Geothermal Heat Pumps Installation: How It Works, What It Costs, and What to Expect
A geothermal heat pump uses the steady temperature underground to heat and cool a home. It's one of the most efficient systems available, but installation is a bigger project than swapping a furnace. Crews dig trenches or drill boreholes, lay a loop of pipe, and connect it to an indoor unit. This guide walks through geothermal heat pumps installation step by step, the loop types DOE describes, efficiency and cost factors, what changed with federal tax credits in 2026, and how to keep basic power during the work.
How Geothermal Heat Pump Installation Works
A geothermal system has three parts: the ground loop, the heat pump inside, and the ductwork or distribution system. Installers pick a loop type based on land, soil, and water. Then they size the system to the home.
The Four Loop Types DOE Describes
DOE groups loops into four types. Three are closed loops, where fluid circulates inside sealed pipe. The fourth is an open loop. The right choice depends on climate, soil conditions, available land, and local installation costs, according to the DOE factsheet.
Loop type (DOE) | Basic description |
Horizontal | Pipe in trenches at least 4 ft deep; needs more land |
Vertical | Pipe in drilled boreholes; less land |
Pond or lake | Coils at least 8 ft deep in water nearby |
Open loop | Uses well or surface water directly, where allowed |
Horizontal loops are generally the most cost-effective option for homes. That is especially true for new builds with enough land. Vertical loops can cost more, but they disturb less of the yard and suit tight lots or shallow soil.
Pond loops may be the least expensive choice when a suitable water body sits close by. The water must meet minimum volume, depth, and quality criteria. Open loops work only with a steady supply of fairly clean water, and they must follow local rules on groundwater discharge.
How Efficient Is the System?
DOE reports that these systems reach 300% to 600% efficiency on the coldest winter nights. In plain terms, they move several times more heat than the electricity they use.
DOE also says they can cut energy use by about 25% to 50% compared with air source heat pump systems.
The Installation Steps
Ground source heat pump installations follow a similar order on most sites. The details vary by installer, soil, and local rules.
Site survey and load calculation: The installer checks land size, soil, water access, and the home's heating and cooling needs. The load calculation sets the system size.
Permits: Drilling and loop work often need local permits. Some areas also have rules for wells and groundwater.
Loop installation: Crews dig trenches, drill boreholes, or sink coils into a pond, depending on the design. This is usually the noisiest and messiest stage.
Indoor unit: The heat pump goes into the mechanical room. It often replaces an older furnace or air handler.
Connections: Crews join the loop to the indoor unit and tie the unit to ducts or another distribution system. Electrical hookups follow.
Testing: Installers typically fill and flush the loop, check flow and pressure, and run the system in heating and cooling modes.
Geothermal is a long-term investment, so some owners first weigh whether geothermal energy is worth it for a property.
Installation can take days and may shut off power to parts of the home. A small, separate budget keeps lights and phones on.
Install Days: Temporary Lights and Phones
Drilling and loop work happen outside, but the indoor swap may leave the mechanical room dark. A power station runs work lights and keeps phones charged. It belongs in a separate budget from the geothermal system.
A geothermal install can run several days, and the indoor changeover may leave the mechanical room without power for a stretch. An EcoFlow portable power station runs work lights and keeps phones and Wi-Fi going. It's an optional, separate cost, and it isn't a backup for the heat pump.
Work lights, phones, and the router are a small load. A 1kWh unit can cover a typical workday of light use and moves easily between rooms.
What the Battery Can Cover (Estimate)
The table below is an example only. Real run time depends on the devices in use.
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) |
Two LED work lights + router + phones (40W + 10W + 20W) | about 70W | about 12 hours |
Method: usable capacity (1,024Wh × 0.85 = about 870Wh) ÷ load (70W). These are estimates, not rated run times.
What It Should Not Be Used For
The unit is not a default backup for the compressor, circulation pumps, or electric backup heat. Those loads need each device's voltage and starting watts checked. They also need a professional electrical plan.
Many homeowners also weigh solar energy versus geothermal energy before picking a project.
Back to the system: what drives the price?
Geothermal Heat Pump Installation Cost Factors
The ground loop is usually the biggest variable. Land, soil, drilling depth, and home size all matter. The geothermal heating and cooling cost to install also shifts with local labor and drilling rates. Several quotes, each with a load calculation, make comparison easier.
What Moves the Price
Loop type. Horizontal trenches need more land but less drilling. Vertical boreholes need less space but more specialized equipment.
Soil and rock. Hard rock or very shallow soil can slow digging and drilling.
Home size and load. A larger or leakier home needs more capacity. The load calculation sets that number.
Indoor equipment and ducts. Existing ductwork may need repairs or changes to work with the new unit.
Permits and local rates. Fees and labor prices differ by location.
Older DOE Figures: A Reference Point
So, how much does a geothermal system cost? The DOE factsheet offers one reference point. It dates to February 2011, so it is a historical figure and not current pricing.
Item | DOE factsheet figure |
Equipment cost | about $2,500 per ton of capacity |
Example 3-ton unit | about $7,500, plus installation and drilling |
Comparable air source system with air conditioning | about $4,000 |
Payback vs. air source | 5 to 10 years |
Indoor heat pump life | 20+ years |
Ground loop life | 25 to 50 years |
The geothermal heating pump cost per ton in that factsheet covers equipment only. DOE notes that installation and drilling come on top. A written quote for geothermal heat pumps installation should list loop work, equipment, and labor as separate lines.
Federal Tax Credit Status in 2026
The IRS says the residential clean energy credit is "not available for any property placed in service after December 31, 2025". Before that date, the credit equaled 30% of qualified costs, and this equipment was on the list.
That change affects the cost of installing a geothermal heat pump in 2026. Systems placed in service this year do not qualify. Local utility or state programs may still offer help, and their terms can change, so homeowners should check them before signing a contract.
Installers can also compare heat pumps versus furnaces for the same home.
Finally, is geothermal right for the property?
Is a Geothermal Heat Pump Worth It?
It suits homeowners planning to stay long enough to recover the cost. Land and local drilling prices matter. New builds often find it easier, since trenches can be dug before landscaping goes in.
Pros
Efficiency: Geothermal heat pumps draw on steady ground temperatures. DOE ties that to 300% to 600% efficiency on cold nights.
Long life: DOE puts indoor units at 20+ years and ground loops at 25 to 50 years.
Quiet operation: DOE says these systems run quieter than air source units and need little maintenance.
Cons
High upfront cost: Loop work drives most of the extra expense. Payback can take years.
Yard disruption: Trenches and drilling rigs leave marks. Lawns and landscaping need time to recover.
Installer availability: Fewer contractors handle loop work than standard HVAC jobs. Scheduling can take longer.
Weighing the Money
The cost of geothermal heating includes the upfront project and the yearly energy bills. DOE cites a 5 to 10 year payback range against air source systems. That range comes from the same older factsheet, so each home should run its own numbers with current quotes.
Local utility rebates can also change the math. Homeowners should look up the utility's current programs by name before signing.
Pairing a new system with smart thermostats and geofencing can help trim HVAC costs.
Geothermal heat pumps installation comes down to a ground loop (horizontal, vertical, pond, or open), an indoor heat pump, and the connections between them. DOE cites 300% to 600% efficiency on the coldest winter nights.
The next steps are simple. Get a load calculation and several quotes. Check land and drilling needs. Note that the federal credit ended for 2026 installs.
Work on the system can leave a mechanical room dim and phones low on charge. For install days, an optional EcoFlow DELTA 3 Classic can keep work lights, phones, and Wi-Fi running. It's a separate purchase and sits outside the geothermal quote. It doesn't run the compressor, loop pumps, or backup heat, so the system's own electrical needs should go through a licensed professional.
How is a geothermal heat pump installed?
Crews install a ground loop in trenches, boreholes, or a pond. Then they connect the loop to an indoor heat pump and the home's ducts or distribution system. A site survey, permits, and testing come before and after the work.
How much does geothermal heat pump installation cost?
It varies by loop type, land, and home size. An older DOE factsheet cited about $2,500 per ton of capacity, plus installation and drilling costs. Current prices differ, so homeowners should collect several local quotes with load calculations.
How deep are geothermal loops?
DOE describes horizontal trenches at least 4 feet deep and pond loops at least 8 feet deep. Vertical loops are drilled, and the final depth depends on the site, the soil, and the system design set by the installer after a site survey.
Is there a tax credit for geothermal in 2026?
No. The IRS says the residential clean energy credit isn't available for property placed in service after December 31, 2025. Systems installed in 2026 don't qualify, so local utility and state programs are worth a close look.
How long do geothermal systems last?
DOE says indoor units last 20+ years and ground loops last 25 to 50 years. Real-world life depends on the quality of the installation, regular maintenance, local site conditions, and how well the system was sized and built.
