What Is Sleet? Meaning, Formation and Sleet Weather Explained
Sleet is a type of winter precipitation that occurs when snow or raindrops fall through layers of air at varying temperatures. Depending on where you live, it could be a mixture of rain and snow or tiny, hard pellets of ice.
Knowing the difference helps you read a forecast accurately, prepare for slippery roads and safeguard your household during a severe winter storm. In this guide, you will learn about sleet meaning, how sleet is formed, how sleet is different from snow, freezing rain and hail, and what hazards come with sleet weather, including the risk of power outages.
What Is Sleet? Meaning and Characteristics
Sleet is winter precipitation that falls as tiny, translucent or transparent ice pellets that are often no larger than five millimetres. When the hard pellets hit pavement or other solid surfaces, they typically bounce back.
People searching for "what is sleet" or "sleet what is" are often surprised to learn that the definition of sleet varies by region. In the United States, the National Weather Service uses the term "sleet" for ice pellets.
In British and many Commonwealth usages, including common Canadian usages, it frequently refers to rain combined with snow. Because of this, Environment and Climate Change Canada does not use the term "sleet" and instead uses "ice pellets" or "wet snow" in its forecasts. The ECCC weather glossary contains official terminology.
What Does Sleet Look Like?
Ice pellets look like tiny clear or milky beads. They differ from snowflakes, which are branching ice crystals, and from raindrops, which are liquid. You can often hear sleet tapping on windows and see it bounce off hard surfaces. It can also collect on roads and sidewalks like a layer of coarse grit. Because pellets have less surface area than snowflakes, they take longer to melt than an equal volume of snow.
What Does Sleet Mean in a Weather Forecast?
If the forecast calls for sleet or ice pellets, expect frozen particles to fall on slick surfaces and change travel conditions. This type of precipitation also signals to forecasters that temperatures aloft and at the ground are near the freezing point. If you wonder, "What is sleeting weather?", the answer is simple: sleeting means ice pellets are falling right now. Conditions can change within hours, so check Environment and Climate Change Canada’s alerts instead of a single forecast.
How Does Sleet Form?
Most winter precipitation begins as snow in the cold upper layers of a storm. As snowflakes descend, they may pass through a warmer layer of air and partially melt. If they then enter a sufficiently deep layer of freezing air near the ground, the partially melted particles refreeze into small ice pellets. These pellets reach the surface as sleet and typically bounce on impact.
This process depends on the vertical structure of the atmosphere, including temperature inversions, where warmer air sits above colder air. Different temperature profiles produce snow, rain, sleet, or freezing rain from the same storm.
The Role of Warm and Cold Air Layers
Warm air aloft partly melts the snow, and freezing air below refreezes it.The depth of each layer determines the type of precipitation. If the warm layer is shallow, flakes only partly melt and the cold layer can turn them into pellets. If the warm layer is deep, the flakes melt completely, which leads to rain or freezing rain instead.
What Temperature Conditions Cause Sleet?
Sleet commonly forms when a layer of warmer air exists above colder air near the ground. However, surface temperature alone cannot determine whether precipitation will fall as sleet, snow, or freezing rain. Forecasters examine the entire vertical temperature profile, including the depth and temperature of both warm and cold air layers. Even relatively small changes in these conditions can affect the type of precipitation that reaches the surface.
The warm layer must be above 0°C (32°F), typically peaking at 1 to 3°C, while the air near the ground stays below 0°C (32°F).
Can Sleet Cause Power Outages and How Can You Prepare Your Home?
Winter storms with heavy sleet, freezing rain and ice formation may interfere with the delivery of energy and damage vulnerable infrastructure. The greatest threat to power wires and trees is freezing rain, which freezes on contact and builds up a heavy glaze. The ground can be slippery largely due to sleet. But combined storms can produce both. By definition from the National Weather Service, an ice storm is at least a quarter-inch of ice on exposed surfaces, enough to snap tree limbs and power lines.
Because heating, refrigeration, lighting, and communications all depend on grid electricity, households should prepare for possible interruptions. Portable power stations and home backup systems are one option. For deeper guidance, see EcoFlow’s guides on ice storm power outages, whether ice accumulation can cause outages, and how to prepare for and recover from outages.
Portable Backup Power for Essential Household Appliances
Imagine a winter storm that causes a power outage overnight. The refrigerator begins to warm, the lights go out, and the Wi-Fi router stops working. The EcoFlow DELTA 3000 Gen4 can provide backup electricity for compatible appliances and essential devices. It has a 3,072Wh battery capacity, 3,600W continuous AC output and 7,200W surge capability. Its UPS function switches to battery power in under 10 milliseconds, so compatible equipment keeps running without interruption during an outage.
Whole-Home Backup for Extended Winter Storm Outages
Longer storms may call for more comprehensive backup. The EcoFlow DELTA Pro Ultra offers a 6,144Wh base battery, 7,200W of continuous AC output, and 10.8kW of surge capability. In a three-inverter system, capacity can expand to 90kWh. With compatible home integration equipment, such as the EcoFlow Smart Home Panel 2, and solar charging, it can support longer household electricity needs.
Actual backup performance depends on system configuration, electrical installation, and household load. Operate both products within their specified temperature and environmental limits.
What Is the Difference Between Sleet, Snow, Freezing Rain, and Hail?
These types of precipitation form in different ways and carry different risks, so they should not be confused.
Weather type | How it forms | Appearance |
Sleet (ice pellets) | Snow or rain that has partially melted and refreezes before it hits the ground | Small, hard, clear pellets |
Snow | Ice crystals develop and remain frozen as they fall | Soft flakes or clusters of crystals |
Freezing rain | Liquid raindrops freeze on contact with cold surfaces | Smooth, slippery coating of ice |
Hail | Ice particles grow inside strong thunderstorm updrafts | Larger, often irregular ice stones |
Rain and snow mixed | Snowflakes begin to melt but do not become rain. | Mixture of rain and wet snow |
Sleet vs. Freezing Rain
Sleet freezes before it reaches the ground, but freezing rain stays liquid until it hits a surface at or below freezing. But freezing rain adds weight that can break branches and bring down lines, and it creates a smooth glaze on power lines, trees, vehicles and roads. That is why it is usually more damaging than sleet.
Sleet vs. Snow and Hail
Snow is made of ice crystals that stay frozen all the way down. Sleet is a hard pellet of refrozen water. Hail forms inside thunderstorms, where raindrops are carried upward by updrafts into very cold air and freeze, growing into larger stones. For more detail, see NOAA’s winter precipitation overview.
Sleet is winter precipitation that usually falls as hard ice pellets, though the term can mean rain mixed with snow in Canada. It forms when partly melted flakes refreeze, and it differs from snow, freezing rain, and hail. Understanding forecasts and slippery conditions helps you prepare for storm-related outages. The EcoFlow DELTA 3000 Gen4 and DELTA Pro Ultra serve different household needs during severe winter storms. Explore EcoFlow’s portable power stations and home backup solutions.
What is the difference between sleet and snow?
Snow is frozen ice crystals, and they remain frozen as they fall. Sleet is snow or rain that partially melts, then freezes into hard pellets.
Is hail the same as sleet?
No. Hail forms in thunderstorm updrafts and is usually larger. Sleet forms in cold-season storms.
Is ice the same as sleet?
Not exactly. Sleet is one type of frozen precipitation. Ice on surfaces more often comes from freezing rain, though sleet can pile up on the ground.
Is sleet snow or hail?
Neither. It is a separate type of precipitation, made of ice pellets that often begin as snow.
Is freezing rain better than sleet?
No. Freezing rain is usually more dangerous because the glaze of ice it produces can cover roads, trees and power lines and cause outages.
