Missouri Flooding: This Summer's Disaster and the Risk
- This Summer's Flooding and Missouri's Road to Federal Aid
- Missouri's Long History of Catastrophic Flooding
- Why Missouri Floods in So Many Different Ways
- Keeping a Sump Pump and Power Running in Missouri
- Checking Your Flood Risk and Insurance in Missouri
- What the Aid Gap Means for Rural Missouri Homeowners
- Conclusion
- FAQs
Nine Missouri counties are still recovering from severe storms and flash flooding in July 2026. The storms hit parts of south-central and southeast Missouri. The Missouri National Guard helped with water rescues and evacuations as roads and infrastructure were overwhelmed. Federal disaster aid arrived about two months later. The flooding also showed that Missouri faces several types of flood risk.This guide explains the flooding that happened this summer. It also looks at why different parts of Missouri can flood. You'll also learn how to protect your home and keep essential equipment running when water starts to rise.
Severe storms and flash flooding hit nine Missouri counties from July 9 through July 11, 2026. The Missouri National Guard carried out water rescues and evacuations as roads and infrastructure were overwhelmed. Damage assessments reached more than $26.5 million. The estimate covers emergency response and public infrastructure costs.
The July Flooding Hit Hard
The flooding damaged roads and buildings across the affected areas. Communities also had to deal with evacuations and damaged infrastructure. The immediate danger ended when the water went down. The work did not. Repairs and rebuilding continued after the flooding.
Federal Aid Took About Two Months
The federal disaster declaration came about two months after the flooding. It approved FEMA's Public Assistance Program for local governments. The program helps cover emergency response and public infrastructure costs. It does not provide direct payments to individual homeowners. This was Missouri's third federal disaster declaration of 2026. It is another reason to prepare before the next storm. This guide on how to prepare a home for a flood covers some practical steps. Missouri has a long history of major floods. Some past floods caused much more damage than the flooding in July 2026.
Missouri's flood history goes well beyond the disaster this summer. Some of Missouri's worst floods have affected entire communities. They have caused major property damage and forced thousands of people to leave their homes.
The Great Flood of 1993
The Great Flood of 1993 remains Missouri's costliest flood. The Mississippi River reached 49.58 feet in St. Louis. The disaster caused more than $15 billion in damage across the country. More than 75 towns in the nine-state flood region were completely flooded. About 54,000 people were evacuated, and around 50,000 homes were damaged or destroyed.
The 1977 Brush Creek Flood
A flash flood on Kansas City's Brush Creek in September 1977 killed 25 people. It caused $90 million in damage, and officials recovered 150 vehicles from the creek channel. The July 2026 flooding was smaller. Still, Missouri's flood history shows how quickly water can disrupt communities. This look at major US floods puts those events into perspective. Flooding can also cause power outages. That can leave important equipment, such as sump pumps, without power when you need them most. Backup power can keep critical equipment and household essentials running during an outage. EcoFlow offers portable and whole-home options for different power needs.
Missouri can flood in several ways depending on the season, rainfall, and location. Flash floods, like the July event, can develop within hours. Heavy rain can quickly overwhelm creeks and drainage systems. River flooding along the Mississippi and Missouri Rivers usually takes longer to develop. It can build over several days, giving communities more time to prepare. However, it can also affect a much larger area. Ice jams and snowmelt can create more flood risks in winter and early spring. Understanding the difference between flash and areal floods can help explain why Missouri faces several types of flooding.
For whole-home backup, the DELTA Pro Ultra X can keep essential systems running during a long outage. The DELTA 3 Max is a more portable choice. You can take it with you during an evacuation or use it to power key appliances.
The DELTA Pro Ultra X can keep essential household systems running while repairs are underway. The DELTA 3 Max gives you a portable option if you need to evacuate. Power can go out early during a flash flood. That's why it's important to keep critical equipment, such as a sump pump, running.
A sump pump can help keep a flash flood from turning into a flooded basement. But it won't work if a power outage shuts it off. Rural counties may face longer waits for utility repairs. Crews may need to work around damaged roads and power lines before they can restore service. A battery backup gives your sump pump another source of power. It doesn't have to wait for the grid to come back. Learn more about how a battery-backed sump pump works. A separate backup power source can also run other essential equipment if the power and cell service go down. Once the water recedes, you'll also need to know what your insurance covers.
Flood damage can leave homeowners facing costs that standard insurance doesn't cover. Knowing your coverage and understanding your property's flood risk can help you prepare before the next storm.
Know What Your Homeowners Insurance Covers
Standard homeowners insurance in Missouri typically doesn't cover flood damage. You may need separate flood insurance for damage caused by flash floods or overflowing rivers. This coverage gap can be a surprise after a flood, especially when fast-moving water causes the damage.
Don't Rely on the Flood Map Alone
FEMA flood maps don't always show the full risk of flash flooding. A property can still flood even when it's outside a high-risk zone. Understanding flood zone designations such as A and AE can help you read your flood map and understand its limits. Insurance is only part of flood preparation. This summer's flooding also showed that federal aid may not reach homeowners right away.
The federal response to this summer's flooding focused on repairing public infrastructure. It did not provide direct help to individual homeowners. That distinction matters for families dealing with damage after the water recedes.
What FEMA's Aid Covers
The disaster declaration approved FEMA's Public Assistance Program. It helps local governments pay for eligible repairs to roads, bridges, and other public infrastructure. It did not include Individual Assistance. That program can help homeowners with home repairs and temporary housing. As a result, many homeowners in the nine affected counties may need to rely on their insurance. Some may also have to pay for flood-related repairs themselves.
Preparing Beyond Federal Aid
When direct federal assistance isn't available, household-level preparation becomes more important. Backup power can keep essential equipment running during an outage. Solar and battery backup is another option to consider when preparing for future emergencies.
Flash flooding hit nine Missouri counties in July 2026. The storms caused more than $26.5 million in emergency response and public infrastructure costs. Missouri also faces other flood risks, including river flooding, ice jams, and snowmelt. Before the next storm, check what your insurance covers and what FEMA aid may provide. It's also worth having a backup power plan. In rural areas, power repairs may take longer. The EcoFlow DELTA Pro Ultra X and DELTA 3 Max can keep a sump pump and other essential equipment running until power returns.
Is Missouri flooding right now?
Missouri's latest flooding affected nine counties after severe storms and flash flooding from July 9 through July 11, 2026. The flooding has ended, but communities are still making repairs and recovering.
Which Missouri counties got federal disaster aid this summer?
The nine counties were Bollinger, Crawford, Iron, Madison, Morgan, Reynolds, Ripley, Washington, and Wayne. FEMA approved Public Assistance for eligible local government and infrastructure costs.
Why does Missouri flood in so many different ways?
Missouri has several types of flood risk. Heavy rain can cause flash floods within hours. The Mississippi and Missouri Rivers can also overflow after several days of rising water. Ice jams and snowmelt can cause flooding in winter and early spring.
Does homeowners insurance cover flood damage in Missouri?
Standard homeowners insurance usually doesn't cover flood damage in Missouri. Separate flood insurance may cover damage from flash floods or overflowing rivers. This coverage is often available through the National Flood Insurance Program.
How can I keep my sump pump running during a Missouri flood outage?
A battery backup can keep your sump pump running during a flood if the power goes out. This can help stop water from building up in the basement. A larger backup system can also power other essential equipment while you wait for utility power to return.
