Austin Power Outage? Here’s How EcoFlow Keeps You Ready
Whether it’s high winds, summer heatwaves, or equipment failure, power outages in Austin can happen without warning. While these disruptions are a part of life in a city prone to severe weather, you don't have to feel unprepared. With the right preparation, you can ensure your home stays powered and safe during any outage. Our guide provides essential tips for staying informed, minimizing the impact of power loss, and keeping your home running smoothly with backup power solutions.
Keep reading to learn how to check for power outages in your area, common causes of power disruptions, and tips to stay safe during them.
How Do I Check the Status of My Power Outage in Austin?
  1. Visit the Austin Energy Outage Map to view current outages and their status. You can type in a specific address and zoom in on specific neighborhoods. The interactive map also provides information on the number of outages, allowing you to gauge how severe and widespread the outage is.
  2. Report and receive updates via text. To report an outage and receive status updates directly on your phone, text “OUT” to 87846. Phone notifications are handy, so you don’t constantly have to monitor their outage map.
  3. Download the Austin Energy mobile app for real-time outage updates, to report outages, and to receive notifications straight to your phone.
  4. Call 512-322-9100 for phone reporting. If you don't have access to the internet, you can call to report an outage and inquire about the current status. This is a reliable way to get information.
What Are the Most Common Causes of Power Outages in Austin?
High Winds
High winds in Austin are a leading cause of power outages that can affect thousands of customers. Strong winds can knock debris into power lines, poles, transformers, and other electrical grid components, triggering a blackout. Tree limbs are often displaced and carried into power lines, breaking them.
Severe Thunderstorms
Severe thunderstorms in Austin can bring heavy rain, lightning, and hail, leading to power outages. The intense rainfall associated with these storms can cause significant damage by leaking into insulation, switches, and brushes, causing short circuits and equipment failures. Lightning strikes are high-voltage and will cause transformers and substations to overheat, short-circuit, or explode if it strikes them. Hail is particularly destructive—large hailstones can physically damage transformers, substations, and power lines. This leads to extended outages while repair crews work to replace or fix damaged parts.
Heat Waves
Austin summers have become well known for their intense heat waves. Residents often crank up their air conditioning to stay cool, increasing electricity demand. When everyone does this at once, it can overload the power grid, causing transformers to overheat and fail.
To keep your air conditioning running during a blackout, consider using a backup power source like the EcoFlow DELTA Pro 3, which is ideal for powering portable AC units and essential devices. Heat-related illnesses are a serious concern during heatwaves. Staying cool and hydrated can be life-saving.
Cold Snaps
Winter storms, like the 2021 freeze, can lead to widespread outages due to grid damage and overload. Freezing rain often causes ice to build up on lines and trees, leading to line breakage and falling limbs. During these cold snaps, heating demands spike as residents try to stay warm, putting even more strain on the power grid and increasing the risk of blackouts and brownouts.
Grid Maintenance
Austin Power performs regular maintenance, which requires scheduled blackouts, to keep the grid components updated and lower the risk of equipment failures. These outages are typically planned in advance and communicated to residents. You’ll have plenty of warning to prepare for this temporary outage.
Small Animals
Raccoons, birds, and squirrels can climb onto transformers or substations to interfere with electrical equipment. This often causes short circuits and trips switches, resulting in unexpected power outages. While these incidents are usually localized, they can still affect hundreds of customers at a time.
How To Stay Safe During an Austin Power Outage
Have an Emergency Kit Ready
Prepare a basic emergency kit ahead of time, including flashlights, extra batteries, and a first aid kit. You should also include enough non-perishable food and bottled water for each person for at least three days. Aim for one gallon of water per person per day. Other useful items include wet wipes, personal hygiene items, a multitool, cash in small bills, and copies of important papers like insurance information and identification cards.
Stay Informed
Use a battery-powered radio or your smartphone to keep up with updates from Austin Energy and local news. Plug your Wi-Fi router into a backup power station, and you may have internet access if your provider still has power, allowing you to stay up-to-date online as well. Sign up for text or email alerts from your utility provider to stay informed about an outage status, estimated restoration times, and safety warnings. Keep a list of important phone numbers handy, like your utility company, local emergency services, and family contacts. When you lose power, these numbers can help you quickly reach out for assistance or get updates on the situation.
Avoid Carbon Monoxide Risks
Never use a gas generator, grill, or camp stove inside your home or other enclosed spaces. These can release deadly carbon monoxide gas. Gas generators should be set at least 20 feet away from doors, windows, and vents to keep your household safe.
For a safer generator alternative, use EcoFlow DELTA Series Solar Generators. These generators rely on sunlight to create electricity instead of gas. The EcoFlow DELTA 3 Series Solar Generator (PV220W) is perfect for home backup, with 5kWh storage capacity and 1800W AC output (2200W in X-Boost mode).
Unplug Electronics
When power is restored, unplug sensitive devices such as televisions, computers, and major appliances to prevent damage from electrical surges. Once the power is back and stable, you can plug them back in.
Keep these devices powered during the blackout with a portable power station like the EcoFlow DELTA Pro 3. It’s easy to move around your home, making it simple to plug in appliances when emergency power is needed. Wheel it into your living room to power a television and DVD player for entertainment. Or, take the power station into the kitchen to power the refrigerator, coffee maker, or toaster oven.
Maintain Safe Temperatures
During hot weather, stay hydrated, close curtains and blinds, and avoid unnecessary movement to keep your body cool. In the winter, dress in warm layers, use blankets, and use black drafts to retain heat. Avoid using ovens or gas stoves as a heat source, as they can be dangerous and inefficient. Have a game plan to combat extreme temperatures before the power goes out to avoid scrambling at the last minute.
How Do I Report a Power Outage in Austin?
To report a power outage in Austin, you can use several methods provided by Austin Energy. You can report online through their outage map. You can also text “OUT” to 287846 to report an outage and receive status updates directly on your phone. Call 512-322-9100 to report via phone call.
Power outages in Austin are inevitable, but being prepared can help you stay safe and minimize disruptions. Whether caused by severe weather, grid issues, or scheduled maintenance, having a reliable backup power source is crucial. Austin Energy offers multiple ways to stay informed about outages, from their website and app to phone notifications. EcoFlow Portable Power Stations provide an efficient and convenient solution to power your home during any blackout. By staying informed and having a plan, you can confidently face power disruptions and ensure your home remains comfortable and safe.
