What Phone has Wireless Charging?
Look at your desk or nightstand. You probably have a bunch of tangled charging cables there. Plugging your phone in every day can also damage the charging port over time. But there is a much easier way to power up. Wireless charging lets you just place your phone down on a special pad, and it starts charging automatically. No more searching for cables or plugging them in.
This guide will explain everything you need to know about wireless charging phones in simple terms. We’ll show you which phones have wireless charging and how it works. We'll also talk about the good and bad parts of it. Finally, we’ll show you how to have wireless power for your phone, both at home and when you’re on the go.
Which Phones Support Wireless Charging?
The first question people usually ask is, "Does my phone have wireless charging?" The good news is that most new smartphones now include this feature. It used to be something you only found on expensive phones, but now it has become a normal feature. This means you have a lot of choices for phones and chargers, and you can trust that the wireless chargers you buy today will work for a long time.
Popular Wireless Charging Phones Available in 2026
To make it even easier, here is a list of popular phones with wireless charging available in the US market that support wireless charging.
Mainstream Brands (High Popularity)
Brand
Models with Wireless Charging
Key Charging Standard(s)
Apple
iPhone 8/8 Plus, iPhone X/XR/XS/XS Max, iPhone 11/11 Pro/11 Pro Max, iPhone 12/12 mini/12 Pro/12 Pro Max, iPhone 13/13 mini/13 Pro/13 Pro Max, iPhone 14/14 Plus/14 Pro/14 Pro Max, iPhone 15/15 Plus/15 Pro/15 Pro Max, iPhone 16/16 Plus/16 Pro/16 Pro Max, iPhone 17/17 Pro/17 Pro Max/iPhone Air (2025)
Qi, MagSafe
Samsung
Galaxy S25/S25+/S25 Ultra, Galaxy S24/S24+/S24 Ultra, Galaxy S23/S23+/S23 Ultra, Galaxy S22/S22+/S22 Ultra, Galaxy S21/S21+/S21 Ultra, Galaxy Z Fold 6/Z Flip 6, Galaxy Z Fold 5/Z Flip 5, Galaxy Z Fold 4/Z Flip 4, Galaxy Z Fold 3/Z Flip 3, Galaxy Z Fold/Z Flip (1st gen)
Qi, Wireless Power Sharing (reverse charging)
Google
Pixel 4/4 XL, Pixel 5/5a, Pixel 6/6 Pro/6a, Pixel 7/7 Pro/7a, Pixel 8/8 Pro/8a, Pixel 9/9 Pro/9 Pro XL, Pixel 10/10 Pro/10 Pro Fold (2025)
Qi, Qi2 (Pixel 10 series)
Motorola
Motorola Edge 60 Pro, Motorola Edge 70 Pro, Motorola Edge 60 Stylus, Motorola Moto Edge 50 Neo, Moto G Stylus Gen 5 (select high-end Moto G models)
Qi
Niche Brands (Limited Popularity)
Brand
OnePlus
OnePlus 8 Pro, OnePlus 9 Pro, OnePlus 10 Pro, OnePlus 12, OnePlus 13
Qi, 50W Wireless SuperVOOC (OnePlus 13)
Sony
Xperia 1 III, Xperia 1 II, Xperia XZ3, Xperia XZ2
Qi
Nokia
Nokia XR20, Nokia 9 PureView, Nokia 8 Sirocco
Qi
This list is not exhaustive but covers the most common models in America. Always check your specific model's specifications to be certain.
How to Check if Your Phone Has Wireless Charging
If you're asking 'Does my phone have wireless charging?' here are a few quick ways to check compatibility before buying a charger :
  • Check the Official Specs: The easiest method is to search for your phone model's official specification sheet online. Look for terms like "Qi Wireless Charging" or "Wireless Charging compatible."
  • Look for the Logo: Many devices and their packaging feature the universal Qi logo, which looks like the letters 'q' and 'i in a simple, stylized design.
  • Consult the Manufacturer: Your phone manufacturer’s official website is the most reliable source of information about its features.
How Wireless Charging Really Works?
At its core, wireless charging works through electromagnetic induction. Inside every wireless charger for phone is a coil of wire . When you plug the charger in, electricity flows through this coil and creates an invisible magnetic field in the area just above the pad.
Your phone also has a similar coil inside it. When you place your phone on the pad, the magnetic field from the charger causes an electric current to flow in your phone's coil. This newly created electricity is what charges your phone's battery.
In simple terms, this magnetic connection works like an invisible handshake, delivering energy straight to your phone.
The Evolution of Standards: From Good to Great
For this handshake to work between different brands, there needs to be a common language or standard. The evolution of this standard tells a story of continuous improvement.
Qi: The Universal Standard
The first main rule for wireless charging was called Qi (pronounced “Chee”). This was a big step because it meant you could use a phone from one brand with a charging pad from another, and they would work together.
However, the first version of Qi had two main problems:
  • You had to place your phone in the exact right spot, or it wouldn't charge well.
  • The charging speed was often quite slow, like 5W or 7.5W.
MagSafe: Apple's Magnetic Solution
Getting the phone in the right spot was the biggest problem with early wireless charging. Apple’s answer to this was MagSafe.
They put a ring of magnets inside the iPhone that perfectly matches the magnets in a MagSafe charger. This makes the two parts instantly "click" together in the perfect position every time you use it.
This perfect alignment is important because it means less energy is wasted. As a result, the charge is not only more reliable, but also much faster—boosting the speed up to 15W.
A smiling man in profile holds a smartphone with a white, ribbed case and kickstand to his earA smiling man in profile holds a smartphone with a white, ribbed case and kickstand to his ear
Qi2: The Best of Both Worlds
The newest and best rule for wireless charging is called Qi2 (pronounced “Chee Two”).
It takes the best part of Apple's MagSafe—the magnets—and makes it the new standard for all companies to use. This means that new phones and chargers from many different brands can now have that same easy, magnetic snap.
Any phone or charger with Qi2 gives you:
  • Perfect Placement: The magnets "click" the charger into the right spot automatically.
  • Faster Charging: It provides a fast and reliable 15W charge for many different phones.
  • Less Wasted Energy: The perfect connection means less power is lost as heat.
Basically, Qi2 creates one great, simple system for everyone, so you get the best charging experience no matter what phone you use.
The Pros and Cons of Going Wireless
Like any technology, wireless charging has its benefits and things to keep in mind. By understanding both, you can make an informed decision.
The Upside: Why You'll Love It
  • Ultimate Convenience: This is the number one benefit. Simply placing your phone on a pad on your desk or nightstand is far easier than fumbling for a cable in the dark.
  • Reduced Wear and Tear: Every time you plug and unplug a cable, you put stress on your phone's charging port. Over the years, this can lead to damage. Wireless charging eliminates this physical connection, potentially extending the life of your device.
  • A Cleaner Aesthetic: Say goodbye to cable clutter. A wireless charging pad creates a more organized, minimalist, and modern-looking space.
  • Enhanced Safety: You no longer have to worry about frayed cables or bent connectors, which can be a safety hazard. Furthermore, certified chargers have built-in mechanisms to prevent overheating and overcharging.
The Reality Check: What to Keep in Mind
  • Heat Generation: Wireless charging can generate more heat than wired charging. This is because some energy is lost during the wireless transfer, and this lost energy dissipates as heat. Excessive heat can degrade battery health over time.
  • Charging Speed: While getting much faster, wireless charging can still be slower than the fastest wired charging options available for some phones.
  • Energy Efficiency: The wireless transfer process is inherently less efficient than a direct cable connection, meaning it uses slightly more electricity to deliver the same amount of charge.
It is crucial to understand that these drawbacks—heat, slower speeds, and inefficiency—are primarily symptoms of older, non-magnetic Qi technology. The imperfect alignment of the coils was the main culprit behind wasted energy. The magnetic alignment introduced by MagSafe and now standardized in Qi2 directly addresses this root cause. By ensuring a perfect connection every time, Qi2 minimizes energy loss, which in turn reduces excess heat and allows for faster, more efficient power transfer. This makes modern wireless charging significantly more effective and better for your phone's long-term battery health.
Powering Your Wireless Life: From the Desktop to the Great Outdoors
Wireless charging pads have decluttered our desks and nightstands, but they introduce a small irony: the "wireless" charger itself is still tethered to a wall outlet by a wire. This limits the true freedom of wireless charging to a single, stationary spot. What happens when you're on a road trip, working from a coffee shop, or camping for the weekend?
To truly unplug, you need a power source that’s as mobile as you are. For those who want to embrace cable-free power on the move, the EcoFlow RAPID Mag Power Bank series offers two options for the best wireless charger for phone portability.
  • For the minimalist who values portability above all, the EcoFlow RAPID Mag Power Bank (5,000mAh) is the perfect solution. It’s incredibly slim and lightweight, designed to magnetically snap right onto the back of your phone. It’s ideal for daily commutes or a night out, providing a solid power boost to get you through the day without adding bulk or the hassle of a separate cable.
  • For the power user, traveler, or content lover, the EcoFlow RAPID Mag Power Bank (10,000mAh) is a more versatile companion. It offers double the capacity for multiple phone charges and includes a brilliant extra feature: a built-in foldable stand. This allows you to prop your phone up to watch movies or take video calls hands-free, all while it’s charging wirelessly. It’s an all-in-one power and convenience hub that’s perfect for long trips or busy days.
EcoFlow RAPID Mag Power Bank (10,000mAh, 7.5W, Magnetic Charging)
Stay powered anywhere with EcoFlow RAPID Mag. Enjoy 10,000mAh capacity, 7.5W magnetic wireless charging, and sleek portability for all-day use.
Embracing a Cable-Free Future
Wireless charging has officially arrived. It’s no longer a futuristic concept but a reliable, mainstream feature built into the phones we use every day. With the universal Qi2 standard solving the biggest historical drawbacks of speed and efficiency, there has never been a better time to cut the cord. The era of fumbling with cables is over. By pairing your phone with a portable solution like the EcoFlow RAPID Mag series, you can finally experience true charging freedom, keeping you powered wherever life takes you.
5 FAQs about Wireless Charging
Q1: Can I wirelessly charge my phone with its case on?
A: Yes, most of the time. Thin cases made of plastic or silicone usually work fine. But very thick cases or ones with metal parts, like a pop-out stand or finger ring, can stop the charge. If your phone isn’t charging, try taking the case off first. For a sure thing, look for a new case that says it’s made for wireless charging.
Q2: What is reverse wireless charging?
A: It’s a cool feature that lets your phone act like a wireless charger for other gadgets. You can turn it on and then place your wireless earbuds or a friend’s phone on the back of your phone to share your power. It’s not super fast, but it’s great for giving a small, emergency charge when you don't have another charger with you.
Q3: Is it safe to charge my phone on a wireless charger overnight?
A: Yes, it is very safe. Smart chargers and phones know when to stop. Once your battery is full, the charger automatically cuts off the power. Good chargers also have safety features to stop charging if your phone gets too warm. This protects your battery from getting damaged, so you can rest easy leaving it on the charger all night.
Q4: Can one charger power multiple devices at once?
A: Yes, you just need a special kind of charger. Look for ones called “dual chargers” or “3-in-1 stations.” These are made to power your phone, smartwatch, and wireless earbuds all at the same time. It’s a great way to charge everything together and reduce the number of cables on your desk, keeping your space clean and organized.
Q5: My wireless charger isn't working. What should I do?
A: If your charger isn't working, try these quick fixes. First, place your phone right in the center of the pad, as bad placement is a common issue. Next, take off your phone case in case it is too thick. Also, check that the charging pad is plugged into a strong wall plug, not a weak computer port. Finally, try restarting your phone.
