Which Solar Batteries Last the Longest for the Price? A US Comparison of Warranties, Cycles and Cost
For the longest lifespan per dollar in the US, compare warranted energy, not just years. Enphase IQ Battery 5P and FranklinWH aPower 2 carry 15-year warranties, while Tesla Powerwall 3 carries a 10-year warranty with unlimited solar cycles under specified uses. Lithium iron phosphate (LFP) batteries generally offer long cycle life, but the best value depends on warranty limits and installed cost. A solar battery's lifespan comes down to more than how long the manufacturer promises to cover it. The warranty may also set a cycle limit, a total energy-throughput limit, or a minimum capacity the battery must retain. Those details matter when comparing the best solar battery for a home. Below, you'll find the main warranty terms, a practical way to calculate cost per warranted kilowatt-hour, and the conditions that can shorten battery life.
How Solar Battery Lifespan Is Measured
How Solar Battery Lifespan Is MeasuredHow Solar Battery Lifespan Is Measured
Warranty years give you a starting point, but they don't tell the whole story. A battery that reaches its cycle or throughput limit early may have less coverage than the headline warranty suggests.
Term
What it means
Why it matters for price
Warranty years
How long does the maker cover the battery
Longer coverage spreads the cost over more years
Cycles
One full charge and discharge of the usable capacity
A cycle cap can end coverage before the years run out
Throughput (MWh)
Total energy the warranty covers the battery to deliver
The truest measure of usable lifetime energy
End-of-warranty capacity
Share of original capacity guaranteed at the end
70% versus 60% changes how much is left in year 10 or 15
A cycle generally represents a full discharge of the battery's usable capacity, although warranty documents define how cycles are counted. Partial discharges can add up to a full cycle. Throughput measures the total energy delivered over time, so it can be more useful than years alone when comparing batteries used for daily charging and discharging. For a closer look at cell types and their trade-offs, read our guide to solar battery chemistry.
Solar battery warranties compared: Years, cycles and throughput
The table below compares the warranty terms listed in the manufacturers' US documentation available for this guide, checked October 26, 2026. When comparing these terms, it's also worth understanding how LiFePO4 and lithium-ion batteries differ in cycle life and performance. Don't treat the longest warranty in years as an automatic winner.
Battery (US)
Usable capacity
Warranty term
Source
Tesla Powerwall 3
13.5 kWh
10 years; unlimited cycles for solar self-consumption, time-based control, and backup
70%
Tesla Powerwall Limited Warranty (USA)
5.0 kWh per unit
15 years or 6,000 cycles
More than 60%
Enphase IQ Battery 5P data sheet
FranklinWH aPower 2
15 kWh
15 years or 60 MWh throughput
70% (requires certified installation, product registration, and internet connectivity)
FranklinWH Limited Warranty for End Users (October 2026)
EcoFlow TITAN 5000
5 kWh per unit, expandable
5 years (unit, battery, and Smart Home Panel 10)
No capacity-retention percentage is stated on the cited product page. Confirm the model-specific warranty terms before purchase.
EcoFlow TITAN 5000 product page: Tech Specs and warranty FAQ
EcoFlow TITAN 5000 Plus
EcoFlow TITAN 5000 Plus product page: Tech Specs and warranty FAQ
What the warranty numbers tell you
Tesla Powerwall 3: The 10-year warranty includes a 70% capacity-retention guarantee and unlimited cycles for specified solar self-consumption, time-based control, and backup uses. The full warranty term also depends on the unit remaining connected for required updates; the warranty document describes a shorter coverage period in certain circumstances when connectivity requirements aren't met.
Enphase IQ Battery 5P: Its 15-year warranty is subject to a 6,000-cycle limit, with more than 60% capacity guaranteed at the end of the warranty. A homeowner who cycles the battery heavily should consider how quickly those cycles could accumulate.
FranklinWH aPower 2: The published specification lists a 15-year warranty or 60 MWh of energy throughput. At one full 15 kWh cycle per day, 60 MWh represents about 4,000 full-capacity cycles, so the throughput limit could arrive before the 15-year mark. Confirm the remaining warranty conditions and end-of-warranty capacity in the official document.
EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus: Both systems start with 5 kWh per battery unit and allow capacity expansion. Their listed five-year warranty is shorter than the 10- to 15-year terms above. That doesn't make them unsuitable for home backup, but it does mean buyers should compare their full system cost, intended use, and official warranty terms rather than assume a longer lifespan.
Where EcoFlow TITAN Fits in a Lifespan-for-Price Comparison
EcoFlow TITAN systems are worth comparing for homeowners who want expandable storage and whole-home backup. Their five-year warranty is shorter than the terms listed for the Enphase, FranklinWH, and Tesla models above, so they shouldn't be presented as the longest-lasting batteries in this comparison. Their fit depends on the home's loads, solar setup, and installed price. The two models mainly differ in how much solar power the home can connect directly.
EcoFlow TITAN 5000
The EcoFlow TITAN 5000 and EcoFlow TITAN 5000 Plus both support whole-home backup, but they differ in how much solar power they can accept directly. Compare their output, solar input, and expandable capacity to find the right fit for your home's energy needs.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
Explore the EcoFlow TITAN 5000 Plus if your home needs more direct solar input. Have a licensed electrician handle the Smart Home Panel 10 and household circuit connections. For either model, compare the same items you would for any other battery: usable capacity, warranty coverage, expected energy use, and the full installed cost. The product with the higher price isn't automatically the longer-lasting choice. For broader price context, see our guide to solar battery costs.
Lifespan for the price: Cost per warranted kWh
Cost per warranted kWh compares a battery's installed price with the energy its warranty covers. A lower figure means better value under the same assumptions. Formula: Cost per warranted kWh = Installed price ÷ Warranted energy (kWh). Estimate warranted energy using usable capacity × 365 × warranty years, assuming one full cycle daily. Compare this with any cycle or throughput limit and use the lower figure. This is an estimate, not a prediction of actual battery life. The examples below use EnergySage’s average installed-cost data from October 2025 to March 2026.
Example (EnergySage average installed cost, Oct 2025 to Mar 2026)
Calculation
Tesla Powerwall 3: 13.5 kWh × $998/kWh = $13,473
$13,473 ÷ (13.5 kWh × 365 × 10 = 49,275 kWh)
About $0.27
FranklinWH aPower 2: 15 kWh × $1,177/kWh = $17,655
$17,655 ÷ 60,000 kWh throughput cap (lower than 15 × 365 × 15 = 82,125 kWh)
About $0.29
What shortens a solar battery's life?
What shortens a solar battery's life?What shortens a solar battery's life?
A battery's real-world life depends on how it's built and how it's used. Even a generous warranty won't tell you everything about degradation, so pay attention to the operating conditions in the manufacturer's documentation.
  • Battery chemistry: LFP (lithium iron phosphate) cells generally support more charge cycles than NMC (nickel manganese cobalt) cells. The exact battery design and warranty still matter.
  • Depth of discharge: Regularly using most of a battery's capacity can affect cycle accumulation. Check how the warranty defines a cycle and what usable capacity the system makes available.
  • Temperature: Extreme heat and cold can affect battery performance and aging. Choose an installation location that stays within the manufacturer's permitted temperature range.
  • Daily use: A battery that charges and discharges every day for time-of-use savings may accumulate throughput faster than one reserved mainly for outages.
  • Connectivity requirements: Some warranties require an internet connection for updates. Tesla's warranty, for example, includes conditions tied to connectivity and the full coverage period.
The best solar battery for lifespan and price is the one that delivers the most warranted energy for the money, not necessarily the one with the longest warranty in years. Compare usable capacity, cycle limits, throughput, end-of-warranty capacity, and the full installed price before choosing a system. Ask each installer for the warranty document and run the same cost-per-warranted-kWh calculation on every quote. If you're considering EcoFlow, compare the EcoFlow TITAN 5000 for up to 4 kW of direct solar input or the EcoFlow TITAN 5000 Plus for up to 8 kW. Check their warranty terms and installed costs against other options, then choose the setup that fits your home and energy needs.
Which solar battery has the longest warranty in the US?
Among the models compared here, Enphase IQ Battery 5P and FranklinWH aPower 2 list 15-year warranties, subject to their respective cycle or throughput limits. Tesla Powerwall 3 lists a 10-year warranty with unlimited cycles for specified solar uses. Compare the full warranty terms rather than years alone.
How long does a solar battery last?
Many home batteries carry warranties of 10 to 15 years, though some systems have shorter coverage. Actual lifespan depends on chemistry, operating temperature, depth of discharge, cycle frequency, and the manufacturer's warranty conditions.
What is battery throughput?
Throughput is the total amount of energy a battery is warranted to deliver, measured in kilowatt-hours or megawatt-hours. For example, FranklinWH aPower 2 lists a 60 MWh throughput limit alongside its 15-year warranty.
Is LFP better for battery lifespan?
LFP batteries generally support more charge cycles than NMC batteries, making them a common choice for home energy storage. However, chemistry alone doesn't determine lifespan. Compare the warranty, capacity-retention guarantee, operating limits, and cycle or throughput terms for the exact model.
How do I compare solar battery value?
Divide the installed price by the warranted energy in kilowatt-hours, using the lower applicable limit when a warranty specifies years plus a cycle or throughput cap. Use the same price basis for every model. A lower cost per warranted kWh indicates better value under those assumptions, but your actual results will depend on usage and installation costs.
Solar Energy
