Off Grid Battery Bank: How to Wire, Size, and Choose One
During a cloudy stretch at an off-grid cabin, the solar panels may barely put anything back into the system. The lights still come on, the refrigerator still runs, and the batteries keep everything going after sunset. That stored energy comes from the battery bank, but a bank isn't one oversized battery sitting on a shelf. It's a group of batteries wired together to reach a target voltage and capacity. Get either number wrong, and the system may fall short when you need it most.
What an Off Grid Battery Bank Is and What Goes Into One
An off-grid battery bank is two or more batteries wired together to work as one larger battery. After sunset or during a stretch of cloudy weather, that stored energy keeps the property running. So unlike a small backup battery, an off-grid bank has to be sized for the amount of energy you may need over several days. DOE lists the batteries, charge controller, inverter, safety equipment, and meters as part of a stand-alone system's balance of system. That supporting equipment can account for a significant share of the total system cost, so the batteries are only one piece of the setup.
What goes around the battery bank?
A battery bank works with several supporting components that control charging, convert stored power for household use, protect the system, and keep track of available energy.
Charge controller: Controls the electricity flowing into the batteries and helps prevent overcharging.
Inverter: Converts the bank's DC power into the AC power used by household appliances.
Fuses, disconnects, and cabling: Carry current between the batteries and other equipment while providing protection when the system needs to be shut down.
Monitoring: A meter or app lets you check the battery's state of charge and see how much energy is available.
Car batteries aren't a good substitute for this kind of storage. DOE describes automotive batteries as shallow-cycle batteries that can be damaged by repeated deep discharge, while deep-cycle batteries are designed to discharge much further and cycle repeatedly.
Common battery building blocks
Off-grid battery banks can start with very different battery types and sizes. These examples show how individual batteries can be combined to build banks for different voltage and storage needs.
Battery (maker) | Type | Nominal voltage | Capacity | Maker's warranty | Typical role in a bank |
Trojan T-105 | Flooded lead-acid | 6V | 225Ah at the 20-hour rate | Not stated on product page | Wired in series strings to reach 12V, 24V, or 48V |
Battle Born BB10012 | Lithium iron phosphate (LiFePO4) | 12V | 1,280Wh | 10 years | Paralleled for more capacity, or wired in series for 24V, 36V, or 48V (maker) |
SOK SK48V100N server rack | LiFePO4 | 51.2V (48V system) | 100Ah (5.12kWh) | 7 years limited | Stacked in parallel in a rack on a 48V system |
EG4 LL-S 48V 100AH | LiFePO4 | 48V class | 100Ah | 10 years (prorated, registration conditions apply) | Paralleled on a 48V inverter; maker lists up to 64 units |
These are examples of common 6V, 12V, and 48V-class building blocks, not a ranking. Battery chemistry is the first major choice, and the main battery types for off-grid living differ in maintenance, weight, and usable capacity. A 6V flooded battery and a 51.2V rack module can both become part of a 48V bank. The difference is how many batteries you need and how they're connected in series or parallel.
Series, Parallel, and Choosing 12V, 24V, or 48V
The way batteries are wired determines the bank's voltage and capacity. Series wiring adds voltage, while parallel wiring adds amp-hours. Larger off-grid banks often use both to reach the voltage and storage capacity the system needs.
Series adds voltage
Connect the positive terminal of one battery to the negative terminal of the next, and the voltage adds while the amp-hours stay the same. For example, eight Trojan T-105 batteries wired in series create a 48V, 225Ah string with about 10.8kWh of nominal capacity (48 × 225).
Parallel adds capacity
Parallel wiring connects positive to positive and negative to negative, so the voltage stays the same while the amp-hours increase. Two SOK SK48V100N modules wired in parallel provide 51.2V and 200Ah, or about 10.24kWh of nominal capacity (51.2 × 200).
Series-parallel
A larger bank can use both wiring methods. Four Battle Born 12V 100Ah batteries in series create a 48V, 100Ah string with about 5.12kWh of nominal capacity. Add a second identical string in parallel, and the bank's capacity doubles. Use batteries of the same model and age, and follow the manufacturer's limits for series and parallel connections. Sandia notes that batteries and cells can age differently, which can make voltage management harder in series-connected systems.
Picking the system voltage
Higher voltage means lower current for the same power demand. A 3,000W load draws 250A at 12V, 125A at 24V, and 62.5A at 48V. The same difference shows up in battery capacity: storing 10kWh takes about 833Ah at 12V, 417Ah at 24V, or 208Ah at 48V.
System voltage | Current for a 3,000W load | Amp-hours needed for 10kWh |
12V | 250A | About 833Ah |
24V | 125A | About 417Ah |
48V | 62.5A | About 208Ah |
Lower current means less demand on the wiring, which is one reason 12V is common in smaller cabins and RVs, while larger off-grid systems often use 48V. The inverter and charge controller must match the bank voltage. Reading a battery voltage chart shows how actual voltage changes as the battery charges and drains. Once you start matching battery strings, protecting parallel branches, and pairing the right inverter, the design can become more involved. An integrated system takes a different approach by bringing those major components together.
Where Integrated Battery Systems Fit
An integrated battery system is a finished battery bank designed to work as one system. The batteries, battery management system, inverter, and solar charge controller are designed and tested together, so you can add modules for more capacity instead of rewiring individual battery strings. The tradeoff is less freedom to mix and match components. EcoFlow's two systems show how this approach works:
EcoFlow DELTA Pro Ultra: Each battery provides 6kWh of storage, with EcoFlow listing 6,144Wh at 102.4V. One inverter delivers 7.2kW of output. The system can expand to 90kWh with up to 15 batteries and reach 21.6kW with three inverters through Smart Home Panel 2.
Solar input: Each EcoFlow DELTA Pro Ultra inverter supports up to 5,600W of solar input across two ports: up to 4,000W through the high-PV port and 1,600W through the low-PV port.
EcoFlow DELTA Pro Ultra X: The standard setup provides 12kWh of storage and 12kW of output with one inverter and two Smart Extra Batteries. It can expand to 180kWh of storage and 36kW of output.
For perspective, 12kWh of storage is roughly equivalent to 250Ah at 48V, while a 6kWh EcoFlow DELTA Pro Ultra battery is about 125Ah at 48V. These are energy comparisons, not runtime estimates. For a home with a main electrical panel, either system connects through its compatible Smart Home Panel and requires installation by a licensed electrician. If you're powering a remote property with no utility service, confirm the system design with EcoFlow or a qualified installer before buying. Loads such as a well pump, electric range, water heater, or central AC can affect the battery and inverter capacity you need.
The EcoFlow DELTA Pro Ultra also supports five charging methods, including solar, a wall outlet, and a generator. That gives you another way to recharge the bank during a long stretch of cloudy weather. If you're comparing a packaged system with a parts-built bank, designing a DIY off-grid solar system can help you map out the loads and components before choosing an approach.
If you need more output and storage for a larger property, the EcoFlow DELTA Pro Ultra X offers a higher-capacity starting point with more room to expand.
How they divide the job: EcoFlow DELTA Pro Ultra starts with one 6kWh battery and one inverter, then scales as you add modules, making it a practical fit for cabins and partial off-grid setups. EcoFlow DELTA Pro Ultra X starts at 12kWh and 12kW and can scale to 180kWh for larger homes with higher energy demands. Whether you're building an off-grid bank with eight flooded batteries or using EcoFlow's stackable 6kWh modules, the next question is the same: how much energy does the bank need to store?
How to Size an Off Grid Solar Battery Bank in kWh
Size your battery bank around your own energy use, not someone else's setup. Start with what you use each day, decide how many cloudy days you want the bank to cover, and then account for the portion of the battery that is actually usable.
1. Start with your daily energy use
List the appliances and equipment you expect to run, including their power use and roughly how many hours you use them each day. Add up their daily energy needs to get a realistic starting point for the battery size. Account for seasonal changes too, especially if heating, air conditioning, well pumps, refrigerators, or other high-use equipment will run more during certain times of the year.
2. Decide how many days you need
Think about how long you want the battery to carry the system when solar production is low. The DOE recommends planning for anticipated cloudy periods. Two to three days is a common choice, but your location, weather, and energy needs may call for more or less.
3. Account for usable capacity
A battery's rated capacity isn't always the amount you should plan to use. The DOE says deep-cycle batteries can repeatedly discharge up to 80% of their capacity. For LiFePO4 batteries, use the usable capacity provided by the manufacturer. For example, if your home uses 5kWh a day and you want two days of storage, you'd need 10kWh of usable energy. At 80% usable capacity, that means roughly 12.5kWh of nominal battery capacity.
4. Match the bank to its voltage
A 12.5kWh bank would be about 260Ah at 48V or 1,042Ah at 12V, which helps explain why larger systems often use higher voltages. The solar array also needs to replace the energy used and charging losses. Calculating your home's kWh usage helps with the load list, while off-grid solar power system design covers the solar side. A larger bank can also keep daily discharge shallower, which may help extend battery life.
Placement, Upkeep, and End of Life for the Bank
Where you place the battery bank affects both its safety and lifespan. The right setup also depends on the battery chemistry, while local electrical and building codes apply to any system.
Location and ventilation
Choose a well-ventilated space away from living areas and sensitive electronics. Batteries can release gases while charging, and the space should protect them from extreme temperatures while keeping the bank accessible for inspection and maintenance.
Lead-acid upkeep and lifespan
Deep-cycle lead-acid batteries used in small systems typically last 5 to 10 years. Vented batteries require regular maintenance, including adding water, while valve-regulated types need less upkeep. Heat can also shorten battery life significantly, so keeping the bank within its recommended temperature range matters.
LiFePO4 batteries don't need watering, but they still need to stay within the manufacturer's temperature limits, especially while charging. Follow the manufacturer's guidance for the battery management system, firmware, and settings, and use the warranty terms as the best reference for expected service life.
Permits and inspection
Electrical requirements vary by state and community, and an off-grid battery system may need an electrical inspection. Check with your local building department before buying equipment so you know which permits and requirements apply.
Federal tax credit
The Residential Clean Energy Credit is not available for property placed in service after December 31, 2025. That means a battery bank installed in 2026 does not qualify for this federal credit. State and utility incentives are separate and can vary by location.
Recycling
Don't put used batteries in the trash. Lead-acid batteries can be returned to a retailer or taken to a household hazardous waste program. For medium and large lithium-ion batteries, contact the manufacturer or an appropriate recycling program rather than putting them in household trash or municipal recycling. For smaller rechargeable batteries, tape the terminals before recycling. Planning the exit before installation also helps. Safe and legal lithium battery disposal explains how to handle lithium batteries when they reach the end of their useful life.
An off-grid battery bank is a system, not a single number on a battery label. Series wiring determines voltage, parallel wiring increases capacity, and the right kWh target starts with the property's daily loads and the number of days you want to cover. From there, match the inverter, charge controller, wiring, and solar array to the bank. If building and balancing multiple battery strings feels like more work than you want to take on, compare a pre-engineered system such as EcoFlow DELTA Pro Ultra or EcoFlow DELTA Pro Ultra X with a licensed electrician.
How big of a battery bank do I need to live off grid?
Start with your daily energy use and multiply it by the number of days of autonomy you want. Then divide by the usable fraction of the battery. For example, 5kWh of daily use for two days at 80% usable capacity calls for about 12.5kWh of nominal storage.
Is a 12V, 24V, or 48V battery bank better for off-grid solar?
It depends on the size of the system. Higher voltage means lower current for the same power, which can make larger systems easier to wire. Small cabins and RVs often use 12V, while larger whole-house systems commonly use 48V.
Is it better to wire batteries in series or parallel?
Neither is automatically better. Series connections raise the bank's voltage while keeping the amp-hours the same, and parallel connections keep the voltage the same while increasing amp-hours. Larger off-grid systems often use both, depending on the power demand and storage capacity needed.
How long does an off-grid battery bank last?
DOE says deep-cycle lead-acid batteries used in small systems typically last five to 10 years. Temperature and depth of discharge affect lifespan, while lithium iron phosphate batteries should be evaluated using the manufacturer's expected life and warranty.
Can I mix old and new batteries in the same bank?
It's best to avoid it. Batteries age at different rates, and mismatched batteries can make a series bank harder to balance and manage. Build strings with batteries of the same model, age, and chemistry, and follow the manufacturer's connection limits.
