Connecticut Nor'easter Guide: Shoreline Surge, Inland Snow, and Power Outages
A Connecticut nor'easter can look very different depending on where you live. The same storm can push Long Island Sound into shoreline streets around Fairfield and Milford while dropping heavy, wet snow across the Litchfield Hills. One brings flooding. The other can take down trees and power lines. This guide covers where to check the forecast for your town, how to report an outage to the right utility, and how to keep heat controls, the fridge, and phones running while crews work.
What a Connecticut Nor'easter Looks Like: Shoreline Surge, Inland Snow
A nor'easter is a coastal storm named for its wind direction, not for snow. In Connecticut, it can bring coastal flooding along the Sound while inland towns deal with heavy snow, rain, and strong winds. Where you live has a lot to do with which problem hits hardest.
What a Connecticut Nor'easter Looks LikeWhat a Connecticut Nor'easter Looks Like
What is a nor'easter?
The National Weather Service defines a nor'easter as a storm along the East Coast where winds over the coastal area typically come from the northeast. These storms can bring heavy rain or snow, gale-force winds, rough seas, and coastal flooding. That mix is what makes a Connecticut nor'easter tricky. A shoreline neighborhood may be watching tide levels while a town farther inland is watching the snow load on trees.
When is nor'easter season in Connecticut?
Nor'easters can happen at any time of year, but the National Weather Service says they're most frequent and most violent between September and April. Connecticut has seen major examples on both sides of that window, including the October 2011 snowstorm and the March 2018 nor'easter. There isn't one month you can circle as the Connecticut peak. The storm track, temperature, wind, and tide setup matter more than the calendar.
Why the shoreline floods
Long Island Sound can amplify coastal flooding when several conditions line up. Connecticut DEEP's coastal hazards report points to winds above 30 mph lasting more than 12 hours, winds from northeast through east-southeast, and high astronomical tides as key factors. The shape of the Sound matters, too. The report lists mean tide ranges of 2.6 feet at Stonington and 7.2 feet at Greenwich, which helps explain why water levels can vary significantly along the Connecticut coast. Forecasters also watch closely for storm surge and snow arriving together because flooded roads and whiteout conditions can slow utility crews at the same time.
Why inland towns lose power
Heavy, wet snow can put a lot of weight on trees and branches. When leaves are still on the trees, they can catch even more snow. A limb comes down, hits a line, and suddenly a clear stretch of road has no power. The National Weather Service's review of the October 2011 storm found that trees and wires came down under heavy snow, with the most widespread and prolonged outages occurring where leaves were still on the trees. The difference between wet and dry snow also matters when judging outage risk because wet snow can put much more weight on trees and wires.
Where you live
Main nor'easter hazard
What usually cuts power
Shoreline towns on Long Island Sound (Greenwich to Stonington)
Coastal flooding at high tide, strong onshore wind
Wind on lines and poles, flooded equipment
Inland valleys and the I-84 and I-91 corridors
Heavy snow or rain, gusty wind
Limbs on lines, especially with leaves on trees
Litchfield Hills and the northeast hills
Highest snow totals
Wet snow loading trees and wires
That difference matters when you're preparing. Forecasters may be watching storm surge and snow at the same time, but the risks at your house won't necessarily be the same.
Where to Check a Nor'easter Forecast for Your Connecticut Town
A blog post can't tell you what tonight's storm will do. Official weather and emergency sources can, and they update as conditions change. This page isn't a live forecast, so check these sources for the latest information before the wind picks up.
Your question
Where to check
What you'll find
What alerts are in effect?
weather.gov (enter your town or ZIP code)
Active watches, warnings, and advisories for your exact location
When will it start, and how much snow?
NWS New York/Upton (weather.gov/okx) for the four shoreline counties
NWS Boston/Norton (weather.gov/box/winter) for northern Connecticut
NWS Albany (weather.gov/aly) for Litchfield County
Snowfall forecasts, probabilistic snow maps, Winter Storm Severity Index, forecast discussions
Will the shoreline flood?
NWS New York/Upton coastal flood page (weather.gov/erh/coastalflood?wfo=okx)
Forecast tide levels for Long Island Sound gauges
Will there be outages, and is mine reported?
Eversource outage map (outagemap.eversource.com) or UI outage map (uinet.com/outages)
Current outages and restoration status
What is the state telling residents to do?
CT DEMHS (portal.ct.gov/demhs) and CT Alert (portal.ct.gov/ctalert)
State guidance, travel restrictions, emergency notifications
You don't need to figure out which National Weather Service office covers your town. Enter your address or ZIP code at weather.gov, and the site routes you to the appropriate forecast office. NWS New York/Upton covers the four shoreline counties, NWS Albany covers Litchfield County, and NWS Boston/Norton publishes snowfall forecasts for northern Connecticut.
What the alert words mean
A Winter Storm Watch means conditions are favorable for a significant winter storm. A Winter Storm Warning means a significant event is expected, with travel potentially difficult or impossible. A Blizzard Warning means frequent wind gusts of at least 35 mph combined with falling or blowing snow that reduces visibility below one-quarter mile for three hours or more. That last one is easy to misunderstand. A blizzard isn't defined by how many inches of snow fall. Wind and visibility are what matter.
CT Alert
CT Alert is Connecticut's emergency notification system for life-threatening conditions. You can choose to receive alerts by phone call, text, or email through the state's signup page. The Department of Emergency Services and Public Protection also points residents to the CT Prepares app and Connecticut 2-1-1 for additional emergency information and assistance. Understanding a winter storm watch versus a warning can help you judge how much time you have to prepare. Once a warning is posted for your county, the next thing to consider is how long you may need to manage without power.
Keeping the heat and fridge on when wet snow takes down the lines
Connecticut's worst nor'easter outage shows how long power can stay out after a major storm. The October 2011 snowstorm caused a record-setting 880,000 customer outages, and the state's Two Storm Panel reported that restoration wasn't completed until 12 days after the first outages. That's an extreme example, not the norm, but it shows why a backup plan should cover more than a few hours.
Start with the loads that matter most
You don't need to keep the whole house running during an outage. Start with the equipment that keeps the house warm, protects food, handles water, and supports basic communication or medical needs.
  • Heating: Keep your furnace or boiler controls powered, along with the blower or circulator. Even oil- and gas-fired heating systems still need electricity for these components to operate.
  • Refrigeration: Keep the refrigerator running so food stays cold during a longer outage. Try to avoid opening the door more than necessary.
  • Sump pump: If your home has a basement or sits near the shoreline, a sump pump may be one of the most important loads to keep running, especially during a wet storm.
  • Communication: Keep your Wi-Fi router and phones powered so you can check weather updates, outage information, and emergency messages.
  • Medical equipment: Include essential equipment such as a CPAP or other powered medical device that someone in the household relies on.
Check the wattage listed on each device's nameplate or in its manual, then make a list of the loads you expect to run at the same time. That gives you a practical starting point for sizing backup power and helps you decide which devices can wait if the outage lasts longer than expected.
EcoFlow DELTA Pro Ultra X
•Whole-Home Backup (with the right setup): 12kW output and 12kWh capacity in the standard bundle (1 inverter + 2 Smart Extra Batteries), expandable up to 36kW and 180kWh with added inverters and batteries. Whole-home backup requires Smart Home Panel 3 installed by a licensed electrician, and coverage depends on your home's loads. • Fast Switchover: Automatic switchover in about 20ms with Smart Home Panel 3, so selected circuits stay on when the grid drops. • Installation: Plug-and-play design that EcoFlow says can be installed in 7 days. Permitting, your electrical panel, and installer schedules can change that timeline. • Comprehensive Safety: End-to-end system protection built to high safety standards.
If you don't need a permanently installed system, a portable option can cover the essentials instead. The EcoFlow DELTA 3 Max is easier to move around the home and can keep devices such as a refrigerator, router, or phone chargers running during an outage.
EcoFlow DELTA 3 Max (2048Wh)
• 2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. • Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA Pro Ultra X is the installed option for homeowners who want selected circuits, such as heating controls, a refrigerator, sump pump, or lights, to switch over automatically through Smart Home Panel 3. The EcoFlow DELTA 3 Max is the portable choice for renters, condo owners, and shoreline households that may need to move backup power upstairs, between rooms, or even take it to a relative's home.
Estimated runtime (labeled example)
Runtime depends on how much power your connected devices draw. For a simple planning estimate, multiply the battery capacity by 0.85, then divide that number by the combined load in watts. The 0.85 is a planning assumption for conversion losses, not an EcoFlow figure. The loads below are examples, so add up the nameplate wattage of the devices you actually plan to run.
Unit
Usable energy (capacity × 0.85)
At a 200W combined load
At a 500W combined load
At a 1,000W combined load
EcoFlow DELTA 3 Max (2,048Wh)
About 1,741Wh
About 8.7 hours
About 3.5 hours
About 1.7 hours
EcoFlow DELTA Pro Ultra X standard bundle (12kWh)
About 10,200Wh
About 51 hours
About 20 hours
About 10 hours
These are estimates, not guaranteed runtimes. Motors can draw more power when they start, while a cold garage, heavier loads, and other operating conditions can reduce runtime. If an outage lasts several days, you'll need to recharge the battery from available power, a generator, or solar, or cut back to essential loads. Both systems produce no exhaust, so the batteries can run indoors as designed. If you use a fuel-burning generator to recharge one, keep the generator outside and well away from windows and doors.
Planning for battery backup during nor'easter season starts with a short list of the circuits and devices you can't go without for a day or two. A battery covers the hours between the lights going out and the crews arriving, and which crews those are depends on the company behind your electric bill.
Eversource, UI, or a Municipal Utility: Who Restores Your Power
Connecticut doesn't have one electric company serving every town. Two investor-owned companies cover most of the state, while several municipalities operate their own electric departments. PURA identifies The Connecticut Light and Power Company dba Eversource Energy and The United Illuminating Company (UI) as the state's two investor-owned electric distribution companies, so check your electric bill now to know which utility to contact during an outage.
Company (exact name)
How to see outages
How to report
Notes
Eversource outage map: outagemap.eversource.com (covers Connecticut, Eastern and Western Massachusetts, and New Hampshire, so select Connecticut)
Online or in the Eversource app through eversource.com/residential/outages ("Report a Power Outage")
Eversource encourages customers to track and report outages online or through the mobile app. Direct customer service phone lines are accessible via their official portal.
UI outage map: uinet.com/outages/reportviewoutage/viewoutagemap
Online at portal.uinet.com/report-outage/guest, or by phone. UI's outage page says: "If your electricity is out, report it using the link below, or by calling 855.784.3637."
UI's page also warns: "Always stay away from downed power lines. Even lines that appear dead can be energized."
Municipal electric utilities (PURA names Wallingford Electric and Norwich Public Utilities as examples)
The utility's own website
The number on your bill
PURA states it does not regulate municipal electric companies' services and rates; they answer to their own local boards
How to report an outage
Don't assume a neighbor has already reported your outage. Contact the utility that serves your address so it can identify the affected section and assess the extent of the problem. If a power line is down or you see sparking or fire, stay away, call 911 first, then report it to your utility. Never approach a downed line, even if it appears to be dead.
Why restoration can take days
After a wet-snow nor'easter, crews may need to clear trees and branches from roads and power lines before repairs can begin safely. Utilities then prioritize immediate hazards and repairs that can restore power to the most customers, so restoration times can vary between neighborhoods. PURA also reviews major storm responses, including its investigation of the 2020 Tropical Storm Isaias response (Docket No. 20-08-03). Reading the Eversource outage map ahead of time can help you understand outage updates and estimated restoration times.
Connecticut Nor'easters on the Record
No two Connecticut nor'easters cause the same kind of trouble. One can push water onto the shoreline, another can bring heavy snow and down trees, while a third can set a snowfall record. These five storms, documented by the National Weather Service or state reports, show how different the risks can be.
Storm
What happened in Connecticut
Source
December 1992 nor'easter
Water reached 12.0 feet MLLW at Bridgeport. NWS records that the storm killed 3 people and destroyed 26 homes in Connecticut.
NWS New York/Upton, Bridgeport coastal flood impacts
October 29 to 30, 2011 snowstorm
Heavy, wet snow on leafed trees. Litchfield County totals: Bakersville 18.6 inches, Winsted 18.0, Litchfield 16.5, New Milford 14.0. The state's Two Storm Panel reported a record 880,000 customer outages and a 12-day restoration.
NWS Albany; State of Connecticut Two Storm Panel report (January 2012)
February 8 to 9, 2013 blizzard
Hamden 40.0 inches, Milford 38.0, East Haddam 35.5. Ansonia's 36 inches in 24 hours was accepted as the state's 24-hour snowfall record, replacing 30 inches at Falls Village in 1969.
NWS New York/Upton; NOAA NCEI State Climate Extremes Committee
March 2 to 5, 2018 nor'easter
A wind and water storm more than a snow one: gusts of 71 mph at the Coast Guard Academy in New London and 62 mph at Bridgeport Airport, coastal flooding closing roads in Stamford, and trees down on wires in Fairfield and New Haven counties.
NWS New York/Upton
February 22 to 23, 2026 blizzard
NWS confirmed blizzard criteria were met on February 23 across 16 counties and sub-regions in New York, New Jersey, and Connecticut. North Stonington measured 30.8 inches, Meriden 22.5, and Groton Airport gusted to 68 mph.
NWS New York/Upton
For shoreline perspective, Hurricane Sandy reached 13.3 feet MLLW at Bridgeport, the record for western Long Island Sound. The December 1992 nor'easter reached 12.0 feet. Sandy was a tropical system, not a nor'easter, but the comparison shows how close a major nor'easter can come to hurricane-level water at the Connecticut coast.
Connecticut Nor'easters on the RecordConnecticut Nor'easters on the Record
What these storms show
  • The biggest outage wasn't the biggest snowstorm. The 2011 storm caused Connecticut's record 880,000 customer outages even though its snow totals were lower than the 2013 blizzard. Trees still carrying leaves made the wet snow especially damaging.
  • The highest snowfall wasn't in the hills. The 2013 blizzard produced its largest Connecticut totals in New Haven County, including the state 24-hour record in Ansonia.
  • Nor'easter flooding can approach hurricane levels. The 1992 storm pushed Bridgeport water levels to 12.0 feet MLLW, compared with 13.3 feet during Hurricane Sandy.
Connecticut's shoreline shares its risk with the rest of the region, and nor'easter flooding along the East Coast follows the same pattern of onshore wind stacked on high tide.
Those storms did different damage along the shoreline and inland, so the two days before a nor'easter should look different depending on your address.
Shoreline Homes vs. Inland Homes: A Two-Day Prep Plan
Generic storm checklists miss what makes Connecticut tricky. A Milford beach cottage and a Torrington colonial may face very different problems during the same nor'easter. Your preparation should reflect where your home sits and what the storm is expected to bring.
Shoreline homes (Long Island Sound)
Inland and hill-town homes
Check the NWS coastal flood forecast for the high tides during the storm, not only the snow map
Check the NWS snowfall forecast and whether the snow is expected to be wet and heavy
Move cars to higher ground before the first high tide
Park away from large trees and overhead lines
Test the sump pump and plan a backup power source for it
Make sure heating controls, well pump (if you have one), and fridge are on your backup plan
Move portable batteries, chargers, and valuables above the lowest floor
Stage flashlights, blankets, and a charged battery where you'll actually be sleeping
Know your evacuation route and follow local orders
Stock food, water, and medications for several days in case roads are blocked by trees
What every Connecticut home should do
When a Winter Storm Watch is issued, charge phones and batteries, sign up for CT Alert, save your utility's outage reporting page, and check on older neighbors or anyone who may need extra help. Never run a generator, grill, or camp stove inside a home or attached garage because of the risk of carbon monoxide poisoning.
If a basement is flooded, don't touch an electrical panel, outlet, or plugged-in device while standing in water. Keep a portable battery or power station on a dry surface above the water line. After the storm, stay away from downed power lines and anything touching them, report the hazard to the utility, and wait for crews to clear trees or other debris from the lines. A few habits can also make getting through a winter storm outage easier, including closing off unused rooms and keeping the refrigerator door shut.
A Connecticut nor'easter can bring two very different problems: coastal flooding along Long Island Sound and tree-breaking snow or wind inland. Check the NWS forecast for your town, know which utility handles your power, and prepare for the few loads you can't go without. If backup power is part of that plan, the EcoFlow DELTA Pro Ultra X is the installed option for selected circuits, while the portable EcoFlow DELTA 3 Max is better suited to individual essentials and smaller setups.
The National Weather Service says nor'easters can happen at any time of year, but they're most frequent and most violent between September and April.
Is a nor'easter the same as a blizzard?
No. A nor'easter is a type of coastal storm. A blizzard is defined by wind and visibility conditions, including frequent gusts of at least 35 mph and visibility below one-quarter mile for three hours or more. Some nor'easters meet those conditions.
Who do I call when my power goes out in Connecticut?
Start with the company listed on your electric bill. Eversource and UI each have their own outage maps and reporting tools, while municipal utility customers should contact their local electric department. For downed lines, fire, or immediate danger, call 911 first.
What was the worst nor'easter outage in Connecticut?
The October 29–30, 2011 snowstorm caused the state's largest recorded customer outage event. The Connecticut Two Storm Panel reported 880,000 customer outages, with restoration taking 12 days.
How long can a portable power station run my essentials during an outage?
It depends on the load. As an example, a 2,048Wh EcoFlow DELTA 3 Max could provide about 8.7 hours at a steady 200W load using a 0.85 planning factor. Check the wattage of your actual devices and add them together before estimating runtime.
Power Outages
