Pros and Cons of Fossil Fuels: The Full Breakdown
Coal, oil and natural gas continue to be the dominant sources of energy in the U.S. Fossil fuels accounted for approximately 58% of US electricity generation in 2025, according to the EIA. That endurance is a function of energy density, existing infrastructure and a steady flow of fuel. But fossil fuels have obvious drawbacks, including greenhouse gas emissions, finite reserves, price swings, and environmental risks. Here's a closer look at the pros and cons of fossil fuels and where backup power fits into the picture.
What Counts as a Fossil Fuel
Fossil fuels originate from plants, animals and other things that were buried and transformed over millions of years. The three main types are coal, petroleum and natural gas. All three are nonrenewable resources meaning that nature replaces them much more slowly than we use them.
Coal
Coal is a solid fossil fuel that has been used for decades for the generation of electricity and in industrial processes. In a power plant, coal is burned to produce heat to turn water to steam. The steam runs a machine that makes electric power. Coal is still part of the U.S. energy mix, although its share of electricity generation has declined as other sources have grown.
Petroleum
Petroleum, also called crude oil, is a liquid fossil fuel. Refineries process crude oil into gasoline, diesel, jet fuel, and other products. Most Americans use petroleum every day through transportation, but it also goes into plastics, chemicals, asphalt, and other manufactured goods. Unlike coal and natural gas, petroleum plays a much larger role in transportation than in U.S. electricity generation.
Natural gas
Natural gas is used for home heating, cooking, industry, and electricity generation. It burns more cleanly than coal or oil, but still releases carbon dioxide. It’s also the largest single source of U.S. electricity generation today. These fuels have different uses, but all come from finite supplies. See this guide to fossil fuels for more detail.
The Advantages of Fossil Fuels
They are still widely used because they provide practical advantages for electricity, transport and industry. They have remained part of the U.S. energy system because they have high energy density, existing infrastructure and the ability to provide power when it is needed.
The Advantages of Fossil FuelsThe Advantages of Fossil Fuels
High energy density
Fossil fuels contain a lot of energy in a relatively small amount of fuel. That makes them practical to store and transport, whether the fuel is moving through a pipeline, shipped across the country, or stored for use in a generator.
Established infrastructure
The U.S. already has pipelines, refineries, power plants, storage facilities, and transportation networks built around fossil fuels. This existing system makes it easier to produce, move, store, and use these fuels on a large scale.
Power when needed
Natural gas and coal-fired power plants can make electricity when we need it, whether the sun is shining or the wind is blowing. That makes these fuels useful for meeting steady electricity demand and supporting the grid when other sources produce less power.
Support for jobs
The fossil fuel industry supports jobs across several areas, including extraction, transportation, processing, and power generation. The industry also creates demand for equipment, maintenance, construction, and other related services.
One of the reasons for having fuel-powered generators for back-up power is that homeowners are able to generate electricity as needed. Considering a purchase? This guide explains what you can expect from a natural gas generator and the costs to operate it. These benefits help explain why fossil fuels continue to be used. But the same energy sources also bring costs related to emissions, fuel supply, prices, and environmental impact.
Where Backup Power Fits Into the Picture
Whether your home gets electricity from coal, natural gas, or rooftop solar, the grid can still go down during a storm or period of high demand. A battery-based power station gives you backup power without relying on fuel during an outage. It stores electricity ahead of time and runs your essential devices quietly, with no emissions while it's operating.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
If you need to keep more devices running at the same time, the DELTA 3 Max gives you more power to work with. Its larger battery and higher output make it a better fit for bigger home backup needs, especially when an outage lasts longer than expected.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
The DELTA 3 Max gives you more capacity when an outage calls for longer runtime or more devices. But fossil fuels have drawbacks, too. They produce emissions and come from limited supplies. Fuel prices can also change, and extracting these fuels can harm the environment.
The Disadvantages of Fossil Fuels
For decades, fossil fuels have powered much of the U.S. economy, but they are not an endless resource. The use of these also involves emissions and may have environmental effects during extraction and transportation.
 The Disadvantages of Fossil Fuels The Disadvantages of Fossil Fuels
They are a finite resource
Fossil fuels such as coal, crude oil, and natural gas take millions of years to form from organic material buried deep beneath the Earth's surface. Because modern societies extract and consume these reserves far faster than natural processes can replenish them, fossil fuels are considered non-renewable resources. Geological deposits are limited, meaning continued reliance on fossil fuels can lead to declining supplies and greater challenges as easily accessible reserves are depleted.
They produce greenhouse gas emissions
Burning fossil fuels releases carbon dioxide and other pollutants. The EPA links greenhouse gas emissions from human activity to climate change. The amount of pollution varies by fuel and how it is used, but fossil fuel combustion remains a major source of emissions.
Fuel prices can fluctuate
Fossil fuel prices can be affected by supply and demand, production, transportation, and events around the globe. Those changes can affect electricity costs as well as the price of running a gas-powered generator during a long outage.
Extraction can affect the environment
Mining fossil fuels may affect the land and the surrounding ecosystems. Environmental risks can be created by mining, drilling, oil spills and transportation of fuel. These impacts are part of the overall cost of using fossil fuels, beyond the emissions produced when they're burned.
For a broader look at the differences between energy sources, you can compare renewable and nonrenewable energy. These drawbacks are a major reason the U.S. energy mix is changing. Looking at fossil fuels alongside renewable sources makes the tradeoffs easier to see.
Fossil Fuels vs. Renewable Energy at a Glance
Fossil fuels and renewable energy both play a role in meeting electricity needs, but they work in different ways. Fossil fuels rely on finite resources and can provide power on demand. Renewable sources such as solar, wind, and water rely on naturally replenished resources, though some depend on weather and time of day.
Factor
Fossil Fuels
Renewable Energy
Supply
Finite, non-renewable
Effectively unlimited (sun, wind, water)
Emissions
High CO2 and pollutants
Little to none during operation
Reliability
Dispatchable, runs on demand
Weather-dependent without storage
Cost trend
Volatile, tied to global markets
Falling as technology improves
For a closer look at the shift toward renewable energy, this guide to renewable energy explains why utilities are adding more wind and solar power.
Fossil fuels are central to the U.S. energy system because they provide dense, reliable energy and are supported by existing infrastructure. But they also have trade-offs such as limited supplies, changing fuel prices, greenhouse gas emissions and environmental risks. No grid is immune to power outages, no matter where the electricity for that grid is coming from. Backup power in your home can keep you ready when the lights go out. EcoFlow’s DELTA 3 Plus and DELTA 3 Max store electricity for backup use, keeping the lights on and appliances and devices running during a power outage and giving homeowners a no-fuel solution when they need reliable power.
What are the three main types of fossil fuels?
They come in three main types - coal, natural gas and oil. Coal is used mainly for electricity generation and industry. Petroleum is refined into fuels such as gasoline and diesel. Natural gas is used for heating, cooking, industry and electricity generation.
Why are fossil fuels still used if they have so many downsides?
Fossil fuels are still widely used because they have a lot of energy in them, have a supply network already in place, and can provide power when you need it. The U.S. already has pipelines, refineries, power plants and other infrastructure built around those fuels.
How much of the U.S. electricity still comes from fossil fuels?
In 2025, the EIA said fossil fuels accounted for about 58% of U.S. electricity generation. This includes electricity generated from coal, natural gas and petroleum. The share can vary from year to year as electricity demand, fuel use, and renewable generation change.
What is the biggest disadvantage of fossil fuels?
There isn't one single disadvantage. Fossil fuels are finite resources, and burning them releases carbon dioxide and other pollutants. Fuel prices can also change, while extraction and transportation can create environmental risks.
Can renewable energy fully replace fossil fuels?
Renewable energy can replace fossil fuels in various applications. The overall transition depends on electricity demand, generation capacity, transmission, storage, local conditions, etc. Solar and wind power also vary with weather and time of day, so storage and other power sources can help keep electricity available when production drops.
Solar Energy
