Solar Panels for a Pool Pump: What It Actually Takes
- How Much Power a Pool Pump Actually Uses
- Variable-speed pool pumps
- DC Solar Pumps vs. Adding Panels to an AC Pump
- Adding Battery Backup for Flexible Pump Timing
- Roughly Sizing a Solar Setup for a Pool Pump
- Keeping the Pool Running When the Power Goes Out
- Conclusion
- FAQs
- Is a DC solar pool pump better than converting an existing AC pump?
A pool pump can be one of the biggest electricity users in a home with a pool. The right solar setup can cut that power draw, but the number of panels you need depends on the pump, how long it runs, and how much sunlight your property gets. Here’s how to size the system, choose between AC and DC pumps, and keep the pool running during a power outage.
A pool pump can be one of the larger electricity loads in a home with a pool. Its power use depends on the pump's horsepower, motor type, and how many hours it runs each day. A typical 1 to 1.5 HP single-speed pump draws around 1,100 to 2,200 watts while running. At six to eight hours of daily use, that can add close to $300 a year to an electric bill at national average rates.
Single-speed pool pumps
A single-speed pump runs at one fixed speed, so its power usage stays fairly consistent while it's running. That can mean higher electricity use if you need to keep the pump on for several hours each day, which also increases the amount of solar power you'll need to cover its operation.
A variable-speed pump can run at a lower speed for longer periods instead of operating at full power the whole time. This can significantly reduce electricity use while still providing the circulation and filtration your pool needs. If you're planning a solar setup, lower daily energy use can also mean fewer panels are needed.
Check the pump's label or manual before sizing your solar system. The rated wattage and daily runtime will give you a more useful estimate than horsepower alone. For another pump example, see how much power a well pump uses. Once you know how much power your pool pump needs, the next question is how to connect it to solar.
There are two main ways to use solar power for a pool pump. You can replace your existing pump with a DC solar model, or keep your AC pump and build a solar system around it. The better fit depends on the equipment you already have and whether you want the pump to run only during sunny hours or at other times, too.
Dedicated DC solar pool pump
You can run a dedicated solar DC pool pump right off the solar array, often four to six panels. Basic day-time operation requires no battery or separate inverter. The pump runs when the panels are producing enough power, so it's a straightforward option if you're mainly planning to circulate the pool during daylight hours.
Keep your existing AC pump
If you want to keep your current AC pump, the solar system needs an inverter to convert the panels' DC electricity into AC power. Adding a battery gives you more control over when the pump runs because you can store solar power and use it later instead of relying on sunlight at that moment.
What about a grid-tied system?
A grid-tied solar system without a battery works differently. The panels produce electricity that offsets your home's power use over the billing cycle. Your pool pump can continue to draw electricity from the grid, rather than running directly from the panels as they produce power.
If you're looking at other ways to use solar around your pool, solar pool heating is a separate setup that uses the sun to heat the water rather than power the pump. Whichever setup you choose, battery storage gives you more flexibility than solar panels alone. You can store excess solar power during the day and use it when the pump needs to run later. That's where a portable power station can fit into the setup.
Solar panels only produce power when there’s enough sunlight, so they can limit when your pool pump runs. A portable power station can store the extra solar energy you produce during the day and make it available later, letting you run the pump or other pool equipment in the morning, evening, or during an outage instead of relying on midday sunlight.
If your pool pump needs more power or you want to run other equipment at the same time, the DELTA 3 Max gives you more capacity and higher output. Its 2,048Wh battery and 2,400W AC output make it a better fit for larger backup setups.
With battery storage available, you have more flexibility around when the pump runs. The next step is to figure out how much solar power you'll need based on your pump's size and daily energy use.
The number of solar panels you need depends on how much electricity your pump uses each day. A larger pump or longer runtime means higher daily energy use, so you'll need a larger solar array to cover it. The table below gives you a rough starting point based on pump size and daily energy use.
Pump Size | Approx. Daily Energy Use | Rough Panel Count Needed |
0.5-1 HP | 4-8 kWh/day | 4-6 panels (300-400W each) |
1-1.5 HP | 8-15 kWh/day | 6-10 panels (300-400W each) |
1.5-2.5 HP | 15-20+ kWh/day | 10+ panels (300-400W each) |
These numbers are estimates, not a final system size. Actual solar production changes with sunlight, weather, panel placement, and other system losses. A pump that runs longer each day will also need more energy than one with a shorter schedule.
If you're planning a larger setup, smart pool solar systems can help you understand how monitoring and system sizing fit together. Sizing the solar array is only part of the plan. You also need to think about how you'll keep the pump running when the grid goes down.
A power outage stops the pool pump along with the rest of your home's electrical equipment. If the pump is off for a day or two, the water can stop circulating and algae and bacteria can build up. But you don't have to run the pump all the time. Running it for a few hours on stored battery power can keep the water moving and help distribute chemicals until grid power returns.
In a longer outage, you can prioritize the pump over less important devices and get more run time out of your batteries. That gives you more time to keep the pool circulating and save power for other essentials. If you need more guidance, this pool maintenance guide covers what to do when an outage lasts longer than expected.
Solar panels can power a pool pump through a dedicated DC pump or an existing AC pump with the right inverter and, when needed, battery storage. Start by checking your pump's actual wattage and daily runtime before estimating how many panels you'll need. Battery storage can give you more freedom to run the pump outside during sunny hours and keep it going during an outage. EcoFlow's DELTA 3 Plus and DELTA 3 Max can charge directly from solar and provide backup power for compatible pool equipment, giving you another option when you want to keep the pump running after the sun goes down or the grid goes out.
How many solar panels does it take to run a pool pump?
The number of panels you will need is dependent on the size of the pump, how many hours per day you will be running the pump and the output of each panel. For a rough estimate, a 0.5 to 1 HP pump will need four to six 300 to 400W panels and a 1 to 1.5 HP pump will need six to 10 panels. Bigger pumps might need 10 or more panels. Check the pump's actual wattage before choosing a system.
Can a pool pump run directly off solar panels without a battery?
Yes. The pump is powered by the electricity generated by the panels and so it only works when there is enough sunlight to power it. If you have an existing AC pump, you will need an inverter to convert the DC power from the panels to AC power. A battery isn't required, but it can let you run the pump when solar production is low.
Is a variable-speed pump worth it for a solar setup?
The variable-speed pump can save electricity by running at a lower speed for longer periods. That can reduce the pump’s daily energy use and may reduce the amount of solar power you need. Whether replacing your current pump makes sense depends on its age, power use, operating schedule, and replacement cost.
What happens to a pool if the pump stops running during an outage?
The water stops circulating and filtering when the pump loses power. During a longer outage, that can lead to water-quality problems, especially in hot weather. Running the pump for a few hours from stored battery power can keep the water moving and help distribute pool chemicals until grid power returns.
It is contingent upon what setup you want. If you are building a new solar pool system and intend to run the pump mainly during sunny hours, a DC solar pump can be a good fit. If you’re not planning to replace it, it can make more sense to keep an existing AC pump. An inverter and battery can also give an AC pump more flexibility over when it runs.
