Preparing a Home for Winter: How to Get Your Home Ready
There’s a weekend in every Canadian autumn when the furnace kicks on for the first time and the house holds its breath. That’s the weekend to find out whether it can take what’s coming. Cold pushes heating demand up, and a frozen pipe, a leaky roof or a dead grid costs far more in February than in October. The rest of this covers the heating system, the insulation, the plumbing and the roof, then what to keep handy when the lights go out.
Why Should You Prepare Your Home for Winter?
If you are deciding how to prepare a home for winter, start before sustained freezing weather. Early checks can reveal air leaks and worn components while exterior caulk can still cure within its rated temperature range. Booking HVAC service earlier in the season may also provide more scheduling options. Include a portable power station in the outage plan only after identifying the devices and runtime your household needs.
Prepare for Higher Winter Energy Demand
Natural Resources Canada reports that space heating accounts for about 63.6% of the energy used in an average Canadian home. Colder weather, air leakage and insufficient insulation can increase heating demand and equipment runtime. Sealing accessible gaps before winter can reduce uncontrolled air leakage and help retain conditioned air.
Be Ready for Winter Power Outages
Ice storms and heavy wet snow can bring branches down onto power lines. A winter outage may also interrupt electrically controlled gas furnaces and electric baseboards, while the rate of indoor cooling depends on insulation, outdoor temperature and wind. Check your utility’s current power outage map, then follow an outage plan that prioritizes heat, medical needs and communication.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
How to Prepare Your Home for Winter
Start with the heating system, doors and windows, insulation, plumbing and roof. The checks below help separate routine homeowner tasks from work that may require a qualified professional. A power station can support selected electrical loads during an outage, but it does not replace weather sealing, plumbing protection or equipment maintenance.
AreaQuick Action RequiredWhy It Matters
Heating SystemSwap filters; schedule a professional tune-upPrevents mid-freeze breakdowns & maintains air quality
Windows & DoorsApply weatherstripping and exterior caulkReduces heat loss and drafts
Attic & BasementSeal rim joists and boost loose-fill insulationSlows heat loss and deters ice dam formation
PlumbingShut off exterior valves and wrap exposed indoor pipesAvoids frozen, burst pipes and water damage
Roof & GuttersClear dead leaves and check for loose shinglesLets melting snow drain off the roof
Inspect the Heating System
Nobody wants to phone for furnace repairs in the middle of a January cold snap. Start with the filter: once it’s loaded up, airflow drops, efficiency follows and the blower strains. Past that, a certified HVAC technician can clean the burners, go over the heat exchanger and make sure the thermostat reads the room accurately. That visit costs a fraction of an emergency call, and it’s what keeps the heat on through the worst stretch of the winter.
Seal Doors and Windows
A gap at a door or a window works like a small chimney, pulling warm air out along the top and feeding cold air in along the floor. A lit stick of incense held near the frame shows you where it’s worst: when the smoke streams sideways, you’ve found one. Worn weatherstripping on an exterior door takes about ten minutes to replace, and a bead of paintable caulk around the casing handles most of the rest. On older single- or double-pane windows, heat-shrink film tightened with a hair dryer gives you another layer of still air.
Check Attic and Basement Insulation
Warm air and air leakage can move heat toward the attic. Check insulation depth and condition, then compare the effective R-value with guidance for your climate zone and local building requirements; the required depth varies by material. In the basement, inspect rim joists above the foundation for accessible air leaks and insulation gaps that may contribute to cold floors.
Protect Pipes From Freezing
Frozen pipes can cause significant water damage, especially in concealed or unheated areas. Before freezing weather, disconnect hoses and follow the property’s plumbing instructions for draining outdoor taps and closing interior shutoff valves. Insulate accessible pipes along exterior walls, in crawl spaces or in other unheated areas, and ask a plumber about vulnerable sections you cannot inspect safely.
Clean Gutters and Inspect the Roof
Leaves left in the eavestroughs turn into a frozen sludge that blocks the only route melting snow has off your roof. Cleaning them out before the first hard freeze keeps the meltwater running to the downspout instead of backing up under the shingles. Shingles that are curling, cracked or missing are easy to pick out from the ground with binoculars, and they need fixing before wind-driven snow finds its way into the attic.
EcoFlow TITAN 5000 Plus Whole-Home Backup PowerEcoFlow TITAN 5000 Plus Whole-Home Backup Power
How to Prepare for a Winter Power Outage
The answer to how to prepare your home for a winter storm begins with essential loads. List the devices that must keep running, record their starting and operating wattage, and estimate how many hours they may be needed. Those figures help size a home battery backup without assuming every circuit must run at once.
Identify Essential Home Devices
Nobody decides well fumbling around a dark hallway, so make the list while you can still read the panel. Keep it to safety and the basics:
  • Food Preservation: The fridge and freezer are what stand between a few hours without power and a few hundred dollars of spoiled food, and they only need to run part of the time.
  • Connectivity & Light: A modem, your phones and a couple of LED lamps let you reach people and move around safely.
  • Other Essential Equipment: Essential household equipment, a sump pump during a January thaw, and continuous power for hardwired smoke and carbon monoxide alarms.
Choose Backup Power for Short Outages
For shorter winter outages, the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) provides 2,048Wh of capacity and 3,000W of rated AC output for compatible refrigerators, routers, computers and lighting. Confirm each device’s starting and running wattage, and estimate runtime from the combined load, temperature and conversion losses. As a battery system, it produces no combustion exhaust during operation.
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Prepare Backup Power for Extended Outages
Multi-day winter outages require more careful planning because some household equipment may need power until utility service returns. The EcoFlow TITAN 5000 Plus Whole-Home Backup Power provides 7.2kW of battery output and can support selected 120V and 240V loads when used with compatible home-integration equipment. This allows households to plan backup power around winter priorities, from refrigeration and communications to a sump pump or other higher-power equipment. Storage starts at 5kWh and can expand up to 30kWh. Adding battery capacity provides more stored energy for a longer outage, while keeping fewer loads running—or running some only when needed—helps that energy last longer.
EcoFlow TITAN 5000 Plus delivers 7.2kW of battery output and up to 10kW of total output with compatible PV. With 5–30kWh expandable capacity, up to 8kW of solar input through dual MPPTs, and X-Fusion 2.0, it supports flexible whole-home backup and everyday solar energy use when paired with compatible home-integration equipment.
What Should Be in a Winter Home Emergency Kit?
Canada’s emergency preparedness guidance recommends supplies for at least the first 72 hours. Store water, non-perishable food, lighting, warm clothing and essential medication together in an accessible location, and review expiry dates and batteries before winter.
Flashlights and Batteries
Your phone’s flashlight will get you to the breaker panel, but lean on it for hours and it drains the one battery you can least afford to lose. Keep high-lumen LED flashlights or headlamps in a drawer on every floor, with spare alkaline or rechargeable lithium batteries alongside, and go through the expiry dates once a year.
Battery-Powered Carbon Monoxide Alarms
Carbon monoxide has no smell or colour, and fuel-burning equipment can create a serious risk during an outage. Install certified CO alarms on every level, especially near sleeping areas, and test them before winter. Never operate a fuel-burning generator, barbecue or camp stove inside a home, basement, garage or other enclosed space.
Warm Clothing and Blankets
Once the house itself starts to cool, the body becomes the thing you’re heating. Heavy wool blankets, a thermal sleeping bag, base layers that wick, wool socks, a toque and insulated gloves packed in a dry tub will keep you warmer than one thick coat. Layers work because of the air trapped between them.
Food and Drinking Water
A hard freeze or outage can interrupt water service. Canada’s emergency kit guidance calls for at least two litres of drinking water per person per day, plus two additional litres per person per day for cooking and cleaning. Store it in food-grade containers where it will not freeze, together with at least three days of food that needs no refrigeration and little or no cooking.
First-Aid Supplies
Working in dim light or handling damaged hardware can cause cuts and burns. Stock bandages, antiseptic wipes, burn care, pain relievers and cold compresses. For essential prescriptions, follow the refill, storage and emergency-supply advice provided by the prescribing professional or pharmacist.
Most of these steps are easier before the first sustained freeze: service the heating system, seal accessible drafts, protect exposed pipes and clear the eavestroughs. Then check emergency supplies and build a backup power plan around the loads your household needs. Schedule professional work early enough to allow for local demand and weather.
When Should You Winterize Your Home?
Early to mid-autumn, somewhere between late September and late October, before the ground starts freezing overnight. You can still work outside then: caulk sets, an hour on a ladder is merely unpleasant, the leaves in the eavestroughs haven’t frozen into a block, and furnace technicians still have room in the schedule.
Should I Leave the Heating on All Night in Freezing Weather?
Keep enough heat on to protect occupants and plumbing, but the appropriate overnight setting depends on the home, heating system, outdoor conditions and pipe locations. Use a modest setback only if the system can recover safely and vulnerable plumbing remains warm.
How Do You Winterize a House That Will Be Vacant?
For a vacant house, follow the insurer’s requirements and have a qualified professional advise whether the plumbing should be drained and protected with an approved non-toxic product. Maintain the required heat level and arrange regular checks or monitored temperature alerts.
What Is the Best House Temperature in Winter?
Many households find about 20°C to 21°C comfortable while rooms are occupied, with a modest setback during sleep or absences. The appropriate setting varies with health needs, humidity, insulation, heating equipment and the location of plumbing.
When Should You Worry About Ice Dams?
When a thick ridge of ice builds up along the eaves and heavy icicles hang there and stay, that’s the moment to act. It means warm air is getting into the attic and melting the snow from underneath, and the water refreezes as soon as it hits the cold overhang past the heated part of the house. The ice then backs water up under the shingles, and the damage shows up on a ceiling inside, often nowhere near the eaves.
Home Backup
