My House Flooded: What to Do First, Step by Step
You didn't come here for background on flooding. Your house flooded, and right now you're typing "my house flooded now what" into a search bar. The two things that matter most in the first hour are safety and stopping further damage, in that order. Everything else, insurance, cleanup, repair, comes after. This guide walks through checking for immediate danger and cutting power and utilities safely. It also covers documenting the damage, starting cleanup, and getting through the outage that often comes with the flood.
Is It Safe to Go Back Inside?
Your first instinct is to rush in and see how bad it is. But a flooded house hides hazards you can't see from the driveway, so run through these checks first.
Wait for the All-Clear Before Re-Entering: FEMA's flood safety guidance for homeowners says to return only when local officials say it's safe.
Check for Gas and Structural Hazards First: Walk around the outside of the house. If you smell gas or hear hissing, back away and call the fire department. Anything cracked or sagging needs an inspection.
What to Wear Before You Go In: Floodwater carries sewage, fuel, and lawn chemicals. Wear waterproof boots, heavy gloves, and an N95 mask once you start moving debris.
Once you're cleared to go in, deal with the utilities before you touch anything else.
Cutting Off Power, Gas, and Water Safely
This step protects you more than it protects the house. Get it right before you do anything else.
Turn Off Electricity at the Breaker Box, If You Can Reach It Safely
If there's no standing water between you and the breaker box, shut off the main electrical supply first. Never wade through standing water to reach a breaker box or an outlet. Live electricity and a wet structure are a serious electrocution risk, not just an inconvenience, according to the Electrical Safety Foundation International.
Know When You Need an Electrician
If floodwater rose above the level of your electrical outlets, don't turn the power back on. Wait until a licensed electrician confirms it's safe. This is one of the few steps in the whole process that isn't a judgment call.
Shutting Off Gas and Water Lines
Turn off the gas supply at the meter if you smell gas or suspect a leak. Shut off the main water line too, if flooding was caused by a plumbing failure rather than water coming from outside. A flooded house and a powerless house tend to go hand in hand. The same order of operations applies to general power outage safety, worth reading alongside this one.
With the utilities handled, the next priority is capturing proof of what happened before anything gets cleaned up or thrown out.
Documenting the Damage Before You Touch Anything
Insurance claims live or die on documentation. This step takes an hour and can save you weeks of argument later.
Photograph and Video Everything First
Take extensive photos and video of the interior and exterior before moving or discarding anything, including the visible waterline on walls. FEMA's FloodSmart program specifically recommends keeping small samples of damaged materials, like carpet, drywall, and insulation, for the adjuster to see later.
Contact Your Insurance Company Right Away
Standard homeowners insurance typically does not cover flood damage. A separate flood policy through the National Flood Insurance Program or a private carrier is usually what applies. Start the claims process immediately, even if an adjuster can't visit for several days after a large-scale disaster.
What to Keep, What to Toss
A quick sorting pass saves time later.
Keep and Dry | Remove Promptly |
Solid wood furniture | Wet carpet and padding |
Family photos and documents | Soaked insulation |
Non-porous valuables | Any porous material that absorbs floodwater |
Don't wait for an adjuster before pulling out wet carpet, padding, and other soaked materials. Mold can begin growing within 24 to 48 hours, according to the EPA, so drying those materials fast matters more than waiting for permission.
Documentation protects the claim. What happens next is the physical work of drying the house out before mold gets a foothold.
Starting the Cleanup Process
Searches for "fix flood damage" and "fix flooded house" spike right about now, once the safety steps are done. Cleanup is where real labor starts. It's also where most people either get ahead of mold or fall behind it.
Remove Everything the Water Touched
Rip out wet carpet and padding, and pull anything porous that absorbed floodwater out of the house entirely. Check hidden spaces too, like the base of kitchen cabinets and islands, for trapped standing water.
Demo Damaged Drywall and Insulation
FEMA's guidance calls for removing wallboard to a height of 4 feet if floodwaters were less than 2.5 feet deep, and up to 8 feet (or the ceiling line) if the water was deeper. This allows for standard-sized drywall replacement while ensuring all wicked moisture is removed. Remove soaked insulation carefully rather than yanking it out, which can leave gaps that cause mold and thermal problems later.
Clean, Disinfect, and Dry
A bleach solution of one cup of bleach per five gallons of water, per the CDC, helps kill mold and bacteria on hard surfaces. Keep it away from electrical outlets and metal hardware. Full drying with fans and open windows can take several weeks, according to FEMA. Rebuilding shouldn't start until that's done.
When to Call in Professionals
Volunteer disaster-response groups and licensed, insured contractors can help with cleanup and rebuilding once the immediate danger has passed. Be cautious of any contractor who asks for a large deposit before starting work.
Cleanup takes weeks. What often makes those weeks harder is losing power in the middle of it, which is common with flood-related outages.
Staying Powered While You Clean Up and Rebuild
Flood-related power outages often outlast the flooding itself, as severe storms and flooding regularly lead to prolonged utility outages across impacted regions, according to the U.S. Energy Information Administration. Flooded substations and damaged distribution lines require significant time for utility crews to inspect and safely restore. Meanwhile, heavy-duty drying fans, sump pumps, and refrigerators all require continuous electricity precisely when local power grids are stretched thin.
Keeping Essential Equipment Running During Drying-Out
Running fans and dehumidifiers to dry out a flooded home takes real power. That's a problem fast if the outage from the same storm hasn't been resolved yet. A working sump pump is critical too, keeping additional water from re-entering while you're trying to dry the house out. Wiring a sump pump into a dedicated battery backup is one of the more practical upgrades a flood-prone home can make.
Portable Power for Displaced Households
If the flood forces a temporary move out of the house, a portable battery still keeps you connected. Phones, medical devices, and small essentials stay charged wherever you land.
Getting through this flood is one thing. A little preparation now makes the next one far less overwhelming.
Preventing the Next Flood From Doing This Again
Once the immediate crisis passes, a few changes actually reduce the odds of a repeat. How does a house flood a second time? Usually the same way it did the first time, through a crack, a gap, or a pump that failed.
Simple Steps That Reduce Future Risk
Sealing noticeable foundation cracks and installing a sump pump with battery backup meaningfully reduce the odds of a repeat event. Water alarms near common trouble spots give an early warning before a small leak becomes a major flood.
Revisit Your Insurance Coverage
If this flood revealed you didn't have flood insurance, or weren't covered enough, use this moment to fix it. A full breakdown of how flood insurance actually works is worth reading now, not after the next flood.
The first hour after you find a flooded house is about safety and stopping further damage, in that order. Wait for the all-clear, then cut the power only if you can reach the panel without standing in water. Photograph everything before you move it, and call your insurer the same day, since a standard policy rarely covers rising water. After that, the job is speed: pull out wet material, cut drywall above the waterline, disinfect, and keep air moving. Because these outages often outlast the flooding, keep backup power in the plan, whether that is a whole-home EcoFlow DELTA Pro Ultra X or a portable DELTA 3 Max.
Is it safe to enter a flooded house before the water fully recedes?
No. Wait until officials say the area is safe, especially after a storm or an evacuation order. Standing water hides structural damage, debris, and live electricity. Wear boots, gloves, and a mask.
Should I turn off my electricity if my house floods?
Yes, if you can reach the breaker box without stepping into water. Never wade through standing water to reach a panel or an outlet. If water rises above your outlets, leave it off until an electrician clears the system.
Does homeowners insurance cover a flooded house?
Usually not. Standard policies exclude damage from rising water. That coverage comes from a National Flood Insurance Program policy or a private carrier. Check your declarations page now, since new policies often have a waiting period.
How long does it take for a flooded house to dry out?
Plan on two to four weeks of drying with fans and open windows before rebuilding starts. Removing wet carpet, drywall, and insulation first speeds that up.
What should I do if I lose power while cleaning up flood damage?
Keep the fans, dehumidifiers, and sump pump running first, since those set the drying timeline. A battery system also avoids the carbon monoxide risk of a generator. A portable station covers phones and tools, while a whole-home system carries larger loads.
