Vancouver Winter Weather: Temperatures, Snow & Rain
Overall, Vancouver has relatively mild, wet winters, with frequent rainfall, cool temperatures, overcast skies and occasional snowfall. Extended periods of severe cold are less common than in many inland parts of Canada, although cold snaps can still occur.
The main reason for this is due to its coastal location. The Pacific Ocean keeps temperatures milder and the city is frequently affected by moist weather systems moving in from the Pacific.
Whilst it can be quite mild, there can be issues with the weather. The rain can cause issues with getting to your destination; you may find it difficult to go outside and your home may feel damp and cold. Strong storms can also cause issues with trees and power lines falling. This guide will tell you everything you need to know about Vancouver winter weather, including what to wear, how to prepare your home for it, and what to expect from December to February.
What Is Vancouver Winter Weather Like?
Typically, Vancouver in winter weather is quite mild during the day with lots of rain. However, there can be some freezing weather, although this will often only last for short periods of time.
Compared to colder continental climates, Vancouver is quite different. Many other areas of Canada will experience snowy conditions and very cold temperatures for months. However, in Vancouver, you will typically get grey skies, drizzly weather and constant rain. Snow isn’t really experienced in the city itself but more in the surrounding mountains.
How Cold Does Vancouver Get in Winter?
During winter, the temperature in vancouver canada winter weather will typically be between 5-8°C during the day. At night, the temperature will often be around 0-3°C depending on the month and area within the region. The coldest months tend to be December and January.
Occasionally there can be some sub-zero temperatures due to cold snaps, but overall these extreme colds aren’t as typical as in many inland cities. This is just a general guide to give you an idea of what the climate is like. Check for the latest forecast.
Does It Snow in Vancouver During Winter?
Yes, Vancouver does get snow in winter, although snowfall is usually limited in the city’s lower-elevation areas. Often the lower areas will receive rain during winter. There is usually little snow in the city.
Depending on where you are in the region, you may receive very little snow in the city centre. Higher areas will receive more snow and the North Shore mountains can receive a lot of snow. However, even a little snow can cause problems. Roadways, hills and pavements can become very slippery due to the freezing temperatures. As the city isn’t set up for heavy snowfall, there can be issues with delays.
Why Is Vancouver So Rainy in Winter?
There are often wet weather systems coming from the Pacific. These bring moist air to the coast of British Columbia. The mountains help to create rain by pulling the moisture out of the air. Winter is the wettest time of year, with typically around 150-165 mm of rainfall in December. Most days will receive rainfall.
The constant rain, cloud and mild temperatures make it quite cool. Heavy and constant rain can cause issues with visibility and standing water on the roads.
How to Prepare for Vancouver’s Rainy and Snowy Winter Weather
Vancouver’s winter weather can be wet and unpredictable. However, there can also be snow, freezing temperatures, strong winds and severe weather. A little preparation will help you know what to wear, prepare for travelling and keep your home running.
What Should You Wear in Vancouver During Winter?
The most important thing to wear is something that will keep you dry. As it is quite rainy, you will want to wear a waterproof coat and waterproof shoes. Gloves, a scarf, and a hat will also help keep you warm.
Wear layers so you can easily take them off and put them on depending on the temperature.
How Do Winter Rain, Snow and Ice Affect Travel?
Heavy rain can cause visibility issues and standing water. This can cause delays, so allow more time. Occasionally, there will be snow and freezing temperatures, causing slippery pavements, icy roads and delays with transport.
Check the weather forecast, road conditions and transport updates.
How to Keep Your Home Powered During Vancouver Winter Storms?
Occasionally, Vancouver in winter weather can experience strong winds, heavy rain, snow and freezing temperatures, causing power cuts. Over half of the outages on the BC Hydro grid are due to tree fall onto electrical equipment. Storms with strong winds are often a cause. Wind storms in the region have caused gusts of around 90 km/h.
Having backup power can help keep your compatible household appliances, communication devices and essential electronics running. It is important to know the limitations of portable power stations. They won’t stop severe weather and can’t guarantee full power to your whole house. For more information on preparing for the future, check out our power outage preparation guide. Check out our range of portable power stations and solar generators.
Portable Backup Power for Essential Appliances During Short Winter Outages
Imagine having a power cut during a storm. Your fridge stops working, your Wi-Fi is down and you’re left with candles and a dying phone.
If you’re looking for a portable power station to keep your compatible essential household appliances running, the EcoFlow DELTA 3000 Gen4 is a great choice. With a 3,072Wh battery capacity and 3,600W continuous AC output, you can keep certain items running in your home. How much power your appliance uses will determine how much you can run. It’s important to keep your fridge running. Find out why in our guide.
Higher-Capacity Home Backup for Extended Winter Storm Outages
During a heavy windstorm or large winter weather event, you may need to power your fridge, lights, communication devices and some heating appliances for an extended period.
The EcoFlow DELTA Pro Ultra has been designed to provide more powerful backup solutions for your home. With the correct set-up, you can run compatible fridges, lights, communication devices and some electric heating appliances. How long you can run these will depend on how much load you’re putting on the system, how much battery you have and how you’ve set it up.
However, if you want to power your heating appliances using a portable power station, then you’ll need to ensure that you have the correct electrical set-up. All home circuits should be backed up using an approved set-up that may require a professional to install.
How Can Homeowners Prepare for Winter Storms?
Clean out your gutters and drain areas to allow heavy rainwater to flow away.
Ensure weather stripping around doors and windows is in good condition.
Get your heating checked over.
As heavy winds and storms can cause issues with the electricity supply, it’s a good idea to have torches, emergency food, water, communication devices and backup charging devices to hand.
Vancouver Winter Weather by Month: December, January and February
As winter progresses, there will be some changes in the weather. December is the wettest and darkest month. January will usually be the coldest. February begins to get brighter with a bit more daylight and slightly warmer temperatures. Below is a brief comparison of what to expect in downtown Vancouver:
Month | Average High | Average Rain Days | Snow Outlook (Downtown) |
December | ~7°C | ~19 | Occasional, light |
January | ~7°C | ~18 | Occasional, light |
February | ~8°C | ~16 | Occasional, light |
Note: This is a general guide to average temperatures and rainfall in downtown Vancouver over a long period of time. Other areas such as the airport will vary.
Vancouver Weather in December
December is a cool, wet month with short days. The shortest day of the year is around 8 hours, meaning there won’t be much sun. You can expect cloudy or rainy conditions. Occasionally, you could see some snow and freezing temperatures.
Vancouver Weather in January
January is usually one of the coldest months of the year in Vancouver. There’s frequent rain and the occasional snowfall. Mornings can be quite chilly with freezing temperatures and wet roads. Winter storms can cause strong winds.
Vancouver Weather in February
February can still be quite cool and wet. However, days begin to get longer as we head into spring. There can still be some snow, frost and short periods of cold air. Each winter can vary quite a bit.
Overall, Vancouver has mild, wet and cloudy winters. Temperatures will usually hover around freezing or above. However, you can still get some snow, ice and occasionally severe storms. It’s a good idea to wear waterproof clothing and take care when travelling. The EcoFlow DELTA 3000 Gen4 provides portable home backup and the EcoFlow DELTA Pro Ultra provides more powerful backup during winter outages. Take a look at EcoFlow Canada’s winter emergency power solutions.
Typically, temperatures will be around 5-8°C. Nighttime temperatures will often be around 0-3°C. Occasionally, temperatures will drop below freezing for short periods of time during cold air outbreaks. However, it’s rare to get long periods of extreme cold.
Does Vancouver Get Snow in Winter?
Yes, however, it doesn’t snow very often in lower areas. Most of the precipitation will fall as rain. Higher areas will get more snow. Even light snow can cause slippery roads.
What Is the Coldest Month in Vancouver?
December and January are typically the coldest months. January will often be slightly colder. There isn’t much difference between the winter months, so it really depends on the weather patterns.
Is Vancouver Rainy During Winter?
Yes! Winter is the wettest time of year. You’ll get rain most days in December and January. Expect cloudy and damp conditions.
Wear waterproof clothing, waterproof shoes and layer up. If it’s colder, wear gloves and a scarf. Layering up will help you to adapt to the temperature changes between outside and inside.
Are Power Outages Common During Vancouver Winter Storms?
Power cuts can occur during heavy winds, rain, or snow, causing trees to fall and damage power lines. However, it’s not every day. It is common enough to have emergency items and a backup power plan.
