HVAC Tune-Up Checklist: What the Spring Cooling Visit and Fall Heating Visit Should Cover
Most homeowners book an HVAC tune-up at the worst possible moment. It usually happens during the first brutal heatwave of July or the first freezing night of December. By then, every local heating and cooling company is booked out for weeks.
ENERGY STAR recommends having a contractor do annual pre-season check-ups instead. You want your cooling system checked in spring and your heating system checked in fall. Because these two visits inspect completely different components, each requires its own process.
Below is a clear, visit-by-visit checklist showing what your technician handles and what you can do yourself. By law, refrigerant handling requires an EPA Section 608 certified professional. You will also find an honest backup plan to keep your lights, Wi-Fi, and phones running if maintenance or severe weather cuts off your household power.
What a Tune-Up Is, How Often to Book One, and Where Your Part Ends
A tune-up is a scheduled inspection and cleaning performed by a qualified HVAC contractor before severe weather hits. ENERGY STAR recommends annual pre-season check-ups: cooling in the spring and heating in the fall. A heat pump handles both jobs, so it gets serviced before both seasons.
When ENERGY STAR says to schedule HVAC checkups
ENERGY STAR advises homeowners to "have a contractor do annual pre-season check-ups." It suggests tying the reminder to your calendar during the spring and fall clock changes.
According to ENERGY STAR, these tune-ups serve two clear purposes:
Keeping your equipment running at "peak performance."
Helping prevent future problems and unwanted costs before extreme temperatures arrive.
ENERGY STAR notes these visits keep equipment operating as designed. However, a tune-up is not a magic guarantee of lower utility bills.
Three lanes of work
HVAC maintenance falls into three distinct lanes. Some tasks belong to the homeowner, while others require certified professionals.
Lane | Who | Examples |
Owner, any time | You | Checking air filters, clearing yard debris around the condenser, and monitoring the condensate drain line. |
Contractor, every visit | HVAC technician | Tightening electrical connections, checking motor current, testing safety controls, and cleaning coils. |
Refrigerant work | EPA Section 608 certified technician only | Checking operating pressures, testing for leaks with a detector, recovering refrigerant, and adjusting charge. |
Federal regulations are strict about refrigerant handling:
Under EPA Section 608, technicians who maintain, service, repair, or dispose of equipment that could release ozone-depleting refrigerants must hold certification.
The EPA issues certifications across four categories: Type I (small appliances), Type II (high-pressure systems), Type III (low-pressure systems), and Universal. These credentials do not expire.
The Department of Energy (DOE) states technicians must capture evacuated refrigerant instead of illegally venting it into the atmosphere.
Homeowners should never attempt to add refrigerant or purchase DIY recharge kits from an auto parts store.
Booking a spring cooling checkup fits naturally alongside your regular spring home maintenance tasks like clearing roof gutters, inspecting window screens, and swapping out smoke detector batteries.
With the scope and schedule clear, we can look at what happens during each seasonal service call.
The Checklist, Visit by Visit
Spring maintenance focuses on cooling performance, airflow, coils, refrigerant, and drainage. Fall maintenance shifts toward combustion, venting, and heating safety. Some checks appear during both visits because they affect the entire system.
Spring cooling visit (central AC or heat pump in cooling mode)
This seasonal visit addresses what is included in an air conditioner tune up.
Item | What the Technician Does | Why It's on the List (Source) |
Coils | Cleans indoor evaporator and outdoor condenser coils. | Dirty coils reduce heat transfer and force the system to run longer to cool the house (ENERGY STAR). |
Refrigerant | Checks operating charge and tests lines for leaks using an electronic detector. | Incorrect refrigerant charge lowers operating efficiency (ENERGY STAR); technicians must locate leaks and recover refrigerant properly (DOE). |
Airflow | Cleans and adjusts blower assemblies; measures airflow across the evaporator coil. | Airflow restrictions can cut overall cooling efficiency by up to 15% (ENERGY STAR); airflow testing verifies proper heat exchange (DOE). |
Condensate Drain | Inspects, flushes, and clears drain lines and pans on AC units, heat pumps, or furnaces. | A plugged drain line causes water damage to ceilings or floors and spikes indoor humidity levels (ENERGY STAR). |
Ducts | Inspects accessible ductwork for disconnects, tears, and air leakage. | Technicians should inspect and seal duct leaks in central forced-air systems to prevent air loss (DOE). |
Controls | Checks operating sequences and thermostat wiring. | Technicians confirm heating and cooling cycles cannot run at the same time (DOE). |
Fall heating visit (furnace, or heat pump in heating mode)
The autumn appointment prepares heating equipment for continuous winter operation.
Item | What the technician does | Why it's on the List (Source) |
Gas or oil connections | Checks fuel lines, line pressure, burner combustion, and the heat exchanger. | Faulty fuel connections present serious fire hazards and can cause dangerous health risks (ENERGY STAR). |
Venting system | Inspects the flue pipe, draft hood, vent connections, and chimney base. | Technicians verify proper draft (DOE); the U.S. Fire Administration (USFA) recommends annual professional chimney and vent cleanings. |
Combustion test | Analyzes fuel-to-air combustion efficiency using a gas analyzer. | Verifies the burner burns fuel cleanly without wasting energy (DOE). |
Forced-air extras | Inspects the heat exchanger for hairline cracks, tests for carbon monoxide, and oils blower bearings. | Cracked heat exchangers allow toxic exhaust into supply air (DOE). |
Heat pump heating | Tests reversing valves, defrost controls, auxiliary heat strips, and outdoor sensors. | Carrier's heat pump service checklist includes reversing-valve, defrost-cycle, and auxiliary-heat checks for heating-season operation. |
Every visit, either season
Whether you're preparing for summer or winter, the technician should also:
Verify thermostat settings and temperature accuracy.
Tighten electrical connections and measure motor voltage and current.
Lubricate moving parts where the manufacturer specifies.
Inspect belts and related moving components.
Run the system through a complete startup, operating, and shutdown cycle.
A central AC compressor draws heavy power the second it kicks on. Knowing how AC starting current works explains why technicians carefully inspect motor capacitors, wiring, and electrical draw on every visit.
For cleaning, disassembly, or other hands-on service, a technician will typically isolate the equipment by switching off the disconnect or breaker. Some diagnostics, such as measuring motor voltage and current, have to be done while the system is energized and running. Qualified technicians handle those checks using the equipment manual and established safety procedures.
When the System Is Switched Off: Lights, Wi-Fi, and a Backup Heater
During a routine tune-up, the technician usually shuts off the HVAC equipment being inspected. The rest of the house can continue operating normally.
The situation changes if electrical work requires a circuit or panel to be shut off, a fault keeps the heat off while parts are ordered, or a storm causes a wider outage. A portable power station can help keep essential plug-in devices running during those interruptions.
What the power station is for, and what it isn't for
This section covers standalone, plug-in backup power only. It does not cover powering hardwired HVAC equipment, which needs a different setup.
What it powers: Smartphones, Wi-Fi routers, desk lamps, laptops, and (on high-capacity units) a standard 120V portable space heater and your kitchen refrigerator. In the setups described here, each device plugs directly into the station’s built-in AC outlets.
What it cannot power: What a plug-in setup does not cover: Hardwired HVAC equipment. Never connect a portable battery station to equipment under active service. Never back-feed household circuits through a wall outlet or connect the unit to an air handler yourself. Carrier points out that outdoor heat pump and AC condensing units run on 220V or 240V circuits. A 120V output cannot run that equipment. Some power stations, including the DELTA 3 Ultra series, offer home integration through a manual transfer switch or inlet box. That requires a compatible configuration, load calculations, and installation by a licensed electrician. It is outside the scope of this article.
Space heater safety guidelines: The Consumer Product Safety Commission (CPSC) says to plug electric space heaters directly into a wall outlet, never into an extension cord or power strip. It also says to keep heaters at least three feet from drapes, furniture, bedding, and other combustible materials, and to turn them off when sleeping. Whether a particular space heater is suitable for use with a power station is a separate question. Check the instructions from both the heater's manufacturer and the power station’s manufacturer before connecting them.
Capacity and runtime planning
A simple planning formula estimates how long a power station might run your devices:
Estimated runtime (hours) = Battery capacity (Wh) × 0.85 ÷ Load (W)
The 0.85 factor is an illustrative allowance for conversion losses. Actual runtime varies with the equipment, operating conditions, and battery state.
Example 1: Lights, phone charging, and Wi-Fi
Suppose your router draws 12W, two LED lamps draw 10W each, and phone charging averages 15W. Together, they use 47W.
Battery capacity: 1,024Wh
Estimated usable energy: 1,024 × 0.85 = 870Wh
Estimated runtime: 870 ÷ 47 = approximately 18.5 hours
This is an example estimate. Check the actual wattage of your devices before planning around it.
Example 2: A space heater and refrigerator
Suppose a 120V ceramic heater draws 1,500W on high, while a refrigerator averages 60W. With a 3,072Wh battery, the estimated usable energy is 2,611Wh.
Heater running continuously: 2,611 ÷ 1,560 = approximately 1.7 hours.
Heater averaging 750W because its thermostat cycles: 2,611 ÷ 810 = approximately 3.2 hours.
These are planning estimates, not guaranteed runtimes. A refrigerator's compressor can draw additional power when starting. Check the starting and running requirements of both appliances against the power station's ratings.
Choose between the two EcoFlow DELTA 3 units below based on how long you need backup power and whether you need to run a space heater.
When a tune-up or storm cuts power for a few hours, the EcoFlow DELTA 3 Classic keeps phones charged, lights on, and the Wi-Fi router running, so the house stays connected without touching the HVAC system.
For a longer outage that also needs a temporary 120V space heater and the refrigerator, the EcoFlow DELTA 3 Ultra Plus supplies the extra capacity and output while still powering only plug-in household devices.
The EcoFlow DELTA 3 Classic keeps your lighting, smartphones, and internet connection active during routine maintenance or brief outages. The EcoFlow DELTA 3 Ultra Plus handles larger loads, making it ideal for running a 120V space heater and your refrigerator if emergency repairs leave you without heat.
Neither unit can run a 240V central HVAC system. They should never be connected to equipment an HVAC technician is currently servicing. Always use space heaters in good condition, match appliance wattage to your unit's output limits, and follow all safety guidelines. Remember that runtimes are calculated estimates, and neither a tune-up nor battery storage guarantees lower utility bills.
Losing power can cut you off from the outside world fast. Setting up portable power for your home internet router ensures you can work remotely and check local emergency updates while technicians finish their repairs.
Your Side of the Checklist Between Visits
Professional maintenance is only part of the job. A few straightforward tasks help homeowners monitor their systems between scheduled appointments.
Check filters and keep the outdoor unit clear
ENERGY STAR recommends inspecting, cleaning, or changing filters monthly. The Department of Energy advises checking them every month or two during cooling season. Follow your equipment manufacturer's instructions and replace disposable filters when dirty.
The Department of Energy also notes that replacing a dirty, clogged AC filter can reduce air-conditioning energy use by 5% to 15%. That is a potential benefit, not a guaranteed saving for every home.
Other homeowner tasks include:
Condensate drain: Watch for water near the indoor unit. Follow the manufacturer's instructions for routine drain maintenance.
Outdoor unit: Remove leaves and loose debris. Turn off power at the outdoor disconnect before clearing the area, and maintain at least two feet of clearance where the equipment's instructions call for it.
Evaporator coil: Leave detailed inspection and cleaning to the technician unless your manual specifically permits a simple homeowner task.
Carbon monoxide alarms: Install battery-operated or battery-backup CO alarms near sleeping areas. Test them regularly and replace batteries according to the manufacturer's instructions.
The CDC recommends checking CO alarm batteries when clocks change in spring and fall. This makes a convenient reminder to pair with your HVAC appointments.
A simple maintenance calendar
Month or moment | Owner task |
Every month in heavy-use seasons | Look at the filter; change it when dirty |
Spring clock change | Book the cooling visit; test CO alarm batteries |
After heavy storms or leaf fall | Clear the outdoor unit with its power off |
Fall clock change | Book the heating visit; test CO alarm batteries |
A thermostat setting checked during the visit is easier to keep once you settle on the best AC temperature for your home and stick with it.
Some problems shouldn't wait for the next scheduled visit at all.
Getting Ready for the Visit, and Signs to Call Sooner
A little prep work before the technician arrives helps them get straight to testing your equipment instead of clearing clutter. Keep a short log of any performance issues you have noticed recently. Most importantly, know which warning signs require immediate emergency help.
Before the technician arrives
Clear access to the indoor unit, outdoor unit, and breaker panel.
Write down unusual noises, odors, short cycling, or rooms that never feel comfortable.
Locate the equipment's model and serial numbers.
Ask whether refrigerant work is planned and confirm the technician's EPA Section 608 certification when required.
Call now, don't wait
Some problems need immediate attention rather than a routine tune-up.
Gas smell: Leave the building immediately. Don't operate switches or use a phone inside. Call the gas utility or 911 from a safe location outside.
Carbon monoxide alarm: Get everyone outside into fresh air and call 911. Do the same if people experience possible CO symptoms, such as headaches, dizziness, nausea, or confusion.
Burning smell or smoke: Stop using the equipment and contact a qualified professional. If there's smoke or fire, leave and call 911.
Repeated breaker trips: Don't keep resetting the breaker. Leave the affected equipment off and call an electrician or HVAC professional as appropriate.
Water pooling near the indoor unit: Shut the system off if safe and arrange an inspection. A blocked condensate drain may be responsible.
If your air conditioning breaks down during a summer heatwave while you wait for service, using practical ways to cool a room without AC can help keep your home livable until the repair crew arrives.
Schedule two HVAC tune-ups each year to prepare your system for seasonal demands. Spring visits focus on coils, refrigerant, airflow, and drainage, while fall visits cover combustion, venting, and heating safety. Between appointments, check filters and keep the outdoor unit clear.
Add both visits to your calendar around the spring and fall clock changes. Before refrigerant work begins, confirm your technician has EPA Section 608 certification.
If service work or a storm interrupts power, the EcoFlow DELTA 3 Classic can keep lights and Wi-Fi running. The EcoFlow DELTA 3 Ultra Plus offers more capacity for compatible devices, including a backup heater and refrigerator.
What is included in an air conditioner tune up?
A typical visit includes coil cleaning, a refrigerant check, airflow and blower inspection, condensate drain inspection, electrical checks, and control testing. The technician should also run the system and identify problems that need further repair.
How often should I get an HVAC tune-up?
You should schedule service once a year for each heating and cooling season. ENERGY STAR recommends booking a cooling system inspection in the spring and a heating system inspection in the fall.
Can I do an AC tune-up myself?
You can inspect filters, clear loose debris around the outdoor unit with power safely off, and watch for drain problems. Leave electrical testing, detailed coil service, combustion checks, and regulated refrigerant work to qualified professionals.
Does a heat pump need two tune-ups a year?
Ideally, yes. Carrier recommends professional heat pump service at least once a year, and ideally twice: once in spring for cooling and once in fall for heating. Because a heat pump handles both seasons, its checklist covers items such as the reversing valve, the defrost cycle, and auxiliary heat.
Can a portable power station run my central AC during a tune-up?
Not with a plug-in setup. Central air conditioner outdoor condensing units and heat pumps run on 220V or 240V circuits, and a 120V output cannot power them. Plug-in use with the EcoFlow DELTA 3 series is meant for electronics, lamps, and small household appliances. Powering hardwired home equipment is a separate project for a licensed electrician.
