Prepper Supplies That Hold Up: An Emergency Kit Built on Ready.gov and Red Cross Guidance
Reliable prepper supplies follow the Ready.gov basic kit: one gallon of water per person per day for several days, a several-day food supply, a battery or hand-crank radio, a flashlight, a first aid kit, extra batteries, and phone chargers. The Red Cross recommends enough food and water for each person for three days if you evacuate and two weeks if you stay home. It also recommends a seven-day supply of medications and any medical items you need. This guide turns that advice into a simple emergency kit checklist. It also keeps lights and radios apart from bigger power needs and shows how to keep your kit ready all year.
What Prepper Supplies Does Every Home Need?
If you've ever stood in a store aisle the day before a hurricane, you know how fast a supply list can grow. It's better to start small. Build the Ready.gov basic kit first, size it by the people, pets, and days you need to cover, and then add what your own household needs.
Start With the Ready.gov Kit
The ready.gov kit is short on purpose. Ready.gov's Build A Kit page lists these core items:
  • Water, one gallon per person per day for several days, for drinking and sanitation
  • At least a several-day supply of non-perishable food
  • A battery-powered or hand-crank radio and a NOAA Weather Radio with tone alert
  • A flashlight, extra batteries, and a first aid kit
  • A cell phone with chargers and a backup battery
  • A whistle, a dust mask, a manual can opener, local maps, and a wrench or pliers to turn off utilities
These emergency preparedness supplies cover most short emergencies, from a winter storm to a tornado warning. The weather radio earns its spot because it doesn't depend on cell service or the internet. The National Weather Service describes NOAA Weather Radio All Hazards as a network for both weather and emergency information.
How Long Should Supplies Last?
Ready.gov says "several days," which leaves room for guessing. The American Red Cross supply list is more specific. It recommends food and water for everyone in your household for three days away or two weeks at home. Pack seven days of medications, along with any medical items each person needs.
Category
Ready.gov / Red Cross guidance
Notes
Water
1 gallon per person per day
Several days (Ready.gov). Three days for evacuation or two weeks at home (Red Cross).
Food
Several-day supply (Ready.gov)
Light and radio
Flashlight, NOAA Weather Radio
Keep their own batteries
Medications
7-day supply (Red Cross)
Ask your doctor
Power
Chargers, backup battery
Bigger loads covered below
Then do the math for your home. A family of four planning for two weeks at home needs 56 gallons of water at one gallon per person per day. Count pets too, and store their food and water with yours.
For food, pick things your family already eats that don't need cooking or a fridge. Canned soup, peanut butter, crackers, and dried fruit all work. If it's canned, the manual can opener on Ready.gov's list matters more than it sounds. Sealed, store-bought water is the easiest to keep, and a cool, dark corner of a basement or closet helps it last.
Add What Your Household Needs
The basic list is a floor, not a ceiling. Ready.gov also suggests prescription medications, common over-the-counter medicines, soap and hand sanitizer, copies of important family documents, and cash. Families with babies, older relatives, or someone with a disability will need more.
Think through a normal day in your home and write down what you'd miss. That might be formula and diapers, a spare pair of glasses, hearing aid batteries, or a pet carrier. Replace infant formula before the Use By date and avoid using it after that date. Where you live matters too. A kit in Minnesota needs warm blankets and hats for a winter storm, while a kit on the Gulf Coast should plan for heat and humidity during hurricane season.
Before storm season, build the survival kit your home needs around these basics. Once the kit is set, the next question is power. Small lights and radios need their own batteries, and bigger loads need more.
How Much Backup Power Should a Prepper Kit Include?
Picture the first night of an outage. Everyone wants to charge a phone, someone wants the Wi-Fi back, and you need light to cook. Keep flashlights and the radio on their own batteries so they never compete with anything else. Then add a power station for phones, a router, and lamps. Medical devices need a separate plan from your provider.
Keep Lights and Radio Separate
This rule is simple, and it matters most late in an outage. If a bigger battery runs low, your flashlight and radio still work. Stock spare AA or AAA cells in the sizes your lights and radio use, and store them in the kit, not in a kitchen drawer. A hand-crank radio adds one more fallback, since it can keep working after the spare batteries are gone.
A headlamp is worth adding too. It keeps both hands free while you cook, check the breaker panel, or help a child find something in the dark. Battery lights are also safer than candles, which add a fire risk at a time when help may be slow to arrive.
Where a Power Station Fits
An emergency power supply covers the next layer: the phones, router, and lamps that keep you in touch. Run portable fuel-powered generators outdoors, more than 20 feet from doors, windows and vents. Point the exhaust away from the home and other buildings. EcoFlow power stations run on a rechargeable battery and don't burn fuel, so they make no exhaust. They're meant for chargers, lamps, and small electronics, while your flashlights and radio keep their own batteries.
EcoFlow DELTA 3 Classic in a home office with a laptop and Wi-Fi router. Photo: EcoFlow.EcoFlow DELTA 3 Classic in a home office with a laptop and Wi-Fi router. Photo: EcoFlow.
For a short outage, the EcoFlow DELTA 3 Classic is a practical size. It can keep phones, a router, and a lamp going, and EcoFlow says it recharges from 0 to 80% in about 45 minutes on AC. That means it's ready again soon after the power comes back.
EcoFlow DELTA 3 Classic (1024Wh) + Bag
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Runtime Estimates
The figures below are estimates, not test results. We counted 85% of the rated 1,024Wh as usable, about 870Wh, and divided by the load. The loads are example figures, not specific models, so check your own device labels or use a plug-in meter.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable, est.)
Phones + router
About 20W (example)
About 43 hours (est.)
LED lamp + phones + router
About 30W (example)
About 29 hours (est.)
Check Your Own Loads
Want numbers that fit your home? Start with the devices you'd actually run. A router's power adapter lists a maximum rating, but the router usually draws less than that. A plug-in energy meter shows what it really uses over a day.
Add up the watts for everything you plan to run at once, then divide the station's usable watt-hours by that total. If the answer is shorter than your typical outage, cut a device, run lamps only at night, or plan to recharge when you can. Most families find that phones, Wi-Fi, and a lamp or two are what they miss first. Starting with those few loads keeps your plan realistic, and you can always add more later once you see how long a full charge really lasts in your home.
Medical Devices Need Their Own Plan
If anyone at home uses a medical device that needs electricity, talk with your provider before the next outage. The FDA's medical device power outage guide suggests getting outage advice from the device maker or your medical provider. It also says to ask whether your device has a backup system, how long it runs, and whether it can use batteries during an outage. Write those answers down and keep them in your kit. Your provider sets that plan, and a power station is no substitute for it.
If storms often knock out power where you live, sketch a 72-hour backup power plan for your household. Next comes a different kind of kit, the one you grab when you have to leave.
What Goes in a Grab-and-Go Kit?
Keep an evacuation kit ready before wildfire or hurricane season. Follow local instructions and leave promptly if officials order an evacuation. Pack three days of food and water for everyone, plus copies of key documents and some cash. Use more than one bag or container if that makes the supplies easier to carry.
Build a 72-Hour Kit
A 72-hour kit covers the three days of food and water the Red Cross recommends for evacuation. Divide supplies among sturdy bags or bins that people in your household can carry. The Red Cross list for this kit includes:
  • Three days of water and non-perishable, easy-to-prepare food
  • A seven-day supply of your medications, plus any medical items you need
  • A flashlight, a battery-powered or hand-crank radio, and extra batteries
  • A first aid kit, a multi-purpose tool, and hygiene items
  • A cell phone with chargers, an emergency blanket, and area maps
  • Family and emergency contact information, plus extra cash
Don't Forget Documents and Cash
Documents are easy to forget. The Red Cross suggests copies of your medication list, medical information, proof of address, deed or lease, passports, birth certificates, and insurance policies. Seal them in a waterproof bag, or save scans on a password-protected drive you keep in the kit.
Cash matters too. When the power is out, card readers and ATMs may not work, so a little money in small bills can cover gas, food, or a motel room. Keep a written list of family phone numbers as well, since a dead phone takes every saved contact with it.
Where to Keep Your Kit
Keep the finished kit near the door you use most so nobody has to search for it in the dark. A closet by the garage or a shelf near the front door works well. Some families also keep a smaller bag in the car with water, snacks, a flashlight, and a phone charger.
If you have kids, let each one carry a small backpack with a change of clothes and a comfort item. It lightens your load and gives them a job during a stressful time.
Packing light takes planning. Start with a bug out bag checklist that fits in one trip to the car. After that, the job is keeping both kits ready.
How Do You Keep Prepper Supplies Ready?
A kit packed five years ago may hold stale food, dead batteries, and a charger for a phone you no longer own. That's why a yearly review helps. Pick a date you'll remember, like the start of hurricane season or the day you change your clocks, then rotate food and water and test your lights. Follow the manufacturer’s schedule for battery care between annual kit reviews.
A household checks food, water and a flashlight in its emergency kit. Photo: FEMA and the American Red Cross, Preparing for Disaster.A household checks food, water and a flashlight in its emergency kit. Photo: FEMA and the American Red Cross, Preparing for Disaster.
Follow Ready.gov's Three Rules
Ready.gov gives three simple rules. Keep canned food in a cool, dry place. Replace expired items and follow the CDC's guidance for stored water. And rethink your needs every year, updating the kit as your family changes.
Item
What to check during the review
Food and water
Rotate food and bottled water before the dates on their labels. Replace expired supplies. Replace water in containers you fill yourself every six months.
Medications
Swap out expired items; update the 7-day supply
Flashlights and radio
Turn them on; replace weak batteries
Power station
Follow the model’s storage schedule. For the DELTA 3 Classic, cycle the battery every three months and store it at about 60%.
Documents and cash
Update copies, contacts, and small bills
Household needs
Add items for a new baby, pet, or medical need
Test Power Gear Before Storm Season
Testing gear before you need it is the whole point. A radio that works in March is far more useful than one you first try during a storm. Turn on every flashlight, play the radio for a few minutes, and make sure the phone chargers in your kit still fit your phones.
Test the power station by running a lamp or charging a phone. For long-term storage, the EcoFlow DELTA 3 Classic manual calls for a charge and discharge cycle every three months: charge it fully, then discharge it to about 60% before putting it away. If a storm or planned outage is approaching, charge the unit before you expect to use it. Learn how to prepare for outages with a simple routine.
Reliable prepper supplies come down to Ready.gov and Red Cross basics: water, food, light, a radio, first aid, and medications. Size them by people and days, keep flashlights and the radio on their own batteries, and review the kit once a year. For phones, a router, and small lamps during short outages, an EcoFlow DELTA 3 Classic can add a rechargeable layer of power, while medical devices follow the plan your provider sets.
What are the most important prepper supplies?
Water and food come first, followed by a flashlight, a battery or hand-crank radio, a first aid kit, and any medications you take. Those items appear on both the Ready.gov and Red Cross lists, so they're the core of any kit.
How much water should I store?
Ready.gov recommends one gallon per person per day for several days, covering both drinking and sanitation. For two weeks at home, a household of three would need 42 gallons. Store extra for pets.
How many days of supplies do I need?
The Red Cross recommends enough food and water for everyone for three days if you evacuate and two weeks if you shelter at home. It also recommends a seven-day supply of medications. Start with three days and build toward two weeks over time. Adding a few extra cans or water jugs on each grocery trip spreads the cost out.
Should I keep extra batteries?
Yes. Extra batteries are on the Ready.gov basic kit list. Keep spares that fit your flashlights and radio, and check them during your yearly review so you aren't stuck with dead cells.
Can a power station run medical devices?
Talk to your medical provider first, since they set the outage plan for any device that needs electricity. The FDA suggests asking whether your device has a backup system and how long it lasts. Ask the device maker what power sources it allows, too, and keep those answers in your kit.
Power Outages
