Tiny House Trailers: Types, Sizing, and What to Know
A tiny house on wheels starts with the trailer. It sets the home's footprint, limits how much the finished house can weigh, and affects how easily you can tow it. If you're planning a trailerable tiny house, leave room in that weight budget for batteries, solar panels, appliances, water, and everything else you'll carry.
Types of Tiny House Trailers
Types of Tiny House TrailersTypes of Tiny House Trailers
The trailer style affects the floor plan, towing setup, and the amount of usable space inside the finished home. Some tiny house trailers work well for smaller builds, while heavier homes may need a trailer with a higher weight rating.
Trailer Type
Key Feature
Bumper pull
Most popular and least expensive; ball-hitch connection
Gooseneck
Heavy-duty with better weight distribution for larger builds
Fifth-wheel
Truck-bed hitch, excellent stability for heavier homes
Utility (deck-over)
Framing sits between wheel wells for more headroom
Bumper pull trailers
Bumper pull trailers are a common starting point for tiny home trailers because the hitch connects to the back of a tow vehicle. They're often less expensive than heavier trailer styles and can work well for smaller homes with a carefully planned weight budget.
Gooseneck and fifth-wheel trailers
Gooseneck and fifth-wheel designs place the hitch closer to the rear axle of the tow vehicle. That can help with weight distribution and stability as the house gets heavier. You'll also need a truck that's equipped for the hitch and rated for the finished trailer.
Utility and deck-over trailers
A utility trailer can work well for a tiny house build when the framing sits between the wheel wells. A deck-over design sits higher but gives you more width across the floor. That extra space can help with the interior layout, while the higher deck can affect the home's overall height. If you're planning to live off-grid, this guide to powering a tiny house can help you think through your electrical needs before you choose a trailer.
Weight and Size Limits to Know
Before choosing a trailer, look closely at its weight rating and dimensions. These numbers determine how much house you can build, what you can carry, and how the finished tiny home can travel on U.S. roads.
Start with the trailer's GVWR
The Gross Vehicle Weight Rating (GVWR) includes the trailer itself and everything loaded onto it. For example, a 7,000-pound trailer that weighs 1,000 pounds empty leaves about 6,000 pounds for the tiny house and everything inside it. Common dual-axle trailers can have combined ratings from 7,000 to 10,000 pounds, depending on the individual axle ratings.
Keep licensing and width in mind
Once a trailer gets heavier, towing requirements can change. Trailers rated above 10,000 pounds GVWR generally require a commercial driver's license (CDL), while road-legal width is typically limited to 8 feet 6 inches in most U.S. states. That width limit can affect everything from your interior floor plan to wall thickness and exterior finishes. For a closer look at how trailer limits affect an off-grid build, see this off-grid tiny house guide. These numbers also matter when you're planning the power system. Solar panels, batteries, and related equipment add weight, so accounting for them early can leave enough payload for the rest of the build.
Budgeting Trailer Weight for Solar and Battery Equipment
A decent off-grid solar array and battery bank can easily add 500 kg, or about 1,100 pounds, to a tiny house build. Give that equipment its own place in the GVWR budget from the start, rather than trying to fit it in after the house is already designed. For a trailer build, the power system also needs to fit the available storage space. Compact options such as the EcoFlow DELTA 3 Max and DELTA 3 Plus can keep the power setup contained in fewer pieces of equipment, which can make the weight and space planning easier.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
If you need more flexibility as your tiny house setup grows, the DELTA 3 Plus gives you expandable capacity from 1kWh up to 5kWh. That makes it easier to add battery capacity later without rebuilding the entire power setup.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
Choosing a Trailer Style for Your Build
Trailer dimensions can shape the inside of a tiny house just as much as the wall layout. Before ordering one, sketch your floor plan around the wheel wells, deck height, roofline, and legal width.
Deck-over vs. between-wheel-well framing
A deck-over trailer puts the floor above the wheel wells, giving you more width for the living space. The tradeoff is a higher floor, which can reduce available headroom within the overall road height. A utility-style trailer keeps the framing between the wheel wells, giving you a lower floor and about 3.5 inches more interior headroom. In a small house, that extra space can make a noticeable difference.
Think about the roof and exterior walls
Eaves can help keep rain off the siding and windows, but they also add to the overall width of the build. If you're working toward the common 8-foot-6-inch road width, account for siding, trim, eaves, and other exterior pieces before you finalize the design. The trailer's height and axle placement also affect door placement, plumbing runs, storage, and the clearance beneath the finished home.
Planning Off-Grid Equipment From the Start
An off-grid power system should be part of the trailer plan from the beginning. Choosing the power setup before you order the trailer gives you a better idea of how much weight and storage space you'll need, which can help you avoid redesigning the build later.
Planning Off-Grid Equipment From the StartPlanning Off-Grid Equipment From the Start
Match the trailer to your power needs
Trailers shorter than about 24 feet generally leave enough weight allowance for off-grid equipment after the main build. Longer trailers can require a higher GVWR, which may also mean a heavier-duty tow vehicle and different licensing requirements.
Leave room for solar and batteries
Solar panels, batteries, and the equipment that connects them all take up space and add weight. Account for those items alongside the house structure, appliances, water, furniture, and personal belongings rather than adding them to the plan at the end. If you're still working out the size of your system, this guide to solar power for tiny houses covers how to size solar for a trailer-based build.
A tiny house trailer sets many of the home's limits before construction begins. Choose the trailer based on your floor plan first. Then check the GVWR and axle ratings. Make sure there's enough capacity left for furniture, water, appliances, and off-grid equipment. Solar panels and batteries can add hundreds of pounds to the build. Include that weight before you order the trailer. A compact power station such as the DELTA 3 Max can provide useful capacity without the weight of a larger lead-acid battery bank. The expandable DELTA 3 Plus gives you another option if you expect your power needs to grow.
What size trailer do I need for a tiny house?
The right trailer size depends on the finished home's dimensions and loaded weight. Start with your floor plan, then check the trailer's GVWR, empty weight, axle ratings, and available payload. Leave enough capacity for furniture, appliances, water, personal belongings, and solar or battery equipment.
Do I need a special license to tow a tiny house trailer?
It depends on the trailer's weight, your tow vehicle, and the rules in your state. Heavier trailer combinations can trigger additional licensing requirements, so check your state's towing and driver's license rules before choosing a trailer.
How much weight does solar equipment add to a tiny house?
A full solar array and battery bank can add about 500 kg, or roughly 1,100 pounds. Your actual system may weigh more or less depending on the battery capacity and number of panels you install.
What is the difference between a gooseneck and bumper pull tiny house trailer?
A bumper pull connects to a ball hitch at the rear of the tow vehicle. A gooseneck connects to a hitch mounted over the truck bed, which can help with weight distribution on heavier builds. The choice also affects the truck you'll need and the layout of the front of the tiny house.
How wide can a tiny house on a trailer legally be?
The common road width limit in the U.S. is 8 feet 6 inches, although state rules and permit requirements can vary. Your total width includes the exterior walls and anything that extends beyond them, such as siding or eaves. Check the rules for the states you'll travel through before finalizing the exterior width of your tiny house.
RV and Motorhomes
