Wintry Mix Meaning: Snow, Ice, and Rain
A wintry mix means two or more types of winter precipitation are expected. Snow, ice pellets, freezing rain, and rain may fall together or arrive in turns.
For your plans, the changeover can matter more than the symbol on your phone.
In a Canadian forecast, check what will fall, when it may change, and which impacts are expected. The label alone doesn't tell you whether your road or front steps will be safe.
What Does a Wintry Mix Include?
A wintry mix can include a mix of rain and snow, frozen pellets, or rain that freezes on contact. Each event has its own blend, and you may see different types as it moves through.
The phrase describes the forecast period, so it doesn't mean everything falls at once. One area might get wet snow, while a nearby area gets freezing rain. Read the forecast for your location rather than apply a nearby city's conditions to your home.
ECCC's cold-season weather definitions distinguish these types by what reaches the surface. Compare their effects before deciding which part of your plans needs to change.
Type
What Reaches the Surface
Why It Changes Your Plans
Snow
Snowflakes that may be wet or dry.
Buildup and poor visibility can affect travel and access.
Ice Pellets
Small drops that freeze before landing.
Pellets can build up and make surfaces slippery.
Freezing Rain
Liquid drops that freeze on cold surfaces.
Ice can coat steps, branches, and power lines.
Rain
Drops that remain liquid when they land.
Runoff can cause problems, and wet surfaces may freeze later.
These are explanations, not a test to carry out on your front steps. A surface can be unsafe even if you can't see a thick ice coating.
American forecasts often call ice pellets “sleet.” Elsewhere, that word can mean rain mixed with snow, so Canadian wording helps avoid confusion. Knowing how ice pellets differ from other precipitation makes the local forecast easier to read.
Keep Essential Devices Ready Before Ice Builds
If the forecast includes disruptive ice, wind, or snow, check your household's power needs early. An outage is possible in damaging weather, but the words “wintry mix” don't predict one.
Decide What Needs Stored Power
A working flashlight, radio, charged phone, and power bank may cover your first needs. A larger battery should solve a gap those items can't cover.
Before sizing backup power for essential devices, list what must run and for how long. Check each device's running watts, extra power needed to start, voltage, and plug type. A fridge motor, for example, may need more power to start than to keep running.
Watts describe power at one time. Watt-hours describe stored energy, which helps set how long the battery can supply a load.
Allow for energy losses and a reserve, then plan a realistic way to recharge. Running a router won't restore internet service if the outside network is down.
Match the Battery to the Checked Devices
A fridge may need power for much longer than a phone takes to charge. That longer job can make a larger energy reserve useful, once you've checked the actual load.
The EcoFlow DELTA 3000 Gen4 Portable Power Station has 3,072 Wh of nominal capacity and 3,600 W total rated 120 V AC output. Its capacity is fixed, so you can't add extra batteries.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
At about 26 kg, it needs a suitable dry indoor spot and a planned lift. Match startup demand and each outlet's limit, as well as total output. The capacity figure doesn't promise a fixed fridge runtime or direct support for 240 V equipment.
A smaller group of devices may need less stored energy. The EcoFlow DELTA 3 Max Portable Power Station (2048Wh) has 2,048 Wh of nominal capacity and 2,400 W total rated 120 V AC output. It weighs about 20.3 kg, reducing the lift as well as the energy reserve.
EcoFlow DELTA 3 Max (2048Wh)
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport. 5. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
Choose between these models for your device needs, rather than treating them as a connected pair. Keep either one dry, leave its vents clear, and charge only within its allowed temperature range of 0 °C to 45 °C.
Public Safety Canada's outage precautions also stress safe connections. Never feed power into a household wall outlet. Hardwired circuits need suitable equipment installed by a qualified electrician. Warmth and a safe place to stay need their own plan.
Why the Mix Changes Above the Ground
The air above your home can be warmer than the air beside it. Falling snow passes through those layers, which helps explain why a sub-zero reading doesn't always mean snow.
In one common setup, snow melts as it falls through warmer air. If it then crosses a deep enough cold layer, the drops can freeze into ice pellets before landing. NAV CANADA's ice-pellet explanation describes this process.
A shallow cold layer may leave too little time for drops to freeze in the air. They can stay liquid until they hit cold steps, branches, or other surfaces. That is freezing rain.
Simplified diagram comparing common temperature layers that produce snow, ice pellets, freezing rain, and rain.Simplified diagram comparing common temperature layers that produce snow, ice pellets, freezing rain, and rain.
The diagram shows common paths, not a fixed sequence every storm follows. Changes in the air layers can shift the type during the event, and nearby places can get different results.
Rain can also create a later hazard if water on the ground freezes quickly. That rapid freeze of wet surfaces is a flash freeze. It concerns water already on the ground, rather than another type falling from the sky.
Read the Forecast Beyond the Mix Symbol
Use the forecast's location, timing, and impacts to judge your next move. A small weather symbol can't show the full range of conditions along your route.
Open ECCC's current forecasts and alerts for the place you need to check. Read the details in this order:
  1. Confirm the location and update time. A saved message may no longer describe the next few hours.
  2. Find the expected type and changeover period. Check the whole trip window, including your return.
  3. Keep snow, rain, and ice amounts separate. Don't turn one total into another or assume an icon shows the amount.
  4. Read the listed impacts and recommended actions. Check again before leaving, as timing and local conditions may change.
Checklist showing location, timing, precipitation, and impacts to check in a winter forecast.Checklist showing location, timing, precipitation, and impacts to check in a winter forecast.
Official alerts add information beyond the general forecast. Under ECCC's alert system, warnings and advisories call for action, while watches call for readiness as hazardous weather may develop. A special weather statement provides information and isn't itself an alert.
Read the full message rather than judge it by the title alone. It gives the expected weather, affected area, timing, possible impacts, and actions to take. A colour or mix symbol doesn't replace those details.
For wider context, understanding Canadian weather alerts helps you separate the forecast from the action an official message calls for.
Adjust Travel and Home Plans to the Next Phase
Match your next step to the hazard expected at that time. A change to rain doesn't prove roads are safe, and a mix isn't always worse than snow.
Public Safety Canada's winter-storm advice supports planning ahead for difficult travel. Delay unnecessary trips during hazardous conditions. If a trip is needed, check the relevant provincial road service and your route before you leave.
At home, put shovels and ice-removal supplies where you can reach them safely. Don't walk onto ice to test it, climb onto a roof, or approach damaged wires. Snow buildup and ice on a short path can each change how you enter or leave.
Keep a flashlight and radio accessible, with a way to charge your phone. Save useful contact details so you can find them without internet access.
Illustration of a DELTA 3000 Gen4 supporting a phone and reading lamp in a dry home work area.Illustration of a DELTA 3000 Gen4 supporting a phone and reading lamp in a dry home work area.
If electricity fails, finding your local power outage information starts with the utility serving your address. Use its reporting and update channels, with radio or saved contact details as a fallback.
A forecast's end time isn't a promise that power will return then. Never use outdoor cooking equipment or a fuel generator indoors. If your home becomes unsafe, follow local guidance and move to a safe place rather than rely on a battery.
Make Your Next Check Before Conditions Change
Check the next forecast phase before you leave or settle in for the evening. Knowing when snow may turn to rain or ice gives you a more useful plan than the mix label alone.
Confirm your route, light, and phone-charging options while there's time to adjust. If that check reveals a power gap, compare portable power stations for selected home devices against your actual loads and safe indoor space. Buy for that need, with a recharge plan, rather than for the forecast symbol.
Is sleet as bad as freezing rain?
Neither has one fixed danger level. Ice pellets can reduce traction, while freezing rain coats cold surfaces with ice. The amount, duration, and local effects determine the risk, so follow the forecast's impacts and actions rather than assume either type is safe.
Can wintry mix happen below 0 °C?
Yes. Warmer air above the ground can melt snow even when the surface air is below freezing. Drops may then freeze in the air or on cold surfaces, so the temperature beside your home doesn't describe the whole path down.
Does wintry mix always include freezing rain?
No. A mix can include different combinations of snow, rain, or ice pellets, and the types can change over time. Check the detailed forecast to see whether freezing rain is expected at your location and during your travel window.
Is wintry mix a weather warning in Canada?
No. The phrase describes expected mixed weather, rather than naming an ECCC alert. Check the official message for its alert type, weather hazard, affected area, timing, and recommended action instead of judging its status from an app symbol.
Home Backup
