Solar Panel Removal and Reinstallation: What to Expect and What It Costs
If your solar panels are still going strong but your roof needs work, you may have to take the panels down before the roofing crew can get started. It's a common situation, especially since solar panels can last 25 to 30 years while roofs often need attention sooner. The good news is that removing and reinstalling a solar system is a routine job for a qualified solar professional. Here's what the process involves, what you can expect to pay, and how to keep your home powered while the system is offline.
Why Solar Panels Need to Come Off in the First Place
It's rarely about the panels failing. More often, the roof reaches the end of its life while the solar system still has years of useful service left. A roof can also need work in a specific area that happens to sit underneath or next to the array. In either case, the panels may need to come off temporarily so the work can be done properly.
The most common reasons include:
  • Roof repair or replacement: A roofing crew needs access to the surface beneath the solar array. Removing the panels gives them room to repair or replace the roof without working around the equipment.
  • Loose or damaged mounting hardware: If part of the racking has become loose or damaged, the panels may need to be removed so the installer can reach the hardware, repair it, and secure the system again.
  • Other rooftop work: HVAC service, chimney repairs, or tree trimming near the array can sometimes require temporary panel removal. Clearing the panels out of the way gives workers safer access to the area they need.
Whatever the reason, taking the panels down is only the first part of the job. The system has to be safely disconnected, the equipment handled and stored properly, and everything put back and checked before your solar production can resume.
What the Process Actually Looks Like
Solar panel removal and reinstallation follows a fairly predictable sequence. The exact work can vary with the size of your system and the roof, but a professional crew will generally handle it in five stages.
What the Process Actually Looks LikeWhat the Process Actually Looks Like
  1. The system and roof are assessed. A solar professional starts by looking over the panels, roof, mounting hardware, and the work that needs to be done. They can then give you a quote and a timeline for taking the system down and putting it back up. If you're replacing the roof, this is also a good time to make sure the solar installer and roofing contractor are on the same schedule.
  2. The system is safely shut down and removed. Before anything comes off the roof, the solar system is de-energized. The installer then removes the panels along with the necessary racking and wiring. Since the system is connected to electrical equipment and may be tied to the utility grid, this isn't a job to hand to the roofing crew or tackle on your own.
  3. The panels are stored if needed. If the roof work won't be finished right away, the panels need a safe place to wait. A secure, dry indoor location is the better choice. Keeping moisture away from the electrical connectors helps prevent problems when the system is ready to go back together.
  4. The roof or other repair work is completed. With the solar equipment out of the way, the roofing or repair crew has a clear surface to work on. They can replace the roof, repair damaged areas, or complete other work without having to work around the panels.
  5. Everything goes back and the system is recommissioned. Once the roof work is finished, the solar installer returns the panels, racking, and wiring to their proper positions. The system is then reenergized and checked to make sure it's properly connected and ready to operate with the utility grid again.
How long does solar panel removal and reinstallation take?
For a typical residential system, plan on about one day for removal and another two to three days for reinstallation and recommissioning after the roof work is complete. That doesn't include the time needed for the roofing project itself. The longer your panels stay off the roof, the longer your home goes without its normal solar production. Having a backup power option ready before the work starts can help cover that gap, especially if the project stretches beyond the original schedule.
Is This a DIY Job? Short Answer: No
Is This a DIY Job?Is This a DIY Job?
Solar panel removal and reinstallation is one of those jobs that's better left to a qualified professional. The system has electrical connections that can be tied to your home and the utility grid, so shutting it down and disconnecting everything safely takes the right training and equipment. There's also a real risk of damaging the panels, wiring, inverter, or mounting hardware if something is handled incorrectly.
Having a solar professional do the work can also help protect your equipment warranties and keep the project in line with applicable permitting and utility requirements. Your roofing contractor can take care of the roof, while the solar installer handles the array. Before the panels go back into service, the installer can check the connections and make sure the system is ready to operate normally again.
What Does It Actually Cost?
Solar panel removal and reinstallation typically costs around $275 to $300 per panel, according to recent project data from Paradise Energy. Since the price is generally tied to the number of panels being handled, larger solar arrays can quickly become more expensive. For example, a homeowner with 15 panels would be looking at roughly $4,125 to $4,500, while a 50-panel system could cost $13,750 to $15,000.
System Size
Estimated Cost
15-panel system
$4,125 - $4,500
30-panel system
$8,250 - $9,000
50-panel system
$13,750 - $15,000
What can affect the final cost?
The $275–$300 per panel range is a starting point. Your roof's height and pitch, panel layout, roofing material, crew travel, and how long the system stays offline can all affect the final price.
Your existing equipment matters, too. Panels, racking, wiring, and microinverters can usually be reused if they're in good condition, while damaged hardware may need replacement. Get a written estimate before work begins, and plan for how you'll keep your home powered while the system is offline.
Keeping the Lights On While Your System Is Offline
Once your solar system is de-energized, your panels will not produce power for your home until they are re-installed and turned back on. That can mean no solar for days at a time, particularly if you’re doing a roof project. A charged solar battery can help fill that gap by keeping essential appliances and circuits running while the panels are off. EcoFlow offers options at two different scales: the DELTA Pro Ultra X for whole-home coverage and the DELTA 3 Max for a smaller, more portable setup.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. •Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. •High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
For a more portable option, the EcoFlow DELTA 3 Max (2,048Wh) is a portable power station designed to keep essential appliances and devices running during a temporary solar shutdown.
•2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
With your backup power sorted, it's worth taking a few steps before the panels come off the roof. Choosing the right installer, confirming the scope of work, and checking what happens to your existing equipment can help protect your system and avoid unexpected costs later.
Protecting Your Investment Before You Hire Anyone
A little planning before the panels come down can save you from unexpected costs later. You'll want to know who is handling the solar equipment, how long the system will be offline, and whether the roof is worth putting the array back on in the first place.
Protecting Your Investment Before You Hire AnyoneProtecting Your Investment Before You Hire Anyone
Choose the right installer and get the details in writing
Have a solar specialist handle the removal and reinstallation rather than leaving the job to a general roofing crew. Ask how much experience they have with this type of work, how long they expect the system to be offline, and what the quote includes. It's also worth getting the plan in writing, including which panels, inverters, racking, and wiring will be reused and which parts may need to be replaced.
Check your roof, insurance, and equipment
Before reinstalling the system, make sure the roof has enough remaining life to make the investment worthwhile. You don't want to pay for another removal a few years from now because the roof needs to be replaced again. If storm or disaster damage caused the work, check with your homeowners insurance provider to see whether your policy covers solar removal and reinstallation. Finally, have the installer document any damaged equipment they find before agreeing to replacement costs.
Solar panel removal and reinstallation is a manageable part of owning a rooftop system when the job is planned properly. Hire a qualified solar professional, get a clear estimate, confirm which equipment can be reused, and make sure your roof is ready before the panels go back up. Since the system will be offline during the work, having backup power ready can also keep your home running without interruption. For larger home power needs, consider the EcoFlow DELTA Pro Ultra X, or choose the more portable DELTA 3 Max for essential devices.
How much does it cost to remove and reinstall solar panels?
Solar panel removal and reinstallation typically costs $275 to $300 per panel. A 15-panel system could cost about $4,125 to $4,500, while a 30-panel system could run $8,250 to $9,000. Your final price can vary based on the roof, panel layout, labor, equipment condition, and scope of the work.
Can I remove and reinstall my own solar panels?
No. Because solar systems include electrical connections, rooftop equipment and utility-grid connections, it’s best to have a qualified solar professional do the work. Professional removal can also lower the risk of damaging your panels or other components and may help prevent potential warranty or permitting issues.
For a typical residential system, removal can take up to a day, and then after the roof work is done, it can take another two to three days to reinstall and recommission. The roofing project itself can add more time, so your solar system may remain offline for several days.
Will my existing solar equipment be reused or replaced?
Frequently, yes. Panels, racking, wiring and microinverters can usually be reused if they are in good shape. Your installer should inspect the equipment during removal and let you know if any damaged components need to be replaced before the system is reinstalled.
Does homeowners insurance cover solar panel removal and reinstallation?
It depends on your policy and why the panels need to be removed. If a covered storm or disaster caused the roof damage, your policy may cover some removal and reinstallation costs. Check with your insurance provider before work begins to confirm your coverage and any documentation you'll need.
Solar Panels
