Freezing Fog can cause very poor visibility and cause ice to form on surfaces such as roads and pavements in the winter months. It may look like ordinary fog, but it presents an additional hazard: its supercooled water droplets can freeze when they come into contact with sufficiently cold surfaces.
This is because Freezing Fog contains extremely small supercooled water droplets. Supercooled water: Water that has not frozen although the temperature is below 0°C. This causes the droplets to instantly freeze once they make contact with a cold enough surface.
This can cause issues for Canadian drivers, pedestrians and families during cold, still weather. If you’re wondering what Freezing Fog is and why it differs from normal fog, this article will help explain how it forms, how it differs from ice fog, and how to prepare your house and stay safe.
What Is Freezing Fog and How Does It Form?
Scientifically, Freezing Fog is formed by supercooled liquid water droplets suspended in the air. Supercooled means that the liquid will instantly freeze in contact with an appropriate surface. This could be a branch, barrier or windscreen. Repeated droplet impacts can build up rime ice, which often appears as a rough, white deposit on exposed surfaces.
Generally, Freezing Fog will occur during cold and humid weather. Still, air will cause fog to settle and keep visibility low.
How Does Freezing Fog Form in Subzero Temperatures?
Fog freezing occurs when humid air cools, causing it to become saturated. Water vapour then condenses into small droplets.
During Subzero Temperatures, the droplets may not freeze. This is because pure water can be supercooled, meaning it will remain in liquid form despite the temperature being below 0°C. As long as the droplets do not make contact with an object to freeze onto (such as a road sign, tree, car or barrier), then they will remain in liquid form. Once they make contact with something, they will instantly freeze, causing ice to build up.
What Weather Conditions Cause Freezing Fog?
To create Freezing Fog, there are several factors:
  • High relative humidity
  • Air temperatures below zero.
  • Light winds.
  • Still air.
Freezing Fog often occurs during the night or early morning due to the surface temperature falling. However, it can also occur at other times of the day depending on the atmosphere.
Where Is Freezing Fog Most Likely to Occur in Canada?
Freezing Fog can occur in valleys and low-lying areas. The geography of the area, temperature inversions and moisture will all play a role in whether this occurs.
Because conditions can vary significantly by location and from day to day, check your local forecast and weather alerts.
Extreme-weather-freezing-fog-cause-poor-visibilityExtreme-weather-freezing-fog-cause-poor-visibility
Freezing Fog vs. Ice Fog: What’s the Difference?
Freezing Fog and ice fog are two different atmospheric conditions. Both can occur during cold weather and cause poor visibility. However, Freezing Fog is mainly made up of supercooled liquid droplets. Ice fog is made up of small ice crystals.
This means Freezing Fog can cause surfaces to be covered in rime ice as the liquid will freeze. Whereas ice fog will generally not leave any ice as it is already frozen.
Freezing Fog
Ice Fog
Composition
Supercooled liquid water droplets
Tiny ice crystals
Typical conditions
Subzero, moist, calm air
Very cold air with enough moisture and suitable atmospheric conditions
Surface effects
Droplets freeze on contact, forming rime ice
Little to no freezing-on-contact deposit
Visibility hazard
Reduced visibility, plus potential icy surfaces and black ice
Reduced visibility
Freezing Fog vs. Regular Fog
As its name suggests, regular fog consists of suspended water droplets; however, it typically doesn’t pose a risk of anything freezing on contact. Regular fog will fall onto surfaces and simply leave everything damp. Freezing Fog will cause everything it falls upon to freeze.
How Is Ice Fog Different From Freezing Fog?
Ice Fog consists of ice crystals rather than super-cooled droplets. This kind of fog is generally seen in very cold weather. It can occur if there is enough moisture in the air and the conditions are right. Unlike Freezing Fog, there isn’t a specific temperature that can be used to define Ice Fog and Freezing Fog.
Does Freezing Fog Always Cause Ice Buildup?
Whilst it can leave rime ice on exposed surfaces, how much will depend on the temperature of the surface, amount of droplets in the air, how exposed the surface is, and how long the fog lasts. It can vary greatly.
How to Prepare Your Home for Freezing Fog and Winter Power Outages
Canadian households can prepare for dangerous winter weather by having emergency supplies on standby, checking the weather forecast, and ensuring essential items have a reliable power source. Take a look at our guide to winter-proofing your home and winter storm checklist for power outages.
Remember, a power station won’t stop Freezing Fog from occurring or melt ice on roads. Its purpose is to provide backup power to your compatible home in winter items if you experience a power cut during a wider winter event.
Backup-battery-as-a-support-option-in-extreme-winterBackup-battery-as-a-support-option-in-extreme-winter
Backup Power for Essential Household Devices During Short Winter Outages
If you experience a short power cut causing your lights, wi-fi, and phone charging to fail, and some smaller appliances to fail, you can use the EcoFlow DELTA 3 Classic as a portable power solution. This has a 1024Wh battery and 1800W AC output.
EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
1. 4 Ways to Charge, Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging. 2. 1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2600W such as microwaves, refrigerators, laptops, and heated blankets. 3. 10ms Auto-Switch: Keep critical devices like NAS systems and servers running smoothly. 4. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
Higher-Capacity Home Backup During Extended Winter Weather Outages
If you experience longer power cuts then you may struggle with your fridge and communication items. As well as the electrical parts of your heating system.
For high-capacity backup options for your home, the EcoFlow DELTA Pro Ultra can provide extra backup power. With the correct setup, you can power selected circuits in your home, your fridge, communication items, and compatible heating system items.
Remember, this will not stop Fog Freezing. Your heating items will need to be wired into the system with the correct electrical connections. This should be done by a qualified professional.
1. The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use. 2. 7.2-21.6kW output, powerful enough to run your whole home even with a central AC 3. 6kWh-90kWh capacity, whole house backup for weeks with comfort 4. Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2 5. 5 Charging Options, even plan B has a plan B
What Are the Dangers of Freezing Fog, and How Can You Stay Safe?
Freezing Fog can be dangerous due to its ability to reduce visibility and deposit ice onto exposed surfaces. Motorists, pedestrians, and homeowners can all be affected. This is especially true when ice begins to form on roads, stairs, pavements, and driveways.
Why Does Freezing Fog Make Roads and Sidewalks Dangerous?
The super-cooled droplets can cause ice to form on roads. This can cause Black Ice to form. This forms a very thin transparent layer of ice and can be extremely difficult to spot. Extra care should be taken on bridges, overpasses, and shaded roads, as these will typically be colder and more likely to ice up.
This can cause issues due to reduced visibility and slippery surfaces increasing the chances of an accident.
How Should You Drive Safely in Freezing Fog?
  • Slow down.
  • Increase your stopping distance.
  • Use your dipped headlights as your high beams will bounce back from the fog, reducing your visibility.
  • Don’t brake or steer sharply.
If visibility and road conditions are particularly dangerous, then try to avoid travelling unnecessarily. Check local weather warnings and road conditions before leaving.
How Can Homeowners Prepare for Freezing Fog?
Look for ice on walkways, stairs, driveways and outside on your property. Use an appropriate grip material or de-icer. Having emergency lighting, communication items, and essentials for your home can be helpful. Whilst Freezing Fog doesn’t cause widespread power cuts, you may still experience some interruptions during wider winter events. It is a good idea to prepare. Take a look at our range of portable power stations for more ideas.
This aligns with official information regarding Freezing Fog. It mentions supercooled droplets, icy surfaces, and Black Ice risks.
Freezing Fog is a type of winter weather caused by super-cooled water droplets freezing on contact with cold enough surfaces. It can cause reduced visibility, Black Ice and can be dangerous on roads, pavements, and outdoors. Monitor the weather forecast, avoid travelling unnecessarily in dangerous conditions, and winter-proof your home. Use the EcoFlow DELTA 3 Classic to keep your essentials running, or use the EcoFlow DELTA Pro Ultra for high-capacity home backup during power interruptions. Take a look at EcoFlow Canada’s winter emergency backup power solutions.
What causes Freezing Fog?
Freezing Fog occurs when humid air becomes saturated and drops below zero. This causes fog to form. The droplets remain liquid as they are super-cooled. Calm winds and stable air will help the fog to remain. When the droplets come into contact with cold surfaces they will freeze.
What is the difference between a Freezing Fog and Ice Fog?
Freezing Fog contains super-cooled liquid droplets that freeze on contact. This can leave rime ice. Ice Fog contains very small ice crystals. Both will reduce visibility but only Freezing Fog will leave ice.
Is Freezing Fog Dangerous to Drive In?
Yes! It reduces visibility and can leave you with slippery surfaces. Slow down, increase your stopping distance, use your dipped headlights, and avoid sudden movements. If conditions are particularly bad then avoid travelling.
Can Freezing Fog cause Black Ice?
Yes! The super-cooled droplets may freeze on roads. This can cause very thin ice to form that can be difficult to see. Bridges, overpasses, and shaded areas are more likely to suffer from this.
What temperature does freezing fog occur at?
Freezing Fog will occur when the temperature drops below 0 degrees Celsius. The fog will contain super-cooled droplets. There is no set temperature as it depends on the moisture, winds, and local conditions.
