Graupel vs Hail: What Winter Storms Mean for Your Home Energy Reliability
Graupel and hail are two types of precipitation that may fall during winter storms. While each is different, both can cause significant damage to homes and property. Not only that, but winter storms, especially those featuring hail or graupel, can disrupt power infrastructure and lead to winter outages that may be catastrophic if you’re not careful.
This guide not only helps you learn more about graupel and hail, but also dives deeper into how winter storms can negatively impact your home’s energy, and how you can prepare for severe winter weather.
What Is the Difference Between Graupel and Hail?
While both graupel and hail are types of precipitation, there are a few main differences between them. First, the texture is very different between the two. Graupel is softer and is similar to tiny snowballs that should easily crush when squeezed between your fingers. On the other hand, hail is hard and solid ice that won’t get crushed as easily.
Graupel is also normally quite small, less than a fraction of an inch in most cases, while hail can vary from relatively small to many inches in size. Another major difference is that while graupel normally falls during winter storms, hail generally tends to fall during thunderstorms, most commonly during the spring or summer.
To avoid extended power outages due to extreme weather, consider a portable power station like EcoFlow DELTA 3 Classic.
An EcoFlow DELTA 3 Classic
How Do Graupel and Hail Form?
Another thing that sets graupel and hail apart is how they form. Graupel forms when snowflakes fall through supercooled water droplets. As the snowflake passes through the liquid, the droplets instantly freeze and stick to the snowflake as it falls.
However, hail forms when raindrops are caught inside strong rising currents during a thunderstorm. These raindrops are carried throughout the cold areas of the atmosphere and freeze. They grow larger by colliding with more water that freezes on impact to build more layers on the piece of hail. Once these become too heavy for the updraft, they fall.
Which Type of Storm Causes More Damage?
While both graupel and hail storms can cause damage, hail storms generally cause more. Hail is capable of denting vehicles, breaking equipment, hurting crops, and damaging roofs. Especially if hail is larger, it can do some serious damage that leads to costly repairs.
But while hail does more damage in a direct way, graupel often does damage indirectly. Graupel can make roads very slippery, which may lead to car accidents that can cause plenty of damage. It can also weigh down trees and power poles and cause them to bend or break, which can cause property damage and/or power outages.
How Can Winter Storms Disrupt Power Infrastructure?
There are a few ways that severe winter weather and storms can disrupt power infrastructure. First, there’s a risk that the icy roads that often occur during winter storms lead to people hitting power poles or electrical boxes with their cars, which can lead to lengthy outages.
The high winds during these storms can also knock over power poles themselves or lead to trees falling on them. Ice that accumulates on power lines or poles can also cause damage due to the sheer amount of weight it adds.
Lastly, colder temperatures often drive higher demand for electricity as some people use it to keep their homes warm. This added demand may put extra strain on the power grid as a whole, which could lead to potential damage or outages.
What Should You Do Before Severe Winter Weather Arrives?
If severe winter weather is approaching your area, or you just want to prepare ahead of time, here are some of the most important things to do:
  • Have a source of backup power to continue powering things like your fridge, security system, and furnace, even during prolonged outages.
  • Fully stock your first aid kit.
  • Make sure you have plenty of food, water, and other essentials in the home, in case you get snowed in and are unable to leave.
  • Take time to seal your home well by blocking any cracks around doors or windows, as these can let cold winter air inside. Sealing up any drafts also helps keep warm air inside.
  • Consider picking up blankets, more sweaters, and other things to keep warm in case your power goes out, and you need to go without heat for a while, or be careful about how much you use it.
In general, winter blackouts are more dangerous than those in the spring or summer, so don’t take preparation lightly. Also, it’s better to have made the proper preparations and not need them than it is to avoid preparing and be stuck suffering through a winter storm.
How Can Backup Power Improve Home Energy Reliability?
Backup power improves home energy reliability by providing the electricity you need to run your home seamlessly when grid outages occur. Many of these solutions provide instant power transfer and ensure your most important appliances continue to operate during outages without any disruptions or drops in performance.
While some types of backup power may only be able to operate one or a few appliances at once, a high-capacity option like EcoFlow DELTA Pro Ultra X may be able to power your entire home. Systems like this also give you energy independence, as well as peace of mind that your home won’t fully shut down during an outage.
So whether you need to stay powered during a New York snowstorm or ensure your home remains functional during a blizzard, backup power plays an important role in your home’s energy reliability.
An EcoFlow DELTA Pro Ultra X
Is Graupel the Same as Hail?
No, graupel and hail are different. Graupel is a mix of snow crystals and ice, and almost appears like a softer version of hail. Hail, on the other hand, is a hard piece of solid ice. Additionally, graupel is relatively easy to crush in your hands, while hail isn’t.
How Rare Is Graupel?
While not incredibly rare, graupel is a much less common type of precipitation to see compared to things like snow and rain. This is because it requires very specific conditions in the atmosphere to form.
Winter Storms Make Reliable Backup Power More Important for Home Resilience
Whether you opt for a portable power solution like EcoFlow DELTA 3 Classic or a whole home generator, having backup power in the winter is very important. It’s hard to predict when a winter storm may come your way and lead to long outages, so it’s best to prepare ahead of time.
Without reliable backup power, you could be stuck without heat and unable to use your electronics and appliances for hours or even days at a time. It also gives you more peace of mind during storms and gives you the confidence that your home is resilient.
Home Backup
