Pepco Outage Map: Checking DC and Maryland Outages, Reporting Fast, and Knowing Who Oversees Restoration
When the power goes out in the Washington, DC, region, knowing where to check matters. Pepco serves the District of Columbia and Maryland's Montgomery and Prince George's counties, but customers in these jurisdictions have different regulators overseeing utility reliability. The quickest way to check affected areas is the Pepco Outage Map. Registered customers who have enrolled in Pepco's outage alert service can also text OUT to 48710 to report an outage. This guide explains how to track Pepco outages, understand restoration estimates, prepare your home, and stay informed during major storms.
Pepco Outage Map: The DC and Maryland Views
Use Pepco's official outage map for reported outages in its DC and Maryland service area. Consult the live page for the location controls, legend, and latest update time; the interface can change.
Use the location controls available on the live map to find your area.
Read the map legend and update time before interpreting outage figures.
For the latest outage information, visit the Pepco Outage Map to check reported power outages in your area. The map provides current outage information to help you stay informed about service interruptions and monitor updates as they become available.
Area | Jurisdiction | Where to check outage figures |
District of Columbia | DC Public Service Commission | |
Montgomery | Maryland Public Service Commission | |
Prince George's | Maryland Public Service Commission | |
Combined service area | DC and Maryland public service commissions |
Use Pepco’s official website or mobile app for outage updates. If a restoration estimate is shown, treat it as an estimate that may change as the work progresses.
How to Report an Outage and Check Updates
Pepco offers several ways to report a power outage, check your status, and receive restoration updates. Knowing which option to use can save time, especially during severe weather when outages affect multiple neighborhoods.
Method | Pepco's instruction |
Text | After registering, text OUT to 48710 to report an outage. Pepco outage reporting guidance. |
Check outage updates | Use Pepco’s official outage website or mobile app to check updates. |
Outage alerts | Text ADD OUTAGE to 48710 to register for the text service or manage alerts through the Preference Center. |
Online | Use the Report an Outage link on Pepco’s Experiencing an Outage page. |
App | Use the Pepco Mobile App, available through the App Store and Google Play. |
Downed lines | Leave the area immediately and call Pepco at 1-877-737-2662, available 24/7 for emergencies. |
Check Pepco’s official outage page or mobile app for updates. If an estimate is provided, it may change as repairs progress. Do not report electrical emergencies through email; call 911 if there is immediate danger. If Dominion Energy supplies your electricity, use its outage resources instead. Backup preparations should reflect your essential loads and housing arrangements.
Backup Power for Pepco Outages in Apartments, Rowhouses, and Suburbs
Pepco serves a mix of district apartments, rowhouses, and single-family homes in Montgomery and Prince George's counties, so backup power needs vary by housing type. Renters often need portable power for refrigerators, routers, lights, and phones, while homeowners can consider professionally installed systems that support selected household circuits. Choosing the right setup depends on your essential loads, available space, and how long an outage may last.
EcoFlow TITAN Plus
For homeowners who want more than portable backup, the EcoFlow TITAN Plus offers a high-output battery system that can support selected household circuits when paired with the required home connection equipment. Its expandable capacity makes it an option for planning around longer Pepco outages and demanding appliances.
EcoFlow TITAN
For homeowners planning backup for selected essential circuits, the EcoFlow TITAN offers a 5kWh starting capacity with 120V/240V split-phase output. Circuit-level home backup requires Smart Home Panel 10 (240V), installed by a qualified electrician. This is a home-backup configuration; renters should agree any installation with their landlord and building management.
How Long Can a Backup Battery Last?
These illustrative runtimes use 5kWh base capacity for both models and assume 85% usable energy after conversion losses. This is a planning assumption, not an EcoFlow runtime claim. Equal stored energy gives the same calculation; the Plus differs in output and solar-input capability. Actual runtime also depends on standby consumption, temperature, and the connected loads.
Continuous load | EcoFlow TITAN (5kWh base) | EcoFlow TITAN Plus (5kWh base) |
150W | about 28.3 hours | about 28.3 hours |
500W | about 8.5 hours | about 8.5 hours |
1,000W | about 4.3 hours | about 4.3 hours |
2,000W | about 2.1 hours | about 2.1 hours |
During a prolonged outage, the EcoFlow TITAN and EcoFlow TITAN Plus can recharge from compatible solar panels when sunlight is available. Home circuit connections require Smart Home Panel 10 (240V) and a qualified electrician. If you rent, discuss any installed backup system with your landlord and include a place to stay in your emergency plan.
One Utility, Two Regulators: How DC and Maryland Oversee Pepco Outages
Pepco operates across two jurisdictions, and each has a separate public service commission. The DC Public Service Commission oversees utility matters in the District, while the Maryland Public Service Commission oversees Pepco service in Montgomery and Prince George's counties.
Topic | District of Columbia | Maryland |
Regulator | DC Public Service Commission (dcpsc.org) | Maryland Public Service Commission (psc.state.md.us) |
Service territory | District of Columbia | Montgomery and Prince George's counties |
Example of oversight | DC PLUG undergrounding program | Major Outage Event reporting requirements |
DC PLUG
The District of Columbia Power Line Undergrounding (DC PLUG) program aims to improve grid reliability by moving selected at-risk overhead power lines underground. The initiative involves Pepco, the District Department of Transportation (DDOT), and other District agencies. It focuses on selected feeders in Wards 3, 4, 5, 7, and 8. According to the DC Public Service Commission, the plan covers 20 feeders across three phases and is expected to benefit approximately 26,000 customers when completed. However, undergrounding does not eliminate all outage risks, as equipment failures, damage to other grid components, and severe weather can still interrupt power.
Maryland's rules
Maryland has a framework for reporting major outage events under COMAR 20.50.12.13 (major outage event reporting). The Maryland Public Service Commission also reviewed the response to the major 2012 storm and directed further consideration of grid resiliency. Customers who depend on electrically powered medical equipment should prepare for interruptions in advance. Discuss an appropriate contingency plan with their healthcare provider and equipment supplier. A dedicated backup plan for medical equipment during power outages can help households identify power needs and alternative arrangements.
The June 2012 Derecho and What It Changed
On June 29, 2012, a powerful derecho swept through the Washington region, bringing damaging winds and widespread power outages. The National Weather Service recorded gusts of 70 mph at Reagan National Airport, 71 mph at Dulles International Airport, and 66 mph at Baltimore/Washington International Airport. These conditions highlight how severe weather can disrupt urban areas, where factors such as urban heat islands and thunderstorm development add context to local weather risks. According to the Maryland Public Service Commission, restoring power across Pepco's territory took 8.25 days, underscoring the need for reliable outage alerts, grid resilience, and preparation before severe weather arrives. Sources: NWS June 29, 2012 storm report; Maryland PSC 2012 Annual Report.
Why Nearby Homes Can Regain Power at Different Times
A nearby street regaining power does not necessarily mean the damage affecting your home has been repaired. An outage can involve different parts of the electricity network, with different repair needs. Follow Pepco’s own updates for the work affecting your address.
Immediate hazards: Stay away from downed wires and report them to Pepco. Call 911 if there is immediate danger.
Transmission equipment: Damage to high-voltage equipment can interrupt the supply feeding a large area.
Essential services: Hospitals, emergency services, and water systems need their own outage contingency plans.
Distribution equipment: Neighborhoods may be supplied by different lines or other equipment, so repair needs can differ.
Individual service: A remaining fault affecting one property may require further attention after nearby customers regain power.
Why Restoration Estimates Change
Restoration estimates can change as damage is assessed and repair needs become clearer. Check Pepco’s official website or app for the latest information. If nearby homes regain power but yours remains off, report the continuing outage. Check a household breaker only if you can do so safely; do not approach damaged equipment or downed wires. During hot weather, plan for hydration, cooling, and access to a cooling center.
Use the Pepco outage map for reported interruptions in DC and Maryland, and check the official website or app for restoration updates. To register for outage texts, send ADD OUTAGE to 48710; registered customers can text OUT to report an outage. For downed wires, stay away and call 1-877-737-2662; call 911 if there is immediate danger. For installed home backup, compare the EcoFlow TITAN and EcoFlow TITAN Plus with Smart Home Panel 10 (240V), installed by a qualified electrician.
Where is the Pepco outage map?
Visit Pepco’s official website and select its outage map. Use the location controls currently available on the live page.
How do I report a Pepco power outage?
Text ADD OUTAGE to 48710 to register for Pepco’s outage text service. Registered customers can text OUT to report an outage. You can also use Pepco’s official website or mobile app. For downed wires, stay away and call 1-877-737-2662; call 911 if there is immediate danger.
Does the Pepco outage map cover Virginia?
No. The map's area reports cover the District of Columbia, Montgomery County, and Prince George's County. Customers outside these areas should check their own utility outage resources.
Who regulates Pepco?
The DC Public Service Commission oversees Pepco's utility service in Washington, DC. The Maryland Public Service Commission oversees service in Montgomery and Prince George's counties.
Why is my Pepco restoration time changing?
Pepco may revise its estimated restoration time as the outage investigation progresses. The expected return of power can change when crews discover additional damage, assess repair needs, or adjust the work required to restore electricity safely.
