Tornado Warning Colorado: Is There One Active Right Now?
As of the most recent check, the National Weather Service had no active tornado warnings posted for Colorado. That's good news in the moment, but it doesn't tell you much about how often the state actually deals with tornadoes, and the real numbers catch a lot of people off guard. This post covers how to check for a live warning yourself, how many tornadoes Colorado really sees, and when they're most likely to hit. It also covers where the risk concentrates, the most extreme events on record, and how to get ready if you live in the state's higher-risk corridor.
Is There a Tornado Warning in Colorado Right Now?
Checking takes about thirty seconds, and it's worth doing before you read another word of this article. The National Weather Service issues these alerts the moment conditions turn dangerous, not on a fixed schedule, so a live tracking tool tells you a lot more than yesterday's forecast ever could.
Here's what each situation actually means for you:
  • No warning right now. Conditions can shift fast once Colorado's peak season gets going, so a clear result today doesn't rule one out tomorrow.
  • A warning is active. A tornado has been spotted or picked up on radar somewhere in your county. Get to your safest room right away. Don't wait to see it with your own eyes first.
  • Still checking status. Live tracking tools and NWS alerts refresh often enough to reflect what's actually happening now, not a static list from last week.
Pulling up your own county's radar and warning history only takes a couple of clicks once you know where to check for live warnings. It's a habit worth building before storms start firing regularly.
Beyond today's status, it helps to understand how often Colorado actually deals with tornadoes in the first place.
How Many Tornadoes Does Colorado Actually Get?
A lot of people picture tornadoes as a Kansas or Oklahoma problem and assume Colorado barely registers. The real numbers say otherwise, and they've been climbing for years.
Combining modern storm-tracking data with older historical archives puts Colorado's tornado count at 2,485 recorded since 1680. The National Weather Service's Boulder office, using the more standardized 1950-to-2024 record, counts 2,452 tornadoes over that 75-year span, which lines up closely once you account for the different start dates. Either way, this isn't a rare event for the state.
Measure
Figure
Tornadoes recorded since 1680
2,485
Historical annual average
16.7
Last decade's annual average
37.3
Deaths recorded
37
Injuries recorded
474
Property damage recorded
$290.9 million
That jump from a 16.7-per-year historical average to 37.3 a year over the last decade is the number that tends to surprise people most. Some of it comes down to better detection technology and more storm spotters on the ground. NOAA's National Centers for Environmental Information maintains the underlying severe weather records used across the industry. Not all of it comes down to detection, though. Colorado's Front Range and eastern plains genuinely see more organized storm activity than they used to.
Colorado's own six-week peak looks different once you set it against how tornado season shifts regionally across the rest of the country.
Those numbers aren't spread evenly across the calendar. Colorado has a distinct peak window, and it's worth planning around.
Colorado's Peak Tornado Season and Time of Day
colorado tornado warningcolorado tornado warning
If you only prepare for one month, make it June. The data on when Colorado tornadoes actually strike is about as lopsided as it gets.
  • June dominates. June alone accounts for 36.2% of Colorado's recorded tornadoes, by far the busiest month of the year.
  • Late afternoon is riskiest. Most tornadoes strike around 4 p.m. local time, when daytime heating has built up the most atmospheric instability.
  • Two years stand out. 1996 was the most active year on record with 98 tornadoes. June 21, 2023 set the single-day record with 37 tornadoes in 24 hours.
Watching the forecast tighten as June approaches matters more in Colorado than in states where risk spreads evenly across the year. Getting the seasonal outlook and safety prep sorted before that window opens beats scrambling once storms are already firing across the plains.
Because so much of the state's tornado activity crowds into one six-week stretch, having backup power ready before June arrives beats trying to track something down once storms are already rolling through. A tornado can knock out power across an entire neighborhood in seconds, even when your own house never takes a direct hit. Not having to wait on a utility crew, or chase down a generator alongside everyone else in your county, makes a real difference in those first few hours.
EcoFlow's DELTA Pro 3 and DELTA Pro Ultra X are both built with that kind of fast-hitting, short-notice outage in mind.
EcoFlow DELTA Pro 3
•High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. •Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. • Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. •Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Features a fast 20ms auto switchover when it matters most. •High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
Timing is one part of the picture. Location within the state matters just as much.
Where in Colorado Tornadoes Actually Strike
Averages for the whole state only tell part of the story. Where you actually live changes the math quite a bit.
County
Tornadoes recorded
Share of state total
Weld
298
About 12%
Washington
222
About 9%
Adams
195
About 8%
Weld County leads by a wide margin, and together these three counties account for nearly 30% of all tornado activity recorded statewide. All three sit on Colorado's eastern plains, right where the High Plains start to flatten out into the broader tornado alley corridor that stretches on through Kansas and Nebraska. If your address falls somewhere in that stretch, the statewide average understates your actual risk by a noticeable margin.
Those county totals include some genuinely extreme individual events worth knowing about.
Colorado's Most Extreme Tornado Events
Most Colorado tornadoes are minor, brief touchdowns that do little damage. A handful of exceptions, though, show just how bad it can get.
  • The only F4 on record. A tornado in Baca County on May 15, 1977 remains the only F4-rated tornado Colorado has recorded since 1950.
  • The deadliest. An F4 tornado in Washington County in 1924 killed 11 people and injured 7 more, the highest single-event death toll in state history.
  • The longest path. A 1922 tornado in Crowley County tracked 79.5 miles, one of the longest tornado paths ever recorded in Colorado.
Staying on the ground for 79 miles means a tornado crosses through entirely different terrain and weather along the way. That's a big part of a tornado's damage path length and why some tracks run so much longer than others.
Big historical events aside, the everyday question is simpler: what do you actually do if you live in this corridor?
How to Prepare If You Live in Colorado's Tornado Corridor
Tornado in colorado preparednessTornado in colorado preparedness
If your address falls in Weld, Washington, or Adams County, you're working with meaningfully higher odds than the statewide average suggests, and it's worth treating that seriously.
Building a shelter plan before June beats figuring one out mid-season, when a watch is already posted and the pressure is on. That starts with picking out your safest room ahead of time. Doing it now, rather than during an actual warning, means everyone in the house already knows which room holds up best without anyone having to think it through under pressure.
Colorado currently has no active tornado warnings, but the state has recorded nearly 2,500 tornadoes since 1680. Activity runs heaviest in June, around 4 p.m., and concentrates in the eastern plains counties of Weld, Washington, and Adams. Check your county's history, pick your safest room, and have backup power ready before summer arrives. EcoFlow's DELTA Pro 3 and DELTA Pro Ultra X are both built to keep your home running through exactly that kind of outage.
Is there a tornado warning in Colorado today?
Check the National Weather Service's live alerts for your specific county, since warnings are issued as conditions develop rather than on a set schedule. As of the most recent check, no tornado warnings were active statewide.
How often does Colorado get tornadoes?
Colorado has recorded roughly 2,485 tornadoes since 1680, averaging 16.7 a year historically. That average has climbed to about 37.3 a year over the last decade.
What month has the most tornadoes in Colorado?
June, by a wide margin. It accounts for 36.2% of all tornadoes recorded in the state, and most strike in the late afternoon around 4 p.m.
Which Colorado counties have the most tornadoes?
Weld County leads with 298 recorded tornadoes, followed by Washington County with 222 and Adams County with 195. All three sit on the state's eastern plains.
What was the worst tornado in Colorado's history?
The deadliest was an F4 in Washington County in 1924 that killed 11 people. The only F4 on record since 1950 hit Baca County in 1977. If you're in one of these higher-risk counties, keeping a home battery system like the EcoFlow DELTA Pro 3 charged and ready before storm season starts can keep your essentials running when the power goes out.
Power Outages
