pressure regulator, running wattage, and startup surge before buying or connecting it. The compressor must also work within your RV manufacturer's pressure limit.
Can I use automotive antifreeze in my RV water lines?
No. Use non-toxic RV antifreeze made for potable water systems. Keystone warns that automotive antifreeze is poisonous and unsuitable for RV drinking water plumbing.
Can a portable power station run an air compressor?
Yes, if the compressor's voltage, running wattage, startup surge, and plug fit the power station's output limits. Check the compressor's nameplate and test the setup before relying on it at a storage lot. Not every compressor will work with every power station.
RV and Motorhomes
