Finding a Current Power Outage Near You, Province by Province
The fastest way to confirm a current power outage near you is almost never a phone call, it's your utility's own live outage map. Nearly every Canadian utility now runs one, and knowing which map belongs to your area, and how to actually read it, saves a lot of time in the first confusing minutes after the lights go out. This guide covers how to check a current power outage near you by province, what to do while you wait, when a short outage turns into a multi-day one, and what actually causes most outages in Canada.
How to Check a Current Power Outage Near You Right Now
Most major Canadian utilities provide a live outage map, and most work the same way: search your address, see whether your area shows a confirmed outage, how many customers are affected, and an estimated time of restoration (ETR).
Province
Utility
Outage Map
British Columbia
BC Hydro
bchydro.com/power-outages
Alberta
EPCOR / FortisAlberta
outages.epcor.com / service.fortisalberta.com
Saskatchewan
SaskPower
saskpower.com/outages
Manitoba
Manitoba Hydro
hydro.mb.ca/outages
Ontario
Hydro One
hydroone.com/stormcentre
Quebec
Hydro-Québec
hydroquebec.com/power-outages
New Brunswick
NB Power
nbpower.com/outages
Nova Scotia
Nova Scotia Power
outagemap.nspower.ca
Newfoundland and Labrador
Newfoundland Power
newfoundlandpower.com/outages
A few provinces, Ontario and Alberta especially, are split between more than one distributor, so the map that covers your specific address depends on which utility actually owns the lines on your street, not just which province you live in. If you're in a city with a local distributor, Toronto Hydro or Hydro Ottawa, for example, that local map is often more precise than the provincial-level one, since it's built around a smaller service area with more granular reporting.
Most of these maps update on a short cycle, and checking your specific address is the fastest way to confirm whether it's a known outage or just your own breaker panel. An ETR is the utility's best estimate, not a guarantee, and it often shifts once a crew actually reaches the site and sees what caused the outage. Treat the first ETR you see as a starting point, not a fixed appointment.
Confirming the outage is step one. What you actually do in the meantime matters just as much.
What to Do While You Wait for Restoration
Check whether it's just your home or the whole neighbourhood first, since a tripped breaker has a different fix than a downed line down the street. If your neighbours still have power and the outage map shows nothing for your address, start with your own breaker panel before assuming it's a utility-side problem.
Once you've confirmed it's a real outage, a few basics make the wait safer and less stressful:
  • Use flashlights or battery lanterns instead of candles. Open flame indoors during a stressful, distracted evening is a genuine fire risk that's easy to avoid.
  • Unplug sensitive electronics. A power surge when service comes back can damage a TV, computer, or other equipment left plugged in.
  • Keep the fridge and freezer closed. Every time the door opens, cold air escapes and the food warms more quickly.
  • Check on anyone nearby who relies on powered medical equipment. A neighbour with a CPAP machine or an oxygen concentrator may need help sooner than they'd think to ask for it.
Working through a first few minutes checklist keeps the situation from feeling chaotic, especially if it happens after dark or during a storm.
There's a small irony to relying on an outage map: checking it repeatedly is exactly what drains the phone you need for updates, along with anything else running on battery in the house. That's where having something already charged and waiting makes the difference.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. •3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Minutes: Ready in Just 48 Minutes (0-80%) with Solar + Generator Dual Charging • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
That covers most outages, since the majority clear up within a few hours. Some don't.
When "a Few Hours" Turns Into "a Few Days"
Not every outage behaves the same way, and the cause usually tells you roughly what to expect before a utility ever gives you an ETR.
Cause
Typical Restoration Time
Blown fuse or single fallen line
2 to 3 hours
Downed pole or broken equipment
At least a day
Damaged substation
Several days
Major storm affecting a wide area
A week or more
Knowing which category an outage falls into, and why outages stretch longer than expected, helps set realistic expectations instead of refreshing the map every ten minutes. A widespread storm outage in particular tends to move slowly at first, since crews prioritize repairs that restore power to most customers before working through smaller, more isolated faults.
Once an outage crosses from hours into days, math changes. A fridge full of food, a sump pump, a home office, and a heating system all need power at once, not just a phone and a lamp. That's the point where a single portable unit stops being enough on its own.
EcoFlow DELTA Pro Ultra
• 7.2 kW–21.6 kW High Output: Delivers robust power capable of running entire households, including high-load appliances like central air conditioners. • 6 kWh–90 kWh Scalable Capacity: Expandable energy storage that provides continuous whole-home backup power for weeks during extended outages. •Smart Home Panel 2 Integration: Features automatic switchover, prolonged outage support, and intelligent scheduling to lower utility bills. •5 Versatile Charging Options: Offers multi-source recharging flexibility to ensure power redundancy under any condition. • Automatic Low-Temp Self-Heating: Built-in heating activates automatically below 0°C (32°F) to ensure uninterrupted battery performance in freezing climates.
Both scenarios come back to the same root causes, which is worth understanding before the next outage hits.
What Actually Causes Most Power Outages in Canada
Severe weather is the leading cause almost everywhere in the country, and the specific threat shifts by season and region:
  • High winds and ice storms bring down tree limbs and power lines, especially in older neighbourhoods with overhead wiring.
  • Lightning strikes can damage equipment directly or indirectly through a voltage spike sent down the line.
  • Heat waves push electricity demand past what parts of the grid can comfortably handle, sometimes triggering rolling brownouts even without any physical damage.
  • Winter storms and freezing rain add ice weight to lines and trees at the same time, often the single most damaging combination for a distribution network.
Aging infrastructure is the next biggest factor. Older cities in particular carry a meaningful share of equipment nearing the end of its service life, which fails more often under stress than newer, upgraded components. Vehicle accidents, construction damage, and animals or overgrown trees contacting power lines round out common causes of outages, alongside planned outages scheduled for maintenance and upgrades, which utilities usually announce well ahead of time.
Knowing the cause doesn't speed up the fix, but reporting what you're seeing does help crews prioritize.
Reporting an Outage and Signing Up for Alerts
current power outages near mecurrent power outages near me
Outage maps rely partly on customer reports, especially early on, before enough sensor data or automated alerts confirm the scope of the problem. A handful of reports from the same street can be what actually triggers a utility to dispatch a crew, rather than waiting on automated monitoring alone.
Most utilities offer a few ways to report and stay updated:
  • A phone line, usually the fastest option if you have no internet or app access.
  • An online form or outage map submission, useful when you can browse but can't easily make a call.
  • A text-based reporting option, offered by several major utilities for a quick report without navigating a website.
  • Account-linked text or email alerts, which push a restoration update the moment it's issued.
Reporting even a confirmed outage helps narrow down exactly where the problem starts and ends. Signing up for alerts tied to your account means hearing about a restoration update the moment it's issued, rather than needing to keep checking the map manually.
Checking a current power outage near you starts with your utility's live map, not a phone call, and most outages clear up within a few hours.
Know where your province's outage map lives, have a plan for the first few minutes, and have enough backup power on hand in case a short outage turns into a multi-day one. The right amount of backup, a portable unit for a short wait or a whole-home system for something longer, depends entirely on how long you expect to actually be without power, so it's worth deciding that before the next outage, not during it.
How do I check if there's a power outage in my area right now?
Go directly to your province's utility outage map and search your address. Most maps show whether your area has a confirmed outage, how many customers are affected, and an estimated restoration time.
Why does the outage map show no outages when my power is out?
Outage maps rely partly on customer reports early on, so your specific outage may not be logged yet. Reporting it directly to your utility helps confirm the scope faster.
How long do power outages usually last in Canada?
Most clear up within two to three hours. A downed pole can take at least a day, and a damaged substation or major storm can stretch into a week or more.
What's the fastest way to report a power outage?
Most utilities offer a phone line, an online form, and a text-based option. Reporting even a confirmed outage helps crews narrow down exactly where the problem starts and ends.
What should I do first when the power goes out?
Check whether it's just your home or the whole neighbourhood, use flashlights instead of candles, and unplug sensitive electronics so a surge doesn't damage them when power returns.
Can a portable power station keep my fridge running during an outage?
Yes, if it's sized correctly. A mid-capacity unit can run a fridge along with a few other essentials for a short-to-moderate outage, while a larger, whole-home-capable unit is better suited to a multi-day outage.
Power Outages
