Greenhouse Heater UK: Types, Running Costs & Solar Power
Keeping your greenhouse heated in the winter can really be quite a challenge, especially with overnight chills and strains on heating bills. Whether it's tender seedlings, exotic flora, or simply extending the growing season, choosing the best greenhouse heating solution is an important step. But how much electricity do greenhouse heaters consume, and what are the options to go for that will take less away from your budget?
Using tubular, fan, or greenhouse solar heaters or batteries may well help you better understand wattage consumption, running costs, thermostat settings and other things related to heating in greenhouse conditions. Due to solar panels and batteries, you will be able to learn about alternative and efficient solutions for managing electricity consumption in your green space.
1. Greenhouse Heaters UK: Types and Heating Options for Gardens
Greenhouse heaters allow gardeners in the UK to shield their plants from frosts, keep proper temperatures, and prolong the growing periods in wintertime. Available in different varieties, heaters may include tubular heaters and electric fan models.
What Is a Greenhouse Heater and Why Do You Need One?
A greenhouse heater is an apparatus used for heating the greenhouse space and keeping the temperature high enough to help keep plants and vegetation alive. It helps to protect plants from frost and assists germination.
In the UK, it is useful from the end of October until the beginning of spring. During the night, the temperature inside the greenhouse and outside can drop sharply even when the daytime temperature appears to be warm enough. In the absence of the heat source, young plants in flower pots and trays may suffer from cold and have their growth slowed down.
Protect frost damage: Ensure frost-intolerant plants stay warm during the cold nights.
Encourage seedling growth: Create conditions that keep seedlings and plants warm and help them grow properly.
Lengthen the growing season: Begin planting in early spring and keep growing some plants until late autumn.
Regulate temperature: Limit sudden changes in temperature that may impact the plant's development.
Safeguard valuable plants: Give winter support to delicate plants such as types of citrus or succulents.
Heating needs differ based on the plants grown. For instance, hardy vegetables will not require too much heat, while tropical plants will need constant warming. Rather than heating the entire greenhouse, the gardener should make sure that the plants have the required minimum temperature.
Different Types of Greenhouse Heaters: Tubular, Fan and Electric
After learning about your greenhouse heating needs, the next step is to select a proper heating system. Various greenhouse heaters are available with a variety of designs, power ratings, and types of operation, some of which are more appropriate for smaller hobby greenhouses than others for larger growing areas.
Below are the most common heating options available for greenhouse gardeners in the UK.
Tubular Greenhouse Heating Units
These tubular heaters are compact electrical appliances that provide smooth, steady heating and are great for small greenhouses, cloches and closed growing spaces where the prevention of frost is more relevant than the increase in temperature.
The wattage in tubular heaters is not very high and can be helpful in protecting plants from drops in temperature during the night. However, you may have to use more than one heating appliance for larger greenhouses depending on insulation and heat requirements.
Electric Fan Greenhouse Heaters
Electric fan heaters consist of a heating unit and a fan used to spread hot air in the greenhouse. Unlike tubular heaters that provide focused heating, fan heaters can heat up the air more quickly, thus eliminating the threat of chilly corners.
Electric fan heaters are best for intermediate and large greenhouses, especially when it is necessary to heat the space quickly. Many electric fan heaters also have a thermostat and different heating settings.
Electric Greenhouse Heating Units Fitted with Thermostats
An electric greenhouse heating unit fitted with a thermostat regulates the heating system’s operations, depending on the temperature levels. Thus, no unnecessary heating is done, provided that the greenhouse already has sufficient warmth.
This heating system is especially advantageous during the bizarre weather of the UK winters, when temperatures fluctuate from day to night. Instead of continuous operation, the heater works when additional heat is required.
When comparing the heating units, emphasis on wattage, accuracy of thermostat, safety features and humidity suitability of the heater. Always get the appliance that has been rated specifically for greenhouse use and follow proper installation and maintenance guidelines.
Solar Greenhouse Heaters: Can Solar Power Heat a Greenhouse?
The use of solar power offers a feasible, energy-efficient method to keep the greenhouse warm without using on-grid electricity. The solar panels produce electric current to power electric heaters inside the greenhouse, even if batteries are needed to store solar energy that is not utilised. However, since solar energy generation is usually lower during winter when the heating demand is exceptionally high, it is vital to select an appropriate solar and battery capacity.
The various methods of solar heating for greenhouses include:
Solar thermal heating: Involves capturing sunlight and harnessing it as heat and moving it into a greenhouse or thermal storage.
Electric heating powered by solar energy: Uses the power from solar panels to provide electricity to an electric greenhouse heater.
Solar panels with a battery: Stores excess energy in a battery for later use.
2. How Much Electricity Does a Greenhouse Heater Use in the UK?
The expense incurred while operating a greenhouse heater during wintertime could lead to increased energy bills. However, one must understand that the true expenses depend on the heater wattage, operating hours, and temperature settings. Therefore, one needs to understand the procedure of electricity usage to operate a greenhouse heater efficiently and control costs.
Greenhouse Heater Wattage and Electricity Consumption
The greenhouse heater consumption has to do with its wattage and operation time. The higher the heater wattage output, the higher the electricity used for each period of time. However, it is essential to understand that the electricity consumed may be lower due to the heater's timers.
Use the following equations to determine the electricity consumption of the heater.
Electricity (kWh) = Wattage (W) x Hours / 1,000
As an example, continuous operation of a 500W greenhouse heater for 8 hours will require 4kWh of electrical energy. In comparison, a 2,000W fan heater will use 16kWh of electricity over the same time frame.
The table below shows the power ratings of the different heaters and their respective electricity consumption.
Greenhouse heater type | Example wattage | Electricity per hour | Electricity over 8 hours |
Tubular heater | 120W | 0.12kWh | 0.96kWh |
Small electric heater | 500W | 0.5kWh | 4kWh |
Medium fan heater | 1,000W | 1kWh | 8kWh |
Large fan heater | 2,000W | 2kWh | 16kWh |
Greenhouse Heater Running Costs: Hourly, Daily and Monthly
The term running cost of a greenhouse heater can assist in managing winter gardening expenses and selecting a less expensive heating method. In the UK, the price of electricity varies depending on the supplier's tariff, heater wattage and the number of hours it works.
For our sample calculation, we will assume the Ofgem average electricity unit rate of 26.32e per kWh for Direct Debit customers in England, Scotland and Wales from 1 October to 31 December 2026. Actual tariffs change across regions and tariffs.
The table below provides estimates on running costs of greenhouse heaters of varying power outputs.
Heater power | Hourly cost | Daily cost (8 hours) | Monthly cost (30 days) |
120W tubular | 3.16p | £0.25 | £7.58 |
500W electric | 13.16p | £1.05 | £31.58 |
1,000W fan heater | 26.32p | £2.11 | £63.17 |
2,000W fan heater | 52.64p | £4.21 | £126.34 |
Note: The calculation is based on 8 hours/day and 30 days/month of continuous operation at full load for each heater. Figures exclude standing charges and are estimates, not actual bills (Ofgem);(National Energy Action). |
A 2,000-Watt electric greenhouse heater, which works for eight hours daily, costs about £126.34 every month. A less powerful 120-Watt tubular heater may incur a cost of approximately £7.58 but will offer less heat.
To find a more precise value, you can apply the actual electricity unit price and the operating hours of your heater.
Greenhouse Heater with Thermostat vs Continuous Heating
How you manage a greenhouse heater significantly impacts the amount of electricity consumed. While a heater that operates continuously heats unless the heater is switched off, a thermostat-controlled heater activates for defined periods to maintain the chosen temperature.
Feature | Thermostat-controlled heating | Continuous heating |
Operation | Switches on when temperature falls below the setting | Runs continuously while switched on |
Electricity consumption | Depending on how often heating is needed | Uses electricity throughout operating hours |
Temperature control | Maintains a selected temperature | May cause unnecessary overheating |
Running costs | Can reduce costs by limiting operating time | Generally higher for the same heater |
Best suited for | Frost protection and temperature-sensitive plants | Situations requiring constant heat output |
Greenhouse heaters in the UK , which are controlled by a thermostat, prove to be an effective option in winter gardening because it prevents unwanted heating when the temperature is more moderate. For instance, a heater with a power of 1,000 W will decrease its running costs from £2.11 if operating for four hours instead of eight.
The Royal Horticultural Society suggests the use of thermostat-controlled greenhouse heating and adds that tubular heaters are good for the provision of background heating and that fans are helpful for heat distribution
Factors That Affect Greenhouse Heating Costs in Winter
Electricity use can change even if one has the same greenhouse heater due to different conditions in the greenhouse as well as outside. The amount of heating needed by one’s greenhouse can depend on several factors as follows:
Size of the greenhouse: In most cases, bigger greenhouses will need more heating as a rule in order to maintain heating.
Insulation: Inadequate insulation is responsible for the escape of warmer air, making a heater operate for a longer time. Using bubble insulation in greenhouses will lessen heat losses.
Glazing materials: A single-glazed greenhouse cools down faster compared to double-glazed or insulated ones.
Desired temperature: The higher the required temperature, the more energy you will need to consume.
Weather in winter in the UK: Frozen nights, strong winds, and frosty periods can require more heating.
Thermostat settings: Correct thermostat settings will help to minimise heating and reduce costs.
Ventilation: Too much ventilation in the cold season will let warm air go out, thus needing more heating.
3. How to Reduce Greenhouse Heating Costs with Solar Battery Storage
To reduce the cost of heating a greenhouse, it is essential to reduce heat loss, introduce more efficient heating management and use more renewable electricity. For gardeners in the UK, practical insulation, along with solar panels and the use of batteries, will help with energy usage.
Practical Ways to Reduce Greenhouse Heat Loss and Energy Use
Keeping the greenhouse warm does not necessarily mean using a heater for a long time. The heat loss can be reduced by making simple changes to insulation, ventilation and temperature management.
Consider some methods to reduce greenhouse heating costs:
Add insulation: Greenhouses can be insulated using horticultural bubble wrap for walls and roofs to help retain heat while still letting light through.
Block gaps and drafts: Examine door frames, windows and joints to find areas where cold air may enter and heated air may escape.
Make use of thermal mass: Place water containers or other thermal mass materials in the greenhouse as heat-absorbing entities that will provide warmth at night.
Design multiple growing areas: Use covers for insulation or break down the greenhouse into smaller areas to maintain the temperature of delicate plants instead of electrically heating the entire structure.
Pick the right heater: Use a tubular or electric fan heater depending on the greenhouse size, plants and heating needs.
Use the thermostat: Set a minimum temperature for the heater to operate, so it activates only when necessary.
Use ventilation with care: Make sure to ventilate the greenhouse during the day, when weather permits, yet don’t forget to close the openings at night.
Using Solar Power and Battery Storage for Greenhouse Heating
Solar panels enable sunshine to be converted into electricity, making it possible to run electric heaters in greenhouses and reduce dependency on grid power during daytime.
However, the heaters may need to be in operation during evening and night when solar panels do not generate any power. By adding battery storage, it is possible to capture excessive energy produced in daytime and make it available later, thus helping British gardeners to manage their heating needs, making use of the plants’ equipment, and enhancing the use of renewable energy sources during the winter.
So, the choice of battery storage systems is determined by the fact of whether you are planning to install a solar system or upgrade your existing one. EcoFlow STREAM provides solutions designed especially for these cases: STREAM 5000 Solar Battery 5kWh is designed for owners starting their own solar storage system, and STREAM AC 5000 is developed for people who are already using solar panels and looking for battery storage. Let’s compare the two systems as means of flexible energy management both at home and outdoors.
EcoFlow STREAM 5000 Solar Battery 5kWh: Supporting Solar-Powered Greenhouse Heating
EcoFlow STREAM AC 5000: Adding Battery Storage to Existing Solar Panels
You do not need to spend a fortune on electricity just to keep your greenhouse warm during the colder months in the UK. You can save on expenses by using an efficient greenhouse heater, improving insulation, and installing a thermostat. Whether you need a tubular heater for frost protection or an electric fan heater for a bigger greenhouse, you need to know how many watts are needed and how much the operational costs are.
Using solar panels, along with batteries, can help you manage electricity use for your greenhouse. If you are making plans for a solar and battery system, the EcoFlow STREAM 5000 Solar Battery 5kWh will help store energy for your household and garden. If you already have a solar panel system installed at home, you can use the EcoFlow STREAM AC 5000 to store surplus energy produced by the solar installation.
You should research EcoFlow STREAM options to use more renewable energy supported by outdoor equipment for your greenhouse.
What Is the Best Greenhouse Heater for Winter in the UK?
The best solar greenhouse heater chosen depends on multiple factors like the dimensions of the greenhouse; its insulation and the type of crops grown there. Smaller greenhouses may benefit from a tubular heater, which provides even heat throughout the greenhouse. Larger greenhouses often require electric fan heaters, which can effectively heat them quickly. A heater fitted with a thermostat will allow for temperature control and cut down on energy waste.
Can You Heat a Greenhouse Using Solar Power?
The answer is yes, as solar energy can complement greenhouse heating. Solar panels turn sunlight into electricity, which then can be used to operate proper electric greenhouse heaters. Batteries will allow you to store the excess electricity generated so that you can use it when required, for example overnight to heat up the greenhouse. It is worth noting that in the UK, there is not so much solar energy available during the winter months, so one needs to carefully consider the heating capacity needed and the performance of solar panels.
How Much Electricity Does a Greenhouse Heater Use Per Day?
Electricity use per day is determined by the power of the heater and how long it has been in operation. Consider the following examples.
A tubular heater of 120W that has worked for 8 hours uses 0.96kWh.
A heater of 500W that has been in operation for 8 hours uses 4kWh.
A fan heater of 1,000W running for 8 hours uses 8kWh.
A fan heater of 2,000W working for 8 hours consumes 16kWh.
By using a thermostat-controlled heater, electricity consumption may be lower since it will turn off once the required temperature is reached.
Are Electric Greenhouse Heaters Expensive to Run?
Electric greenhouse heaters can be expensive, especially when using higher-wattage models that are powered for long periods of time. However, the operating costs of electric greenhouse heaters depend on the heater's power rating, the amount of time it is used and electricity fees. Using your heater with a thermostat, improving insulation of your greenhouse, and having the right heater for your growing area can help save energy consumption.
Can Solar Panels Power an Electric Greenhouse Heater?
Yes, it is possible to operate an electric greenhouse heater with solar panels as long as there is sufficient electricity. However, demand for heating increases in the evenings during winter when no solar energy is produced. This difference in timing can be solved by using batteries for electricity storage, which can store excess energy received during the day for later use. The batteries must have enough output to operate the heater.
