Carbon Monoxide From a Generator: Risks and Safety Tips
Carbon monoxide from generator use can turn dangerous fast when a fuel-powered unit runs too close to a home or sits inside an enclosed space. Gasoline, propane, natural gas and diesel generators all produce carbon monoxide, or CO, while they burn fuel.
Since CO has no color and no smell, exposure can sneak up on you without any warning at all. Proper generator placement and working CO alarms matter a lot here, while battery-based options like the EcoFlow DELTA Pro 3 and DELTA Pro Ultra give you backup power without combustion exhaust during normal battery operation.
Can a Generator Release Carbon Monoxide?
Yes. Your generator puts out carbon monoxide for as long as the engine’s running.
A generator uses an internal combustion engine to make electricity. Fuel burns inside that engine to create mechanical energy, which then gets converted into electrical power. That combustion process also kicks out exhaust gases, and carbon monoxide is one of them.
This applies across gasoline-, propane-, natural gas-, and diesel-powered generators. If you’re wondering, do diesel engines produce carbon monoxide? Yes, they do. Diesel engines generally show different emissions patterns than gasoline engines, but carbon monoxide still shows up in diesel exhaust regardless.
How much CO gets produced can depend on engine design, operating conditions, maintenance, load, fuel quality and a handful of other factors. A poorly maintained engine tends to put out dirtier exhaust than one that’s been properly serviced too.
The real danger shows up when generator exhaust builds up around people. Running a generator inside a house, garage, basement, shed, crawlspace, carport or any other enclosed or partly enclosed spot can let CO climb to dangerous levels. Cracking open a garage door or window just doesn’t offer enough protection here.
Symptoms of Carbon Monoxide Poisoning From a Generator
Recognizing carbon monoxide poisoning generator symptoms matters a ton because CO can’t be picked up by smell or sight.
Early or moderate exposure can bring on symptoms that feel a lot like the flu. Common warning signs include:
  • Headache
  • Dizziness
  • Weakness or fatigue
  • Nausea
  • Shortness of breath
As exposure gets worse, symptoms can progress into vomiting, confusion, loss of coordination, unconsciousness and potentially death. How bad it gets depends on both the concentration of carbon monoxide and how long someone stays exposed to it.
Generator-related exposure can turn dangerous fast, since generators are capable of pumping out huge amounts of CO. People who are asleep may be especially vulnerable because they might not catch the symptoms or hear other warnings in time to act.
If you suspect carbon monoxide poisoning, get everyone into fresh outdoor air right away and call emergency services. Don’t stick around inside trying to hunt down where the gas is coming from.
How to Prevent Carbon Monoxide Poisoning From a Generator
Good generator safety starts well before the power ever goes out. Prepping the installation area, testing alarms and understanding proper operation can cut the risk down a lot.
1. Place the Generator at a Safe Distance
Always run a portable generator outdoors.
CPSC guidance recommends keeping it at least 20 feet away from the home or other occupied buildings. Keep it clear of windows, doors, vents, crawlspace openings and other spots where exhaust could sneak in.
Never run a portable generator inside a garage, even with the garage door open. Porches, carports, sheds, basements and crawlspaces count as unsafe operating spots too.
2. Point the Exhaust Away From Buildings
Distance alone isn’t the only thing to think about. Position the generator so the exhaust points away from your home, neighboring buildings, windows and air intakes.
Wind conditions shift, so check every so often that the exhaust isn’t getting blown back toward occupied spaces.
3. Choose a Generator With Automatic CO Shutoff
Some newer generators come with carbon monoxide sensors that automatically shut the engine down once dangerous CO concentrations are detected around the unit.
A generator with this feature adds an extra layer of protection, but you should never treat it as permission to run the generator indoors or too close to a house.
4. Install a Carbon Monoxide Detector
A working carbon monoxide detector for generators uses ranks among the most important household safeguards you can have.
CPSC recommends battery-operated CO alarms or alarms with battery backup on every level of the home and outside sleeping areas. Battery backup matters especially during an outage, since the alarm has to keep working even when grid electricity isn’t available.
Check your alarms often, and replace the batteries or the whole unit as the manufacturer recommends.
5. Maintain the Generator
Staying on top of maintenance keeps your generator running the way it should. Go through the engine oil, air filter, fuel system, exhaust parts and anything else the owner’s manual calls for.
Don’t run the generator if it’s damaged, and don’t touch the exhaust or safety systems unless the manufacturer says it’s okay.
6. Never Ignore a CO Alarm
If your CO alarm goes off, don’t brush it off as a false alarm just because you don’t smell anything.
Move to fresh air and follow the alarm manufacturer’s emergency instructions. Remember, carbon monoxide itself has no smell, taste or color whatsoever.
7. Follow Additional Generator Safety Tips
Other important generator safety tips include keeping generators protected from unsafe wet-weather operation, following electrical connection instructions, letting the unit cool before refueling and keeping fuel away from flames or ignition sources.
Always follow your generator manufacturer’s operating and maintenance instructions.
8. Consider Battery Backup Instead
If carbon monoxide exposure worries you a lot, battery-powered portable power stations can eliminate the combustion process entirely during normal battery use.
Unlike conventional engines, batteries don’t need to burn fuel to supply electricity. That makes them handy when outdoor generator placement isn’t practical or when you’d rather have backup power without any combustion exhaust at all.
For more information, check out EcoFlow’s guide to carbon monoxide safety and gas generator alternatives.
Select Safer Alternatives to Gas Generators for Backup Power
Portable power stations and solar generators supply electricity using stored battery energy instead of continuously running an internal combustion engine.
You can charge them ahead of time from AC electricity and, depending on the system, top them back up using compatible solar panels. Since the battery itself doesn’t burn fuel while supplying power, normal battery operation doesn’t generate carbon monoxide or engine exhaust.
Two EcoFlow options target different levels of home backup needs.
EcoFlow DELTA Pro 3
The EcoFlow DELTA Pro 3 Portable Power Station suits homeowners seeking substantial backup capacity for emergency outages, essential circuits and larger household appliances.
4,096Wh base capacity with an expandable system capacity of 4–48kWh and 4,000W continuous AC output. Supports larger household appliances, essential circuits, home backup applications and multiple charging options.
It offers:
  • 4 to 48kWh expandable system capacity
  • 4000W continuous AC output
  • Support for larger appliances and home backup applications
  • Multiple charging options
EcoFlow lists a base rated capacity of 4,096Wh, while compatible system configurations can expand capacity quite a bit. Its continuous AC output is rated at 4,000W.
This makes the DELTA Pro 3 particularly handy when you need more power than a small portable battery can give but want to skip running a traditional fuel generator for every single outage.
EcoFlow DELTA Pro Ultra
If you’re dealing with longer outages or need more power for the whole house, the EcoFlow DELTA Pro Ultra gives you a backup setup that can scale up with you.
Expandable 6–90kWh system capacity with 7.2–21.6kW system output. A single inverter provides up to 7.2kW continuous AC output, while multi-inverter configurations can reach 21.6kW. Designed for whole-home backup, high-demand appliances and extended outages.
The system supports:
  • 6 to 90kWh system capacity
  • 7.2 to 21.6kW system output
  • Whole-home backup configurations
  • High-demand household appliances
  • Extended emergency power requirements
A single DELTA Pro Ultra inverter provides up to 7.2kW continuous AC output, while compatible multi-inverter configurations can scale up to 21.6kW. EcoFlow also specifies system battery expansion up to 90kWh.
For households dealing with longer outages or needing to keep several major appliances running at once, this higher capacity and output can give you more backup flexibility without leaning entirely on a combustion generator.
Carbon monoxide from generators is preventable with proper placement, regular maintenance and working CO alarms. Always run fuel-powered generators outdoors and away from doors, windows and vents.
For backup power without combustion exhaust, look at the EcoFlow DELTA Pro 3 for home essentials and large appliances, or the EcoFlow DELTA Pro Ultra for higher-capacity whole-home backup. Explore EcoFlow’s battery backup solutions to find the right fit for your home.
How common is carbon monoxide poisoning from a generator?
CO poisoning from generators is still a real safety risk, especially during outages and bad weather. CPSC has identified portable generators as one of the leading sources of post-storm carbon monoxide deaths.
Can you smell carbon monoxide from a generator?
No. You can’t see or smell carbon monoxide, so your senses won’t warn you. A properly installed and working CO alarm is essential here.
Is it safe to run a generator all night?
Running a generator for an extended stretch requires sticking strictly to the manufacturer’s instructions and generator safety rules. Never run it inside or near the home. Keep it outdoors at least 20 feet away, with exhaust directed away from buildings.
Do generators produce carbon monoxide when off?
No. Once a fuel generator is switched off, it’s not burning fuel anymore, so it’s not putting out any exhaust. CO only comes out while the engine’s actually running.
