Winter Heating Costs Are Rising: How Home Backup Power Can Help Reduce Bills
Freezing cold temperatures are best left to the outdoors. Staying warm and comfortable inside your home is the best way to enjoy winter, though it can certainly cause a dramatic spike in your energy bills.
With the winter season we’ve been having this year, freezing temperatures have been sticking around for weeks at a time with no real end in sight. If you’re looking for ways to save on your electricity bills while surviving the cold, we are here to help.
Below, we dive into some of the more common reasons your energy bills spike around this time of year, as well as how the EcoFlow DELTA Pro Series can help lessen the blow each month.
EcoFlow DELTA Pro Ultra
Why Winter Heating Costs Keep Rising
Across the board, cost of living expenses are on the rise with seemingly no end in sight. As with most things, supply and demand are certainly strong indicators of the rising costs, though there are some other factors at play.
This winter has already proven to be one of the more intense winters that we’ve seen throughout the United States in some time. Hefty amounts of snowfall and extended freezes require residents to hunker down and stay warm in their homes by blasting their heating units, in turn, spiking their monthly costs.
In addition to colder temperatures, energy prices are also trending upwards, making it more expensive to access and afford the resources needed to keep your home at a comfortable temperature. That being said, rising costs and extended winters are just some of the reasons you may notice an increase in your monthly bills. There are other things that are within your control that may be causing the spike in your electricity costs.
Homes that have poor energy efficiency or that are poorly insulated are more likely to see a climb in electricity costs when outdoor temperatures begin to drop. These buildings often require heating units to work much harder and for much longer in order to keep the interior temperature at a comfortable level, which will result in a higher bill for you to pay.
Why Power Outages and Winter Bills Are Connected
In neighborhoods where power lines are on full display, it’s very common to see widespread power outages when freezes and snowstorms begin to make an appearance.
Ice and snow are capable of damaging power lines and can even take down entire grids for extended periods of time. These freezing conditions also drastically increase the demand for electrical resources in a specific area, which typically can cause a strain on the grid that may lead to widespread outages.
Learning about the risks involved with winter is important as a homeowner and can help you to prepare for the worst. With the EcoFlow DELTA Pro 3 installed, you can rest easy knowing you have reliable access to store energy even if the grid were to go dark.
EcoFlow DELTA Pro 3
How Home Backup Power Can Help Reduce Winter Heating Costs
Investing in the proper tools and devices for your home is a great way to ensure you can stay warm all winter long without having to break the bank. Backup power systems are designed to build resilient homes and, beyond the upfront investment costs, help you save money in the long run.
To take full advantage of a backup power system in the winter, it’s important that your system is up and running year-round. Backup power systems equipped with solar panels are designed to capture and store energy for use at a later time. The longer your device has to capture this renewable energy, the better off you will be during the winter months.
Many backup power systems are fully capable of keeping an entire home up and running, even if the traditional grid system were to go down.
Backup Power and Time-of-Use Optimization
In addition to using your backup power source, you can also learn ways to save on your monthly electricity costs simply by creating a well-thought-out strategy for your time of use.
Time-of-use, or TOU, optimization is simpler than it sounds. TOU plans are typically run through electricity providers and are designed as incentive programs for homeowners who are willing to limit their use of on-grid energy during peak hours and instead use stored energy from their backup power systems.
Backup power systems and TOU plans go hand in hand and are a great way to reduce your monthly bills. Be sure to contact your energy provider to learn more about the plans available in your area.
EcoFlow DELTA Pro is a portable home battery built for plug-and-play backup, delivering 3,600–7,200W AC output to run 99% of appliances. Expand capacity from 3.6kWh up to 25kWh with Smart Extra Batteries, recharge fast with up to 6,500W MultiCharge (as little as 2.7 hours via AC), and even top up at thousands of EV charging stations—powered by a long-lasting LFP battery designed to support up to 10 years of use.
Can Backup Power Lower My Winter Heating Bill?
The right kind of backup power system can absolutely help to lower your winter heating bill over time, but it’s important that you invest in the correct system to reap these rewards. Backup power systems that are equipped with some type of battery or energy storage system will be your best bet in saving on monthly bills, as you can harness the power of stored solar energy late into winter.
What Runs Your Heating Bill up the Most?
In most cases, a poorly insulated home is the number one cause of a sky-high heating bill. Drafty doors or windows can cause air leaks and make it very hard for your heating system to do its job efficiently. Depending on where you live and what your winters look like, it is absolutely worth looking into your current insulation and making any updates where needed.
Home Backup Power Systems Reduce Winter Electricity Costs
Building a reliable and comfortable home starts with the right set of products to keep things running without a hitch. With the EcoFlow DELTA Pro Series, it is easier than ever before to save on your monthly electricity costs while still maintaining a cozy living environment. Backup power solutions are certainly worth your investment. Learn more about what EcoFlow’s whole-home backup solutions can do for you.
Home Backup
