Unlocking 25W Wireless Charging for iPhone 17: A New Era of Speed
The iPhone 17 has arrived, and with it, the implementation of bigger and better wireless charging, making for the most impressive launch yet.
Yes, there are a ton of other great new features, including design upgrades, performance improvements, and of course, the eye-catching orange colour-way, but the new 25W wireless charging speed is a game-changer. Don’t believe us? Keep reading to find out all you need to know about what 25W wireless charging means for iPhone 17 users and how Qi2.2 compares to Apple’s MagSafe.
Understand 25W Wireless Charging on iPhone 17: Why Qi2.2 Matters
The iPhone 17 series has introduced Qi2.2 wireless charging, enabling fast charging speeds that are on par with traditional wired charging. Qi2.2 follows the implementation of Qi2, which achieved speeds of up to 15W. But now, things are being taken up a notch. Not only does it reach new heights with 25W of power, but it also retains all the battery safety features that keep your devices protected from harm, including overheating and overcharging. Qi2.2 features the same powerful magnet alignment to minimize energy loss, allowing you to continue streaming your favorite show or listening to a podcast while wirelessly charging.
EcoFlow power bank charging at wall outlet
Compare Magsafe vs Qi2.2 for Faster Wireless Charging
Qi2.2 has taken a leaf out of the Apple notebook and used what made MagSafe so effective: its magnet alignment. While the two appear and behave quite similarly, there are some notable differences.
MagSafe was the benchmark for wireless charging. It provided up to 15W of power and was the first to feature super-strong magnets that allowed your device to accurately “click” into place and not budge. This waved goodbye to readjusting and shuffling to get consistent power. The downside was that MagSafe was only compatible with Apple products, leaving Android users in the dark.
Then Qi2 came along and provided the same impressive charging speeds, but made it for everyone. The newest advancement, Qi2.2, uses the same powerful magnets for sturdy attachment, but now with even bigger power and faster charging speeds with up to 25W. With the newly released iPhone 17 supporting Qi2.2, by using the right accessories, you can enjoy wired charging speeds without the wires.
EcoFlow RAPID Pro X Power Bank
Power through your day with the EcoFlow RAPID Pro X Power Bank — a compact, flight-friendly 27,650 mAh powerhouse that recharges to 80% in just 20 minutes² and delivers 300W across three USB-C ports. With a modular magnetic design, smart LCD display, app-based battery optimization, and a retractable cable included, it’s the ultimate travel-ready charging companion backed by a 24-month warranty.
Navigate Wired Charging Reality: USB-PD, GaN Chargers, and Top-Speed Adapters
Wired charging still tops the bill when it comes to speed. By using a USB-C PD charging cable, you can take advantage of fast charging, reaching speeds of up to 100W+. USB PD is the universal fast charging standard that’s built into a USB-C cable. It optimizes the charging speed between your device and your phone, so you never have to worry about overheating or overcharging.
GaN (Gallium Nitride) chargers are generally smaller, run cooler, and are more efficient than older silicon chargers. They usually have higher wattage, as manufacturers can pack more power into smaller chargers, making them ideal for travelers and those who need to charge on the go.
EcoFlow RAPID Mag Qi2.2 Magnetic Power Bank (10,000mAh, 25W, Built-in USB-C Cable)
Maximize Speed on the Go: Pick High-Wattage PD Chargers and Quality Cables
Whether you’re working on your daily commute or charging on the go, pairing a high-wattage PD charger with a good-quality cable allows you to achieve maximum charging speeds without damaging your battery.
By using a PD-ready wireless power bank like the EcoFlow RAPID Mag Power Bank (Built-in USB-C Cable), you can easily connect on the move without having to carry extra cables. The power bank is compact and lightweight—perfect to stuff in your backpack or handbag—but still delivers safe, efficient power when you need it most. Its 11N magnetic grip keeps your phone safely attached, whether you’re working out or maneuvering through the hustle and bustle of daily life.
What Charger Should I Buy for My iPhone 17?
When choosing a charger for your iPhone 17, buy one from a reliable manufacturer. For wired, opt for a charger that supports USB-C Power Delivery with at least 25W output for maximum efficiency. For wireless, ensure it’s Qi2-certified and has up to 15W output for max speed and strong magnet alignment.
Is 25W Safe for iPhone?
Yes, 25W charging is very safe for the iPhone. Using a charger with a power rating of 25W or higher will not harm the battery. iPhones have integrated smart battery management features, which allow them to regulate their power intake. This means they know how much power they can handle without overcharging or overheating.
How Many Watts Can the iPhone 17 Charge At?
The iPhone 17 can charge at up to 25W with wireless charging and over 100W+ with standard wired charging. Charging speeds will vary depending on the type of charging pad or wire you use. Choose one from a reputable manufacturer for the best results.
EcoFlow Power Banks
EcoFlow RAPID is our newest fast-charging lineup, powered by the same advanced X-Core 3.0 Tech System behind the flagship DELTA Series. It delivers top-tier charging speeds, safe performance, and intelligent power management. With up to 99.5Wh flight-safe capacity, 15W–300W output options, and next-gen Qi2 wireless charging, RAPID Power Banks are the ultimate portable solution for work, travel, and everyday power.
Discover Ecoflow’s Fast and Convenient Wireless Charging Solutions
The latest update for the iPhone 17 unlocks a world of new potential for wireless charging. With Qi2.2 compatibility, you can choose from a range of accessories and wireless charging products, including the EcoFlow RAPID Mag Power Bank (Built-in USB-C Cable). When paired with the right charger, you can enjoy 25W wireless speeds and charge more conveniently than ever before, all while knowing you’re protecting your battery from harm (and avoiding tangled wires!).
For whole-home backup, EcoFlow has you covered. Shop the full range of battery systems so you can keep your devices powered day and night.
