Is Your Wireless Charger Overheating? Here’s Why and How to Fix It
Wireless chargers have become increasingly common, and for good reason. These wonderful chargers make powering up your device easier and faster than ever before, without the need to keep all your charging cables organized.
If you have used a wireless charger, you know just how great these devices can be for quickly and easily charging your phone’s battery to full capacity. But there are some safety concerns that you should be aware of if you intend to use these types of chargers regularly. Let’s take a closer look.
How Wireless Charging Works?
In simple terms, wireless charging works by harnessing the power of a magnetic field. The charging pad connects to a magnetic coil located inside your phone or device, which in turn creates energy to charge the battery. This energy transfer works similarly to a standard charging cable, but without the need to worry about the cord getting in the way.
Common Reasons Your Wireless Charger Overheats
  • Low-quality charger
  • Poor coil alignment
  • Charging in an environment with hot temperatures
  • Debris built up in the charging ports
How to Stop Your Wireless Charger From Overheating
  1. Purchase and use a high-quality charger every time you charge your phone with a wireless charger.
  2. Ensure your phone is aligned with the charging cable. If the magnetic coils do not align properly, overheating can occur.
  3. Take off your phone case when charging your phone. The added material can block the charging connection, causing it to work much harder than necessary.
  4. Cleaning your charger regularly can also reduce the chance of overheating. Residue, like dust and other debris that build up over time, may contribute to rising temperatures when in use.
Wireless Charging Safety and Battery Health
Knowing the basic charging safety rules above can greatly help to increase the longevity of your battery and charger. Here are some common things to look out for when using your wireless charger.
When Heat Is Normal and When It Becomes a Problem
Due to the nature of wireless chargers and the energy transfer between the charging port and your device, some warmth is completely normal. That being said, it is important to keep an eye on rising temperatures around your charger, as there are a few worrisome conditions that can lead to serious malfunctions.
Warning Signs
If you notice that your wireless charger is getting hot at a rapid rate, that is a cause for concern. Remove your phone from the charger to see if the temperature drops, and if it doesn’t, unplug your device quickly.
Another warning sign to look for is if your device stops charging altogether. This malfunction is another sign that something is not working properly with your charger and should be addressed by unplugging and ceasing use of the charger.
EcoFlow Power Banks
EcoFlow RAPID is our newest fast-charging lineup, powered by the same advanced X-Core 3.0 Tech System behind the flagship DELTA Series. It delivers top-tier charging speeds, safe performance, and intelligent power management. With up to 99.5Wh flight-safe capacity, 15W–300W output options, and next-gen Qi2 wireless charging, RAPID Power Banks are the ultimate portable solution for work, travel, and everyday power.
Using Certified Chargers and Wireless Power Banks Safely
A surefire way to ensure your charger works as it is intended is to purchase and use a certified device and a reliable power bank.
Benefits of Qi Certified Wireless Chargers and Compatible Devices
Using a certified charger is a surefire way to ensure you are using a device that meets the highest safety standards. These devices undergo multiple rounds of quality control to ensure they are ready for their intended purpose.
Best Practice for Portable Wireless Power Banks at Home and on the Go
The EcoFlow RAPID Mag Power Bank (Built-in USB-C Cable) is a device compatible with the majority of wireless chargers on the market. This powerful yet compact power bank is designed for on-the-go use, helping to ensure you stay charged and connected. Be sure to use compatible charging cables designed for your chosen charger.
EcoFlow RAPID Mag Qi2.2 Magnetic Power Bank (10,000mAh, 25W, Built-in USB-C Cable)
Is It Normal for a Wireless Charger to Feel Hot to the Touch?
It is normal for wireless chargers to conduct some heat while in use, but they should never feel overly hot to the touch. If your charger is showing signs of overheating, you should cease use immediately and take a closer look to ensure that nothing is visibly wrong. Try wiping down your device and checking the charging ports for any signs of damage or debris.
Can Wireless Charging Damage My Phone Battery Over Time?
As long as you invest in a high-quality, certified charger, your phone battery should not be damaged even if you use it on a regular basis. If your charger is regularly showing signs of overheating, or you notice that your phone battery life is failing in shorter periods of time, there may be an issue with the charger you are using, and you should replace it as soon as possible.
Do Wireless Power Banks Overheat More Than Regular Wireless Chargers?
Yes, wireless power banks have to work a bit harder to charge phones and other devices, so they typically overheat more frequently. Higher-quality power banks are less likely to overheat, though they will usually be warm to the touch while in use.
How Can I Choose a Safe Wireless Charger and Power Bank?
Purchasing a product with an official certification is the best way to ensure that you buy a safe wireless charger for your device. You can also choose to shop for devices that feature safety features such as temperature control and foreign-object detection. Both of these features can help to ensure you are getting the best possible product for your money.
EcoFlow RAPID Pro X Power Bank
Power through your day with the EcoFlow RAPID Pro X Power Bank — a compact, flight-friendly 27,650 mAh powerhouse that recharges to 80% in just 20 minutes² and delivers 300W across three USB-C ports. With a modular magnetic design, smart LCD display, app-based battery optimization, and a retractable cable included, it’s the ultimate travel-ready charging companion backed by a 24-month warranty.
Smart Charging Practices Prevent Overheating Risks
Wireless chargers are wonderful devices and make charging your device easier than ever before. With the information above, you are equipped with the knowledge to spot any safety concerns before they worsen.
EcoFlow’s RAPID Mag Power Bank (Built-in USB-C Cable) is a game-changing gadget and will keep you juiced up on the go with a convenient way to charge.
