Snowfall Warning: What It Means and How Canadians Should Prepare
A snowfall warning from Environment and Climate Change Canada (ECCC) signals that significant snow may create hazardous conditions and disruption. Impacts vary with location, timing, temperature, wind and forecast confidence, so read the full alert rather than relying on the headline alone. This guide explains the alert, common travel and outage risks, and practical steps before, during and after the storm.
What Is a Snowfall Warning in Canada?
Understanding the terminology helps you assess the forecast, expected impact and action recommended for your location.
A Snowfall Warning Signals Significant Snowfall
ECCC issues snowfall alerts when expected snow and its impacts warrant public attention. Under the current system, heavy snowfall weather alerts combine forecast confidence with expected effects on travel, services, property and health. Read the alert for accumulation, timing, location and safety instructions because the same snowfall can affect communities differently.
Snowfall Warning Criteria Vary Across Canada
A snowfall that shuts down Vancouver would barely slow Winnipeg down, so ECCC didn't use one number for the whole country. Under its former criteria, in use until November 2025, the bar moved region by region:
  • Ontario & Quebec: 15 cm or more within 12 hours.
  • Atlantic Canada: Newfoundland and Labrador, New Brunswick, Nova Scotia and PEI shared the same 15 cm in 12 hours, often arriving as wet, heavy, ocean-driven snow that weighs on trees and power lines.
  • Alberta & the Prairies: 10 cm or more in 12 hours across Alberta, Saskatchewan and Manitoba, where sub-zero temperatures tend to produce lighter, powder snow that drifts easily and cuts visibility once the wind picks up.
  • Coastal British Columbia: The mildest region carried the lowest bar — 10 cm in 12 hours along the southern and central coastal sections (Metro Vancouver among them), or 5 cm in just six hours when it came down fast. Mountain regions stayed at 15 cm in 12 hours.
Region / Province
Snowfall Warning Threshold (to Nov 2025)
Typical Local Hazards
Ontario & Quebec
≥ 15 cm / 12 hrs
Gridlock on Hwy 401 and Autoroute 20, long delays at the airports
Atlantic Provinces
≥ 15 cm / 12 hrs
Heavy wet snow, gale winds, ice mix
≥ 10 cm / 12 hrs
Blowing snow, whiteouts on the highway, rapid temperature drops
B.C. South & Central Coast (coastal sections)
≥ 10 cm / 12 hrs, or ≥ 5 cm / 6 hrs
Commuter gridlock, transit disruptions, steep-hill collisions
Note: These are historical thresholds. On November 26, 2025, ECCC moved to colour-coded alerts, and its Weather Impact Guides replaced the former criteria: a warning’s colour, yellow, orange or red, now reflects expected impact and forecast confidence rather than a fixed number of centimetres. The amounts above still give a good sense of what counted as significant snowfall in each region.
Snowfall Warning vs. Winter Storm Warning vs. Snow Squall Warning
Not every winter alert shares the same hazards or triggers:
  • Snowfall Warning: Issued for snow heavy enough to cause hazardous conditions and significant disruption on its own; strong winds are not required, though they often come along.
  • Winter Storm Warning: A snow storm warning in Ontario or elsewhere may cover a combination of hazardous winter conditions, such as significant snow, freezing rain, strong wind or blowing snow. Current alert text explains the specific hazards and impacts.
  • Snow Squall Warning: Issued for intense, localized bursts of snow that slash visibility and often bring strong, gusty winds. Cold air crossing open water, the Great Lakes above all, or a passing cold front can spin one up and bury one town while the next one over sits under blue sky.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
What Can Happen During a Snowfall Warning?
Snow that lands this quickly sets off a chain reaction that runs from the highways to your own basement.
Heavy Snow Can Reduce Visibility and Threaten Road Safety
Fast-falling or blowing snow can reduce visibility and traction, while road conditions differ by route, temperature and maintenance activity. During a Toronto snowfall warning or any local alert, check the official road service and transit or carrier updates before travelling, and postpone non-essential trips when authorities advise it.
Snow and Ice Can Weigh Down Trees and Power Lines
Wet snow can adhere to branches and overhead equipment, increasing the chance of localized damage when combined with wind or existing tree stress. Accumulation and infrastructure impacts vary by storm, so treat sagging branches and damaged lines as hazards and follow utility guidance.
Snowfall Can Cause Power Outages and Heating Disruptions
Snow, wind, ice and falling branches can damage local distribution equipment and cause outages of varying size and duration. Electric heating stops during a blackout, and many fuel-burning furnaces also need electricity for controls and blowers. Prepare for winter power outages by identifying essential loads and monitoring utility restoration updates.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
How Should Canadians Prepare Before a Snowfall Warning?
Prepare before travel conditions deteriorate. Check household supplies, heating, communication and backup power needs as soon as the alert is issued. A portable power station may support selected plug-in devices when its output and stored energy match the load.
Prepare Essential Supplies Before the Snow Arrives
Keep food that does not require cooking or refrigeration, a manual can opener, flashlights, first-aid supplies, traction material, pet supplies and necessary medication. Current federal checklist guidance recommends stored or bottled water for at least 72 hours, with two litres per person per day for drinking, cooking and hygiene, plus additional supplies for specific household needs.
Check Heating Systems and Winterize the Home
Check the furnace filter, pull the leaves out of the outside exhaust vents, and run a hand around the window frames to find drafts where the caulking has given out. If you heat with wood, bring the seasoned firewood under cover now, onto the porch or into the garage, while you can still reach it.
Prepare Portable Backup Power for Essential Devices
For a short outage, prioritize phones, lighting, internet equipment and refrigeration. Battery-based backup produces no combustion exhaust during operation, but it still must be used within the manufacturer’s output, temperature and connection limits. The EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) provides 2,048Wh of capacity and 3,000W of rated AC output for compatible refrigerators, routers, phones, lighting and other selected devices. Check running and startup wattage, then estimate runtime from the combined load, temperature and conversion losses. Its portable format allows it to be moved as household priorities change.
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Plan Higher-Capacity Backup Power for Home Loads
Extended outages require a larger energy plan. List priority circuits and devices, including any well pump, refrigeration, medical equipment or communication system, then compare starting watts, continuous output, stored energy and required connection equipment. The EcoFlow DELTA Pro Ultra Whole-Home Backup Power starts with about 6kWh of capacity and provides up to 7.2kW AC output, with supported configurations scaling to 90kWh. Through compatible equipment installed according to local electrical requirements, it can support selected 120V and 240V circuits. Actual runtime depends on system configuration, temperature and household loads.
6kWh-90kWh capacity, whole house backup for weeks with comfort. One hour of solar for one day of power. Powers through the most challenging situations. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items.
What Should You Do During a Snowfall Warning?
Once the snow is banked against the doors, the job stops being preparation and becomes staying put and paying attention.
Stay Updated as Weather Conditions Change
Monitor the current ECCC alert, local emergency information and the appropriate provincial road service before travelling. Forecast snowfall and impacts can change, so review updated timing, accumulation, confidence and recommended actions rather than relying on an earlier estimate.
Limit Unnecessary Travel During Heavy Snow
Limit non-essential travel when visibility or road conditions deteriorate and follow instructions from local authorities. If travel is necessary, check the route, vehicle readiness and current road reports before leaving.
Use Backup Power Safely
Operate fuel-burning generators outdoors and at least 6 metres from windows, doors and vents, following the manufacturer’s instructions. Carbon monoxide can enter a building without warning. A battery power station produces no combustion exhaust during operation; keep it dry, observe its temperature limits and route cables to reduce trip hazards.
What Should You Check After a Snowfall Warning?
When the storm clears and the sun comes out, walk the property. A careful look that afternoon catches the damage while it’s still small and cheap to deal with.
Look for Downed Power Lines and Property Damage
Check from a safe distance for damaged trees, low cables and downed lines. Treat any downed line as energized, stay at least 10 metres away, keep others back and report it to the local utility or emergency services.
Assess Heating and Essential Home Systems
Keep snow and ice clear of furnace exhaust and intake vents, heat-pump equipment and the gas meter as directed by the equipment or utility provider. Blocked fuel-burning appliance vents can increase carbon monoxide risk; if an alarm sounds or equipment is not operating normally, leave the area and contact emergency or qualified service personnel.
Recharge Backup Power and Restock Emergency Supplies
After the storm, recharge power stations and battery banks according to their manuals, replace used or expired supplies and test flashlights and radios. Record anything that was missing so the kit is ready for the next alert.
A snowfall warning calls for attention to the current alert, travel conditions, household supplies, heating and potential outages. Prepare early, follow official updates and size any backup power plan around essential loads and equipment limits. These steps can reduce disruption while conditions change.
How Long Do Snow Squalls Last?
Snow-squall duration varies with the band’s movement and local conditions. Intense periods may be brief or recur as bands redevelop, so use the current ECCC alert and radar rather than a fixed national duration.
What Month Is Most Likely to Snow?
January is historically the coldest month across most of Canada, but the peak month for total snowfall varies significantly by region. Central and Atlantic Canada typically see their heaviest accumulations between January and February. In Alberta, and across the Prairie and mountain regions generally, the big snowfalls often hold off until March or April, when late-season storms drag in moisture and run into air that’s still cold enough to turn it to snow.
How Many Centimetres of Snow Is a Snowfall Warning?
Historically, 15 cm or more within 12 hours in Central and Eastern Canada, 10 cm across the Prairies, and as little as 5 cm within 6 hours on the B.C. coast. Since November 2025, ECCC bases alerts on expected impact rather than a fixed amount.
Can You Drive When It Is Snowing?
Driving rules and winter-tire requirements vary by province, route and season. Reduce speed, increase following distance and follow official travel restrictions or advice during a blizzard, snow squall or snowfall warning.
Does a Snowfall Warning Mean Schools Will Be Closed?
No, a snowfall warning alone doesn’t close schools. That call belongs to the local school board, and it comes down to whether the roads have been plowed, whether transit is running in the morning, and whether a bus can get kids there safely.
