Cost to Install Tubular Skylight Kits: Price Factors, Installation Steps, and Tips
The cost to install a tubular skylight depends on tube size, tube length, roof type, attic access, add-ons, permits, and local labor rates. No single price fits every home, so itemized quotes with the same scope give the clearest comparison. Tubular skylights, also called solar tubes or sun tunnels, bring daylight into hallways, bathrooms, and closets without a large roof opening. This article covers price drivers, how the Department of Energy describes these devices, installation steps, and quote tips. A solar tube carries light, not electricity.
What Is a Tubular Skylight and How Does It Work?
A tubular skylight has a small dome on the roof, a reflective tube through the attic, and a diffuser in the ceiling. Light bounces down the tube into the room. It brings daylight but does not make power.
The Three Main Parts
  • Roof dome: This collector sits on the roof and captures daylight. Its small footprint keeps the roof opening modest.
  • Reflective tube: The No-Regrets Remodeling guide, hosted by the U.S. Department of Energy (DOE), says tubular skylights have a highly reflective inner surface that bounces sunlight into the living space. Long runs and elbows can reduce the light that reaches the room.
  • Ceiling diffuser: A diffusing lens spreads the light across the space. It mounts on the ceiling or sits recessed into it.
What DOE Says About Tubular Skylights
DOE notes that tubular skylights are smaller than most other skylights. Their roof collectors gather light without needing a large size. That small surface area helps limit heat loss in winter and heat gain in summer. It also keeps their impact on a home's architecture low.
Cutaway of tubular skylight light pathCutaway of tubular skylight light path
There is one trade-off. DOE points out that tubular designs do not provide views or ventilation. They are a daylighting tool, nothing more.
A solar tube is not a solar panel. It carries light, not electricity. Still, daylight can reduce how often a household needs to think about light bulb wattage and power use during the day. Interest in solar tube cost often starts there, since the parts look simple and the roof opening is small.
Installation can take a few hours, and some jobs call for power off in the work area. A small, separate budget line covers temporary light.
Install Day: Temporary Light and Phones (Separate Budget)
Installers may cut power to a ceiling light circuit while they work. A dark attic or hallway slows the job. A small power station can run a work light and keep phones charged. It is a separate cost from the skylight.
The tube skylight cost starts with three pieces: the tube equipment, the roof opening, and labor. Those lines come first. A power budget is optional. It only applies where the work needs temporary lighting and phone use with power off.
Professionals do the roof and ceiling work. The power station stays on the floor in a dry, safe spot below the work area. A solar tube brings in natural light. It is not a solar panel, and a power station is not part of the skylight.
If the installer shuts off a ceiling light circuit while cutting in the diffuser, the hallway or bathroom goes dark. An EcoFlow portable power station runs a work light and keeps phones charged for the few hours of work. It is an optional, separate cost, and it has nothing to do with how the solar tube works.
A work light and a couple of phones are a light load. The EcoFlow DELTA 3 Classic is a 1kWh unit that can cover a full install day. It sits safely on the floor below the work area.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Estimated Runtime for Install Day
The figures below are estimates. They use a simple method: usable capacity (Wh × 0.85) divided by the load (W). Real runtime shifts with temperature, settings, and the devices in use.
Load (example)
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
LED work light + phones (40W + 20W)
about 60W
about 14 hours
Roof work is also a good time to check items for winterizing your home for safety. A short walk through the attic and ceiling can turn up gaps and worn parts.
Back to the skylight itself: what drives the price?
What Affects the Cost to Install a Tubular Skylight?
The tube kit, roof type, and attic run matter most. Labor varies by region and access. Several itemized quotes show where the money goes. The cost to install a solar tube also shifts with the number of bends and the amount of ceiling finish work.
For a Colorado example, Skylight Specialists quotes installations starting at $950 for a 10-inch rigid VELUX Sun Tunnel with 43 inches of tubing under standard conditions. The price excludes interior repairs, painting or staining, and permit fees. Compare local bids for the same scope.
Cost driver
Why it matters
Tube diameter
Larger tubes bring more light and cost more
Tube length and bends
Long runs and elbows add parts and labor
Roof type and pitch
Tile, metal, or steep roofs take more work and flashing
Attic access
Tight or no attic adds time
Add-ons
Light kits, dimmers, or ventilation fans
Permits
Required in some areas
Kit and Tube Choices
  • Tube diameter: Ask the installer to size the tube for the room, its existing daylight and the proposed tube length. Compare the manufacturer’s coverage estimates for each diameter.
  • Length and bends: Every elbow and extra tube section adds parts. It also adds time in the attic.
  • Labels: DOE advises looking for NFRC and ENERGY STAR labels on skylights. ENERGY STAR notes that certified products may cost more, though the labor involved should be comparable.
Roof and Attic Conditions
  • Roof type and pitch: Tile, metal, or steep roofs need more careful work and flashing. A sun tunnel cost can climb when the roof is hard to reach or seal.
  • Moisture control: DOE says water leaks are a common problem with poorly installed skylights. A curb, flashing, and sealed joints help limit that risk.
  • Attic access: A tight attic, or none at all, adds time. Building America guidance explains that the shaft must be insulated and air sealed in the attic, which adds a step.
Add-Ons and Permits
  • Add-ons: Light kits, dimmers, and ventilation fans raise the total. A fan is a separate add-on, since the tube itself does not ventilate.
  • Permits: Some areas require one. The local building office can confirm the rule.
Have the installer follow the manufacturer’s roof flashing, air-sealing and insulation instructions. The Building America Solution Center illustrates how to seal the tube at the ceiling and insulate it through an unconditioned attic.
Typical Installation Steps
Steps vary by brand and roof, so the manufacturer's instructions come first. A typical job follows this order:
  1. Mark the spot: The installer picks a ceiling location and checks the attic path.
  2. Cut the openings: A roof hole and a ceiling hole are cut in line with the planned tube run.
  3. Set the base and flashing: The curb and flashing go on, with sealed joints to shed water.
  4. Mount the dome: The collector attaches to the base on the roof.
  5. Connect the tube: Sections link from the roof down to the ceiling.
  6. Insulate, seal, and finish: The shaft is insulated and air sealed, and the diffuser goes in the ceiling.
Home efficiency upgrades often go together. Daylighting is one of several ways to reduce the electric bill, though a tubular skylight adds no power of its own.
Once the drivers are clear, comparing quotes is the last step.
How to Compare Tubular Skylight Quotes
Each quote should cover the same scope. Ask about flashing and warranty. Check roof warranty rules too.
Homeowner reviewing itemized skylight quotesHomeowner reviewing itemized skylight quotes
What Every Quote Should List
  • Tube size and brand: The quote should name the diameter and the maker. A Solatube installation cost can differ from another maker's kit, so the brand and model belong on the page.
  • Flashing type: Flashing should match the roof type. Ask what comes with the kit and what is sold apart.
  • Attic insulation and air sealing: Building America guidance calls for an insulated, air-sealed shaft. Confirm that this work sits inside the price.
  • Ceiling finish: Patching, paint, and trim around the diffuser can be left out of a low bid.
  • Permit: The quote should say who pulls the permit and who pays for it.
  • Roof warranty impact: Cutting into a roof can affect its warranty. Ask for the answer in writing.
  • Cleanup: Confirm that the crew hauls away debris.
Why Quotes Look So Different
Two bids can sit far apart for small reasons. One may include attic work while the other leaves it out. A sun tunnel installation cost that looks low may skip insulation or finish work. Each sun tunnel cost installation breakdown should name materials, labor, and finish work.
Size can help here too. DOE says the small size of tubular skylights minimizes their impact on a home's architecture. That gives more freedom in picking a spot, but it does not remove the need for a clear quote. Some households also pair daylighting with energy-saving appliances for the home.
The cost to install a tubular skylight depends on tube size, length, roof type, attic access, add-ons, permits, and labor. Ask the installer to include flashing, air sealing and tube insulation in the quote.
The takeaway is simple. Get itemized quotes with the same scope, and check roof warranty rules before signing.
For install day, an optional EcoFlow DELTA 3 Classic can keep a work light and phones on while power is off in the work area. It is a separate purchase from the skylight, and it plays no role in how the tube moves daylight. A household that already owns a power station can skip it. Professionals handle the roof and ceiling work.
What affects the cost to install a tubular skylight?
Tube diameter, tube length and bends, roof type and pitch, attic access, add-ons, permits, and local labor all shape the price. Itemized quotes with the same scope make those differences easier to compare side by side across bids.
Is a solar tube cheaper than a regular skylight?
Often, because the roof opening is smaller and the install is simpler. Still, tube size, roof type, and attic run can change the total. Itemized quotes for both options show which one costs less for a given home, including flashing and finish work.
Can I install a solar tube myself?
Consider a qualified installer for work that penetrates the roof. Proper flashing, a curb, and an insulated, air-sealed shaft help limit leaks and energy loss. A pro also knows local permit rules and how roof work can affect a roof warranty.
Do solar tubes produce electricity?
No. A solar tube carries daylight through a reflective tube to a ceiling diffuser in the room. It is not a solar panel, so it makes no power. Solar panels convert sunlight into electricity, while tubes only move light into a room.
Do tubular skylights let heat in?
DOE notes that the small roof collector limits heat loss in winter and heat gain in summer. Results still vary by climate, roof direction, and product ratings, so check the NFRC and ENERGY STAR labels on the kit before buying.
Home Solutions
