Winter Storm Emergency Kit: Check What's Missing
Check your winter storm emergency kit by testing the supplies you'll rely on during a power outage. That means more than counting cans or seeing a full battery icon.
A flashlight with dead batteries leaves a gap, even beside a packed supply bin. So does food you can't open or eat without cooking.
Start with what you own, then check food, water, warmth, light, and updates for everyone at home. Keep home supplies separate from a bag you can carry if you must leave.
Find the Gaps in Your Winter Storm Emergency Kit
You don't need to replace a whole kit to make it more useful. Find the missing job first, then add, test, or move the item that fills it.
The Canadian emergency kit checklist starts with supplies for at least three days. Follow local advice, and allow for longer needs in remote or northern communities.
Build your emergency kit for a winter storm around the people who'll use it. A child's food needs, a pet's water, and a person's ability to lift containers all affect the plan.
Use this sample check to spot gaps in your own supplies:
Need | Check What You Have | Fix the Gap |
Water and meals | Enough for everyone, with food you can eat without cooking. | Add usable food, water, and a manual opener. |
Light | A working flashlight and matching spare batteries. | Test it and keep it within easy reach. |
Updates and contacts | A working battery or crank radio and printed contacts. | Find a local station and your utility's phone number. |
Phone power | A charged power bank and the right cable. | Plug in your phone to test both together. |
Warmth | Dry layers and bedding that fit each person. | Make them easy to reach and plan a safer place to stay. |
Personal needs | First aid, hygiene, prescriptions, infant supplies, and pet care. | Check current needs and ask about safe refills and storage. |
Write down what's missing before buying more. A wider list of household outage supplies can help you check for overlooked basics.
Fix essential gaps first. Extra gear won't help if you still lack drinking water or a working light.
Make the Power Plan Work With the Kit
Keep a flashlight, radio, and phone power bank ready on their own. A larger battery becomes useful when selected plug-in devices need power too.
Check the Load Before Choosing Equipment
List the devices you need, their running power, and any extra power needed to start. Check their plugs and voltage, then decide how long they must run before you can recharge.
Watts measure power at a given moment. Watt-hours describe stored energy, though some energy is lost when the battery supplies AC power. These checks are the basis for sizing backup power for essential devices.
A compatible fridge, light, and phone charger may form a useful home plan. Check their actual demand and leave a reserve rather than relying on a headline runtime. Powering your router won't restore an outside network that's down.
Choose Storage for the Devices You'll Keep On
If your checked devices need more energy between charges, the EcoFlow DELTA 3000 Gen4 Portable Power Station offers 3,072 Wh of nominal storage. Its total rated 120 V AC output is 3,600 W. Capacity is fixed, with no battery expansion, so size it for the plan you expect to use.
At about 26 kg, it's equipment to position safely at home. Check startup demand and each outlet's limit too. Its standard AC outlets are rated up to 20 A each, within the shared total.
If fewer devices need power, the EcoFlow DELTA 3 Max Portable Power Station (2048Wh) may meet the need with a smaller lift. It holds 2,048 Wh and supplies 2,400 W of total rated 120 V AC output. Its roughly 20.3 kg weight still belongs in the home plan, separate from your carried bag.
These are alternatives, not a connected pair. Neither directly supplies a 240 V heat pump or a whole hardwired home. Don't plug a power station into a wall outlet to feed household wiring.
Keep both dry and well-ventilated, with clear vents. Their charging range is 0°C to 45°C. Three days of supplies doesn't mean three days of battery power, and winter sun isn't a certain recharge source.
Check Meals, Water and Warmth Without Electricity
Check these needs even if your power plan is ready. A stocked cupboard can hide gaps when meals need heat or water you haven't stored.
Count Usable Water and Ready-to-Eat Meals
Count water by person and day. Health Canada's emergency food and water guidance lists 2 L per person daily, plus a suggested extra 2 L for cooking and cleaning.
For example, two people planning for three days need 12 L at the base amount. The suggested cooking and cleaning allowance adds another 12 L, making 24 L in this example. Pets, individual needs, and local advice can call for more.
Choose meals you can open and eat without power. Include a manual opener, utensils, and food suited to allergies or infant feeding needs. Try one planned meal while normal services are working to find missing tools.
A fridge on backup power still needs to stay at or below 4°C. Use a fridge thermometer, and check refrigerator food safety during an outage when deciding what to keep. Don't judge food safety from the battery display or move frozen food outdoors.
Prepare for Warmth Without Unsafe Substitutes
Set aside dry layers, socks, and warm bedding for each person. Check that smoke and carbon monoxide alarms work, including their backup batteries.
Choose a safer place to stay before the home becomes too cold. Ask how you'll get there and who can help if stairs or travel become difficult. A supply bin can't make an unsafe home suitable for staying.
Follow Public Safety Canada's outage advice, and use flashlights rather than candles. Never use a barbecue, camp stove, or outdoor burner indoors, or idle a vehicle in a garage.
Keep health planning separate from battery shopping. Ask a pharmacist about medicine storage and refills, and seek professional advice for health needs affected by an outage.
Make the Kit Easy to Find and Use
Store your winter storm emergency supplies where the people who need them can reach them. A full bin on a high shelf may be useless to someone who can't lift it.
Choose a dry spot, and divide heavy supplies into loads you can manage. Keep a light near your sleeping or main living area so you can find the rest. Store a separate grab-and-go bag for leaving, without blocking an exit.
Walk through the plan with your household while the lights work. Keep them on during the check, especially around stairs. Ask each person to:
Find a light and turn it on.
Locate food, water, and the manual opener.
Connect their phone to the stored cable and power bank.
Find the printed contacts and the radio station you've chosen.
Save the correct utility details when finding your local power outage information. Keep a paper copy in case the internet fails, with private records protected. Check that children can't reach unsafe tools or batteries.
Refresh the Kit When Supplies or Needs Change
Refill supplies after you use them, and review the kit before winter. Family changes, new devices, and worn cables can make last year's plan less useful.
The Canadian Red Cross kit guidance calls for a review at least once a year. Check food and water dates, clothing fit, contacts, and battery condition. Note the next review date where you'll see it.
Follow each battery maker's storage and maintenance steps. Readiness before use and long-term storage can call for different charge levels, so don't give every battery the same schedule.
Keep preparing the home for winter on a separate task list. Heating maintenance and weather sealing still matter, even with a well-stocked kit.
Fix One Useful Gap Before the Next Storm
Pick one useful fix today: test the flashlight, replace a missing cable, or add a meal you can eat cold. Each check makes your winter storm emergency kit easier to use.
If you find a genuine plug-in power gap, compare portable power stations for selected home devices against your loads and time between charges. Choose only what fits the need and has a safe place at home.
Is a store-bought winter emergency kit enough?
A store-bought kit needs a household check before you rely on it. Check food and water amounts, then add personal items the package lacks. Test the tools too, since a sealed box doesn't show that everything works.
Can I keep my winter kit in an unheated garage?
Only store items there if their instructions allow the temperatures they'll face. Freezing can affect water and other supplies, while batteries have separate storage and charging limits. Keep everyday essentials somewhere you can reach safely.
Does a 72-hour kit mean three days of battery power?
No. The kit's planning period doesn't set a battery's runtime. Runtime depends on how much energy your devices use, battery conditions, power losses, and when you can recharge. Check the electrical plan on its own.
How often should I check a winter emergency kit?
Check it at least yearly and before winter, then refill anything you use. Also review it when someone joins the household or their needs change. Follow expiry dates and each item's maintenance steps between full checks.
