mWh to mAh: Answers to the Battery Capacity Questions People Ask Most
To convert mWh to mAh, divide by the nominal voltage of the whole battery pack: mAh = mWh ÷ V. A 37,000 mWh pack rated at 3.7 V holds 10,000 mAh. The same energy in a 7.4 V pack equals 5,000 mAh. Use the pack rating rather than the USB output voltage.
Battery labels mix energy units and charge units, and mWh and MWh differ a billionfold. Below you’ll find a conversion table, a quick voltage check, and a way to turn watt-hours into a runtime estimate for real devices.
How do you convert mWh to mAh?
Divide mWh by the battery’s nominal voltage. A 37,000 mWh, 3.7V pack is 10,000 mAh. The same math works for Wh and Ah. The FAA’s PackSafe guidance gives the same relationship: to calculate Wh, multiply the battery voltage by the amp hours (Ah). The milli-units scale the same way.
Formula: mAh = mWh ÷ V (nominal voltage)
Reverse: mWh = mAh × V
mWh on the label (example) | Nominal voltage | mAh |
18,500 mWh | 3.7V | 5,000 mAh |
37,000 mWh | 3.7V | 10,000 mAh |
74,000 mWh | 3.7V | 20,000 mAh |
37,000 mWh | 7.4V (two cells in series) | 5,000 mAh |
Quick check: 37,000 ÷ 3.7 = 10,000.
Going the other way works the same, as converting watt-hours to milliamp-hours shows.
For small batteries, mAh is common, but for a power station that runs AC and USB outputs, only one unit makes sense.
Which unit should you compare for a power station?
Use watt-hours (Wh). A power station’s outputs run at different voltages, so mAh can’t describe them fairly. Divide usable Wh by a device’s watts to estimate runtime.
Once you move past phone-sized batteries, mAh stops being useful. EcoFlow lists every power station in watt-hours, the one unit that works across AC outlets and USB ports alike. Divide the usable Wh by a device’s watts, and you have a realistic runtime to plan around.
For a laptop, a lamp, and phones through an evening, a 1,024Wh unit is the right scale, and its capacity is printed in the unit that matters.
EcoFlow DELTA 3 Classic (1024Wh)
Rated in Wh: 1,024Wh LFP battery, so there’s no mAh guesswork across outputs (see estimates).
Lights and laptops: run a laptop and lamp for many hours.
Pure sine wave: 1,800W AC, per EcoFlow.
For a full workday or a fridge, the 3,763Wh unit lasts several times longer and can add compatible extra batteries.
EcoFlow DELTA 3800 Gen4
Longer work or fridge: 3,763Wh LFP battery (see estimates).
Expandable: 4 to 12kWh with compatible extra batteries and the Smart Extra Battery Expansion Adapter (sold separately).
3,600W at 120V: 7,200W surge, per EcoFlow.
How do these products divide the job?
EcoFlow DELTA 3 Classic: short use for lights and laptops.
EcoFlow DELTA 3800 Gen4: longer work or fridge loads with expansion.
Runtime estimates (estimates only)
Load (example) | Watts used | EcoFlow DELTA 3 Classic (870Wh usable est.) | EcoFlow DELTA 3800 Gen4 (3,199Wh usable est.) |
Laptop (placeholder 60W) + lamp (10W) | about 70W | about 12 hours | about 46 hours |
13.9 cu ft fridge (ENERGY STAR, about 38W average) | about 38W | about 23 hours | about 84 hours |
Method: usable capacity (Wh × 0.85) ÷ load (W).
Before comparing models, it helps to know what a watt-hour actually measures.
Back to the two labels: what each one actually measures.
What is the difference between mWh and mAh?
mWh measures energy; mAh measures electric charge. They only line up when you know the voltage. That’s why mAh comparisons across different voltages mislead.
mWh (milliwatt-hour) | mAh (milliamp-hour) | |
Measures | Energy | Charge |
Depends on voltage? | Already includes it | No; needs voltage to become energy |
Fair across different voltages? | Yes | No |
Common on | Phone and laptop labels, airline rules (in Wh) | Phone specs, power bank ads |
The EIA defines energy as power × time. A 40-watt (0.04 kW) bulb used for five hours consumes 200 Wh, or 0.2 kWh.
Watch the letter case. Lowercase m means milli (one-thousandth); uppercase M means mega (one million). 1 MWh = 1,000,000,000 mWh. Never mix them.
Power bank shoppers can start with the basics of battery capacity.
Even with the right formula, real labels can still seem not to add up.
Why do mAh and mWh numbers sometimes not match?
Usually the difference is voltage. The pack’s nominal voltage depends on how its cells are connected. A USB output can operate at a different voltage, and conversion losses reduce the energy delivered.
Example: a 10,000 mAh pack at 3.7V = 37,000 mWh. At a 5V USB output, that energy equals 7,400 mAh before losses (37,000 ÷ 5). Converter losses lower the delivered energy further.
For air travel, the FAA generally permits spare lithium-ion batteries up to 100 Wh in carry-on baggage. With airline approval, a passenger may carry up to two larger spares over 100 Wh and no more than 160 Wh each. Protect the terminals and check the airline’s restrictions.
The voltage gap explains a lot when comparing 10,000mAh versus 20,000mAh power banks.
To convert mWh to mAh, divide by the nominal voltage: mAh = mWh ÷ V. The FAA’s Wh = V × Ah formula works the same way, and mWh is never MWh. When voltages differ, compare batteries in Wh, then divide usable Wh by a device’s watts for a runtime estimate. For bigger needs, EcoFlow DELTA 3 Classic or EcoFlow DELTA 3800 Gen4 lists capacity in Wh, so you can plan around real loads.
1. How do I convert mWh to mAh?
Divide the milliwatt-hours by the battery’s nominal voltage. For example, 37,000 mWh ÷ 3.7V = 10,000 mAh. Use the whole pack’s nominal voltage. The USB output voltage serves a different purpose.
2. Is mWh the same as MWh?
No. Lowercase mWh is a milliwatt-hour, one-thousandth of a watt-hour. Uppercase MWh is a megawatt-hour, one million watt-hours. That makes MWh a billion times larger, so never mix them.
3. Which is better to compare, mWh or mAh?
Compare mWh or Wh. Both are units of energy, so they already include voltage. mAh only measures charge, so it misleads when batteries run at different voltages.
4. What does mAh mean on a battery?
Milliamp-hours, a measure of electric charge at the battery’s rated voltage. Use the rated voltage of the complete battery pack. A 10,000 mAh pack at 3.7V stores 37,000 mWh, so you need voltage to know its energy.
5. Why is my power bank's output less than its mAh rating?
For this example, the whole pack is rated at 3.7V and the USB output is 5V. A 10,000 mAh pack equals about 7,400 mAh at 5V, before conversion losses lower it further.
