What Is Sleet? Why It Happens and What to Expect
If you have brushed the snow off the car in a Canadian driveway and watched what was coming down ricochet off the windshield instead of settling, you have already met sleet. In many parts of Canada, winter weather does not always commit to a single kind of precipitation, and one system can shift from snow to sleet to freezing rain and back again before dinner. Sleet is the changeover that catches people off guard: little pellets of hard ice that bounce on landing and can quickly turn roads, walkways and the morning drive into a mess.
This guide explains what the sleet is, how it forms in the layers of air stacked above a storm and the distinct hazards it poses. Then it turns practical, covering how to travel safely, keep the house warm and run key appliances on reliable backup power when the power goes out.
What Is Sleet?
What Americans call sleet, Environment and Climate Change Canada (ECCC) records as ice pellets, so Canadian forecasts and alerts generally use the second term. People asking what sleeting is are usually referring to this same hard, bouncing precipitation.
Sleet Falls as Small Ice Pellets
Sleet comes down as hard, translucent ice pellets, each 5 millimetres across or smaller. Where snow drifts down quietly, sleet lands with enough weight and speed to bounce off asphalt, parked cars and jacket sleeves, and a burst against the siding often sounds like gravel thrown at the house. Underfoot it crunches like coarse sand, building a loose, granular layer well before any solid ice sheet forms.
Sleet Forms When Snow Melts and Refreezes
Knowing what sleet weather means starts with the vertical temperature profile. Snow forms high in the cloud, then falls through a band warmer than 0°C that melts the flakes partly or completely into raindrops. A sufficiently deep layer of sub-zero air near the ground then refreezes the drops before they land, producing hard ice pellets instead of rain or snow.
Sleet vs. Snow vs. Freezing Rain vs Hail
All four can look interchangeable from the window, but they form differently, land differently and cause very different problems:
Precipitation Type
How It Forms
Appearance / State at Impact
Main Hazard
Sleet
Snow melts in warm air aloft, then refreezes in deep sub-zero air near the ground
Hard, translucent pellets (≤5 mm) that bounce on contact
Dense, slippery accumulation and quick traction loss
Snow
Water vapour freezes directly into ice crystals without melting
Delicate, crystalline flakes
Poor visibility and drifting
Freezing Rain
Snow melts into rain, crosses only a shallow cold layer and freezes on contact
Liquid drops that glaze surfaces with ice
Downed power lines, glazed trees, severe ice buildup
Hail
Severe thunderstorm updrafts carry raindrops back up into freezing air over and over
Layered balls or lumps of ice, mostly warm-season
Roof, siding and vehicle impact damage
What Can Sleet Mean for Winter Conditions in Canada?
From the Maritimes through the St. Lawrence Valley and across Southern Ontario, sleet is frequently the middle chapter of a storm, turning a straightforward snowfall into something messier and scrambling the day’s driving and plans.
Making Roads and Walkways Slippery
Soft snow gives winter tires something to bite into. Sleet does the opposite, scattering hard little pellets across the pavement that roll under treads and boots like ball bearings. Even a centimetre or so of it, pressed down by traffic, compacts into a concrete-hard, glazed pack that shrugs off road salt, and when the snowplow comes by, the windrow it leaves hardens before most of us get out there with a shovel. Shovelling it is heavier work than moving powder, closer to wet sand than anything that fell as a flake.
Reducing Visibility and Travel Conditions
In gusty wind, sleet comes at the windshield sideways, loading the wipers with slush that ices over faster than washer fluid clears it. Add the spray from transport trucks on routes like the 401 or the Trans-Canada, plus early twilight, and visibility can shrink to a few car lengths. That is an afternoon for slowing down, leaving extra following distance and waiting on the salt trucks’ first pass.
Combining With Snow and Freezing Rain
Sleet frequently arrives wedged between wet, heavy snow and freezing rain, and each layer makes the others worse. Pellets caught in the snowpack keep road salt off the asphalt, while freezing rain forms a crust over the top and locks the slush below into one solid sheet that makes municipal clearing and residential snow removal exhausting work.
EcoFlow TITAN 5000 Classic Whole-Home Backup PowerEcoFlow TITAN 5000 Classic Whole-Home Backup Power
How Can Sleet Affect Power and Energy Systems?
On its own, sleet is seldom the main cause of a power outage. The trouble is that it often arrives inside a broader storm of wet snow, gusting wind or freezing rain, and the combined strain on power lines, tree limbs, heating systems and essential household loads can turn a weather event into a power problem.
Winter Storms Can Disrupt Local Power Infrastructure
Freezing rain is usually the greater infrastructure threat because ice can accumulate on lines and branches until they sag or break. Sleet can still make roads hazardous and slow access for repair crews. When sleet changes to freezing rain, continued ice buildup on trees and electrical infrastructure can increase outage risk.
Cold Weather Can Increase Household Electricity Demand
When a storm drags temperatures well below zero, heating systems across the neighbourhood run continuously. Heat pumps, baseboard heaters and furnace blowers all draw hard on the grid through the coldest hours, and that surge lands just when ice and wind have left the lines most exposed, raising the risk of brownouts or a sudden outage on your street.
Outages Can Interrupt Heating and Essential Loads
When the power cuts out in January, a house begins losing access to electrically powered systems. Even a high-efficiency gas furnace may stop because its blower, exhaust fan and ignition controls require electricity. A sump pump cannot operate, Wi-Fi drops and refrigerated food becomes a concern as an outage continues. A portable power station can support selected devices when its continuous output, surge rating and capacity match the planned loads.
How Can Canadian Homes Prepare for Sleet-Related Outages?
Planning before the weather closes in can help keep a household warm, safe and connected once conditions worsen. A solar generator can be part of that plan when its battery capacity and solar input are sized for the loads you intend to support.
Monitor Local Weather and Winter Storm Alerts
Following Environment and Climate Change Canada (ECCC) weather alerts is a practical part of power outage preparedness. Special Weather Statements, Winter Storm Watches and Freezing Rain Warnings can signal when to check emergency kits, charge communications devices and verify that backup batteries are ready before wind and ice arrive.
Match Backup Power to Essential Loads
When heavy snow, freezing rain or sleet causes short-term outages, start by listing priority devices such as refrigerators, Wi-Fi routers, essential lighting and smartphones. A solar generator can combine battery storage with compatible solar charging, but its output and capacity still need to match the planned loads.
For short outages, most homes do not need to power everything at once. A practical first step is to cover the refrigerator, Wi-Fi router, lights, phones and a few small appliances. For that kind of essential-load backup, the EcoFlow TITAN 5000 Classic Whole-Home Backup Power can provide up to 4 kW of AC output and expandable storage from 5 kWh to 30 kWh, giving households room to start with basic coverage and scale up if longer winter outages are common in their area.
4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, and lighting all at once. 5–30kWh Expandable Capacity. Quiet enough for indoor use—quieter than a whisper.
Scale Battery Capacity for Higher Energy Needs
If your backup plan includes higher-draw loads, such as a furnace blower, multiple refrigerators or selected kitchen appliances, the EcoFlow TITAN 5000 Plus Whole-Home Backup Power offers 7.2 kW of battery output and up to 10 kW of total output with compatible PV. Its expandable 5–30 kWh capacity allows households to scale storage to their backup needs. For home backup integration, the TITAN 5000 Plus must be paired with a compatible 120V/240V Smart Home Panel 10, with installation completed by a qualified electrician in accordance with local electrical codes. Actual backup duration depends on connected loads, battery configuration and available charging.
7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 50% lower upfront cost. Smarter choice.
Keep Electrical Equipment in Dry, Safe Locations
Cold and damp conditions can reduce battery performance. Keep portable power stations, inverters and emergency kits in a dry location within the manufacturer’s permitted temperature range rather than an exposed shed or garage. Moderate storage temperatures can support more consistent charging and discharge performance, subject to the product manual.
Sleet is often a sign that the day is about to get complicated, especially when it arrives with wet snow, freezing rain or strong winds. Knowing what that word signals in a forecast, and what the pellets are doing to the road under the snow, is the difference between reacting to a bad afternoon and being ready for it, whether that means leaving work early, salting the front walk or having backup power charged and waiting.
Is Snow, Sleet, Or Freezing Rain Worse?
The relative danger depends on intensity, duration and local conditions. Freezing rain can glaze roads, wires and branches with load-bearing ice; sleet can create dense, slippery accumulation; and heavy or blowing snow can sharply reduce visibility and make travel hazardous.
At What Temperature Do You Get Sleet?
Sleet reaches the ground when surface air sits at or below 0°C (32°F) and the cold layer near the ground runs deep enough to refreeze the drops, provided warmer air aloft has melted the falling snow first. If that cold layer warms past freezing, what falls quickly turns to plain rain.
Is Sleet More Slippery Than Snow?
Sleet can be more slippery than fresh snow because round ice pellets move under tyres and boot soles. Once traffic compacts them, the layer may form a dense frozen crust with very little traction.
What Does Sleet Mean in a Forecast?
It means a layered storm is moving through, often along a warm front, with temperatures stacked so that precipitation melts and refreezes on the way down. On the ground, conditions are often somewhere between plain snow and freezing rain, with the road changing by the hour.
Is It Safe to Go Outside During Sleet?
On foot, brief outings are manageable with deep-treaded boots or slip-on ice cleats, but driving in sleet is hazardous and best left until the roads are treated. Wind-driven pellets can sting uncovered skin and severely narrow your peripheral vision.
Home Backup
