Tornado Warning Wisconsin: Inside the Appleton EF3 and a Record Year
Wisconsin has already recorded 47 confirmed tornadoes in 2026. That makes it the state's second-highest tornado total since 1950, and the season is not over yet. The most destructive storm came on July 27. An EF3 tornado tore through Appleton, Neenah, and Menasha, leaving a 12-mile path of damage. It also knocked out power to more than 400,000 customers. The storm was part of an unusually active tornado season across Wisconsin. This article looks at what happened in Appleton and what followed after the storm. It also examines why 2026 has been such an unusual year for tornadoes, another smaller tornado in Washington County, and what Wisconsin households can do to prepare for the rest of the season.
What Happened in Appleton: An EF3 Tornado in the Fox Cities
What Happened in Appleton: An EF3 Tornado in the Fox CitiesWhat Happened in Appleton: An EF3 Tornado in the Fox Cities
The tornado touched down near Appleton in Outagamie County at about 11:56 a.m. on July 27, 2026. The National Weather Service rated it EF3, with peak winds estimated at 140 mph. It tracked roughly 12 miles through the Fox Cities, passing through Neenah and Oshkosh before dissipating over Lake Winnebago. At its widest point, the damage path stretched more than three-quarters of a mile.
The tornado caused widespread damage along its path. Numerous homes were damaged or destroyed, particularly in Menasha. Downed trees and power lines added to the destruction, while public water systems were also disrupted. The National Weather Service reported no injuries or deaths. The scale of the damage shows how much destruction a tornado can cause even when it moves through an area quickly. How tornadoes cause damage explains what happens inside a tornado's wind field and why the damage can be so severe.
The wind damage was only part of the story. The storm also left a much larger power outage behind, affecting hundreds of thousands of customers beyond the tornado's direct path.
The Power Outage Aftermath
More than 400,000 customers across Wisconsin and Illinois lost power in the immediate aftermath of the storm system. That number extended well beyond the neighborhoods directly hit by the tornado. Downed power lines left many households without electricity as communities began cleaning up.
Wisconsin Governor Tony Evers described the damage in Appleton and Menasha as “widespread and significant.” He said the state would use “every available resource” to help with the recovery. Public water systems were also disrupted. That made recovery harder for households already dealing with storm damage and power outages.
When an outage affects this many customers, restoration time can vary from one area to another. The length of a power outage depends on factors such as the extent of the damage, access to damaged lines, and how quickly crews can make repairs. How long does a power outage last? covers the main factors that can affect restoration time.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. •Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Features a fast 20ms auto switchover when it matters most. •High Savings: Saves up to $6,000 per year with a 3-year ROI. •Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
EcoFlow DELTA Pro 3
• High Power & Versatility: Delivers up to 4000W (6000W via X-Boost) with 120V and 240V outputs to run a 3-ton central AC and essential appliances. •Continuous Power: Maintains stable 120/240V output at 4000W during pass-through charging. •Endless Energy: Compatible with portable generators and auto-recharges using the EcoFlow Smart Generator 4000. •Durable Battery Life: EV-grade LFP battery retains 80% capacity after 4000 cycles.
Public water systems were also disrupted, adding another problem for households already dealing with storm damage and power loss. As destructive as the Appleton tornado was, it was only one part of an unusually active tornado year for Wisconsin.
2026 Is Already Wisconsin's Second-Highest Tornado Year on Record
Wisconsin has recorded 47 confirmed tornadoes in 2026. That puts the state at its second-highest yearly total since 1950, and the severe weather season is not over yet. The state's annual average is 23 tornadoes, so this year's activity is already well above normal.
The record is still 62 tornadoes, set in 2005. The severe weather season still has several weeks to go. If tornado activity continues, Wisconsin could move closer to the 2005 record.
Tornadoes do not occur evenly from one year to the next. A few active storm systems can produce several tornadoes in a short period, which can push the yearly total much higher than usual. Tornadoes in Wisconsin provides more context on tornado activity and risk across the state.
A Second Touchdown: The Hubertus EF-0
 A Second Touchdown: The Hubertus EF-0 A Second Touchdown: The Hubertus EF-0
Wisconsin saw another, much smaller tornado on August 18. An EF-0 tornado touched down southwest of Hubertus in Washington County that evening. The tornado lasted only about two minutes and left a short damage path.
Winds reached roughly 80 mph. The storm dented siding, blew out a window, and uprooted mature trees along its path. The damage was far less severe than what Appleton experienced. Still, the Hubertus tornado was another confirmed tornado in an unusually active year for Wisconsin.
The same storm system also produced strong straight-line winds across the area. Winds of 60 to 80 mph damaged parts of western Washington County, Waukesha County, and the Milwaukee metro area. In some cases, straight-line winds can leave damage that looks similar to tornado damage. Straight-line winds vs. tornado: how to tell them apart explains some of the differences.
Why Wisconsin Sees So Many Tornadoes
Wisconsin sits in a part of the Midwest where warm, humid air from the south often meets cooler air moving in from the north and west. Warm and cool air can meet over Wisconsin during the warmer months. This can lead to severe thunderstorms and, in some cases, tornadoes.
Tornado activity also tends to come in clusters rather than spread evenly across an entire year. One active storm system can produce several tornadoes in a short period. That can push a state's annual total well above its usual average, as Wisconsin's 2026 numbers show.
Past active seasons can offer some useful context, too. Tornado watch 2025: key events and forecasts looks at tornado activity and forecasts from the previous year.
How to Prepare for the Rest of Wisconsin's Season
How to Prepare for the Rest of Wisconsin's SeasonHow to Prepare for the Rest of Wisconsin's Season
A watch means conditions are favorable for tornadoes to form. A warning means a tornado has been detected or indicated by weather radar, and people in the affected area should take shelter. Knowing the difference can help you act before a storm reaches your location. Tornado watch vs. warning explains what each alert means and how to respond.
The Appleton storm also showed why preparation should include more than shelter. More than 400,000 customers lost power after the tornado, including people outside the storm's direct path. Keep phones charged and have a plan for a power outage. Having backup power ready can also help households manage the hours or days after a major storm.
Wisconsin's tornado season is not necessarily finished just because the state has already reached an unusually high yearly total. Fall storms can still bring severe weather, so a tornado watch or warning deserves attention whenever one is issued.
Wisconsin has recorded 47 confirmed tornadoes in 2026. It is the state's second-highest tornado total since 1950. The July 27 EF3 tornado in Appleton also showed how quickly a severe storm can cause major damage and widespread power outages. With the season still underway, households should stay alert to tornado watches and warnings and prepare for possible power loss. Backup options such as the EcoFlow DELTA Pro Ultra X and DELTA Pro 3 can help keep essential appliances running when the grid goes down.
Is there a tornado warning in Wisconsin right now?
Tornado warnings are issued for a particular area when a tornado has been sighted or indicated by weather radar. Severe weather conditions can change quickly, so don’t rely on an earlier warning. Always check current alerts from the National Weather Service or local emergency officials before taking action.
How many tornadoes has Wisconsin had in 2026?
Wisconsin has recorded 47 confirmed tornadoes in 2026. That is the state's second-highest yearly total since 1950. The record is 62 tornadoes, set in 2005.
What happened in the Appleton, Wisconsin tornado?
An EF3 tornado touched down near Appleton in Outagamie County on July 27, 2026. Peak winds reached an estimated 140 mph. The tornado traveled roughly 12 miles through the Fox Cities before it dissipated over Lake Winnebago. Homes were damaged or destroyed, trees and power lines came down, and public water systems were disrupted.
How many people lost power in the Appleton tornado?
More than 400,000 customers across Wisconsin and Illinois lost power in the immediate aftermath of the storm system. The outage affected areas well beyond the tornado's direct path.
Why has Wisconsin had so many tornadoes this year?
When warm humid air from the south meets cooler air from the north and west, Wisconsin can have active tornado seasons. Sometimes that mix can produce the severe thunderstorms that spawn tornadoes. Tornadoes can also occur in groups, and a large portion of a year's total can be accounted for by one or more active storm systems.
Power Outages
