Yellow Warning - Winter Storm: Meaning and Next Steps
A yellow warning - winter storm calls for action on your local weather alert. Don't wait for orange before changing a trip or checking household supplies.
Snow may be only part of the problem. Wind can reduce visibility, while ice can affect the journey home after snowfall ends.
Read the hazards and their timing together, then decide what needs to change. Use Canada's official weather services for current alerts, rather than treating this explanation as a live warning.
What Does a Yellow Warning - Winter Storm Mean?
A yellow winter storm warning combines three messages about risk, urgency, and the weather hazard. Read all three before deciding what to do.
Under ECCC's alert definitions, a warning calls for action because severe weather is happening or expected. A watch means you should get ready for possible severe weather.
The yellow risk colour commonly points to moderate, local or short-term impacts. Forecasters also weigh how sure they are about those impacts. Yellow doesn't rule out a serious risk to you.
Each part of the headline answers a different question.
Headline Part
What It Tells You
What It Does Not Decide
Yellow
The assessed risk, based on possible impacts and forecast confidence.
A fixed snow amount or a safe road.
Warning
Severe weather is happening or expected. Act on the notice.
The same thing as a watch or advisory.
Winter Storm
Several types of severe winter weather may cause problems together.
Exact conditions at every address.
A watch can also carry yellow. Check the full title instead of using colour to tell watches and warnings apart.
Nor is every winter storm a blizzard. With winter blizzards, wind and poor visibility need close attention, even when little new snow falls.
 Diagram separates weather risk colour, alert type and the named hazard. Diagram separates weather risk colour, alert type and the named hazard.
Prepare for Disruption Without Predicting a Blackout
Cover the household needs you can address safely before conditions worsen. Treat lost power as a possibility, rather than an outcome promised by the colour.
Ready the Supplies You Already Have
Charge phones, find your LED lights and check the radio's batteries. Put warm layers, food, water, and household contacts within reach.
Check your emergency supplies for a power outage for gaps that matter to your household. Arrange help early for anyone who may struggle to get supplies or leave safely.
Federal emergency-kit guidance sets a target of at least 72 hours on your own. That's a supplies target, not a prediction of storm length or battery runtime.
Leave bigger seasonal home checks for safe conditions before a storm. Don't climb onto a roof or make a risky shopping trip to finish a checklist.
Match Future Backup to Essential Tasks
A charged power bank may cover a phone-only plan. For more devices, check voltage, running watts, extra startup power, and energy needed between charges.
Use those loads for battery-backup sizing, rather than choosing a battery from the warning colour. Watt-hours describe stored energy, while watts show the power needed at one time.
If your checked plug-in plan needs several kilowatt-hours, the EcoFlow DELTA 3000 Gen4 Portable Power Station provides 3,072 Wh in a fixed-capacity unit. You can't add extra batteries later, so check the full device list before buying.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Its total rated AC output is 3,600 W at 120 V. That rating doesn't tell you how long your devices will run. At roughly 26 kg, plan where to keep it and how to move it safely.
If you expect your checked energy needs to grow, consider the EcoFlow DELTA 3800 Gen4 Portable Power Station instead. It starts with 3,763 Wh and supports expansion advertised up to 12 kWh with compatible extra batteries and required equipment.
1. Longest Runtime: Powers a refrigerator for up to 70 hours — 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. 4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Allow for the extra batteries' cost and space, plus a base unit of about 30.6 kg. The total rated AC output remains 3,600 W at 120 V. More stored energy doesn't add 240 V output.
Each model has four 20A AC outlets and one 30A AC outlet. However, the combined AC output remains limited to 3,600W. Check each appliance's power requirements and the specific outlet rating before connecting it.
Keep either unit dry, with clear vents. Charging requires 0 °C to 45 °C, so an unheated garage may be unsuitable. Home-circuit backup needs qualified assessment and approved equipment. Never feed a household outlet.
Plan new equipment for future storms. For an active warning, prepare what you already have rather than relying on an order arriving in time.
Match Each Winter Hazard to Its Timing
Check which hazards overlap and when they affect your plans. Snow that looks manageable at home may be followed by ice during your return trip.
Open the ECCC weather map and alert table, choose your location, and read the complete notice. Check the latest issue time, affected area, hazard period, likely impacts, and safety actions.
Use the hazards actually named in that notice. These checks aren't a forecast that every yellow warning includes all four.
If the Bulletin Names
Decision to Recheck
Important Limit
Accumulating Snow
Can you reach home and needed services during that period?
Colour isn't set by one national snow total.
Blowing Snow or Poor Visibility
Can you delay both parts of the trip?
Little new snow doesn't mean clear views.
Freezing Rain or Ice
What changes for roads, walking surfaces and utility service?
Ice can remain after snowfall stops.
Strong Wind With Winter Precipitation
Are exposed travel or damaged trees a concern?
Keep away from fallen branches and wires.
For a hypothetical trip, snow might affect the morning drive while freezing rain is forecast later. An easier outward journey wouldn't settle whether the return is sensible.
Read the sequence before setting a departure time. A social post's date or a saved screenshot doesn't confirm the alert is still valid.
Check the Whole Journey Before You Leave
Check the route and destination, as well as the forecast for home. Change non-essential plans when official advice or conditions call for it, without waiting for a higher colour.
Federal winter-storm guidance advises delaying driving during a storm. Use the provincial or territorial road service for the full route and local authorities for closures. An open road isn't a promise of safe travel.
Different sources confirm weather, road access, service operations and electricity status.Different sources confirm weather, road access, service operations and electricity status.
Your school or board confirms classes and school transport. The transit operator or airline confirms its own service. Check those notices separately from the weather alert.
Before leaving, confirm the return plan with anyone travelling with you. Allow for their needs if a service stops or you can't get home as planned.
Change the Home Plan When Conditions Change
Recheck your decisions when the alert, local conditions or household needs change. A cancelled warning and a restored electricity supply are separate pieces of information.
Keep Updates Separate From an All-Clear
Use WeatherCAN notifications to prompt a fresh look at the full bulletin. Colours can change as expected impacts or forecast confidence change. Alerts don't have to pass through every colour.
After a cancellation, check roads, utilities, and local instructions before resuming plans. Snow clearing and service repairs may still be underway.
Watch for a separate flash-freeze warning if temperatures drop sharply over wet surfaces. The end of snowfall doesn't remove that risk.
Respond to Lost Power or Heat
If power fails, contact your local electricity distributor and keep clear of damaged lines. Follow its updates for repair news, since the weather alert can't provide that timing.
Follow federal outage guidance for safe lighting, working carbon monoxide alarms, and plans for lost heat. A charged router may help only if the outside network still works.
A DELTA 3000 Gen4 supports a small indoor lighting and charging setup.A DELTA 3000 Gen4 supports a small indoor lighting and charging setup.
Use prepared backup equipment within its limits. Never run portable fuel generators, barbecues, or camping stoves indoors or in a garage.
Arrange a safe heated place if home becomes unsafe, and follow evacuation instructions. Don't wait for a battery percentage to decide whether someone needs help.
Keep One Local Storm Plan Ready
Write down the hazard period, the plan you'll change, your household check-in, and the next official update. Keep that note where everyone can find it.
A yellow warning - winter storm is a reason to act on local details. For future backup, compare portable power stations after checking your essential tasks and safe recharge options.
FAQs About a Yellow Warning - Winter Storm
What does a yellow warning mean in a storm?
Yellow identifies the assessed weather risk using possible impacts and forecast confidence. Read the named hazard and safety actions, too. Local conditions and your own needs can make the consequences serious even at the lowest colour.
Is a yellow winter storm warning the same as a watch?
No. A warning calls for action because severe weather is happening or expected. A watch tells you to get ready for possible severe weather. Either alert type can carry yellow, so read the complete title.
How much snow triggers a yellow winter storm warning?
There's no single national snow total that defines the yellow colour. The assessment considers impacts and confidence, while a winter-storm notice can cover several hazards together. Read its local details rather than using centimetres alone.
Does a yellow winter storm warning close schools?
No, the warning doesn't make that decision. Check your school or board's latest notice and school-transport updates. Classes and buses may have different arrangements, so confirm both before leaving home.
Should I prepare for a power outage during a yellow warning?
Yes, as a possible disruption rather than a forecast. Charge existing devices safely and check accessible lights and supplies. If service fails, use your electricity distributor's updates for the actual outage information.
