Best Generator for Sump Pump Backup: Sizing, Types, and Top Picks
Power tends to go out during heavy rain, and that's exactly when your sump pump needs it most. A dedicated backup generator for sump pump protection is the most reliable way to prevent flooding, switching on the moment utility power fails rather than leaving your pit to fill on its own.
Portable generators like the EcoFlow DELTA Pro 3 and EcoFlow DELTA Pro Portable Power Station give homeowners a fuel-free way to keep a sump pump running during a multi-day outage. They do this without the fumes, fuel runs, or maintenance a gas engine demands.
In this guide, we'll walk you through how to size your backup power for sump pump effectively and the different types of generators available. We'll also cover the features that actually matter, along with top selections to consider before the next storm blows in.
What Size Generator for a Sump Pump Do You Need?
Before you buy a generator for sump pump backup, you need to know how much power your pump actually draws. Most sump pumps list their draw in amps on a data plate, and household circuits run at 120 volts, so the sizing formula is simple.
You can calculate it using the sizing formula below:
Watts = Volts x Amps.
For instance, a 1/2 HP sump pump drawing approximately 9.8 amps at 120V would use about 1,176 running watts. That figure is important because when you undersize the unit, it does not have enough headroom when the pump's motor kicks on, and the breaker or the generator's overload protection trips just when you need power the most.
Surge (Starting) Watts vs. Running (Rated) Watts Explained
The sump pump is an inductive electric motor. These motors require a lot more power to start spinning than to keep spinning. When the float switch turns the pump on, the motor needs to overcome the inertia of a stationary rotor and generate a burst of energy that's usually 2 to 3 times the running watts. That surge lasts only a second or two before the motor settles into its steady working demand. If your backup power can't supply that brief spike, the pump will stall or trip the unit's breaker before it ever moves water. That's why running watts alone is the incorrect figure to shop for. You have to size around the surge.
Sump Pump Wattage Quick-Reference Table
Pump Size | Running Watts | Surge Watts | Recommended Output |
1/3 HP | 800W | 1,600-2,000W | 2,000W+ |
1/2 HP | 1,050-1,200W | 2,100-2,400W | 2,500W+ |
3/4 HP | 1,300-1,400W | 2,700-3,000W | 3,000W+ |
1 HP | 1,500-1,600W | 3,000-3,600W | 3,600W+ |
Use this table as a first guide, but always check your pump's data plate. The actual draw will vary by brand and motor design, and your backup should have a comfortable margin above surge watts, not just be sufficient to match it.
Types of Sump Pump Generators
Not all sump pump backup generators are the same. The ideal one for you depends on your home's layout, your access to the basement, and how you wish to handle fuel. Sump pump generators are often categorized into three groups according to their portability, fuel requirements, and safety clearances.
Portable Gas/Dual-Fuel Inverter Generators
Portable sump pump backup generators are generally the least expensive option for your first purchase. That said, the gas or dual-fuel inverter types do have a good surge capacity for the price, but their safety clearance is the issue. These units emit carbon monoxide, so they must run outside, at least 20 feet from the home, with exhaust directed away from windows and doors. That clearance need can be a major problem on a tiny lot or in a townhome, and you'll need an extension cord long enough to reach the pump from a safe outdoor place, plus the discipline to refuel it manually if the outage extends into a second or third day.
Indoor Battery-Powered Generators & Power Stations
For homeowners who can't put a gas engine 20 feet from the house, an indoor generator for sump pump setup solves the clearance problem entirely. LiFePO4 (lithium iron phosphate) battery stations don't burn fuel and don't emit exhaust, so they can sit directly in the basement next to the sump pit with none of the ventilation concerns a combustion engine requires. Setup is plug-and-play. Charge the battery ahead of time, plug the pump in, and it's ready the moment the power drops. This is the category the EcoFlow DELTA Pro 3 and DELTA Pro fall into, and it's worth a closer look further down.
Automatic Whole-House Standby Generators
An autonomous whole-house standby generator is usually a permanent installation that runs on natural gas or propane. It is then wired to the home via an automated transfer switch (ATS). When utility power is lost, the ATS detects the loss and automatically starts the generator. You don't have to move a finger. This makes it the most hands-free generator backup for sump pump protection, hands down. The downside is how complex and pricey it is. They have to be professionally installed, and you'll need a dedicated fuel line or propane tank. Not only that, but they will cost you a lot more upfront than a portable or battery-powered option.
Key Features to Look for in a Sump Pump Generator
Once you've settled on a type, the details matter just as much as the category. Whether you're weighing a fuel model or a battery model, here's what actually determines whether a generator for sump pump backup keeps running when it counts.
Pure Sine Wave Inverter Technology
Pure sine-wave technology is more important for a sump pump than most people think. Look for pure sine-wave output with Total Harmonic Distortion (THD) under 3%. A modified sine wave generator outputs a rougher stair-step electrical signal that causes electric motors to run hotter and hum louder. It can damage or fry the digital float sensors that many modern sump pumps rely on to switch on and off. Quality inverter generators and practically all battery power stations have pure sine wave as standard, but it's worth checking before you buy, as cheaper open-frame models sometimes skip it.
Runtime and Fuel Flexibility
Three days without power in heavy rain is more than an inconvenience; it's a threat of flooding. If you are running fuel engines, you'll want to use a stable fuel like propane, which doesn't go bad as quickly as gasoline. The main factor for battery-based systems is capacity. Most power stations will accept modular battery packs or solar panel inputs, so you can extend your run time to near infinite, at least as long as there is sunshine to recharge.
Automatic Transfer / UPS Functionality
If you're not home when the power goes out, a manual-start generator does you no good until you get back. Automatic transfer, sometimes marketed as EPS (Emergency Power Supply) or UPS (Uninterruptible Power Supply) mode, switches the pump onto backup power automatically, often in under 20 milliseconds. That's fast enough that the sump pump never actually stops running, which matters because a pit can fill and overflow in the time it takes to drive home and manually start a backup unit.
Noise Level (dBA)
Noise is easy to take for granted until you are in the middle of a storm at midnight. Open frame gas gensets generally operate at 70 dBA or higher, which can lead to noise complaints even in some neighborhoods during a declared emergency. Quiet, enclosed inverter generators bring that down to around 50 to 58 dBA. A battery-powered power station does not have an engine, so it runs at around 30 dBA and is the easiest option to leave on overnight without disturbing anyone else in the house or next door.
Top Backup Generators for Sump Pumps
When it comes to picking the best backup generator for sump pump protection, the top-performing models share a few things in common. They deliver clean pure sine wave power, automatic start or transfer, and enough surge headroom to handle an engine kicking on without hesitation. Two models worth a close look are the EcoFlow DELTA Pro 3 and the EcoFlow DELTA Pro Portable Power Station.
EcoFlow DELTA Pro 3
The EcoFlow DELTA Pro 3 is built for exactly this kind of job. Its EPS (Emergency Power Supply) mode switches over immediately, so a sump pump connected to it doesn't lose a beat when utility power drops, solving the "away from home" problem manual-start units can't. With 4,000W of continuous output and an 8,000W surge rating in a single unit, it comfortably covers the starting wattage of even a 1 HP sump pump. Because it runs on a sealed lithium battery with no combustion and no exhaust, it's a genuinely indoor-safe unit, fine to keep in the basement a few feet from the pit itself, and it stays essentially silent while it works.
EcoFlow DELTA Pro
If your home needs capacity to run a sump pump in addition to other basics, like a fridge, a sewage ejector pump, or a few lights, the EcoFlow DELTA Pro offers a proven, high-capacity solution. Its modular design lets you add extra battery packs to sustain intermittent pumping through multi-day storms without having to replace your base unit. And like the DELTA Pro 3, it features automated EPS switchover and a pure sine wave output, so pump engines and float sensors will work just as they would on grid power, with none of the noise or odors of a petrol engine.
The right generator for sump pump protection provides sufficient surge power, has enough runtime, and is safe to operate anywhere. A power that is too small, a poor electrical signal, or a slow manual start can result in the same basement flooding during the same storm you were trying to prepare for. If you want a generator for sump pump backup that starts automatically, runs silently, and can sit safely right next to the pit, the EcoFlow DELTA Pro 3 Portable Power Station and EcoFlow DELTA Pro Portable Power Station are worth putting at the top of your list.
Can you run a sump pump off a generator?
Yes, any generator for sump pump use just needs to meet two requirements. It must supply clean power (ideally pure sine wave) so the motor and float sensors run safely, and it must have enough peak surge wattage, typically 2 to 3 times the pump's running watts, to start the motor without tripping.
How much battery power do I need to run a sump pump?
It depends on the duty cycle, not just the wattage. A sump pump doesn't run continuously. It typically cycles on for 10 to 15 seconds every couple of minutes during heavy rain, then sits idle. Because of that short duty cycle, a 2kWh to 3.6kWh battery station can typically run a pump through an entire 24- to 48-hour storm event.
What is the best backup generator for sump pump protection?
This will depend a lot on your setup, but most households opt for a battery solution like the EcoFlow DELTA Pro 3 or DELTA Pro. It has automatic switchover, clean sine wave power, enough surge to start the pump and safe interior installation without fuel, fumes or engine noise.
How long can a generator run a sump pump?
Run time varies with fuel supply or battery capacity and pump run time. You can run a fuel-based unit until you need to refill, while a battery-based power station will generally run for 24-48+ hours on a single charge. With solar input or additional battery modules, you can extend that time.
Do sump pumps take a lot of electricity?
No, most sump pumps use about 800-1,500W continuous operating power, which is about the same as a toaster. The snag is the short initial surge, which demands a lot of electrical overhead from any backup power source for a brief moment. That's why surge watts are so important, not just running watts.
