Get 500 EcoCredits, Worth $25
Existing user?
Get Expert Help
Long-Duration Emergency Power Supply for Extreme Weather
Massive 180kWh expandable capacity delivers rock-solid 12kW continuous output when you need it most.
  • Stay Comfortable
    Stay Comfortable
    Complete power outage emergency kit meeting your long-duration backup needs during extreme weather, keeping your home powered and family comfortable.
  • Less Waiting
    Less Waiting
    Quick installation process can be completed before storms arrive, ensuring your emergency power generator system is ready when needed most.
  • Unlimited Power
    Unlimited Power
    Expandable system provides unlimited backup power capacity, the ultimate solution for power outage preparedness during severe weather and natural disasters.
  • Ultimate Control
    Ultimate Control
    Integrates Weatherbit forecasting to predict storms and charge batteries, then switches to backup power within 20 ms during outages.
Stay Comfortable
Stay Comfortable
Less Waiting
Less Waiting
Unlimited Power
Unlimited Power
Ultimate Control
Ultimate Control
Find Your Versatile Emergency Backup Power For:
5 Days+
1-4 Days
Hours
24/7
Get Expert Help
Whole-Home Backup Kit
For Over 5-Day Outages
Ensure uninterrupted home life for multiple days—work, cook, and unwind without compromise during blackouts.
Expandable Capacity for Growing Needs
Simple Setup
Seamless Auto-Switchover
12kWh Capacity | 12kW Output | 10kW Solar Input
1 × EcoFlow DELTA Pro Ultra X Inverter + 2 × Smart Extra Battery
Luxury Whole-Home Power.
Learn More
18kWh Capacity | 7.2kW Output | 5.6kW Solar Input
1 × EcoFlow DELTA Pro Ultra Inverter + 3 × Smart Extra Battery
Add To Cart
Learn More
12kWh Capacity | 7.2kW Output | 5.6kW Solar Input
1 × EcoFlow DELTA Pro Ultra Inverter + 2 × Smart Extra Battery
Whole-Home Power that grows with your home
Add To Cart
Learn More
Essential Backup
For 1-4 Day Outages
Power through a days-long outage—keep your lights, Wi-Fi, and refrigerator running for fresh food and reliable essentials.
Blackout-Ready in 70 min
Plug-and-Play
Energy Conserved on Standby
In-App Energy Management
6-90kWh | 7.2-21.6kW | 120V/240V
Whole-home backup solution starts here
Add To Cart
Learn More
4-48kWh | 4-12kW | 120V/240V
EcoFlow DELTA Pro 3
The most portable whole-home backup battery
Add To Cart
Learn More
3.6-25kWh I 3.6-7.2kW
EcoFlow DELTA Pro
Your first whole-home backup battery
Add To Cart
Learn More
3072Wh | 3600W
EcoFlow DELTA 3 Ultra Plus
Charge Your Essentials— One Station Powers it All
Add To Cart
Learn More
Basic Power
For Hours-Long Outages
Keep your essentials powered—medical devices, work tools, and IoT during outages or off-grid situations.
Plug-and-Play
Compact and Portable
Multiple Outlets
1024Wh I 1800W
EcoFlow DELTA 3 Plus
Enhanced backup with 10ms UPS and NAS system integration
Add To Cart
Learn More
1024Wh | 1800W
EcoFlow DELTA 3 Classic
Ultra-versatile 4 charging options and a 45-minute fast-charge.
Add To Cart
Learn More
286Wh I 600W
EcoFlow RIVER 3 Plus
Next-gen UPS with longer-lasting LiFePO4
Add To Cart
Learn More
245Wh I 300W
EcoFlow RIVER 3
Extremely lightweight for backup and outdoors
Add To Cart
Learn More
The Ultimate Whole-Home Power Command Center
Multi-Day
EcoFlow DELTA Pro Ultra X delivers fast-install whole-home backup power, ready in 7 days for any emergency situation.
Ready in 7 Days*
100% Whole-Home Power*
Wide Generator Compatibility
Smart Home Energy Integration
24kWh Capacity | 12kW Output | 200A Panel | 32 Controllable Circuits
1 × EcoFlow DELTA Pro Ultra X Inverter + 4 × Smart Extra Battery + 1 ×Smart Home Panel 3
Backup your Whole-Home, Cut your bills.
Add To Cart
Learn More
24kWh Capacity | 24kW Output | 200A Panel | 32 Controllable Circuits
2 × EcoFlow DELTA Pro Ultra X Inverter + 4 × Smart Extra Battery + 1 ×Smart Home Panel 3
100% Whole-Home Power. For 24/7 uninterrupted backup and cost saving
Add To Cart
Learn More
Power Where Your Generator Can't
EcoFlow portable emergency power supply is ready in seconds, safe for indoor use, and scalable for extended outages. No gas, no noise, no fumes—just reliable, clean power when you need it most.
EF-Picture
Traditional Generators
EF-Picture
EcoFlow Battery Backup
EF-Picture
Home Standby Generators
Hard to operate, manual setup
Plug-and-play, instant power
Month-long installation
Requires regular maintenance and fuel storage
No maintenance, flexible charging options
Gas emissions, outdoor use only
Indoor-safe, no emissions
Gas emissions, fixed outdoor only
Loud and disruptive
Ultra-quiet (<30 dB)
Loud and disruptive
Heavy and bulky
Lightweight and portable for homes, garages, RVs, and more
Permanently installed
No scalability, fixed output
Expandable capacity and scalable output
Fixed capacity once installed
Runs on gas
Solar-compatible, save energy bills and reduce emissions
Runs on gas
Requires additional equipment and professional setup
Seamless home power integration via Inlet Box or Transfer Switch
Permanently installed and requires professional setup
None
0ms auto-switchover, prolonged backup, and energy bill savings with Smart Home Panel 3
None
EF-Picture
EF-Picture
EF-Picture
Loud and disruptive
Heavy and bulky
Runs on gas
None
EF-Picture
Loud and disruptive
Runs on gas
None
Built for Real Emergencies. Certified for Peace of Mind
EcoFlow powers your home through blizzards, heatwaves, and blackouts—backed by industry-leading safety certifications and extreme-condition engineering.
Certified Safe, Inside and Out
UL9540
Whole-system certified for electrical and environmental resilience.
UL9540B
Proven to prevent fire propagation and ensure safe home installations.
Ready for the Worst Weather
Self-Heating Battery
Keeps running below 32°F during winter storms and freezes.
X-Cooling System
Dissipates heat fast, even in scorching summer garages.
SOC Balancing
Intelligently balances charging and discharging across all cells—prevents overheating and extends battery lifespan.
Tough from the Core
Cell-to-Chassis Integration
Built like a tank—engineered to withstand impacts and vibration for long-lasting durability.
IP54-Rated LFP Battery
Sealed tight against dust and water splashes for reliable all-weather performance.
UL9540B Certified
Proven fire safety protection prevents propagation and ensures secure home installations.
Long-Term Reliability, Guaranteed
5-Year Warranty
Backed by EcoFlow's official support for lasting peace of mind.
10+ Years Lifespan
With 4,000 full cycles to 80% capacity, it's built for the long haul—powering your family through thousands of outages.
Sign up to unlock special deals on more EcoFlow backup solutions!
Sign up to unlock special deals on more EcoFlow emergency backup solutions!
Also Available at Trusted Retailers
https://websiteoss.ecoflow.com/upload/image/1749621746281/logo1.png
https://websiteoss.ecoflow.com/upload/image/1749621746664/logo2.png
https://websiteoss.ecoflow.com/upload/image/1749621746472/logo3.png
https://websiteoss.ecoflow.com/upload/image/1749621746947/logo4.png
https://websiteoss.ecoflow.com/upload/image/1749621747856/logo5.png
https://websiteoss.ecoflow.com/upload/image/1749621747578/logo6.png
https://websiteoss.ecoflow.com/upload/image/1749621747345/logo7.png
https://websiteoss.ecoflow.com/upload/image/1749621747104/logo8.png
Protect Your Home with Instant Power Backup
One-Day Delivery
Order by 7 AM, and your power will be ready in as little as 1 business day.*
Interest-Free Installments
Backup first, pay over time.
In-Store Pickup
Get home backup power at select shops.
Go Now
Customer service
800-368-8604  (Mon-Fri 9-7, EST)
Free Quote
Global No.1 in Portable Power Station Sales
EcoFlow is the No.1 portable power station brand in the world based on sales and revenue in 2024,* committed to powering a new world.
5M+
Global Users Back Up Using EcoFlow
140+
Worldwide Markets' First Choice
1125+
X-Core 3.0 Technological Patents
65+
Media Awards
Their Real-life Prepping Stories
Join our EcoFlow Group to learn more backup power stories from real-life users.
Jason Molnar
Never fell overwhelm because of an unexpected power cut. These are the times I’m proud to be an EcoFlow owner. I am able to function as usual. Internet + Wi-Fi , lights, computer, tv and AC by the Wave2.
El Niño
Hope everyone in Hourton,Tx is safe, power went out like at 3am the portable a/c never missed a beat didn’t even know there was no power….. very thankful for having the solar set up….
Joe Lopez
Well...since Beryl just hit us with a vengeance. Ecoflow for the win!!!. Powered my fridge, freezer and internet modem to stay in touch!...I had a separate source for my movin' cool 14 classic AC unit...ALL GOOD!!!
Aline Tarullo
Our family went through hurricane Beryl without any hiccup with SHP, 3x DP + 1EB, hooked to 4600w solar array. It was no surprise that we did okay because Ecoflow has been running our house daily for almost a year now. Our electric bill went from $300 to $150. Estimated payoff time is September 2028, when the savings will surpass the $10k investment.
Victor M Roman
Extremely happy we got this ecoflow, all power went out about 30 min ago here in St cloud Florida. Hurricane Milton. We up and running.
Tony Fresco
A lot of posts had me scared. Installed this yesterday, updated the firmware to both (lots of errors while updating) but everything is working as it should. Shut my power yesterday 3pm @ 90% 8:30 am 71% left normal use including well pump. Only day 2 but nice so far
Hector Salgado
I am in Western NC and we were hit hard by the storm! Glad I got my delta max and delta 2 a few months ago. The combination of solar with a gas generator made all the difference! Generator ran for about 2 hrs in the morning and charged up my eco products for the day. Saving a ton of gas and noise! I had no trouble going 4 days till I got power back. 🙏
Together, We'll Power Through
As a WRN Ambassador of NOAA and a partner of local groups, EcoFlow’s #PowerForAll program empowers communities in emergencies. Stay prepared, stay safe, and protect your loved ones.
EF-Picture
EF-Picture
EF-Picture
EF-Picture
EF-Picture
EF-Picture
Emergency Power During Hurricane Helene in the US
In the wake of catastrophic Hurricane Helene in September, EcoFlow partnered with the Special Forces Charitable Trust and donated 10 portable power stations to help the most vulnerable homes recover after Hurricane Helene in September. EcoFlow has also partnered with the non-profit Red Lightning to preposition donated power stations and solar panels in Florida for future hurricane strikes.
EF-Picture
Keep Maui Connected During 2023 Wildfires
In the summer of 2023, Hawaii faced power outages caused by wildfires. In a collaborative effort, EcoFlow and Blue Hawaiian Helicopter donated our products to support the powering of Starlink satellite broadband systems. This initiative ensures that the Maui community remains connected, enabling crucial assistance and maintaining connections with loved ones.
EF-Picture
Texas Winter Storm
After the 2021 Texas snowstorm triggered widespread power outages, we donated all of the portable power stations in our Texas warehouse to the Houston Food Bank in support of local communities.
EF-Picture
California Wildfires
During the 2020 California wildfires, California utility company PG&E purchased 5,000 of our portable power stations for local residents to use in the event of a power failure. This partnership between EcoFlow and PG&E demonstrates our shared dedication to supporting communities and enhancing resilience during challenging times.
