Generator for Mobile Home: What to Size, How to Connect, and Where to Put It
- Why Electricity in a Mobile Home Changes the Generator Choice
- Sizing Mobile Home Generators Around Real Loads
- Battery Backup Options That Fit a Mobile Home
- Connecting a Portable Generator for Mobile Home Use
- Where Generators for Mobile Homes Can and Can't Run
- Tornado Warnings: Backup Power Stays, You Go
- Conclusion
- FAQs
Most mobile home owners check the generator size first. They rarely look at the power cord or feeder that actually serves the home. That feeder sets the real limit. Manufactured homes follow a federal HUD standard for electricity. It quietly caps what any generator for mobile home backup needs to handle.
In this guide, you will learn how to size for your real loads. We will cover how to hook up power without illegal backfeeding. You will see where to run a gas unit safely. Finally, we will cover when you must leave the home altogether.
Manufactured homes are built to federal HUD standards. They do not follow standard local building codes. This distinct setup directly governs your home electrical supply.
According to 24 CFR 3280.803, the power supply must use a specific feeder. It allows "not more than one listed 50 ampere manufactured home power supply cord, or a permanently installed circuit."
The code permits a 40-amp cord only if the home has factory-installed gas or oil appliances for heating and cooking. If your calculated load is over 50 amps, the home must use a permanent feeder.
Under 24 CFR 3280.804, every home has a single main disconnect. This disconnect is a master breaker or switch with fuses. It sits right near where the main power cord enters. When an electrician wires up a transfer device, this main panel is where they work.
Understanding electricity in a mobile home comes down to your major appliances. The heaviest electric draws are your furnace, water heater, and range. If you heat with propane or natural gas, backup power is simple. If your home uses electric heat, first calculate how much power an electric furnace draws before choosing backup equipment.
Knowing whether the home runs on a 40-amp or 50-amp supply sets the ceiling. The next step is listing which appliances actually need power during an outage.
Do not try to power your entire breaker box during an outage. Sizing mobile home generators means picking only the loads you genuinely need. That keeps your setup manageable and saves you money.
Motors pull extra current for a few seconds right when they kick on. This spike is called starting watts or surge watts. Running watts is the steady power the appliance needs once it is moving.
For example, Honda Power Equipment notes that a typical refrigerator needs 1,600 watts to start. Yet that same fridge runs on only about 200 watts.
Common Mobile Home Loads
The following figures are general estimates for common household appliances. Actual power requirements vary by appliance model.
Appliance | Running watts | Starting watts |
Refrigerator/freezer (ENERGY STAR) | 132 to 192 | 1,200 |
Window AC (10,000 BTU) | 1,500 | 2,200 |
Furnace fan (1/3 HP, gas furnace blower) | 700 | 1,400 |
Microwave (800W) | 1,300 | 1,300 |
Sump pump (1/2 HP) | 1,050 | 2,150 |
Flat-screen TV (46") | 190 | 190 |
Laptop | 200 to 250 | 200 to 250 |
Hot water heater (electric) | 4,500 | 4,500 |
Clothes dryer (electric) | 5,400 | 6,750 |
These numbers show why a small generator may handle essentials but not the entire home.
An electric water heater, electric dryer, and electric strip heat push past what most portable units or plug-in batteries can handle. Keeping a window unit running is often the summer priority. It helps to know how many watts a window AC pulls on startup before sizing.
Once you have your load list, pick your power source. You can choose a simple indoor battery station or an installed home system.
A battery power station runs quietly and produces no exhaust. Because there are no fumes, you can use it indoors, including in the kitchen, as long as it sits away from heat and water. That is a real advantage in a tight mobile home park with tiny yards.
Plug-In Power: Simple and Portable
A portable power station lets you plug appliances right into its built-in outlets. There are no panel modifications or wire splices required. That makes it the best choice for renters and community residents.
When estimating battery runtimes, always factor in real-world efficiency. We multiply total watt-hours by 0.85 because roughly 15% of battery energy is lost as heat during the DC-to-AC conversion and consumed by internal system safeguards.
Take a 2,048Wh unit like the EcoFlow DELTA 3 Max. Here is an estimated runtime calculation:
Refrigerator estimate:
2,048Wh × 0.85 ÷ 192W ≈ 9 hours
A refrigerator compressor cycles on and off throughout the day. Because of that cycling, real-world fridge runtime is usually much longer.
For a 10,000 BTU window AC pulling 1,500 running watts:
Estimated runtime = (2,048 Wh × 0.85) ÷ 1,500 W ≈ 1.2 hours.
The air conditioner's 2,200-watt starting draw fits easily within the unit's 2,400-watt rating and 4,800-watt surge cap.
If the outage drags on, recharging is simple. The unit charges from 0 to 80% in 68 minutes using a wall outlet or generator. It features four flexible charging methods, including solar and car charging.
Installed Path for Circuit Backup
The EcoFlow DELTA Pro Ultra X is an installed home system, not a portable unit. The standard bundle is one inverter plus two Smart Extra Batteries. That gives 12kW output and 12kWh capacity. It expands to 36kW and 180kWh. Actual performance varies with your final equipment setup.
It requires a Smart Home Panel 3 or Smart Gateway and installation by a licensed electrician. In a leased lot or park, get written approval from the park or landlord first.
Consider this estimated runtime for essential circuit loads:
Refrigerator: 192W
Gas furnace fan: 700W
Flat-screen TV: 190W
Laptop: 250W
Total continuous load: 1,332W
Estimated runtime = (12,000 Wh × 0.85) ÷ 1,332 W ≈ 7.7 hours of continuous draw.
Keeping a battery unit indoors is one of the clearest advantages of backup batteries during indoor storms compared with any fuel-burning unit.
If an installed system isn't an option, in a leased lot where the park won't approve panel work, the EcoFlow DELTA 3 Max is the portable route. It needs no electrician: appliances plug straight into the unit, which delivers 2,400W from a 2,048Wh battery.
The EcoFlow DELTA 3 Max covers your fridge, lights, and a window unit without touching your breaker box. Meanwhile, the EcoFlow DELTA Pro Ultra X suits homeowners who want an electrician-installed setup for whole-home circuits.
Whether the backup is a gas unit or a battery, the connection to the home has to be done in a way that never sends power back up the line.
There are two safe ways to use backup power. Plug appliances straight into the unit. Or have an electrician connect it through a transfer device at the home's disconnect.
Essential safety rules:
Never backfeed: The CPSC (Pub. 5123) is blunt about this. Never plug a generator into a wall outlet. This causes dangerous "backfeeding" that can electrocute utility workers and neighbors on the same transformer. It also bypasses your home's circuit protection.
Keep it outdoors: Run the generators at least 20 feet away from windows, doors, and vents. Use heavy-duty, outdoor-rated extension cords longer than 20 feet when connecting appliances directly to the generator.
Transfer switch or interlock
A transfer switch or interlock isolates the home from the utility line. Always hire a licensed electrician to handle these installations and pull any required local permits. Picking the hardware starts with knowing how to choose a manual transfer switch for your supply size.
Park rules and leased land
Mobile home parks have specific community rules. Many parks restrict fuel storage on the lot. Others enforce strict noise limits or ban permanent equipment modifications. Read your lease carefully before investing in any portable generator for mobile home use.
Plug-In Backup for Renters and Park Residents
A portable power station sidesteps park restrictions entirely. It needs no panel tie-ins or wire connections. You simply bring it inside and plug your lamps or cooler directly into the front sockets. There is no exterior engine noise, so neighbors will not complain.
Connection keeps the lines safe. Placement keeps the people inside safe. A mobile home's porches, carports, and skirting make that harder than it sounds.
Carbon monoxide is an invisible, odorless, and deadly gas. Running fuel-powered generators for mobile homes requires smart placement. Manufactured home properties often have layout traps that tempt owners into poor decisions.
Follow these strict placement rules from the CPSC and CDC:
Keep it far away: Place the generator outdoors, at least 20 feet from your home.
Avoid porches and carports: Covered porches and carports trap exhaust right next to your doors.
Point exhaust out: Direct the tailpipe away from your house and neighboring units.
Look for safety shut-offs: Purchase modern models equipped with built-in CO auto-shutoff sensors.
Keep away from openings: Maintain 20 feet of clearance from windows, doors, and floor vents.
Never run it in enclosed spaces: Garages, sheds, and screen rooms trap fumes, even with windows open.
Stay out of the skirting crawlspace: Never place an engine under your mobile home. Fumes seep directly through the floorboards into your bedroom.
A May 2026 CPSC report (2022 annual estimates) puts generators at about 98 non-fire CO deaths a year from 2020 to 2022. And 64% of 2022's CO deaths happened in the four coldest months.
The EPA warns that toxic carbon monoxide can linger for hours, even after the generator engine shuts off. Always mount working, battery-backed CO alarms directly outside every sleeping area.
In wet weather, run the generator on a dry surface under an open, canopy-like cover. Winter storms bring their own risks. The hidden dangers of carbon monoxide rise when people run heaters and generators in tight spaces.
Placement rules cover outages from ice and wind, but one kind of storm calls for leaving the home instead of powering it.
No generator or battery setup can protect a manufactured home from tornadic winds. When severe weather threatens, you must prioritize your physical safety over maintaining home power.
The National Weather Service puts it plainly: "Sheds and storage facilities are not safe. Neither is a mobile home or tent. If you have time, get to a safe building."
Plan before the sirens
Know your nearest sturdy building or community shelter.
Ask the park office or local emergency management.
Grab your weather radio, phone, and emergency go-bag.
Pack a charged portable power station if you can carry it quickly.
A portable battery pack can travel with you to a storm shelter. It will keep your phones and emergency radios running through the night. Once local authorities issue an all-clear, bring it back home to power your refrigerator.
After the storm, check for downed lines. Call 911 for immediate danger. And don't run a gas generator in a damaged home's carport or under the home.
A short list of tornado power outage preparedness steps helps owners decide what to take and what to leave running.
A generator for mobile home backup must match your 40-amp or 50-amp supply and real loads. Always connect safely without backfeeding, and keep fuel units well clear of porches, carports, and skirting. Start by listing your three to five essential appliances, confirming whether your heat runs on gas or electricity, and reviewing park rules. For plug-in, fume-free backup, look at the EcoFlow DELTA 3 Max. For electrician-installed circuit backup with park approval, consider the EcoFlow DELTA Pro Ultra X.
What size generator do I need for a mobile home?
It depends entirely on your specific loads. Homes with gas heat can cover essentials with smaller units. Check your 40-amp or 50-amp supply limit, and calculate starting versus running watts to avoid overloading your system.
Can I plug a generator into my mobile home's outlet?
No. Plugging a generator into an outlet can cause dangerous backfeeding. Connect appliances directly with suitable cords or use a properly installed transfer device instead.
How far should a generator be from a mobile home?
Keep a fuel-burning generator outdoors and at least 20 feet from windows, doors, and vents. Never operate it under the home, inside a carport, or on a porch.
Can a portable power station run a mobile home's air conditioner?
Yes, for a window unit for limited durations. An EcoFlow DELTA 3 Max powers a 1,500W unit for roughly 1.2 hours. Running whole-home central AC requires a much larger, hardwired battery backup system.
Do I need permission to install backup power in a mobile home park?
Often yes. Most parks enforce strict rules regarding noise, fuel storage, and electrical modifications. Always review your lease agreement first, and hire a licensed electrician to safely complete and permit any hardwired installation work.
