HomeGrid Battery Comparison: Specs, Price per kWh, and How to Compare Quotes
Start a HomeGrid battery comparison with usable capacity in kWh and continuous AC backup power in kW. Compare both on the same basis, along with what each installed quote includes. HomeGrid's LV Stack'd Series uses two to eight 4.8 kWh modules per stack, for 9.6 to 38.4 kWh of rated capacity and up to 14.4 kW of continuous DC battery output. For grid-tied jobs, HomeGrid's spec sheet lists specific Sol-Ark 12K and 15K combinations. Its off-grid inverter list is separate. Include the inverter in the price. This guide covers Stack'd specs, quotes per usable kWh, and warranty terms. It also shows how an integrated system differs.
What Are the HomeGrid Stack'd Series Specs?
Battery spec sheets rarely line up from brand to brand. Stack'd keeps things fairly simple. It's a modular LFP (lithium iron phosphate) battery. Capacity grows in 4.8 kWh steps. Continuous DC battery output reaches 14.4 kW at four modules.
The current HomeGrid LV Stack'd spec sheet shows a base, a battery management system (BMS) on top and two to eight modules in between. CSA's UL 1973 certificate covers the listed battery models. The UL 9540 listing covers specific complete systems with approved inverter and battery combinations. CSA also documents UL 9540A unit-level thermal runaway fire propagation testing for Stack'd.
Modules | Rated capacity | Continuous DC power | DC surge (10 seconds) | Weight |
2 | 9.6 kWh | 8.6 kW | 14.4 kW | 304 lb |
3 | 14.4 kWh | 12.9 kW | 14.4 kW | 412 lb |
4 | 19.2 kWh | 14.4 kW | 24 kW | 520 lb |
5 to 8 | 24 to 38.4 kWh | 14.4 kW | 24 kW | 628 to 952 lb |
HomeGrid LV Stack'd Series specifications, overview and performance tables.
What Capacity and Power Mean for Your Home
So what do those columns mean for you? Capacity (kWh) tells you how long a battery can keep your loads running. Power (kW) tells you how much load the system can support at once. Beyond four modules, a single stack adds capacity while its continuous DC rating stays at 14.4 kW. The inverter and installation determine how much AC power reaches your loads.
Surge matters too. Motors in well pumps, air conditioners, and some appliances pull a short burst of extra power when they start. The battery’s 10-second DC surge rating rises from 14.4 kW to 24 kW at four modules. Is a big motor load on your backup list? Ask the installer to check its starting draw against both the battery and the inverter.
Weight is the last column, and it's easy to skip. An eight-module stack weighs 952 lb, so the install spot needs a solid floor and enough room around it. Ask where the stack will sit before you sign, not on install day.
How Much Capacity Does a Home Need?
For a sense of scale, look at EIA's data on electricity purchases by residential utility customers. In 2022 U.S. residential utility customers bought an average of 10,791 kWh from the grid, about 899 kWh per month or 30 kWh per day. Those figures can omit solar electricity used on site. To size backup, list the circuits you want to keep running and use representative appliance measurements and, if available, on-site solar consumption data.
Your own number may be very different. A home with a gas furnace and gas water heater uses less electricity than an all-electric home of the same size. Your utility bill shows monthly kWh. Start there, then decide how much of that use you'd want covered in an outage.
Inverters and the HomeGrid Compact
Stack'd is a 48 V DC battery that uses a separate inverter. HomeGrid's LV Stack'd spec sheet lists specific Sol-Ark 12K and 15K combinations for on-grid UL 9540 installations. Its separate off-grid list includes compatible models from Sol-Ark, Schneider, SMA, Victron and Outback. Ask your installer to confirm the exact models, wiring, local permit or utility requirements, and continuous AC backup rating.
HomeGrid also sells a smaller option. HomeGrid lists the wall-mounted Compact Series for off-grid installations, with 5.12 kWh of rated capacity per battery and up to 5.12 kW continuous DC output. Did a search for "HomeGrid Stackd" pricing turn up a number far lower than you expected? Check whether it was for a Compact or a smaller stack.
Prices vary by setup, and the same battery can land at very different totals depending on the inverter and labor. Check what solar batteries cost before you read any quote line by line. That's also where an integrated system starts to look different, because it packages the inverter in another way.
How Does an Integrated Home Battery Compare?
If you're collecting quotes, you might end up with two very different setups side by side. Stack'd needs a separate inverter. EcoFlow TITAN 5000 has the inverter built in, with 7,200W of split-phase output. Compare usable kWh, continuous AC backup power and the same installation scope. The Stack'd battery's DC rating is a separate specification.
What Changes in an Integrated Quote
A modular battery quote usually splits things into separate lines. You'll see the battery modules, a third-party inverter, panel work, and labor. With an integrated unit, the inverter is already part of the battery price. Neither setup is automatically the better deal. The real question is whether both quotes cover the same job.
A modular system gives the installer more choices, such as which inverter brand to use and how many modules to start with. An integrated system trims the number of separate parts on the quote. Which one suits you depends on your loads, your space, and how much you want to add later.
Where EcoFlow TITAN 5000 Fits
EcoFlow TITAN 5000 combines battery and inverter in one stationary, floor-standing home unit. EcoFlow lists 5kWh per unit and a 7,200W rated output at 120V/240V. You can expand to 30kWh with up to five EcoFlow TITAN Battery 5kWh add-ons. Adding batteries raises stored energy (kWh), not output power (kW). So in a HomeGrid vs EcoFlow TITAN 5000 quote, treat runtime and power as two separate questions.
Why does that matter? If you mostly want longer runtime through an overnight outage, extra batteries help. If you want to run more heavy loads at the same time, more batteries won't change the 7,200W rated output. Knowing which problem you're solving keeps you from paying for the wrong upgrade.
For home circuit backup, a licensed electrician can install EcoFlow TITAN 5000 with Smart Home Panel 10 (240 V). EcoFlow specifies No Export for this grid-connected setup. On Nov. 25, 2026, EcoFlow's U.S. store listed the stand-alone 240 V panel at $1,199 and showed a $1,099 240 V panel add-on on its TITAN 5000 page. The bundle of one TITAN 5000 and one 240 V panel was $4,199 for hardware. Ask for installation separately and confirm current availability on the product pages.
EcoFlow TITAN 5000 includes its inverter. For an installed home backup comparison, include the 240 V panel and associated electrical work on the TITAN quote. Include the selected third-party inverter, panel work and labor on the Stack'd quote.
Backup scope changes cost as much as brand does. Decide whole home versus critical loads before you compare. That choice sets the kW and kWh you actually need. Once the scope is clear, you're ready to line up the quotes.
How Should You Compare HomeGrid Prices?
A HomeGrid price can look high or low depending on what's bundled in. Get quotes that include the same items: modules, inverter, panel work, installation, and warranty. Then divide by usable kWh, and write down the date on each quote, since prices change.
That last step matters because the battery itself is only part of the bill. The National Laboratory of the Rockies’ 2024 residential battery cost model splits system cost into two parts. Energy costs track kWh, and power costs track kW. It also notes that the battery pack is only a fraction of the total. The inverter, labor, permits, and other items add up fast.
A Simple Home Battery Price per kWh Formula
The math for home battery price per kWh is simple. Take the installed price and divide it by usable kWh. For example, assume an installed quote is $20,000 and the installer confirms 19.2 kWh of usable capacity. That works out to about $1,042 per usable kWh. Write the system's continuous AC backup rating next to that figure. Two systems with the same price per kWh can run very different loads at once.
Make sure each quote states usable kWh, not just total or nominal capacity. HomeGrid's spec sheet gives total energy. Ask each installer to state how many kWh your loads can use before the system reaches its backup reserve under the proposed configuration.
Compare Two HomeGrid Hardware Packages
Here are two U.S. hardware listings from the same seller, BatteriesInAFlash, checked on Nov. 25, 2026. Each includes a HomeGrid battery stack and one Sol-Ark 15K-2P hybrid inverter. Both stacks have the same 14.4 kW continuous DC rating. Sol-Ark separately lists up to 12 kW of continuous AC output at 120/240 V in backup mode. Ask the installer to confirm actual system output and whether the quote includes the required connections and accessories.
U.S. hardware comparison | ||
Battery model and rated energy | PF5-LFP19200-2A01, 19.2 kWh | PF5-LFP28800-2A01, 28.8 kWh |
Inverter and AC backup rating | Sol-Ark 15K-2P, up to 12 kW continuous at 120/240 V | Sol-Ark 15K-2P, up to 12 kW continuous at 120/240 V |
Listed hardware price | ||
Installation and permits | Obtain a separate installed quote | Obtain a separate installed quote |
Usable capacity | Confirm for the installed configuration | Confirm for the installed configuration |
Hardware price per rated kWh | About $833 | About $694 |
In these listings, $4,000 buys 9.6 kWh more rated storage with the same inverter. The hardware prices exclude installation and permit costs. Get a site quote for labor, panel work and permit fees, and ask which cables, busbars and other accessories are included. Use confirmed usable kWh to compare installed offers.
Questions to Ask Every Installer
Try to collect several quotes. The FTC's home improvement contractor tips cover what a written estimate needs. It should describe the work, the materials, the completion date, and the price. The FTC also warns against picking the lowest bid by default. If two bids differ widely, ask why.
A few questions make quotes easier to compare. Ask each installer the same ones and keep their answers next to the quote:
What is the usable kWh, and is it written on the quote?
What is the inverter's continuous kW rating?
Which circuits will the battery back up?
Are permits, inspections, and panel upgrades included?
Who handles warranty claims, and is labor covered?
If you already have solar panels, your quote may look different. Ask about adding storage to existing solar during the quote. It can change the inverter and wiring the installer proposes. Price is only half the picture, though, and the warranty decides what that money covers over time.
How Do HomeGrid Warranties Compare?
Two batteries can both say "10 years" and still cover very different things. Read three parts of any warranty: the years, the throughput limit, and the capacity promised at the end of the term. HomeGrid's U.S. limited warranty distinguishes the battery modules from the battery management system and specifies who pays for repair labor.
What to Read in a Battery Warranty
Years are the easy part. Throughput is the total energy a battery can move before coverage ends, even if the years haven't run out. End-of-life capacity is the share of its first capacity the battery should still hold when the warranty ends.
HomeGrid's U.S. limited warranty covers eligible 4.8 kWh Stack'd modules for up to 10 years from the first installation or 14.11 MWh of throughput per module, whichever comes first. It specifies 60% energy retention at year 10, subject to those limits. The battery management system has no stated throughput or energy-retention figure. Register within one year of installation and keep the built-in connection available for firmware updates as required by the warranty. Check eligibility for the original purchaser, certified U.S. installation, and solar self-consumption or backup use in the written terms.
Under HomeGrid's U.S. repair terms, the buyer pays labor charges. A repaired or replacement product keeps the remaining original warranty term. Ask the installer who will handle removal and reinstallation and what contract covers that work.
HomeGrid vs EcoFlow TITAN 5000 Warranty Terms
EcoFlow lists a 5-year warranty for EcoFlow TITAN 5000, covering the unit, battery, and Smart Home Panel 10. EcoFlow's product page doesn't state an end-of-life capacity percentage either. Compare that number only where each maker publishes it.
Warranty item | HomeGrid Stack'd | EcoFlow TITAN 5000 |
Term | Up to 10 years from installation, subject to the module throughput limit. Register within one year. | 5 years (unit, battery, SHP10) |
Throughput limit | 14.11 MWh per 4.8 kWh module. BMS: no stated throughput limit. | Not on product page; ask EcoFlow |
End-of-life capacity | 60% at year 10 per covered 4.8 kWh module, subject to warranty limits. BMS: no capacity figure. | Not on product page; ask EcoFlow |
Labor coverage | Buyer pays repair labor. Repaired or replaced equipment keeps the remaining original term. | Ask EcoFlow or the installer |
The FTC's guide to warranties says parts or repairs that aren't listed are presumed not covered. It also tells you to check whether you contact the maker or the seller, and whether you pay for labor or shipping.
It also helps to compare solar battery warranty terms before you sign, and keep a copy with your receipt. If an installer can't answer a warranty question in writing, treat that as a reason to keep shopping.
A HomeGrid battery comparison works when every quote shares the same scope. Compare usable kWh and continuous AC backup power side by side. Line up the modules, inverter, panel work, installation, and warranty. Then divide the installed price by usable kWh and note each quote's date. Read every warranty's years, throughput, and end-of-life terms in writing. If you'd like an integrated option in the mix, add the EcoFlow TITAN 5000 to your quote list.
How much does a HomeGrid battery cost?
Two U.S. hardware listings checked Nov. 25, 2026, were $15,990 for a four-module Stack'd and $19,990 for six modules, each with a Sol-Ark 15K-2P inverter. Installed costs depend on your site and labor rates. Compare installed quotes with the same scope by dividing each total by its confirmed usable kWh.
How big is HomeGrid Stack'd?
HomeGrid's spec sheet lists 2 to 8 modules of 4.8 kWh each, so one stack runs from 9.6 to 38.4 kWh. Continuous DC battery output reaches 14.4 kW at four modules and stays at that rating through eight modules.
Does HomeGrid need a separate inverter?
Yes. Stack'd is a 48 V DC battery that uses a separate inverter. Its specification lists on-grid UL 9540 combinations with specific Sol-Ark 12K and 15K units and separate off-grid options. Ask your installer to identify the exact approved combination and the system's continuous AC backup rating.
What warranty does HomeGrid offer?
HomeGrid's U.S. limited warranty for eligible 4.8 kWh Stack'd modules runs up to 10 years from installation or 14.11 MWh per module, whichever comes first. It specifies 60% retention at year 10 subject to those limits. There is no throughput or capacity figure for the BMS. Register within a year, meet the connectivity terms, and budget for repair labor.
How does EcoFlow TITAN 5000 differ?
EcoFlow TITAN 5000 has a built-in inverter rated at 7,200W, split-phase 120V/240V. It starts at 5kWh and expands to 30kWh with add-on batteries, while its output power stays the same. It pairs with an electrician-installed Smart Home Panel 10 (240 V) for selected home circuits and carries a 5-year warranty.
