Solar Panels for a House in Quebec: What to Plan
Planning solar panels for a house starts with your electricity use, roof and project goal. In Quebec, reducing grid purchases and preparing for an outage require different choices.
Panels produce electricity when sunlight is available, while batteries store energy for later use. Keeping household circuits powered during an outage also needs a suitable connection and backup design.
Bring twelve months of electricity use and a clear goal to an installer before choosing equipment.
What Should Solar Panels Do for Your House?
Choose what you want home solar panels to do before comparing equipment. Lowering your bill, backing up selected loads and supplying an off-grid property call for different plans.
Photovoltaic panels make direct-current electricity, or DC. An inverter converts it to the alternating current, or AC, used by household appliances. Batteries can store some of that energy instead of using it immediately.
Quebec's solar-energy information explains why production changes through the day and across seasons. Solar water-heating panels do a different job and aren't part of this electricity plan.
Compare your main goal with the design it needs.
Goal
What to Plan
Main Limit
Reduce Grid Purchases
A solar array with approved utility connection and credit arrangements.
A conventional rooftop system stops during a grid outage.
Back Up Selected Loads
Storage, suitable output and a properly installed backup connection.
Battery energy and the loads running together limit coverage.
Supply an Off-Grid Property
Seasonal generation, storage and a plan for energy shortfalls.
An annual energy total can't prove winter independence.
Understanding the components of a home solar array helps you compare complete systems. The price of an individual panel does not represent the total cost of an installed system.
Do You Need Storage for Solar Backup?
Storage is optional if your main aim is to reduce grid purchases. For outage backup, list the loads you need, their startup demands and how long they must run.
Capacity measures stored energy, while output limits the power you can use at once. Both affect a backup plan, along with the voltage your equipment needs.
More Direct Solar Input With TITAN Plus
A direct-solar configuration allows the installer to design the solar array and battery system together. With the EcoFlow TITAN 5000 Plus, that plan can use two solar inputs, accepting up to 8 kW total and 4 kW each.
Its battery starts at 5 kWh and supplies 7.2 kW of battery-only output. Your installer must also check solar voltage and current, since the input rating doesn't guarantee charging power.
1. 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. 2. 100% Whole-Home Savings. Save up to $1,100 per year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
Selected-Circuit Storage With TITAN 5000
An existing rooftop system needs a compatibility check before you add storage. The EcoFlow TITAN 5000 also starts at 5 kWh and supplies 7.2 kW for compatible 120 V/240 V loads.
Connecting suitable rooftop solar on the household's AC side requires Smart Home Panel 10 (240 V) and a CT sensor for monitoring. Your installer must confirm the inverter and complete setup.
EcoFlow TITAN 5000
1. 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. 2. 100% Whole-Home Savings. Save up to $1,000/year. 3. Only 50% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle. 4. OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day.
These models are alternatives, with the same starting energy capacity. For household circuits, both need the correct Smart Home Panel 10 and installation by a qualified, licensed electrician.
A conventional rooftop connection shuts down during an outage, so it can't recharge TITAN through that path. Direct-solar recharge needs a separately checked design. Keep either unit in a dry, ventilated indoor location.
How Many Solar Panels Does Your House Need?
Work out how many solar panels your house needs from your electricity use and a site estimate. Floor area or a neighbour's panel count can't answer that question alone.
Start With Annual Use and an Offset Goal
Use your electricity bills to set a target for the energy you want solar to produce. Work through these inputs before dividing by a panel's wattage.
  1. Add the electricity used over twelve months, measured in kWh.
  2. Choose the share you want solar to supply over a year.
  3. Ask for the expected annual production per installed kW at your site.
NRCan's photovoltaic-potential estimates provide a starting model for production. Their yield already accounts for modelled system losses, so don't deduct the same losses again. A roof assessment still needs local shade, layout and equipment details.
Annual use, an offset goal and site yield lead to a panel-count estimate.Annual use, an offset goal and site yield lead to a panel-count estimate.
Turn the Array Size Into a Panel Count
Consider a hypothetical home using 12,000 kWh a year, with a 50% solar offset goal. Assume a planning yield of 1,200 kWh per installed kW each year.
The target is 6,000 kWh annually. Dividing that by 1,200 gives a 5 kW array estimate. Neither the household use nor the yield is a Quebec average.
With two assumed panel ratings, the rounded count changes as follows.
Assumed Module Rating
Panels Rounded Up
Resulting Array Rating
400 W
13
5.2 kW
500 W
10
5 kW
The 400 W calculation gives 12.5 panels, rounded up to 13. Your installer must check whether that layout fits the roof and inverter.
A 5 kW rating doesn't mean constant 5 kW production. This annual estimate also doesn't prove winter backup or compatibility with a battery's direct-solar inputs.
Will Your Roof and Winter Conditions Suit Solar?
Solar panels for your house need sound mounting space and useful exposure to sunlight. Check the roof's condition and remaining life before committing to an array.
Ask the assessor to review orientation, shade through the seasons, structural loading and safe maintenance access. Needed roof repairs belong in the project budget before the panels go up.
Cold weather can slightly improve panel efficiency, but shorter days and weaker sunlight reduce winter generation. Snow can also block light. An annual production estimate can hide these monthly changes.
Ask for a monthly estimate if you expect solar to help meet winter demand. A roof that meets an annual offset target may still leave a large winter shortfall.
Agree on a safe maintenance plan with the installer. Don't assume snow will clear itself or climb onto the roof to remove it.
What Belongs in the Cost and Incentive Calculation?
Compare the same installed scope before comparing prices or projected savings. Keep rooftop generation, optional storage and roof or electrical upgrades on separate cost lines.
Compare the Same Installed Scope
An itemised quote lets you see what each contractor includes. Check these items rather than comparing panel prices alone.
  • Panels, inverter and mounting equipment.
  • Roof work, electrical protection and installation labour.
  • Utility submissions and any local permit requirements.
  • Monitoring, warranties, handover and taxes.
  • Optional storage and its required connection equipment.
 A homeowner compares solar-project paperwork with an assessor at a kitchen table. A homeowner compares solar-project paperwork with an assessor at a kitchen table.
Ask how the savings estimate treats self-used electricity, bill credits and ongoing costs. Check which fixed charges remain on your bill when solar reduces grid purchases.
Request the rate and credit assumptions in writing before relying on a payback estimate. Your own consumption pattern affects how much solar electricity you use directly.
Check Program Rules Before Deducting a Grant
Hydro-Québec announced a solar grant of $1,000 CAD per installed kW in April 2026. Support is capped at 40% of eligible costs.
Confirm current eligibility and connection approval before subtracting aid from your budget.
Surplus-electricity credits under net metering apply to future use. They aren't stored battery energy or a cash payment for every exported kWh.
The separate Rénoclimat fixed-battery measure has permanent-connection and inverter conditions, and excludes transportable batteries. Don't assume either TITAN configuration qualifies or combine grants without checking the rules.
What Should Your Installer Confirm Before Work Starts?
Get a written plan naming who handles the roof, electrical work, utility submission and local approvals. Confirm the contractor has the right qualifications for each part.
CMEQ distinguishes electrical work from rooftop-panel installation, which needs its own licence scope. An electrician's licence alone doesn't cover every solar-project task.
Work through the project in this order before accepting a quote.
  1. Share your annual electricity use, roof assessment and project goal.
  2. Confirm qualified contractors, equipment compatibility and required approvals.
  3. Compare itemised quotes and request written operating and maintenance instructions.
 A homeowner reviews household loads, with an EcoFlow TITAN 5000 Plus in the background. A homeowner reviews household loads, with an EcoFlow TITAN 5000 Plus in the background.
Use your actual appliance list to make the backup discussion specific. Ask the installer these questions before choosing storage or accepting the quote.
  • Which equipment stays powered during an outage, and how can it recharge?
  • What assumptions support monthly generation and bill credits?
  • Who confirms the inverter, storage and utility requirements before connection?
A battery's no-export setting doesn't replace utility or local approval. Get the proposed equipment, responsibilities and handover instructions in writing before work begins.
Decide What Your Solar Project Must Deliver
Gather a year's electricity use, roof information and a clear bill-reduction or backup goal before requesting quotes. Choose solar panels for a house around that evidence, then compare complete installed plans.
If your project also needs stored backup energy, compare the EcoFlow TITAN series and confirm the proposed configuration with a qualified local installer.
How much solar capacity does a house need?
There isn't one capacity that fits every house. Use annual electricity use, the share you want solar to supply and a site-specific yield, then check seasonal needs separately if backup matters.
Why is a panel price different from a home-solar quote?
A panel price covers one component. An installed quote also needs the inverter, mounting, electrical work and approvals, plus any roof repairs or storage included in your chosen scope.
Which solar panel is best for a house?
The best fit depends on usable roof space, verified output, warranty and compatibility with the mounting and inverter. A higher wattage alone doesn't prove a panel suits your roof or project.
Can solar panels power a house during an outage?
Only if the installation is designed for backup operation, with the required isolation, equipment and available energy. A conventional rooftop connection or net-metering credit doesn't provide power when the grid fails.
Does Quebec's battery grant cover any solar battery?
No. Rénoclimat sets fixed-installation and inverter conditions and excludes transportable batteries. Confirm the exact proposed system's eligibility before buying, rather than assuming a solar battery or either featured TITAN model qualifies.
Solar Panels
