Indoor Propane Heater for Power Outage Use: Safe Models, Venting Rules, and an Electric Alternative
- Indoor-Safe Propane Heaters Compared: Buddy Heaters and Vent-Free Wall Units
- What "Indoor Safe" Means: ODS, Tip-Over Switches, Venting, and CO Alarms
- Propane vs. an electric heater on a battery: How to choose for an outage
- How to Use an Indoor Propane Heater Safely When the Power Is Out
- State and Local Rules on Vent-Free Propane Heaters
- Planning Fuel for a Multi-Day Outage
- Conclusion
- FAQs
When winter weather knocks out the power, your central heating system may stop working just when you need it most. A propane heater can provide heat without an electrical outlet, but indoor use comes with specific safety rules. The right choice depends on the room size, heat output, fuel supply, and ventilation requirements. This guide compares portable propane heaters and vent-free wall units, explains what their safety features can and can't do, and looks at an electric alternative for households that would rather not burn fuel indoors.
Most indoor-rated propane heaters fall into two groups: portable radiant heaters that use small propane cylinders and vent-free wall or floor heaters connected to a larger fuel supply. Both burn propane inside the room, so ventilation and the manufacturer's instructions matter. The specifications below come from the product information provided for each model. Check the current product page and manual before buying, especially for ventilation requirements and local restrictions.
Heater (maker, model) | Heat output (BTU/hr) | Heating area (maker) | Safety shutoffs | Run time stated by maker | Max altitude | Ventilation in manual | Fuel |
Dyna-Glo 20K BTU LP Blue Flame Vent Free T-stat Wall Heater (BFSS20LPT-4P) | 16,000 to 20,000 | 16,000 to 20,000 | Oxygen depletion sensor; thermostat | Not stated | Pilot outage possible above 4,500 ft | Not verified | Liquid propane; maker says a 100-lb or larger tank with a two-stage regulator from your gas company |
Mr. Heater Little Buddy (MH4B) | 3,800 | 95 sq ft | ODS with automatic low-oxygen shut-off; tip-over shut-off | 5.6 hours on a 1-lb cylinder | 7,000 ft | Not verified | One 1-lb cylinder |
Mr. Heater Portable Buddy (MH9BX) | 4,000 / 9,000 | 225 sq ft | ODS; tip-over shut-off | About 6 hours on low, 3 hours on high, per 1-lb cylinder | 7,000 ft | 9 square inches at ceiling and floor level | 1-lb cylinder, or a 20-lb cylinder with optional hose and filter |
Mr. Heater Big Buddy (MH18B) | 4,000 / 9,000 / 18,000 | Up to 450 sq ft | ODS with automatic low-oxygen shut-off; tip-over shut-off | Up to 11 hours with dual tanks (setting not stated) | 7,000 ft | 18 square inches at ceiling and floor level | One or two 1-lb cylinders (product page lists 2x 1-lb minimum; manual variants note single-cylinder use), or a 20-lb cylinder with optional hose |
Mr. Heater 20,000 BTU Vent Free Blue Flame Propane Heater (MHVFBF20LPT) | 20,000 | Up to 700 sq ft | Automatic low-oxygen shut-off system; thermostat | Not used (bulk tank) | 4,500 ft | Not verified | Liquid propane; 20-lb minimum cylinder that "must remain outdoors" |
How to read the table when choosing a heater
Start with the room you need to heat, not your entire home. A 3,800 BTU heater may suit a small space, while an 18,000 BTU model can provide much more heat. This guide to BTU ratings explains how output relates to room size. Check the altitude limit if you live in the Mountain West. The vent-free models listed above have a 4,500-foot limit, while the Buddy models are rated for use up to 7,000 feet. Fuel is another practical consideration: a 1-lb. cylinder may last only a few hours, while a vent-free wall heater needs a larger propane supply and may require professional installation. An indoor rating doesn't mean a heater is safe to use without conditions. Ventilation, carbon monoxide alarms, and rules about sleeping or leaving the heater unattended all matter.
An indoor rating means a heater is designed for indoor use under the conditions in its manual. It doesn't mean the heater produces no carbon monoxide (CO), or that you can run it in any room without ventilation. The safety instructions are part of using the heater correctly.
Oxygen depletion sensors and tip-over shutoffs
An oxygen depletion sensor (ODS) shuts off a heater when oxygen in the surrounding air falls to a specified level. A tip-over switch can shut it down if the unit gets knocked over. The U.S. Consumer Product Safety Commission (CPSC) discussed the industry's use of ODS technology in a December 2003 news release about unvented gas heaters. These features address specific risks. Neither one replaces a carbon monoxide alarm. CO can build up when fuel doesn't burn properly, and you can't reliably detect it by smell.
Follow the ventilation instructions
Portable propane heaters can require a specific amount of open ventilation. For example, the Mr. Heater Portable Buddy MH9BX manual specifies a minimum 9-square-inch opening, while the Big Buddy MH18B manual specifies 18 square inches at both ceiling and floor level. Those requirements are model-specific. Read the manual for your exact heater and provide the ventilation it calls for, including any instructions about opening a window or door. Don't assume that a cracked window automatically meets the requirement.
Rules that apply to every indoor propane heater
The CPSC warns against operating unvented fuel-burning appliances in rooms where people are sleeping. Mr. Heater's Buddy manuals also say not to operate the heater while sleeping or leave it unattended while burning. Take these precautions during an outage:
Install CO alarms. The CPSC recommends battery-operated alarms or alarms with battery backup on every level of the home and outside sleeping areas. Choose an alarm that meets the current UL 2034 safety standard.
Check alarms regularly. Test them according to the manufacturer's instructions. The CPSC recommends monthly testing.
Keep the heater clear of combustibles. The CPSC advises keeping portable heaters at least three feet from beds, clothing, curtains, papers, and other items that can burn.
Turn the heater off before sleeping or leaving the room. Follow the manual's instructions every time.
Know the warning signs. Headaches, dizziness, and nausea can indicate CO exposure. If an alarm sounds or you suspect exposure, get everyone outside into fresh air immediately and call 911 if needed.
The CDC reports that more than 400 Americans die each year from unintentional CO poisoning unrelated to fires. Never heat your home with a gas oven or use a portable gas camp stove indoors. An ODS monitors oxygen, not CO, so a working CO alarm remains essential. Propane heaters provide strong heat but require ventilation and constant attention. If you'd rather avoid indoor combustion, a battery-powered electric heater is another option, though it provides less heat and limited runtime.
A propane heater delivers more heat, but using one indoors requires careful attention to ventilation and carbon monoxide safety. If you'd rather avoid burning fuel inside, a portable power station can run a small electric heater instead. The trade-off is shorter runtime and less heat. Here's how the Mr. Heater Portable Buddy compares with a Lasko electric heater powered by the EcoFlow DELTA 3 Max (2048Wh).
Factor | Indoor propane heater (example: Mr. Heater Portable Buddy MH9BX) | Electric heater on a portable power station (example: EcoFlow DELTA 3 Max with a Lasko heater) |
Fuel or energy | 1-lb propane cylinders, or a 20-lb cylinder with optional hose | 2,048Wh of stored electricity, recharged between uses by any of its 4 charging methods |
Ventilation | Manual requires a 9 sq in vent area at ceiling and floor level | No combustion, so no venting for CO; normal heater clearances still apply |
Heat output | 4,000 or 9,000 BTU/hr | Lasko MyHeat (101) at 200W is about 682 BTU/hr; Lasko 754200 at 900W is about 3,071 BTU/hr (our conversion, EIA: 1 kWh = 3,412 Btu) |
How long it runs | About 6 hours on low, 3 on high per 1-lb cylinder (maker) | About 8.7 hours at 200W, or about 1.9 hours at 900W (our estimate, below) |
While sleeping | Never, per CPSC and the manual | Not recommended: CPSC says never leave a portable heater unattended in a confined space |
Heats | A room up to 225 sq ft (maker) | One person or a small area; Lasko says the MyHeat is "designed to warm you directly rather than an entire room" |
Propane delivers far more heat than a battery-powered electric heater. The EcoFlow DELTA 3 Max has about 1,741Wh of usable energy under our 85% planning assumption, equivalent to roughly 5,940 BTU of heat. By comparison, the Mr. Heater Portable Buddy MH9BX produces 9,000 BTU per hour on high. The electric option's main advantage is that it doesn't burn fuel indoors.
The EcoFlow DELTA 3 Max can power one compatible 120V electric heater rated within its 2,400W output limit. Plug the heater directly into the power station, and use it for short periods of local warmth rather than overnight or whole-house heating. A power station isn't a heater, and it doesn't remove the safety requirements for propane. For households considering the electric option, the following specs show what the EcoFlow DELTA 3 Max can handle and how quickly it can recharge.
The EcoFlow DELTA 3 Max suits households that need a few hours of personal or small-area warmth without indoor combustion. For example, it can power a small desk heater while you work through an outage. However, it can't match propane's heat output or serve as a whole-house heating solution, and its limited runtime makes it unsuitable for relying on overnight.
Estimated runtime by heater setting
Runtime depends on the heater's wattage and how much stored energy is available. For this estimate, we assume 85% of the EcoFlow DELTA 3 Max's 2,048Wh capacity is usable after conversion losses. That's about 1,741Wh, based on our calculation rather than an EcoFlow specification. The heater wattages come from Lasko's product pages.
Heater (Lasko) | Rated watts | Plug (per Lasko) | Estimated runtime on EcoFlow DELTA 3 Max |
MyHeat Personal Ceramic Heater (101) | 200W, 120V, 2A | 2-prong, 6-foot cord | About 8.7 hours (1,741 ÷ 200) |
Ceramic Space Heater (754200), low | Unverified low-setting wattage (often cited at 900W; exact nameplate spec pending formal verification) | Not stated | About 1.9 hours (1,741 ÷ 900) |
Ceramic Space Heater (754200), high | 1,500W, 120V | Not stated | About 1.2 hours (1,741 ÷ 1,500) |
Actual runtime may vary. The Lasko 754200's thermostat can extend runtime by cycling on and off, while a cold battery can shorten it. EcoFlow lists the EcoFlow DELTA 3 Max's discharge temperature range as 14°F to 113°F. The MyHeat estimate assumes continuous use, so treat it as a best-case figure for attended daytime use, not overnight heating. For safety, plug the electric heater directly into the power station without using a power strip. The CPSC gives this guidance for portable electric heaters used with wall outlets. Cost matters, too. These propane and electric heater costs vary with fuel prices and the length of the outage. If you choose propane, safe placement, ventilation, and proper cylinder storage become especially important during a multi-day outage.
Most propane-heater risks come down to placement, ventilation, fuel handling, and how the unit is operated. Before lighting one during a storm or winter outage, work through these steps.
Check the manual and local rules. Confirm that the exact model is approved for indoor use where you live, and review all ventilation and clearance requirements.
Choose a safe location. Set the heater on a level, hard surface away from beds, curtains, clothing, papers, and other combustibles. Follow the CPSC's three-foot clearance guidance for portable heaters.
Provide the required ventilation. Use the vent opening specified in your model's manual. The MH9BX and MH18B have different requirements, so don't apply one model's instructions to another.
Test your CO alarm. Make sure it works before using the heater. Keep alarms installed on every level of the home and outside sleeping areas.
Stay awake and nearby. Never leave a burning heater unattended or operate it while sleeping. Turn it off before going to bed or leaving the room.
Handle propane cylinders correctly. Follow the manufacturer's instructions for connecting and removing cylinders. Mr. Heater's guidance says cylinders must be stored outdoors; some vent-free units also require the cylinder to remain outdoors during operation.
Leave if you suspect CO exposure. If anyone develops a headache, dizziness, or nausea, get outside into fresh air immediately. If the CO alarm sounds, leave the home and call 911 from outside.
If you use a portable generator during the same outage, keep it outdoors at least 20 feet from windows, doors, and vents, as the CDC advises. Never run a generator inside a home, garage, or other enclosed space.
Vent-free gas heaters aren't permitted in every location or type of housing. Manufacturers list restrictions for some models, so check the rules that apply to your home before buying one. As part of preparing your home for winter outages, review local heating rules alongside your plans for fuel, warmth, and backup power.
California: Title 25, Section 34 of the California Code of Regulations prohibits unvented fuel-burning heaters in dwelling units and guest rooms offered for rent or lease under the State Housing Law regulations. Check local codes for rules that may apply to other properties or situations.
Massachusetts: The City of Worcester's unvented-heater permit application cites the state fire code and says unvented propane or natural-gas space heaters may be used only for supplemental heat or decorative purposes. It also calls for a permit and final inspection, requires a CO detector in the room, and prohibits installation in bedrooms or bathrooms. Residents elsewhere in Massachusetts should check with their local fire department.
These examples don't cover every state, city, or housing type. Check current code requirements, permits, and manufacturer restrictions before installing or operating a vent-free unit. If you rent, ask your landlord or property manager before changing a gas supply or installing a wall heater. Once you know a heater is legal and safe to use, the next step is estimating how much fuel you'll need for a multi-day outage.
A small propane cylinder may last only a few hours, so estimate your daily heating needs before a storm arrives. Use the manufacturer's runtime figures as a starting point, then allow for changes in setting and conditions. For example, running the Mr. Heater Portable Buddy MH9BX on low for six hours a day takes about one 1-lb. cylinder. On high, the same usage could require about two cylinders. Mr. Heater lists fuel consumption at 0.044 gallons per hour on low and 0.099 gallons per hour on high. Based on those figures, one gallon of propane would last about 23 hours on low or 10 hours on high. These are estimates, not guarantees of actual runtime.
Altitude can also affect operation. The Buddy models listed above have a stated maximum altitude of 7,000 feet, compared with 4,500 feet for the vent-free wall units. Follow your specific model's limit, store propane cylinders outdoors as directed, and stock up before severe weather makes travel difficult. Running costs can add up during a prolonged outage. Compare propane use with space heater costs per hour to see how electric heating costs stack up against fuel. For broader outage preparation, explore your home's backup power options alongside your heating and fuel plan.
An indoor propane heater can provide useful heat during a winter outage without an electrical outlet, but only when the model is approved for your location and used exactly as its manual directs. Check room size, BTU output, ventilation, CO alarms, fuel supply, and local restrictions before buying. If you'd rather avoid combustion indoors, the EcoFlow DELTA 3 Max can power one compatible small electric heater for limited periods. It won't match propane's heat output, so plan around the warmth and runtime it can realistically provide.
Is it safe to use a propane heater indoors during a power outage?
Only use a model approved for indoor use in your location, and follow its manual. Provide the required ventilation, maintain clearances, keep a working CO alarm nearby, and never leave the heater unattended or running while you sleep.
Can I sleep with an indoor propane heater on?
No. The CPSC advises against operating unvented fuel-burning appliances in rooms where people are sleeping. Mr. Heater's Buddy manuals also warn against operating the heater while sleeping.
How long does a 1-lb. propane cylinder last in a Buddy heater?
Mr. Heater lists about six hours on low and three hours on high for the Portable Buddy MH9BX. The Little Buddy MH4B is listed at 5.6 hours per 1-lb. cylinder. Actual runtime depends on operating conditions.
Are vent-free propane heaters legal in every state?
No. Restrictions vary by state, city, and housing type. California's housing regulations prohibit unvented fuel-burning heaters in covered rental dwellings, and Worcester, Massachusetts, requires permits and restricts where such heaters can be installed. Check the rules for your address.
Is an electric heater on a battery safer than propane?
A battery-powered electric heater avoids burning fuel indoors and therefore avoids combustion-related CO from the heater. It still poses fire and burn risks and needs proper clearance and supervision. It also provides much less heat for a shorter time than a propane heater in the examples above.
Can a portable power station heat an entire house?
The EcoFlow DELTA 3 Max is a portable power station, not a whole-house heating system. It can run a compatible electric heater within its output limits, but its stored energy is limited. Use it for short periods of local warmth rather than relying on it to heat the house throughout an outage.
