How to Choose a Generator for Well Pump Backup (Sizing, Types, and Top Picks)
When the grid goes down, a well pump stops instantly. Unlike city water, which keeps flowing from an elevated tank even during an outage, a private well depends entirely on electricity to lift water from underground and push it through your pipes. Within minutes of a power outage, the pressure tank drains, leaving a household without drinking water, working toilets, or a functioning shower for as long as the outage lasts.
You can prevent this with a properly sized generator for well pump backup. In this guide, we'll walk through how to calculate a well pump's wattage, the different types of generators available, and the features that matter most in a well pump generator. We'll talk about portable power stations worth considering, like the EcoFlow DELTA Pro and EcoFlow DELTA Pro 3, both built to handle the surge demands of water well pump systems.
How to Correctly Size a Generator for a Well Pump
A well pump is not a light bulb. Lights, space heaters, and kettles are resistive loads, so they draw the same wattage the moment you switch them on as they do an hour later. A pump engine behaves differently because it is an inductive load. It has to create a magnetic field, spin a rotor from a dead stop, and push a column of water up the well casing before it settles into normal operation.
That first moment is where most people get their sizing wrong. If you add up the nameplate running watts of your pump and buy a machine that barely covers it, you have bought a generator that cannot start your pump. Correct sizing for a generator for well pump duty always begins with the surge figure, not the running figure.
What are Running Watts (Rated) and Starting Watts (Surge)?
Running watts, or rated watts, are the power the pump will need after it's up to speed and moving water at a consistent pace. Starting watts, or surge watts, or locked rotor watts, are the watts the motor draws for about one to three seconds to overcome the static inertia and raise water up the casing for the first time.
The surge watt for most well pump motors is two to four times the operating power. A 1 HP pump rated at 2,000 operating watts could surge to 4,000W, 6,000W, or more at startup, depending on pump depth, impeller design, and how far the water level has dropped during the prior cycle.
If you buy a generator for well pump backup based on running watts, the machine will look OK on paper until the pump tries to crank, the voltage sags, the motor hums instead of spinning, and the breaker trips.
Voltage Requirements: 120V or 240V Connections
Another item many get wrong is voltage, and that is just as important as wattage. Some shallow-well jet pumps, which are above ground and draw water from wells less than around 25 feet deep, may be operated on a standard 120V circuit. Almost always, the submersible pumps that are lowered into the casing itself and suck water from far deeper depths run on 240V single-phase power.
Before you acquire a generator for well pump service, be sure what voltage your pump really needs. Check the wiring of the pressure switch or the pump's nameplate. So if the answer is 240V, you need a generator with a corresponding output. Usually, this is done using a NEMA L14-30R twist-lock outlet or something else that can accept a 240V receptacle, not simply a couple of regular 120V household plugs.
Well Pump Wattage Sizing Chart (By Horsepower)
Use the chart below as a starting point for matching horsepower to wattage. Every pump is different, so treat these well pump wattage figures as typical ranges and confirm the exact numbers on your own pump's nameplate before you commit to a generator.
Pump Motor Size | Running Watts | Typical Starting Watts | Recommended Generator Capacity (20% Cushion) |
1/3 HP | 750W | 1,500W to 2,000W | ~2,400W |
1/2 HP | 1,000W | 2,000W to 3,000W | ~3,600W |
3/4 HP | 1,500W | 3,000W to 4,500W | ~5,400W |
1 HP | 2,000W | 4,000W to 5,500W | ~6,600W |
1.5 HP | 2,500W | 5,000W to 7,000W | ~8,400W |
2 HP | 3,000W | 6,000W to 8,500W | ~10,200W |
A generator for well pump backup in a normal single-family home usually has between 4,000W and 6,500W of starting power once cushion is accounted for. This is because most of the home systems are in the 1/2 HP to 1 HP range.
The last column is more essential than people assume. Add 20% to the peak surge amount before you decide what size generator you need. This cushion accounts for voltage drop in long wires from the generator to the pressure switch, and derates for altitude (generators lose about 3% to 4% of their output for every 1,000 feet of elevation above sea level).
There's also the possibility of a refrigerator, sump pump, or furnace blower coming on at the same time as the well pump. Most of the time, a well pump will still be shut down on a hot day, at high altitude, or on a fully loaded day by a "properly sized" generator, since the cushion wasn't added.
Types of Generators for Water Well Pumps
Homeowners generally choose between three categories of generator for water well pump duty, and each one trades off differently on cost, convenience, and runtime.
Portable Gas & Dual-Fuel Generators (Best Value & Versatility)
A portable generator for well pump backup is usually the cheapest way to get enough surge capacity for the money. Gas and dual-fuel units in the 5,000W to 8,500W range cover most residential pumps once the 20 percent cushion is applied, and dual-fuel models add the flexibility of running on propane when gasoline isn't available. The tradeoff is upkeep. These units need oil changes, fresh fuel and periodic carburetor cleaning, and they have to run outdoors, at least 20 feet from doors, windows and air intakes, to keep exhaust out of the house.
Whole-House Standby Generators (Best for Automatic Backup)
A backup generator for well pump systems that's tied permanently into a natural gas line or a large propane tank. It is then paired with an Automatic Transfer Switch (ATS) that starts within seconds of a grid outage and shuts off once utility power returns. There's no pulling a cord in the dark or hauling fuel cans, but the upfront cost is its disadvantage. Whole-house standby units and their installation typically run several times the price of a portable unit sized for the same load, which makes sense for homes that lose power often or that can't tolerate the well pump being off while someone walks outside to start a generator.
Portable Power Stations & Battery Backups (The Silent Alternative)
Battery systems, often marketed as solar generators, store electricity and release it through an inverter. There is no engine, no fuel, no oil, and no exhaust, which means they can sit inside a utility room and run at conversational volume or quieter. For anyone tired of hauling gas cans, this is an appealing option.
The catch is that the same inrush math still applies. A battery power station needs enough inverter headroom to absorb the pump's starting surge, not just its running watts, so check the peak or surge rating of the inverter itself, not only the battery's stored capacity in kWh. Two EcoFlow models that are worth looking for as backup for well pump outage power are:
EcoFlow DELTA Pro 3 for 240V Well Pumps and Whole Home Backup
The DELTA Pro 3 is the better match of the two for deep submersible pumps because it provides native 120V and 240V from a single unit, with a NEMA L14-30R outlet on the front. Rated output is 4,000W with an 8,000W surge, which covers the inrush of a 1 HP pump with room left over for the fridge and a few lights. Capacity scales from 4kWh to 48kWh, so you can start small and add batteries as your outage history tells you what you actually need.
EcoFlow DELTA Pro for 120V Jet Pumps and Paired 240V Setups
The DELTA Pro suits households with a shallow 120V jet pump or a smaller 1/2 HP setup. A single unit delivers 3,600W with a 7,200W surge and 3.6kWh of storage, expandable to 25kWh with extra batteries. If you need 240V for a submersible, two units paired through the Double Voltage Hub or a Smart Home Panel give you 7,200W at 240V, which is enough for a 1.5 HP pump alongside other essential circuits.
Key Factors to Consider When Choosing the Best Generator
Once you have your wattage number and your voltage, use this checklist to separate the best generator for well pump backup from the machine that merely looks capable on the box.
Total Harmonic Distortion under 5%. Modern pump control boxes, soft starters, and variable frequency drives are electronic devices, and dirty power can damage them. Inverter generators and battery power stations produce clean sine wave output. Cheap open-frame units can run at 15% THD or worse, which is fine for a work light but risky for a VFD.
Starting headroom for simultaneous loads. Your pump does not wait its turn. Size for the pump surge landing on top of a running refrigerator, freezer, and furnace blower, because that is exactly when it will happen.
Runtime and fuel efficiency at 50% load. Manufacturers quote runtime at 25% load, which flatters the number. Ask what it does at half load, then work out how many gallons or kilowatt hours a three-day outage would cost you.
Electric start versus recoil pull. Yanking a cord on a cold engine at 2 a.m. in freezing rain gets old fast. Electric start, or a battery unit you switch on with a button or a phone app, is worth the premium.
Outlet configuration. Confirm the 240V receptacle type before you buy the cord, and buy a cord rated for the full amperage of the run.
Safe Hookup and Installation Methods
Getting power from the machine to the pump is where the legal and safety issues live. A well pump is hard-wired into your service panel, so you cannot simply run an extension cord to it. The connection has to go through the panel, and it has to isolate your house from the utility grid while it does.
Manual Transfer Switch vs. Generator Interlock Kit
A manual transfer switch is a small sub-panel installed near the main panel. With this switch, you can disconnect individual circuits, such as the well pump, from the utility line and power them with the generator.
An interlock kit does the same job with a mechanical plate that prevents the main breaker and the generator breaker from ever being switched on together. Interlocks cost far less than transfer switches and give you access to every circuit in the panel, though they require a panel-specific kit and usually an electrician plus a permit.
What you must never do is backfeed. That is plugging a double-male cord into a wall outlet and feeding the panel backward. It energizes your house wiring with nothing isolating it from the utility service, so your generator pushes power back through the pole transformer and out onto lines that a lineman believes are dead. It has killed utility workers, which is why it's illegal in most jurisdictions, and it voids insurance.
Step-by-Step Connection and Startup Procedure
Follow the order. Sequence matters as much as the equipment.
Shut off the main breaker first to isolate the house from the grid.
Position the portable unit outside on a level surface at least 20 feet from the building, with the exhaust pointed away from doors, windows, and air intakes. Battery units can be stored indoors in a dry, ventilated area.
Connect the 240V heavy-duty cord, typically an L14-30 rated for the load, from the generator to the power inlet box.
Start the generator and let the engine reach a stable RPM under zero load. Give it thirty seconds to a minute before adding anything.
Engage the well pump breaker so the pump primes the pressure tank, then add your remaining circuits one at a time, starting with the largest.
When utility power returns, reverse the process. Shed the loads, switch the circuits back, shut the generator down, and only then restore the main breaker.
Whether you can keep your water flowing during a power outage depends on your pump's voltage and starting wattage. Make sure you don't size a generator for well pump service on running watts alone and don't guess at voltage. Determine if your pump needs 120V or 240V, add a 20 percent cushion above peak surge, and the remaining purchase decision becomes much easier.
If what needs to stay powered up is the well pump and a few devices like a refrigerator and some lighting, the EcoFlow DELTA Pro is ideal. The EcoFlow DELTA Pro 3 has native 240V output and extensible capacity to grow with the property if the well pump is in the 1.5 HP to 2 HP range, shares the panel with an AC unit, or the residence needs a larger buffer for longer outages.
How big of a generator do I need to run a well pump?
For most homes, a generator for well pump duty with a 4,000W to 6,000W surge range is sufficient for a 1/2 HP to 1 HP pump. A 1.5 HP or 2 HP pump needs 7,500W to 10,000W. Check your engine nameplate and add 20% on top of the surge figure.
Can I run my well pump with a generator?
Yes, provided the generator matches the pump's voltage and surge demand and is connected through a transfer switch or interlock kit. A generator for water well pump service also has to be wired into the panel, since submersible pumps are hard-wired rather than plugged in.
How many watts does it take to run a well pump?
Running wattage is roughly 750W for a 1/2 HP pump, 1,500W for 1 HP, and 2,500W for 1.5 HP. Starting wattage is two to four times higher for a second or two, but always size the surge watts, not the running one.
Can a 5000 watt generator power a well pump?
A 5,000W unit will handle a 1/2 HP or 3/4 HP pump comfortably and can usually manage a 1 HP pump if nothing else large is running at the same time. For 1.5 HP and above, it will trip. Confirm that the 5,000W rating is surge capacity and that the machine has a 240V outlet.
How do I wire my well pump to a generator?
You do not wire the pump directly. An electrician installs either a manual transfer switch containing the pump circuit or an interlock kit on your existing panel, along with an exterior power inlet box. You then run a rated 240V cord from the generator to that inlet, shut off the main breaker, and switch the pump circuit over.
