How Off-Grid Living With Solar Panels Actually Works in Canada
Most off-grid solar guides size a system for a sunny July afternoon. A Canadian winter doesn't work that way. This guide covers how the parts of an off-grid system fit together. It covers how to size a battery bank and panel array for winter. It covers when to scale up to a whole-home setup. It also covers what the system actually costs once most rebates don't apply.
How an Off-Grid Solar System Actually Works
An off-grid system has four core parts. Panels generate DC power. A charge controller regulates it. A battery bank stores it. An inverter turns it into the AC power a home actually runs on.
The real difference from a grid-tied rooftop system shows up when production drops. There's no utility to draw from. There's no net metering to fall back on. The battery bank alone has to carry the home through the gap.
Matching each part correctly is where most off-grid systems go wrong. This happens more often than a problem with the panels themselves. Our guide on going solar array to inverter walks through how each piece connects.
Getting the components right only matters if the battery bank behind them fits the season that matters most.
Sizing a Battery Bank That Gets You Through a Canadian Winter
Start with your daily energy use in watt-hours. Add roughly 20 percent overhead for inefficiencies. That's the baseline your battery bank has to cover on a low-production day, not an average one.
Winter is the real constraint, and it doesn't hit every part of Canada the same way. Peak sun hours drop a lot in winter, but by how much depends entirely on where you live. A property in southern Ontario sees very different winter sun than one in northern Manitoba or coastal British Columbia. Natural Resources Canada's photovoltaic potential and solar resource maps break this down by month for thousands of municipalities across the country. Look up your own location and month before sizing anything. A single national number, whether it's an average or a worst case, will steer you wrong in either direction depending on where you actually are.
A cabin-scale setup usually starts small and grows from there. Our daily energy needs framework is worth following for any off-grid property, not just a weekend cabin.
For a cabin or smaller off-grid property, a portable power station can combine battery storage and an inverter in one unit.
The EcoFlow DELTA 3 Ultra Plus is one option for portable backup and smaller-scale off-grid power, with solar input and expandable capacity. It can simplify a smaller setup, but it should not be treated as a substitute for a purpose-built whole-home off-grid electrical system. That means less gear to buy, wire, and troubleshoot when something goes wrong in January.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•3600 W Powerful Output: 7,200 W surge output. With X-Boost™ mode, supports heavy-duty appliances up to 4,600 W such as clothing steamers, electric dryers, lawnmowers, and electric frying pans. •Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most. • 3-11 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • 6 Ways to charge, Ready in Just 48 Mins: Ready in Just 48 Mins (0-80%) with Solar + Generator Dual Charging
That covers a cabin or a smaller home well. A full-time, year-round household needs a different scale entirely.
Scaling Up to a Full-Time, Whole-Home Off-Grid Setup
Daily electricity use varies enormously from one household to the next. Home size, insulation, heating method, climate zone, and how many people live there all change the number. There's no single "average Canadian home" figure worth building a system around.
The better approach is working out your own load, room by room. Add up your major appliances and their running watts. Then check their starting watts too. A well pump or a furnace fan can draw several times its running wattage the moment it switches on, and that spike matters just as much as the steady draw. Our appliance loads room by room guide walks through this process step by step, using your actual appliances rather than a generic estimate.
Once you have that number, you'll know whether a single portable unit covers your home or not. This is the point where most off-grid households move from one portable unit to a stacked, whole-home system. That system needs to run everything at once, not just the essentials.
A battery bank alone can't generate power. It only stores what the panels produce.
•High-Input Solar Charging: Delivers up to 400 W of high-capacity solar input for significantly faster recharge times. •Up to 23% Conversion Rate: Utilizes premium solar cells to capture maximum sunlight and convert energy efficiently. • Durable & Weather-Resistant: Built with multi-layered protective materials and an IP68 waterproof rating for rugged outdoor use. •Self-Supporting Adjustable Design: Includes a protective carrying case that doubles as a kickstand to optimize sunlight angles. • Compact One-Piece Folding Frame: Folds down cleanly for convenient transport and seamless storage. •Included XT60 Cable: Comes bundled with the standard solar-to-XT60 charging cable for immediate plug-and-play setup.
The battery and the panel are both sized in theory now. What's left is matching the array to your specific winter, not a summer afternoon.
Sizing Your Solar Panel Array for Winter, Not Summer
Size your array against your local winter peak sun hours. Don't use the yearly average. A system built for a sunny August day will fall short in December. It will fall short in January too.
Peak sun hours vary a lot by location. This is where guessing gets expensive. Natural Resources Canada publishes solar resource maps for the whole country. The data covers a roughly 2km grid. It covers thousands of municipalities. It breaks the numbers out month by month. Check the actual numbers for your property. Do this before buying panels, not after.
Once you know your location's monthly numbers, compare them to your own annual electricity use. Don't use a borrowed national figure. Our guide to sizing a system to your specific home walks through this. It shows how installers handle the swing between summer surplus and winter shortfall. It uses your household's real numbers, not an assumed average.
Even a correctly sized system comes with real costs. Not all the usual incentives apply once you're off the grid.
What Off-Grid Solar Costs, and the Mistakes That Blow the Budget
What Off-Grid Solar Costs, and the Mistakes That Blow the BudgetWhat Off-Grid Solar Costs, and the Mistakes That Blow the Budget
A full off-grid system, battery bank, inverter, and a winter-sized panel array together, typically runs into five figures. This happens once everything is sized for the coldest months rather than the sunniest ones.
Most federal and provincial solar programs are built around net metering and grid connection. An off-grid property usually doesn't qualify for the same rebates as a grid-tied home. There are only a handful of regional exceptions for remote communities.
The most common budget-blowing mistake is sizing the whole system off a summer estimate. Then January arrives, and the panels produce a fraction of what the household actually needs.
A close second is skipping a backup plan entirely. Even a well-sized battery bank can run short after several consecutive cloudy days. A generator or a secondary charging option is what keeps that stretch from becoming a real problem.
An off-grid solar system lives or dies on winter sizing, not summer output. The battery bank usually matters more than the panel count.
Size the battery for a low-production week specific to your own region. Size the array against your local winter peak sun hours, checked directly through Natural Resources Canada's own tools, not a single national average. Budget for the system without counting on a rebate that likely doesn't apply. The DELTA 3 Ultra Plus and 400W Portable Solar Panel linked above are a solid starting point for a cabin or smaller off-grid home, scaled up from there based on your own numbers.
Can a home run entirely on solar panels off-grid in Canada?
Yes, if the battery bank and panel array are sized for your specific location's winter production, not a summer estimate or a national average.
How many solar panels do I need to live off-grid?
It depends on your household's actual daily electricity use and your location's winter peak sun hours. Check Natural Resources Canada's solar resource maps for your specific area, then size the array against that number.
How much does an off-grid solar system cost in Canada?
A full system, battery bank, inverter, and a winter-sized panel array together, typically runs into five figures once sized for the coldest months.
Do off-grid solar systems qualify for government rebates?
Usually not. Most federal and provincial programs are built around net metering and a grid connection, so an off-grid property often doesn't qualify, aside from a few regional exceptions for remote communities.
What size battery bank do I need for a Canadian winter?
Start with your daily energy use in watt-hours, add about 20 percent overhead, and size that against your own location's low-production winter days rather than an average day.
Can I add a generator as backup to an off-grid solar system?
Yes. A generator or a secondary charging option covers the gap after several consecutive cloudy days, which even a well-sized battery bank can struggle with on its own.
