RV vs. Motorhome: What's Actually the Difference
RV and motorhome are commonly used interchangeably, although they are not the same thing. RV is the catch-all name for recreational vehicles, which are towable and powered. A motorhome is an RV containing both the engine and living quarters. This book covers the major distinctions between towable RVs and motorhomes, the three classes of motorhomes, their power requirements, and factors to consider when deciding between them.
RV Is the Umbrella Term, Motorhome Is One Branch
RV is a blanket term for recreational vehicles. These are vehicles for travel, for amusement, for temporary habitation. They range from little teardrop trailers to large Class A motorhomes. There are two types of RVs – towable RVs, which are pulled by another vehicle, and motorized RVs, which are self-propelled vehicles with their own engine and driving cab. A motorhome combines the vehicle and living space in one unit, while travel trailers and fifth wheels are separate living spaces that connect to a truck or SUV. If you're also wondering how the term RV differs from camper, see The real difference between an RV and a Camper for a closer look at the terminology. In short, a travel trailer or fifth wheel is an RV but not a motorhome, while Class A, B, and C vehicles are both RVs and motorhomes.
RV vs. motorhome at a glance
Feature
RV
Motorhome
Defination
Broad category of recreational vehicles
A type of RV with its own engine
Types
Towable and motorized
Class A, Class B, and Class C
Engine
May or may not have its own engine
Has its own engine
Tow vehicle
Required for towable RVs
Not required
Living and driving areas
Maybe separate
Combined in one vehicle
Examples
Travel trailers, fifth wheels, pop-ups, motorhomes
Class A, B, and C motorhomes
Motorhomes are one branch of the RV category, but they are also divided into three main classes. Class A, Class B, and Class C motorhomes differ in size, chassis, interior layout, and maneuverability, making each suited to different travel needs.
The Three Motorhome Classes
Motorhomes are divided into three main classes: Class A, Class B, and Class C, each with different sizes, layouts, and driving characteristics. Class A models offer the most interior space, while Class B models are more compact and easier to maneuver. Class C motorhomes provide a balance of living space and drivability. Adding solar to a motorhome can also vary by class because each type has different roof space and power requirements.
Three motorhome classesThree motorhome classes
Class
Chassis
Typical Characteristics
Best For
Class A
Bus-style chassis
Largest interiors and extensive amenities
Full-time living, long trips, maximum space
Class B
Full-size van chassis
Compact and easy to drive
Easy driving, solo or couple travel
Class C
Truck/cutaway van chassis
Cab-forward design with additional living space
Balance of space and maneuverability
Class A Motorhomes
Class A Motorhomes are the largest of the motorhome types and are generally built on a bus-style chassis and include a huge interior. They often have full kitchens, baths, bedrooms, and beautiful living areas. Their size and amenities make them great for long journeys and full-time RV living.
Class B Motorhomes
Class B motorhomes are small RVs that are constructed on full-size van chassis, so they're easier to drive and navigate than larger motorhomes. Inside, they make good use of space, often with sleeping areas, tiny kitchens, bathrooms, and storage. Usually, they are a good choice for solo travelers and couples.
Class C Motorhomes
Class C motorhomes are often built on a truck or cutaway van chassis and are recognized by the sleeping or storage compartment over the driver's cab. They offer more inside capacity than other Class B models, while still being easier to operate than bigger Class A motorhomes. They can be a suitable option for families and longer travels.
Depending on whether you choose a Class A, B, or C motorhome or a towable RV, your power consumption will be dictated by the size of your rig and the appliances you use. Motorhomes may recharge their house batteries while on the move using the vehicle’s charging system, while towable RVs rely on additional charging sources. Knowing the differences might help you plan a stable power configuration for your trips.
How Power Needs Differ Between RV Types
Motorhomes and towable RVs have various electrical system configurations; hence their power requirements are variable. Motorhomes often have a means to charge their house batteries from the vehicle's alternator while traveling. Towables have to rely on their onboard batteries, solar, shore power, or generators. A portable power station can provide an additional flexible power source for either kind when campsite hookups are not available.
EcoFlow DELTA 3 Plus — Portable Power for Towable RVs
For towable RVs, having a separate power source can be useful when campground hookups are unavailable. The EcoFlow DELTA 3 Plus provides 1,800W of continuous output and starts with 1kWh of capacity, which can be expanded up to 5kWh. It also has a range of charging options, including solar and an 800W alternator charger, making it a versatile choice for RV travel.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
EcoFlow DELTA Pro — Portable Power for Larger Motorhomes
With the EcoFlow DELTA Pro, you can get 3.6kWh of initial capacity, scalable to 25kWh, and an AC output of 3,600W (expandable to 7,200W with two units and Double Voltage Hub), depending on configuration. It is also compatible with EV charging, giving you versatile options on the road.
EcoFlow DELTA Pro
•Expandable Capacity: 3.6kWh to 25kWh expandable capacity with DELTA Pro Smart Extra Battery. •Powerful AC Output: 3,600W AC output (expandable to 7,200W with two units and Double Voltage Hub). • Home Backup: Plug & Play home backup solution. • Fast Charging: Incredible 6500W MultiCharge delivering 2.7 hours of AC charging. •EV Charging: Industry first feature allowing recharge at thousands of EV stations worldwide. • Durability: Long-lasting LFP battery supporting up to 10 years of use.
Power is just one consideration when buying an RV. If you choose to have a towable configuration with a separate tow vehicle, there are multiple types of towable RVs with various sizes, hitch systems, and towing requirements. Travel trailers, fifth wheels, pop-up campers, and teardrop trailers give you many alternatives for room, comfort, and portability.
Towable RVs: Travel Trailers, Fifth Wheels, and More
Motorhomes are only one part of the RV category. Towable RVs offer several configurations, including travel trailers, fifth wheels, pop-up campers, and teardrop trailers, each with different towing requirements, sizes, and interior layouts.
Towable RVs: Travel trailers, fifth wheels, and moreTowable RVs: Travel trailers, fifth wheels, and more
Travel trailers
Travel trailers are one of the most popular types of towable RVs. They connect to a proper vehicle or SUV using a hitch and are available in a wide range of sizes. It is reasonably easy to tow smaller models behind a car, but larger trailers can have several sleeping places, restrooms, dining areas, bedrooms, and kitchens. Before buying, make sure your tow vehicle's capacity matches the trailer's loaded weight and hitch requirements.
Fifth wheels
Fifth wheels connect to a hitch mounted on the bed of a pickup truck rather than attaching behind the rear bumper. Their front section extends over the truck bed, creating distinctive floor plans and additional interior space. Because they are often larger and heavier than travel trailers, fifth wheels generally require an appropriately equipped pickup truck.
Pop-up and teardrop trailers
Pop-up campers and teardrop trailers are smaller towable solutions for those who desire a simpler camping arrangement. Pop-ups fold down for easy storage and transportation. Teardrop trailers are small and aerodynamic. Their smaller size can be attractive to travelers who value portability, easy setups, and towing.
If you are planning a travel trailer setup, sizing a battery for a travel trailer can help you determine whether your existing battery capacity is suitable for your expected electrical needs.
Which One Actually Fits You
The right choice depends on your budget, driving preferences, storage space, and travel style. Towable RVs generally cost less upfront than a comparably sized motorhome, while motorhomes offer a more convenient driving experience without the need to manage a separate tow vehicle. Storage and maintenance also matter: a motorhome occupies the entire vehicle when parked, while a towable can be unhitched and left at a campsite. Power needs are another consideration, and portable power stations built for RV use can provide a flexible source of electricity for appliances and devices when hookups are unavailable.
An RV is the umbrella term. A motorhome is a Class A, B, or C and is a self-driving RV. Towable items such as travel trailers and fifth wheels require a separate vehicle to tow. When choosing between them, consider your budget, driving preferences, storage space, and power requirements. For even more capacity, EcoFlow's DELTA 3 Plus can power towable RVs on the go, and the DELTA Pro has an even bigger capacity for larger motorhomes and longer excursions.
1. Is a motorhome the same thing as an RV?
A motorhome is a type of RV, but the two terms are not interchangeable in the strictest sense. RV is the broader category that includes motorhomes as well as towable vehicles such as travel trailers and fifth wheels. In other words, every motorhome is an RV, but not every RV is a motorhome.
2. What are the three classes of motorhomes?
The three main motorhome classes are Class A, Class B, and Class C. Class A models are generally the largest, Class B models are typically van-based and compact, and Class C models commonly use a truck or cutaway van chassis with a cab-over section. Each class offers a different balance of interior space, maneuverability, storage, and amenities.
3. Is a travel trailer considered an RV or a motorhome?
A travel trailer is an RV, but it is not a motorhome. It does not have its own engine and must be towed by a compatible vehicle. This also means you can typically disconnect the trailer at a campsite and use the tow vehicle independently.
4. Which is cheaper, a towable RV or a motorhome?
The purchase price of a towable RV can be lower than that of a comparable motorhome, but the total cost depends on the complete setup. Towable RV owners also need a suitable tow vehicle if they do not already have one, along with associated fuel, maintenance, and equipment costs. Comparing the entire ownership setup rather than only the RV's sticker price gives a more useful picture of the cost.
5. Do I need a special license to drive a motorhome?
Licensing requirements for motorhomes vary by jurisdiction and can depend on factors such as vehicle weight and local regulations. Some motorhomes can be driven with a standard driver's license, while heavier vehicles may be subject to additional requirements in certain locations. Always check the current licensing rules with the relevant transportation or motor-vehicle authority where you will drive the motorhome.
RV and Motorhomes
