BC Highway Snowfall Warnings: Check Before You Go
Before driving on major B.C. highways during a snowfall warning, check the official alert and road status. A weather warning doesn't tell you whether your whole route is open.
Rain on your driveway can become snow higher on the pass.
Check the trip through to your destination, including the time you'll return. Delay non-essential travel when conditions are poor, or officials advise against it.
Check the Warning and the Road Before Leaving
ECCC describes the expected weather threat, while DriveBC reports conditions and restrictions on the road. You need both to judge a planned trip.
Start with these two checks:
  1. Open ECCC weather information for the places and highway areas along your route. Read the full alert for its location, timing, expected impacts, and instructions. Check when it was issued or updated.
  2. Look up the whole trip on DriveBC. Check closures, delays, road conditions, and camera timestamps. Read the details for each affected section, rather than relying on a map icon.
 Diagram showing how an ECCC weather alert and DriveBC road status inform a trip delay decision. Diagram showing how an ECCC weather alert and DriveBC road status inform a trip delay decision.
For a BC snowfall warning, read beyond the colour. Alert colours reflect expected impacts and forecast confidence. Yellow doesn't mean a route is suitable, and a warning isn't always orange.
Keep the date of any news report in view, too. A shared headline may describe an older storm. The current official alert is the place to check the weather affecting your plans.
Follow closures and official advice to avoid travel. If conditions are poor, postpone a non-essential drive. One clear camera view can't confirm the rest of a mountain route.
Understanding what a snowfall warning means can help with the wording. Your departure decision still depends on current weather, road restrictions, and your ability to handle the conditions.
Use a Travel Delay to Finish the Home Plan
A postponed trip may leave you at home longer than planned. If winter weather also interrupts power, household backup is a separate need.
Include lights, food, warmth, and charged phones in your winter home preparation. Know who you'll check in with and where you could stay if the home loses safe heat. A battery doesn't replace that plan.
Cover a Larger Checked Device List
A fridge, a task light, and communications equipment can form a limited home backup plan. Check the fridge's normal running power and the extra power it needs to start.
The EcoFlow DELTA 3000 Gen4 Portable Power Station stores 3,072 Wh of energy. Its 3,600 W total rated 120 V AC output must cover your devices' running and starting demands.
1. Longest Runtime: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power. 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. 4. UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. 5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Watts measure power at one time, while watt-hours measure stored energy. When sizing backup power for essential devices, check both the load and how long you need it. Actual runtime also depends on cycling devices and energy losses.
The total output is shared, and the ordinary AC outlets each have a 20 A limit.
The 3000 model doesn't support battery expansion. At about 26 kg, it also needs a lifting plan and a dry place with clear vents. Its 120 V outlets don't directly supply 240 V appliances or connect it to hardwired home circuits.
Keep the Setup Smaller When Demand Is Lower
If your measured needs are lower, extra storage may add weight you don't need.
Consider the EcoFlow DELTA 3 Max Portable Power Station (2048Wh) for that smaller home plan. It pairs 2,048 Wh of storage with 2,400 W total rated 120 V AC output.
EcoFlow DELTA 3 Max (2048Wh)
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. 2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. 3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport. 5. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
At about 20.3 kg, the Max is lighter than the Gen4 here, but it stores less energy. Check total demand and each outlet's limit before connecting devices. Choose between the models based on the job, rather than buying both by default.
Keep either unit dry and ventilated, and charge within its 0 °C to 45 °C range. Neither is a snow-exposed roadside supply or a car-heating plan.
Check Every Part of the Mountain Route
The weather where you start doesn't describe every pass or the return journey. For a snowfall warning in BC, check which sections it covers and when you'll reach them.
Break a longer drive into smaller checks. These corridors are examples to inspect, not a list of roads currently under warning or suggested detours:
Example Corridor
What to Check
Highway 5 Between Hope and Kamloops
Relevant Coquihalla sections, pass conditions, restrictions, and your travel period.
Highway 3 Between Hope and Princeton
The alert's exact area, plus road conditions, incidents, and restrictions along the trip.
Highway 1 Through Eagle and Rogers Passes
Both pass areas, closure information, and the rest of the route beyond them.
Highway 97C Between Merritt and Kelowna
Conditions on the connector and how the timing fits your outward and return trips.
A lower valley may have rain while a higher pass has snow. Don't carry a city's forecast across the whole route, or assume one clear stretch represents the next.
Read camera timestamps as well as the view. A useful image shows one place at one time. It doesn't show every bend, shaded section, or change in elevation ahead.
If your route closes, follow official directions. A navigation app's side-road suggestion isn't proof of a suitable winter alternative.
Tell someone your intended route and expected check-in time. If the route or departure time changes, update that person before leaving. Build the return journey into the same plan, since conditions may change while you're away.
Prepare the Vehicle Without Treating Gear as Permission
Suitable tires, a maintained vehicle, and a delay kit solve different problems. None overrides a closure or official advice to avoid travel.
Match the Tires to the Route Rules
Check the BC winter tire and chain route guidance for your vehicle and route. Requirements apply on most designated routes from October 1 to April 30. Some end on March 31, so read the posted signs and route details.
For a standard passenger vehicle, the legal winter-tire definition requires at least 3.5 mm of tread. The tire must carry either the M+S marking or the three-peaked mountain/snowflake symbol.
Meeting that minimum doesn't settle whether you're equipped for the forecast. BC recommends mountain/snowflake tires for cold-weather driving. All-wheel drive doesn't remove the tire requirement or guarantee braking grip. Commercial vehicles have separate chain rules.
Pack for a Delay, Not Just the Drive Time
The winter driving advice from ICBC includes vehicle preparation and an emergency kit. Check lights, wipers, washer fluid, and tire condition before the trip. Plan fuel or vehicle charging along the intended route, with room for delays.
Pack supplies for the people travelling with you:
  • Warm clothing, gloves, and a blanket.
  • Food, water, and any personal essentials.
  • A flashlight and a first-aid kit.
  • An ice scraper, a shovel, and suitable vehicle supplies.
  • A charged phone and a small power bank.
Adapt a snowstorm emergency kit to your passengers and forecast, rather than packing only for the normal drive time. Keep the two home power stations in their indoor role. A phone power bank is a different, smaller road-kit item.
 Illustration of winter clothing, food, water, and vehicle supplies packed for a delayed trip. Illustration of winter clothing, food, water, and vehicle supplies packed for a delayed trip.
Recheck Before Starting the Delayed Trip
An earlier road report can't settle a later departure. If a BC snow warning changes, refresh the whole route before reconsidering the trip.
Reopen the official alert, revisit DriveBC restrictions, and check the update times. Confirm the vehicle is ready and your contact knows the revised plan. Include the expected return conditions, not just the next hour's weather.
Save useful information before entering an area with weak mobile service. A saved map or screenshot can help you recall a route, but it isn't a live update. If you can't confirm current conditions, delay non-essential travel.
If home power also fails, finding the current local power outage starts with identifying your serving utility. Use its current report when changing plans. Don't assume every BC address has the same provider or that a restoration estimate is a promise.
 Illustration of a dry home planning area with a DELTA 3000 Gen4 and a phone on charge. Illustration of a dry home planning area with a DELTA 3000 Gen4 and a phone on charge.
Leave Only When the Route and Plan Are Ready
Before committing to a drive, recheck both official services against your route and travel times. Tires and supplies matter, but they don't turn poor conditions into suitable ones. Keep the option to delay open.
For a separate household backup need, compare portable power stations for selected home devices after checking energy, output, and connection needs. Choose that equipment for the home plan, while letting current weather and road information guide the trip.
Does a snowfall warning mean the highway is closed?
A snowfall warning doesn't mean a highway is closed. Check that section on DriveBC, and remember that an open road can still have conditions that make delaying wiser.
How much snow triggers a snowfall warning in BC?
There isn't one province-wide centimetre cutoff you can use to judge warnings. ECCC considers impacts and forecast confidence, so read the alert's location, timing, expected conditions, and instructions.
Does all-wheel drive replace winter tires?
All-wheel drive doesn't replace the winter-tire requirements on designated BC routes. Check tire markings, tread depth, and route signs, without assuming the drive system guarantees grip when you brake.
Can I leave as soon as a snowfall warning ends?
You shouldn't leave based only on the warning ending, since road restrictions and poor conditions can remain. Recheck DriveBC, the whole route's forecast, and current official instructions before choosing a departure time.
