House Humidity in the Winter: Ideal Levels & Tips
When Canadian winters begin, and we use our heaters more, the air inside our homes changes quickly. Cold air from outside doesn’t have much moisture. When we heat this air indoors without adding humidity, it becomes even drier. This can lead to dry skin, sore noses, and static electricity. Going too far the other way results in foggy windows, damp surfaces, and mould-friendly conditions.
Getting the right house humidity in the winter requires a balance of comfort, temperature, ventilation, and moisture control. If you've ever wondered what humidity should be in winter, this guide provides a clear range, explains why it changes, and demonstrates how to keep critical equipment powered during an outage. For more seasonal preparation, check out our guide to winterising your home.
What Should House Humidity Be in the Winter?
Most Canadian guidelines recommend a winter indoor relative humidity (RH) range of 30-50%. CMHC recommends that RH not exceed 50% during the heating season. In extremely cold weather, a level of 30% or lower may be required to avoid window condensation. In practice, many homes perform their best around 30-40% when it is bitterly cold.
The right figure depends on outdoor temperature, insulation, window performance and how much condensation you see. Upgraded, energy-efficient windows can tolerate a higher level, while older windows call for the lower end. No single percentage suits every home or every cold snap, so finding the correct humidity for house in winter is about watching your own home rather than chasing one number.
What Is the Ideal Indoor Humidity Level During Canadian Winters?
Relative humidity (RH) describes how much water vapour is in the air compared with the maximum amount the air can hold at its current temperature. When air is heated without adding moisture, its relative humidity decreases, even though the actual amount of water vapour remains the same. When the air cools, its relative humidity rises.
What is the ideal humidity level for a residence to be comfortable and damage-free throughout the winter? As the temperature drops, aim for the lower end of the 30-50% range. While too much moisture encourages condensation and the growth of mould, overly dry air can irritate skin and lungs.
Condition
Indoor RH
What you may notice
Low
Below about 30%
Dry skin, static electricity, irritated nasal passages
Generally acceptable
About 30–50% (lower end in very cold weather)
Comfortable air, little or no condensation
Potentially excessive
Above about 50%, or any level that causes condensation
Fogged windows, damp surfaces, musty odours, mould risk
Should You Lower Indoor Humidity When Outdoor Temperatures Drop?
Often, yes. Colder outdoor temperatures chill windows and other surfaces, so warm indoor air that touches them cools and releases moisture as condensation. If you see fogged glass or water on frames during a cold snap, lowering house humidity in winter is the usual fix.
One Canadian insurer's guide gives an example: with a 22°C indoor temperature, condensation may begin at roughly 35% RH when it is –10°C outside and at far lower levels at –30°C, but it stresses that window performance varies. Treat figures like these as examples, not a rigid rule.
How Can You Measure Humidity Inside Your House?
You can get cheap digital hygrometers from hardware stores. A smart thermostat with a humidity sensor or an indoor humidity monitor is also a good choice. Measure in the rooms you use the most, including bedrooms and living spaces, and follow changes through the heating season. Readings can vary from room to room and near windows, bathrooms or kitchens, so check in more than one place.
Backup-battery-as-a-support-option-for-working-humidifierBackup-battery-as-a-support-option-for-working-humidifier
How to Maintain Comfortable Winter Humidity and Keep Essential Equipment Powered
Managing humidity comes down to the right equipment, good moisture control and regular monitoring. Portable humidifiers add moisture to a single room. Whole-home humidifiers work through your heating system and are best installed by a professional; ventilation (such as bathroom and kitchen fans) removes moisture from its source, and dehumidifiers help when levels run high. Our guide to winter humidifiers explains the options. Used together with a hygrometer, they help keep house humidity in winter within a healthy range.
Outages complicate things. Portable power stations are supplementary electricity sources for compatible equipment during winter power outages, and a power station does not measure or regulate humidity on its own. Read our guides to winter storm backup power for warmth and safety and preparing for and recovering from power outages for broader planning.
Maintain a Portable Humidifier During Short Winter Power Outages
Picture an extended winter outage where your household needs backup electricity for essential appliances and selected electrically powered heating-system components. The EcoFlow DELTA 3800 Gen4 suits higher-capacity backup needs.
Where appropriate connections are available, it may support compatible plug-in humidifiers, monitoring equipment, ventilation devices or heating-system electrical components. Check each device's wattage first.
Keep in mind that maintaining temperature and electricity supply supports comfort but does not guarantee a specific humidity level. You still need to monitor and adjust it.
1. Longest Runtime¹: Powers a refrigerator for up to 70 hours; 17 hours (32.6%) longer than the industry average for 3-4kWh portable power stations. 2. Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴ . 3. Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3-4kWh capacity and 3,600W output. 4.4–12 kWh Expandable Capacity: Compatible with EcoFlow DELTA Pro 3 Smart Extra Battery and EcoFlow DELTA 3 Max Plus (2,048 Wh) Smart Extra Battery.
Whole-Home Backup for Heating and Humidity Control During Winter Outages
Now imagine a prolonged winter outage that interrupts heating, ventilation and humidity-control equipment. The EcoFlow DELTA Pro Ultra is a higher-capacity backup solution for compatible essential home systems. A properly configured home backup system can help maintain electricity for selected furnace blowers, ventilation equipment, humidifiers and other essential appliances.
Maintaining power does not automatically maintain ideal indoor humidity, so keep monitoring RH and controlling moisture. Any connection to hardwired heating or ventilation circuits must use an approved configuration and professional installation where required.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home, even with a central AC 3. 6kWh-90kWh capacity, whole-house backup for weeks with comfort 4. Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
Why Does House Humidity Change During Winter?
Winter humidity in house air is shaped by outdoor temperature, heating practices, ventilation and everyday activities. It helps to separate two different problems: low relative humidity caused by heating cold outdoor air, and excess moisture generated inside the home. Low winter humidity in the house usually comes from the first, while foggy windows and musty smells point to the second.
indoor-humidity-levels-adjusted-by-meterindoor-humidity-levels-adjusted-by-meter
How Does Indoor Heating Affect Winter Humidity?
When you heat cold air from outside, it can hold more moisture. So if you don't add more moisture, the relative humidity will go down. Forced-air systems, electric heaters and other heating methods can all contribute to the sensation of dry air. Heating does not necessarily remove water vapour from the air; the change in RH is mainly a result of temperature.
What Causes Excessive Humidity and Window Condensation?
Moisture is introduced by cooking, showering, drying laundry indoors, leaks from water and poor ventilation. Warm, moisture-laden indoor air cools upon contact with cold window glass or poorly insulated surfaces, and the moisture condenses. If you still see condensation, lower the humidity level and check the ventilation.
What Are the Signs of Low or High Indoor Humidity?
Dry skin, static electricity and dry nasal passages suggest low humidity. Condensation, musty odours and visible mould suggest too much. These signs are useful clues but not precise measurements, so confirm with a hygrometer.
Maintaining appropriate house humidity in the winter protects indoor comfort and shields your home from moisture damage. So, what should the winter humidity in the house be? A general 30–50% RH range works, adjusted for outdoor temperatures, window condensation and your building's condition.
Measure regularly and use suitable humidification, ventilation and moisture-control practices. For compatible household equipment during winter outages, consider the EcoFlow DELTA Pro Ultra or the EcoFlow DELTA 3800 Gen4. Explore EcoFlow Canada's portable power solutions to stay comfortable all winter.
What Should House Humidity Be in the Winter in Canada?
The general range is 30–50% RH. In very cold weather, 30–40% or even lower may be needed to avoid condensation.
Is 40% Humidity Too High for a House in Winter?
Not usually. If your windows stay clear, 40% is fine. If condensation forms, lower it.
Is 30% Humidity Too Low in Winter?
It is at the low edge of the general range and is often appropriate in very cold weather. If dryness bothers you, raise it slightly while looking at your windows.
Why Does My House Get So Dry During Winter?
Heating cold outdoor air lowers its relative humidity, and drafty homes lose indoor moisture faster.
How Can I Increase Humidity in My House During Winter?
Use a portable or whole-home humidifier, keep a hygrometer nearby and adjust gradually to avoid condensation.
Home Solutions
